path: root/fs/gfs2/rgrp.h
2011-07-15GFS2: combine duplicated block freeing routinesEric Sandeen
__gfs2_free_data and __gfs2_free_meta are almost identical, and can be trivially combined. [This is as per Eric's original patch minus gfs2_free_data() which had no callers left and plus the conversion of the bmap.c calls to these functions. All in all, a nice clean up] Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2011-02-24GFS2: deallocation performance patchBob Peterson
This patch is a performance improvement to GFS2's dealloc code. Rather than update the quota file and statfs file for every single block that's stripped off in unlink function do_strip, this patch keeps track and updates them once for every layer that's stripped. This is done entirely inside the existing transaction, so there should be no risk of corruption. The other functions that deallocate blocks will be unaffected because they are using wrapper functions that do the same thing that they do today. I tested this code on my roth cluster by creating 200 files in a directory, each of which is 100MB, then on four nodes, I simultaneously deleted the files, thus competing for GFS2 resources (but different files). The commands I used were: [root@roth-01]# time for i in `seq 1 4 200` ; do rm /mnt/gfs2/bigdir/gfs2.$i; done [root@roth-02]# time for i in `seq 2 4 200` ; do rm /mnt/gfs2/bigdir/gfs2.$i; done [root@roth-03]# time for i in `seq 3 4 200` ; do rm /mnt/gfs2/bigdir/gfs2.$i; done [root@roth-05]# time for i in `seq 4 4 200` ; do rm /mnt/gfs2/bigdir/gfs2.$i; done The performance increase was significant: roth-01 roth-02 roth-03 roth-05 --------- --------- --------- --------- old: real 0m34.027 0m25.021s 0m23.906s 0m35.646s new: real 0m22.379s 0m24.362s 0m24.133s 0m18.562s Total time spent deleting: old: 118.6s new: 89.4 For this particular case, this showed a 25% performance increase for GFS2 unlinks. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2010-11-30GFS2: fix recursive locking during rindex truncatesBenjamin Marzinski
When you truncate the rindex file, you need to avoid calling gfs2_rindex_hold, since you already hold it. However, if you haven't already read in the resource groups, you need to do that. Signed-off-by: Benjamin Marzinski <bmarzins@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2010-09-30GFS2 fatal: filesystem consistency error on renameBob Peterson
This patch fixes a GFS2 problem whereby the first rename after a mount can result in a file system consistency error being flagged improperly and cause the file system to withdraw. The problem is that the rename code tries to run the rgrp list with function gfs2_blk2rgrpd before the rgrp list is guaranteed to be read in from disk. The patch makes the rename function hold the rindex glock (as the gfs2_unlink code does today) which reads in the rgrp list if need be. There were a total of three places in the rename code that improperly referenced the rgrp list without the rindex glock and this patch fixes all three. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-09-08GFS2: Be extra careful about deallocating inodesSteven Whitehouse
There is a potential race in the inode deallocation code if two nodes try to deallocate the same inode at the same time. Most of the issue is solved by the iopen locking. There is still a small window which is not covered by the iopen lock. This patches fixes that and also makes the deallocation code more robust in the face of any errors in the rgrp bitmaps, or erroneous iopen callbacks from other nodes. This does introduce one extra disk read, but that is generally not an issue since its the same block that must be written to later in the deallocation process. The total disk accesses therefore stay the same, Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2009-08-17GFS2: Improve error handling in inode allocationSteven Whitehouse
A little while back, block allocation was given some improved error handling which meant that -EIO was returned in the case of there being a problem in the resource group data. In addition a message is printed explaning what went wrong and how to fix it. This extends that error handling so that it also covers inode allocation too. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2009-05-20GFS2: Improve resource group error handlingSteven Whitehouse
This patch improves the error handling in the case where we discover that the summary information in the resource group doesn't match the bitmap information while in the process of allocating blocks. Originally this resulted in a kernel bug, but this patch changes that so that we return -EIO and print some messages explaining what went wrong, and how to fix it. We also remember locally not to try and allocate from the same rgrp again, so that a subsequent allocation in a different rgrp should succeed. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-03-31[GFS2] Add extent allocation to block allocatorSteven Whitehouse
Rather than having to allocate a single block at a time, this patch allows the block allocator to allocate an extent. Since there is no difference (so far as the block allocator is concerned) between data blocks and indirect blocks, it is posible to allocate a single extent and for the caller to unrevoke just the blocks required for indirect blocks. Currently the only bit of GFS2 to make use of this feature is the build height function. The intention is that gfs2_block_map will be changed to make use of this feature in future patches. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-03-31[GFS2] Merge gfs2_alloc_meta and gfs2_alloc_dataSteven Whitehouse
