path: root/fs/gfs2/ops_fstype.c
2015-04-15VFS: normal filesystems (and lustre): d_inode() annotationsDavid Howells
that's the bulk of filesystem drivers dealing with inodes of their own Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-01-20fs: remove mapping->backing_dev_infoChristoph Hellwig
Now that we never use the backing_dev_info pointer in struct address_space we can simply remove it and save 4 to 8 bytes in every inode. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Reviewed-by: Tejun Heo <tj@kernel.org> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-12-10Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs Pull quota updates from Jan Kara: "Quota improvements and some minor cleanups. The main portion in the pull request are changes which move i_dquot array from struct inode into fs-private part of an inode which saves memory for filesystems which don't use VFS quotas" * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: udf: One function call less in udf_fill_super() after error detection udf: Deletion of unnecessary checks before the function call "iput" jbd: Deletion of an unnecessary check before the function call "iput" vfs: Remove i_dquot field from inode jfs: Convert to private i_dquot field reiserfs: Convert to private i_dquot field ocfs2: Convert to private i_dquot field ext4: Convert to private i_dquot field ext3: Convert to private i_dquot field ext2: Convert to private i_dquot field quota: Use function to provide i_dquot pointers xfs: Set allowed quota types gfs2: Set allowed quota types quota: Allow each filesystem to specify which quota types it supports quota: Remove const from function declarations quota: Add log level to printk
2014-11-17GFS2: update freeze code to use freeze/thaw_super on all nodesBenjamin Marzinski
The current gfs2 freezing code is considerably more complicated than it should be because it doesn't use the vfs freezing code on any node except the one that begins the freeze. This is because it needs to acquire a cluster glock before calling the vfs code to prevent a deadlock, and without the new freeze_super and thaw_super hooks, that was impossible. To deal with the issue, gfs2 had to do some hacky locking tricks to make sure that a frozen node couldn't be holding on a lock it needed to do the unfreeze ioctl. This patch makes use of the new hooks to simply the gfs2 locking code. Now, all the nodes in the cluster freeze and thaw in exactly the same way. Every node in the cluster caches the freeze glock in the shared state. The new freeze_super hook allows the freezing node to grab this freeze glock in the exclusive state without first calling the vfs freeze_super function. All the nodes in the cluster see this lock change, and call the vfs freeze_super function. The vfs locking code guarantees that the nodes can't get stuck holding the glocks necessary to unfreeze the system. To unfreeze, the freezing node uses the new thaw_super hook to drop the freeze glock. Again, all the nodes notice this, reacquire the glock in shared mode and call the vfs thaw_super function. Signed-off-by: Benjamin Marzinski <bmarzins@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2014-11-10gfs2: Set allowed quota typesJan Kara
We support user and group quotas. Tell vfs about it. Acked-by: Steven Whitehouse <swhiteho@redhat.com> CC: cluster-devel@redhat.com Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2014-07-16sched: Remove proliferation of wait_on_bit() action functionsNeilBrown
The current "wait_on_bit" interface requires an 'action' function to be provided which does the actual waiting. There are over 20 such functions, many of them identical. Most cases can be satisfied by one of just two functions, one which uses io_schedule() and one which just uses schedule(). So: Rename wait_on_bit and wait_on_bit_lock to wait_on_bit_action and wait_on_bit_lock_action to make it explicit that they need an action function. Introduce new wait_on_bit{,_lock} and wait_on_bit{,_lock}_io which are *not* given an action function but implicitly use a standard one. The decision to error-out if a signal is pending is now made based on the 'mode' argument rather than being encoded in the action function. All instances of the old wait_on_bit and wait_on_bit_lock which can use the new version have been changed accordingly and their action functions have been discarded. wait_on_bit{_lock} does not return any specific error code in the event of a signal so the caller must check for non-zero and interpolate their own error code as appropriate. The wait_on_bit() call in __fscache_wait_on_invalidate() was ambiguous as it specified TASK_UNINTERRUPTIBLE but used fscache_wait_bit_interruptible as an action function. David Howells confirms this should be uniformly "uninterruptible" The main remaining user of wait_on_bit{,_lock}_action is NFS which needs to use a freezer-aware schedule() call. A comment in fs/gfs2/glock.c notes that having multiple 'action' functions is useful as they display differently in the 'wchan' field of 'ps'. (and /proc/$PID/wchan). As the new bit_wait{,_io} functions are tagged "__sched", they will not show up at all, but something higher in the stack. So the distinction will still be visible, only with different function names (gds2_glock_wait versus gfs2_glock_dq_wait in the gfs2/glock.c case). Since first version of this patch (against 3.15) two new action functions appeared, on in NFS and one in CIFS. CIFS also now uses an action function that makes the same freezer aware schedule call as NFS. Signed-off-by: NeilBrown <neilb@suse.de> Acked-by: David Howells <dhowells@redhat.com> (fscache, keys) Acked-by: Steven Whitehouse <swhiteho@redhat.com> (gfs2) Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Steve French <sfrench@samba.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/20140707051603.28027.72349.stgit@notabene.brown Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-02GFS2: Prevent recovery before the local journal is setBob Peterson
This patch uses a completion to prevent dlm's recovery process from referencing and trying to recover a journal before a journal has been opened. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2014-05-14GFS2: remove transaction glockBenjamin Marzinski
GFS2 has a transaction glock, which must be grabbed for every transaction, whose purpose is to deal with freezing the filesystem. Aside from this involving a large amount of locking, it is very easy to make the current fsfreeze code hang on unfreezing. This patch rewrites how gfs2 handles freezing the filesystem. The transaction glock is removed. In it's place is a freeze glock, which is cached (but not held) in a shared state by every node in the cluster when the filesystem is mounted. This lock only needs to be grabbed on freezing, and actions which need to be safe from freezing, like recovery. When a node wants to freeze the filesystem, it grabs this glock exclusively. When the freeze glock state changes on the nodes (either from shared to unlocked, or shared to exclusive), the filesystem does a special log flush. gfs2_log_flush() does all the work for flushing out the and shutting down the incore log, and then it tries to grab the freeze glock in a shared state again. Since the filesystem is stuck in gfs2_log_flush, no new transaction can start, and nothing can be written to disk. Unfreezing the filesytem simply involes dropping the freeze glock, allowing gfs2_log_flush() to grab and then release the shared lock, so it is cached for next time. However, in order for the unfreezing ioctl to occur, gfs2 needs to get a shared lock on the filesystem root directory inode to check permissions. If that glock has already been grabbed exclusively, fsfreeze will be unable to get the shared lock and unfreeze the filesystem. In order to allow the unfreeze, this patch makes gfs2 grab a shared lock on the filesystem root directory during the freeze, and hold it until it unfreezes the filesystem. The functions which need to grab a shared lock in order to allow the unfreeze ioctl to be issued now use the lock grabbed by the freeze code instead. The freeze and unfreeze code take care to make sure that this shared lock will not be dropped while another process is using it. Signed-off-by: Benjamin Marzinski <bmarzins@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2014-03-31GFS2: Fix address space from page functionSteven Whitehouse
Now that rgrps use the address space which is part of the super block, we need to update gfs2_mapping2sbd() to take account of that. The only way to do that easily is to use a different set of address_space_operations for rgrps. Reported-by: Abhi Das <adas@redhat.com> Tested-by: Abhi Das <adas@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2014-03-07GFS2: Use pr_<level> more consistentlyJoe Perches
Add pr_fmt, remove embedded "GFS2: " prefixes. This now consistently emits lower case "gfs2: " for each message. Other miscellanea around these changes: o Add missing newlines o Coalesce formats o Realign arguments Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2014-03-07GFS2: Move recovery variables to journal structure in memoryBob Peterson
If multiple nodes fail and their recovery work runs simultaneously, they would use the same unprotected variables in the superblock. For example, they would stomp on each other's revoked blocks lists, which resulted in file system metadata corruption. This patch moves the necessary variables so that each journal has its own separate area for tracking its journal replay. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2014-03-06GFS2: global conversion to pr_foo()Fabian Frederick
-All printk(KERN_foo converted to pr_foo(). -Messages updated to fit in 80 columns. -fs_macros converted as well. -fs_printk removed. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2014-03-03GFS2: Clean up journal extent mappingSteven Whitehouse
This patch fixes a long standing issue in mapping the journal extents. Most journals will consist of only a single extent, and although the cache took account of that by merging extents, it did not actually map large extents, but instead was doing a block by block mapping. Since the journal was only being mapped on mount, this was not normally noticeable. With the updated code, it is now possible to use the same extent mapping system during journal recovery (which will be added in a later patch). This will allow checking of the integrity of the journal before any reply of the journal content is attempted. For this reason the code is moving to bmap.c, since it will be used more widely in due course. An exercise left for the reader is to compare the new function gfs2_map_journal_extents() with gfs2_write_alloc_required() Additionally, should there be a failure, the error reporting is also updated to show more detail about what went wrong. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2014-02-24GFS2: Move log buffer lists into transactionSteven Whitehouse
Over time, we hope to be able to improve the concurrency available in the log code. This is one small step towards that, by moving the buffer lists from the super block, and into the transaction structure, so that each transaction builds its own buffer lists. At transaction commit time, the buffer lists are merged into the currently accumulating transaction. That transaction then is passed into the before and after commit functions at journal flush time. Thus there should be no change in overall behaviour yet. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2014-01-30Merge branch 'for-3.14/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull core block IO changes from Jens Axboe: "The major piece in here is the immutable bio_ve series from Kent, the rest is fairly minor. It was supposed to go in last round, but various issues pushed it to this release instead. The pull request contains: - Various smaller blk-mq fixes from different folks. Nothing major here, just minor fixes and cleanups. - Fix for a memory leak in the error path in the block ioctl code from Christian Engelmayer. - Header export fix from CaiZhiyong. - Finally the immutable biovec changes from Kent Overstreet. This enables some nice future work on making arbitrarily sized bios possible, and splitting more efficient. Related fixes to immutable bio_vecs: - dm-cache immutable fixup from Mike Snitzer. - btrfs immutable fixup from Muthu Kumar. - bio-integrity fix from Nic Bellinger, which is also going to stable" * 'for-3.14/core' of git://git.kernel.dk/linux-block: (44 commits) xtensa: fixup simdisk driver to work with immutable bio_vecs block/blk-mq-cpu.c: use hotcpu_notifier() blk-mq: for_each_* macro correctness block: Fix memory leak in rw_copy_check_uvector() handling bio-integrity: Fix bio_integrity_verify segment start bug block: remove unrelated header files and export symbol blk-mq: uses page->list incorrectly blk-mq: use __smp_call_function_single directly btrfs: fix missing increment of bi_remaining Revert "block: Warn and free bio if bi_end_io is not set" block: Warn and free bio if bi_end_io is not set blk-mq: fix initializing request's start time block: blk-mq: don't export blk_mq_free_queue() block: blk-mq: make blk_sync_queue support mq block: blk-mq: support draining mq queue dm cache: increment bi_remaining when bi_end_io is restored block: fixup for generic bio chaining block: Really silence spurious compiler warnings block: Silence spurious compiler warnings block: Kill bio_pair_split() ...
2014-01-16GFS2: Don't use ENOBUFS when ENOMEM is the correct error codeSteven Whitehouse
Al Viro has tactfully pointed out that we are using the incorrect error code in some cases. This patch fixes that, and also removes the (unused) return value for glock dumping. > * gfs2_iget() - ENOBUFS instead of ENOMEM. ENOBUFS is > "No buffer space available (POSIX.1 (XSI STREAMS option))" and since > we don't support STREAMS it's probably fair game, but... what the hell? Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Al Viro <viro@ZenIV.linux.org.uk>
2014-01-14GFS2: Move quota bitmap operations under their own lockSteven Whitehouse
Gradually, the global qd_lock is being used for less and less. After this patch it will only be used for the per super block list whose purpose is to allow syncing of changes back to the master quota file from the local quota changes file. Fixing up that process to make it more efficient will be the subject of a later patch, however this patch removes another barrier to doing that. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Abhijith Das <adas@redhat.com>
2014-01-14GFS2: Only run logd and quota when mounted read/writeSteven Whitehouse
While investigating a rather strange bit of code in the quota clean up function, I spotted that the reason for its existence was that when remounting read only, we were not stopping the quotad thread, and thus it was possible for it to still have a reference to some of the quotas in that case. This patch moves the logd and quota thread start and stop into the make_fs_rw/ro functions, so that we now stop those threads when mounted read only. This means that quotad will always be stopped before we call the quota clean up function, and we can thus dispose of the (rather hackish) code that waits for it to give up its reference on the quotas. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Abhijith Das <adas@redhat.com>
2014-01-09GFS2: Add initialization for address space in super blockSteven Whitehouse
Spotted by Andy Price. This should fix the odd messages from lockdep caused by 70d4ee94b370c5ef54d0870600f16bd92d18013c Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Andrew Price <anprice@redhat.com>
2014-01-03GFS2: Use only a single address space for rgrpsSteven Whitehouse
Prior to this patch, GFS2 had one address space for each rgrp, stored in the glock. This patch changes them to use a single address space in the super block. This therefore saves (sizeof(struct address_space) * nr_of_rgrps) bytes of memory and for large filesystems, that can be significant. It would be nice to be able to do something similar and merge the inode metadata address space into the same global address space. However, that is rather more complicated as the on-disk location doesn't have a 1:1 mapping with the inodes in general. So while it could be done, it will be a more complicated operation as it requires changing a lot more code paths. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2013-12-13GFS2: don't hold s_umount over blkdev_putSteven Whitehouse
This is a GFS2 version of Tejun's patch: 4f331f01b9c43bf001d3ffee578a97a1e0633eac vfs: don't hold s_umount over close_bdev_exclusive() call In this case its blkdev_put itself that is the issue and this patch uses the same solution of dropping and retaking s_umount. Reported-by: Tejun Heo <tj@kernel.org> Reported-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2013-11-23block: Abstract out bvec iteratorKent Overstreet
Immutable biovecs are going to require an explicit iterator. To implement immutable bvecs, a later patch is going to add a bi_bvec_done member to this struct; for now, this patch effectively just renames things. Signed-off-by: Kent Overstreet <kmo@daterainc.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "Ed L. Cashin" <ecashin@coraid.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Lars Ellenberg <drbd-dev@lists.linbit.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Matthew Wilcox <willy@linux.intel.com> Cc: Geoff Levand <geoff@infradead.org> Cc: Yehuda Sadeh <yehuda@inktank.com> Cc: Sage Weil <sage@inktank.com> Cc: Alex Elder <elder@inktank.com> Cc: ceph-devel@vger.kernel.org Cc: Joshua Morris <josh.h.morris@us.ibm.com> Cc: Philip Kelleher <pjk1939@linux.vnet.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Neil Brown <neilb@suse.de> Cc: Alasdair Kergon <agk@redhat.com> Cc: Mike Snitzer <snitzer@redhat.com> Cc: dm-devel@redhat.com Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: linux390@de.ibm.com Cc: Boaz Harrosh <bharrosh@panasas.com> Cc: Benny Halevy <bhalevy@tonian.com> Cc: "James E.J. Bottomley" <JBottomley@parallels.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: "Nicholas A. Bellinger" <nab@linux-iscsi.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Chris Mason <chris.mason@fusionio.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Cc: Jaegeuk Kim <jaegeuk.kim@samsung.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Dave Kleikamp <shaggy@kernel.org> Cc: Joern Engel <joern@logfs.org> Cc: Prasad Joshi <prasadjoshi.linux@gmail.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Ben Myers <bpm@sgi.com> Cc: xfs@oss.sgi.com Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Len Brown <len.brown@intel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Guo Chao <yan@linux.vnet.ibm.com> Cc: Tejun Heo <tj@kernel.org> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: "Roger Pau Monné" <roger.pau@citrix.com> Cc: Jan Beulich <jbeulich@suse.com> Cc: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Cc: Ian Campbell <Ian.Campbell@citrix.com> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Jiang Liu <jiang.liu@huawei.com> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Jerome Marchand <jmarchand@redhat.com> Cc: Joe Perches <joe@perches.com> Cc: Peng Tao <tao.peng@emc.com> Cc: Andy Adamson <andros@netapp.com> Cc: fanchaoting <fanchaoting@cn.fujitsu.com> Cc: Jie Liu <jeff.liu@oracle.com> Cc: Sunil Mushran <sunil.mushran@gmail.com> Cc: "Martin K. Petersen" <martin.petersen@oracle.com> Cc: Namjae Jeon <namjae.jeon@samsung.com> Cc: Pankaj Kumar <pankaj.km@samsung.com> Cc: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Mel Gorman <mgorman@suse.de>6
2013-10-04GFS2: Protect quota sync generationSteven Whitehouse
Now that gfs2_quota_sync can be potentially called from multiple threads, we should protect this bit of code, and the sync generation number in particular in order to ensure that there are no races when syncing quotas. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Abhijith Das <adas@redhat.com>
2013-10-04GFS2: Remove obsolete quota tunableSteven Whitehouse
There is no need for a paramater which relates to the internals of quota to be exposed to users. The only possible use would be to turn it up so large that the memory allocation fails. So lets remove it and set it to a sensible value which ensures that we don't ask for multipage allocations. Currently the size of struct gfs2_holder means that the caluclated value is identical to the previous default value, so there should be no functional change. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Abhijith Das <adas@redhat.com>
2013-09-05GFS2: Don't flag consistency error if first mounter is a spectatorBob Peterson
This patch checks for the first mounter being a specator. If so, it makes sure all the journals are clean. If there's a dirty journal, the mount fails. Testing results: # insmod gfs2.ko # mount -tgfs2 -o spectator /dev/sasdrives/scratch /mnt/gfs2 mount: permission denied # dmesg | tail -2 [ 3390.655996] GFS2: fsid=MUSKETEER:home: Now mounting FS... [ 3390.841336] GFS2: fsid=MUSKETEER:home.s: jid=0: Journal is dirty, so the first mounter must not be a spectator. # mount -tgfs2 /dev/sasdrives/scratch /mnt/gfs2 # umount /mnt/gfs2 # mount -tgfs2 -o spectator /dev/sasdrives/scratch /mnt/gfs2 # ls /mnt/gfs2|wc -l 352 # umount /mnt/gfs2 Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2013-06-06GFS2: fix error propagation in init_threads()Alexey Khoroshilov
If kthread_run() fails, init_threads() returns IS_ERR(p) instead of PTR_ERR(p). Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2013-03-03fs: Limit sys_mount to only request filesystem modules.Eric W. Biederman
Modify the request_module to prefix the file system type with "fs-" and add aliases to all of the filesystems that can be built as modules to match. A common practice is to build all of the kernel code and leave code that is not commonly needed as modules, with the result that many users are exposed to any bug anywhere in the kernel. Looking for filesystems with a fs- prefix limits the pool of possible modules that can be loaded by mount to just filesystems trivially making things safer with no real cost. Using aliases means user space can control the policy of which filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf with blacklist and alias directives. Allowing simple, safe, well understood work-arounds to known problematic software. This also addresses a rare but unfortunate problem where the filesystem name is not the same as it's module name and module auto-loading would not work. While writing this patch I saw a handful of such cases. The most significant being autofs that lives in the module autofs4. This is relevant to user namespaces because we can reach the request module in get_fs_type() without having any special permissions, and people get uncomfortable when a user specified string (in this case the filesystem type) goes all of the way to request_module. After having looked at this issue I don't think there is any particular reason to perform any filtering or permission checks beyond making it clear in the module request that we want a filesystem module. The common pattern in the kernel is to call request_module() without regards to the users permissions. In general all a filesystem module does once loaded is call register_filesystem() and go to sleep. Which means there is not much attack surface exposed by loading a filesytem module unless the filesystem is mounted. In a user namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT, which most filesystems do not set today. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Reported-by: Kees Cook <keescook@google.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-13GFS2: Reinstate withdraw ack systemSteven Whitehouse
This patch reinstates the ack system which withdraw should be using. It appears to have been accidentally forgotten when the lock module was merged into GFS2, due to two different sysfs files having the same name. Reported-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2013-01-29GFS2: Use ->writepages for ordered writesSteven Whitehouse
Instead of using a list of buffers to write ahead of the journal flush, this now uses a list of inodes and calls ->writepages via filemap_fdatawrite() in order to achieve the same thing. For most use cases this results in a shorter ordered write list, as well as much larger i/os being issued. The ordered write list is sorted by inode number before writing in order to retain the disk block ordering between inodes as per the previous code. The previous ordered write code used to conflict in its assumptions about how to write out the disk blocks with mpage_writepages() so that with this updated version we can also use mpage_writepages() for GFS2's ordered write, writepages implementation. So we will also send larger i/os from writeback too. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2013-01-29GFS2: Clean up freeze codeSteven Whitehouse
The freeze code has not been looked at a lot recently. Upstream has moved on, and this is an attempt to catch us back up again. There is a vfs level interface for the freeze code which can be called from our (obsolete, but kept for backward compatibility purposes) sysfs freeze interface. This means freezing this way vs. doing it from the ioctl should now work in identical fashion. As a result of this, the freeze function is only called once and we can drop our own special purpose code for counting the number of freezes. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2012-11-07GFS2: Speed up gfs2_rbm_from_blockBob Peterson
This patch is a rewrite of function gfs2_rbm_from_block. Rather than looping to find the right bitmap, the code now does a few simple math calculations. I compared the performance of both algorithms side by side and the new algorithm is noticeably faster. Sample instrumentation output from a "fast" machine: 5 million calls: millisec spent: Orig: 166 New: 113 5 million calls: millisec spent: Orig: 189 New: 114 In addition, I ran postmark (on a somewhat slowr CPU) before the after the new algorithm was put in place and postmark showed a decent improvement: Before the new algorithm: ------------------------- Time: 645 seconds total 584 seconds of transactions (171 per second) Files: 150087 created (232 per second) Creation alone: 100000 files (2083 per second) Mixed with transactions: 50087 files (85 per second) 49995 read (85 per second) 49991 appended (85 per second) 150087 deleted (232 per second) Deletion alone: 100174 files (7705 per second) Mixed with transactions: 49913 files (85 per second) Data: 273.42 megabytes read (434.08 kilobytes per second) 852.13 megabytes written (1.32 megabytes per second) With the new algorithm: ----------------------- Time: 599 seconds total 530 seconds of transactions (188 per second) Files: 150087 created (250 per second) Creation alone: 100000 files (1886 per second) Mixed with transactions: 50087 files (94 per second) 49995 read (94 per second) 49991 appended (94 per second) 150087 deleted (250 per second) Deletion alone: 100174 files (6260 per second) Mixed with transactions: 49913 files (94 per second) Data: 273.42 megabytes read (467.42 kilobytes per second) 852.13 megabytes written (1.42 megabytes per second) Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2012-09-24GFS2: Get rid of I_MUTEX_QUOTA usageJan Kara
GFS2 uses i_mutex on its system quota inode to synchronize writes to quota file. Since this is an internal inode to GFS2 (not part of directory hiearchy or visible by user) we are safe to define locking rules for it. So let's just get it its own locking class to make it clear. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2012-07-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-nmwLinus Torvalds
Pull GFS2 updates from Steven Whitehouse. * git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-nmw: GFS2: Eliminate 64-bit divides GFS2: Reduce file fragmentation GFS2: kernel panic with small gfs2 filesystems - 1 RG GFS2: Fixing double brelse'ing bh allocated in gfs2_meta_read when EIO occurs GFS2: Combine functions get_local_rgrp and gfs2_inplace_reserve GFS2: Add kobject release method GFS2: Size seq_file buffer more carefully GFS2: Use seq_vprintf for glocks debugfs file seq_file: Add seq_vprintf function and export it GFS2: Use lvbs for storing rgrp information with mount option GFS2: Cache last hash bucket for glock seq_files GFS2: Increase buffer size for glocks and glstats debugfs files GFS2: Fix error handling when reading an invalid block from the journal GFS2: Add "top dir" flag support GFS2: Fold quota data into the reservations struct GFS2: Extend the life of the reservations
2012-07-14VFS: Pass mount flags to sget()David Howells
Pass mount flags to sget() so that it can use them in initialising a new superblock before the set function is called. They could also be passed to the compare function. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-13GFS2: Add kobject release methodBob Peterson
This patch adds a kobject release function that properly maintains the kobject use count, so that accesses to the sysfs files do not cause an access to freed kernel memory after an unmount. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2012-05-22Merge tag 'dlm-3.5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/teigland/linux-dlm Pull dlm updates from David Teigland: "This set includes some minor fixes and improvements. The one large patch addresses the special "nodir" mode, which has been a long neglected proof of concept, but with these fixes seems to be quite usable. It allows the resource master to be assigned statically instead of dynamically, which can improve performance if there is little locality and most resources are shared." * tag 'dlm-3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/teigland/linux-dlm: dlm: NULL dereference on failure in kmem_cache_create() gfs2: fix recovery during unmount dlm: fixes for nodir mode dlm: improve error and debug messages dlm: avoid unnecessary search in search_rsb dlm: limit rcom debug messages dlm: fix waiter recovery dlm: prevent connections during shutdown
2012-05-02dlm: fixes for nodir modeDavid Teigland
The "nodir" mode (statically assign master nodes instead of using the resource directory) has always been highly experimental, and never seriously used. This commit fixes a number of problems, making nodir much more usable. - Major change to recovery: recover all locks and restart all in-progress operations after recovery. In some cases it's not possible to know which in-progess locks to recover, so recover all. (Most require recovery in nodir mode anyway since rehashing changes most master nodes.) - Change the way nodir mode is enabled, from a command line mount arg passed through gfs2, into a sysfs file managed by dlm_controld, consistent with the other config settings. - Allow recovering MSTCPY locks on an rsb that has not yet been turned into a master copy. - Ignore RCOM_LOCK and RCOM_LOCK_REPLY recovery messages from a previous, aborted recovery cycle. Base this on the local recovery status not being in the state where any nodes should be sending LOCK messages for the current recovery cycle. - Hold rsb lock around dlm_purge_mstcpy_locks() because it may run concurrently with dlm_recover_master_copy(). - Maintain highbast on process-copy lkb's (in addition to the master as is usual), because the lkb can switch back and forth between being a master and being a process copy as the master node changes in recovery. - When recovering MSTCPY locks, flag rsb's that have non-empty convert or waiting queues for granting at the end of recovery. (Rename flag from LOCKS_PURGED to RECOVER_GRANT and similar for the recovery function, because it's not only resources with purged locks that need grant a grant attempt.) - Replace a couple of unnecessary assertion panics with error messages. Signed-off-by: David Teigland <teigland@redhat.com>
2012-04-30GFS2: Eliminate vestigial sd_log_le_rgBob Peterson
This patch eliminates gfs2 superblock variable sd_log_le_rg which is no longer used. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2012-03-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-nmwLinus Torvalds
Pull gfs2 changes from Steven Whitehouse. * git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-nmw: GFS2: Change truncate page allocation to be GFP_NOFS GFS2: call gfs2_write_alloc_required for each chunk GFS2: Clean up log flush header writing GFS2: Remove a __GFP_NOFAIL allocation GFS2: Flush pending glock work when evicting an inode GFS2: make sure rgrps are up to date in func gfs2_blk2rgrpd GFS2: Eliminate sd_rindex_mutex GFS2: Unlock rindex mutex on glock error GFS2: Make bd_cmp() static GFS2: Sort the ordered write list GFS2: FITRIM ioctl support GFS2: Move two functions from log.c to lops.c GFS2: glock statistics gathering
2012-03-20switch open-coded instances of d_make_root() to new helperAl Viro
2012-03-05GFS2: Eliminate sd_rindex_mutexBob Peterson
Over time, we've slowly eliminated the use of sd_rindex_mutex. Up to this point, it was only used in two places: function gfs2_ri_total (which totals the file system size by reading and parsing the rindex file) and function gfs2_rindex_update which updates the rgrps in memory. Both of these functions have the rindex glock to protect them, so the rindex is unnecessary. Since gfs2_grow writes to the rindex via the meta_fs, the mutex is in the wrong order according to the normal rules. This patch eliminates the mutex entirely to avoid the problem. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2012-02-28GFS2: glock statistics gatheringSteven Whitehouse
The stats are divided into two sets: those relating to the super block and those relating to an individual glock. The super block stats are done on a per cpu basis in order to try and reduce the overhead of gathering them. They are also further divided by glock type. In the case of both the super block and glock statistics, the same information is gathered in each case. The super block statistics are used to provide default values for most of the glock statistics, so that newly created glocks should have, as far as possible, a sensible starting point. The statistics are divided into three pairs of mean and variance, plus two counters. The mean/variance pairs are smoothed exponential estimates and the algorithm used is one which will be very familiar to those used to calculation of round trip times in network code. The three pairs of mean/variance measure the following things: 1. DLM lock time (non-blocking requests) 2. DLM lock time (blocking requests) 3. Inter-request time (again to the DLM) A non-blocking request is one which will complete right away, whatever the state of the DLM lock in question. That currently means any requests when (a) the current state of the lock is exclusive (b) the requested state is either null or unlocked or (c) the "try lock" flag is set. A blocking request covers all the other lock requests. There are two counters. The first is there primarily to show how many lock requests have been made, and thus how much data has gone into the mean/variance calculations. The other counter is counting queueing of holders at the top layer of the glock code. Hopefully that number will be a lot larger than the number of dlm lock requests issued. So why gather these statistics? There are several reasons we'd like to get a better idea of these timings: 1. To be able to better set the glock "min hold time" 2. To spot performance issues more easily 3. To improve the algorithm for selecting resource groups for allocation (to base it on lock wait time, rather than blindly using a "try lock") Due to the smoothing action of the updates, a step change in some input quantity being sampled will only fully be taken into account after 8 samples (or 4 for the variance) and this needs to be carefully considered when interpreting the results. Knowing both the time it takes a lock request to complete and the average time between lock requests for a glock means we can compute the total percentage of the time for which the node is able to use a glock vs. time that the rest of the cluster has its share. That will be very useful when setting the lock min hold time. The other point to remember is that all times are in nanoseconds. Great care has been taken to ensure that we measure exactly the quantities that we want, as accurately as possible. There are always inaccuracies in any measuring system, but I hope this is as accurate as we can reasonably make it. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2012-02-28GFS2: Read resource groups on mountSteven Whitehouse
This makes mount take slightly longer, but at the same time, the first write to the filesystem will be faster too. It also means that if there is a problem in the resource index, then we can refuse to mount rather than having to try and report that when the first write occurs. In addition, to avoid recursive locking, we hvae to take account of instances when the rindex glock may already be held when we are trying to update the rbtree of resource groups. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2012-01-11GFS2: let spectator mount do read only recoveryDavid Teigland
Previously, a spectator mount would not even attempt to do journal recovery for a failed node. This meant that if all mounted nodes were spectators, everyone would be stuck after a node failed, all waiting for recovery to be performed. This is unnecessary since the failed node had a clean journal. Instead, allow a spectator mount to do a partial "read only" recovery, which means it will check if the failed journal is clean, and if so, report a successful recovery. If the failed journal is not clean, it reports that journal recovery failed. This makes it work the same as a read only mount on a read only block device. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2012-01-11GFS2: dlm based recovery coordinationDavid Teigland
This new method of managing recovery is an alternative to the previous approach of using the userland gfs_controld. - use dlm slot numbers to assign journal id's - use dlm recovery callbacks to initiate journal recovery - use a dlm lock to determine the first node to mount fs - use a dlm lock to track journals that need recovery Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2011-11-08GFS2: Fix up REQ flagsSteven Whitehouse
Christoph has split up REQ_PRIO from REQ_META. That means that we can drop REQ_PRIO from places where is it not needed. I'm not at all sure that the combination WRITE_FLUSH_FUA | REQ_PRIO makes any kind of sense, anyway. In addition, I've added REQ_META to one place in the code where it was missing. REQ_PRIO has been left for read/writes triggered by glock acquisition and writeback only. We can adjust it again if required, but these are the most important points from a performance perspective. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Christoph Hellwig <hch@infradead.org>
2011-10-31fs: add export.h to files using EXPORT_SYMBOL/THIS_MODULE macrosPaul Gortmaker
These files were getting <linux/module.h> via an implicit include path, but we want to crush those out of existence since they cost time during compiles of processing thousands of lines of headers for no reason. Give them the lightweight header that just contains the EXPORT_SYMBOL infrastructure. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-21GFS2: Misc fixesSteven Whitehouse
Some items picked up through automated code analysis. A few bits of unreachable code and two unchecked return values. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2011-10-21GFS2: Use rbtree for resource groups and clean up bitmap buffer ref count schemeBob Peterson
Here is an update of Bob's original rbtree patch which, in addition, also resolves the rather strange ref counting that was being done relating to the bitmap blocks. Originally we had a dual system for journaling resource groups. The metadata blocks were journaled and also the rgrp itself was added to a list. The reason for adding the rgrp to the list in the journal was so that the "repolish clones" code could be run to update the free space, and potentially send any discard requests when the log was flushed. This was done by comparing the "cloned" bitmap with what had been written back on disk during the transaction commit. Due to this, there was a requirement to hang on to the rgrps' bitmap buffers until the journal had been flushed. For that reason, there was a rather complicated set up in the ->go_lock ->go_unlock functions for rgrps involving both a mutex and a spinlock (the ->sd_rindex_spin) to maintain a reference count on the buffers. However, the journal maintains a reference count on the buffers anyway, since they are being journaled as metadata buffers. So by moving the code which deals with the post-journal accounting for bitmap blocks to the metadata journaling code, we can entirely dispense with the rather strange buffer ref counting scheme and also the requirement to journal the rgrps. The net result of all this is that the ->sd_rindex_spin is left to do exactly one job, and that is to look after the rbtree or rgrps. This patch is designed to be a stepping stone towards using RCU for the rbtree of resource groups, however the reduction in the number of uses of the ->sd_rindex_spin is likely to have benefits for multi-threaded workloads, anyway. The patch retains ->go_lock and ->go_unlock for rgrps, however these maybe also be removed in future in favour of calling the functions directly where required in the code. That will allow locking of resource groups without needing to actually read them in - something that could be useful in speeding up statfs. In the mean time though it is valid to dereference ->bi_bh only when the rgrp is locked. This is basically the same rule as before, modulo the references not being valid until the following journal flush. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: Bob Peterson <rpeterso@redhat.com> Cc: Benjamin Marzinski <bmarzins@redhat.com>
2011-08-23block: separate priority boosting from REQ_METAChristoph Hellwig
Add a new REQ_PRIO to let requests preempt others in the cfq I/O schedule, and lave REQ_META purely for marking requests as metadata in blktrace. All existing callers of REQ_META except for XFS are updated to also set REQ_PRIO for now. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