Thanks to the preceeding patches, the only difference between these two functions is their name. We can thus merge them and call the new function gfs2_alloc_block to reflect the fact that it can allocate either kind of block. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-03-31[GFS2] Get rid of unneeded parameter in gfs2_rlist_allocBob Peterson
This patch removed the unnecessary parameter from function gfs2_rlist_alloc. The parameter was always passed in as 0. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-01-25[GFS2] Reduce inode size by moving i_alloc out of lineSteven Whitehouse
It is possible to reduce the size of GFS2 inodes by taking the i_alloc structure out of the gfs2_inode. This patch allocates the i_alloc structure whenever its needed, and frees it afterward. This decreases the amount of low memory we use at the expense of requiring a memory allocation for each page or partial page that we write. A quick test with postmark shows that the overhead is not measurable and I also note that OCFS2 use the same approach. In the future I'd like to solve the problem by shrinking down the size of the members of the i_alloc structure, but for now, this reduces the immediate problem of using too much low-memory on x86 and doesn't add too much overhead. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-07-09[GFS2] Addendum patch 2 for gfs2_growRobert Peterson
This addendum patch 2 corrects three things: 1. It fixes a stupid mistake in the previous addendum that broke gfs2. Ref: https://www.redhat.com/archives/cluster-devel/2007-May/msg00162.html 2. It fixes a problem that Dave Teigland pointed out regarding the external declarations in ops_address.h being in the wrong place. 3. It recasts a couple more %llu printks to (unsigned long long) as requested by Steve Whitehouse. I would have loved to put this all in one revised patch, but there was a rush to get some patches for RHEL5. Therefore, the previous patches were applied to the git tree "as is" and therefore, I'm posting another addendum. Sorry. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-10-12[GFS2] Fix uninitialised variableSteven Whitehouse
This fixes a bug where, in certain cases an uninitialised variable could cause a dereference of a NULL pointer in gfs2_commit_write(). Also a typo in a comment is fixed at the same time. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-05[GFS2] More style fixesSteven Whitehouse
As per Jan Engelhardt's follow up emails, here are a few small fixes which were missed earlier. Cc: Jan Engelhardt <jengelh@linux01.gwdg.de> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-05[GFS2] Make headers compile on their ownSteven Whitehouse
As per Jan Engelhardt's comments, this should make all the headers compile on their own by including and/or declaring structures early. Cc: Jan Engelhardt <jengelh@linux01.gwdg.de> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-04[GFS2] Change all types to uX styleSteven Whitehouse
This makes all fixed size types have consistent names. Cc: Jan Engelhardt <jengelh@linux01.gwdg.de> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-01[GFS2] Update copyright, tidy up incore.hSteven Whitehouse
As per comments from Jan Engelhardt <jengelh@linux01.gwdg.de> this updates the copyright message to say "version" in full rather than "v.2". Also incore.h has been updated to remove forward structure declarations which are not required. The gfs2_quota_lvb structure has now had endianess annotations added to it. Also quota.c has been updated so that we now store the lvb data locally in endian independant format to avoid needing a structure in host endianess too. As a result the endianess conversions are done as required at various points and thus the conversion routines in lvb.[ch] are no longer required. I've moved the one remaining constant in lvb.h thats used into lm.h and removed the unused lvb.[ch]. I have not changed the HIF_ constants. That is left to a later patch which I hope will unify the gh_flags and gh_iflags fields of the struct gfs2_holder. Cc: Jan Engelhardt <jengelh@linux01.gwdg.de> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-07-11[GFS2] Add generation numberSteven Whitehouse
This adds a generation number for the eventual use of NFS to the ondisk inode. Its backward compatible with the current code since it doesn't really matter what the generation number is to start with, and indeed since its set to zero, due to it being taken from padding in both the inode and rgrp header, it should be fine. The eventual plan is to use this rather than no_formal_ino in the NFS filehandles. At that point no_formal_ino will be unused. At the same time we also add a releasepages call back to the "normal" address space for gfs2 inodes. Also I've removed a one-linrer function thats not required any more. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-06-22[GFS2] [-mm patch] fs/gfs2/: make code staticAdrian Bunk
This patch makes the following needlessly global code static: - eaops.c: struct gfs2_security_eaops - rgrp.c: gfs2_free_uninit_di() Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-06-14[GFS2] Fix unlinked file handlingSteven Whitehouse
This patch fixes the way we have been dealing with unlinked, but still open files. It removes all limits (other than memory for inodes, as per every other filesystem) on numbers of these which we can support on GFS2. It also means that (like other fs) its the responsibility of the last process to close the file to deallocate the storage, rather than the person who did the unlinking. Note that with GFS2, those two events might take place on different nodes. Also there are a number of other changes: o We use the Linux inode subsystem as it was intended to be used, wrt allocating GFS2 inodes o The Linux inode cache is now the point which we use for local enforcement of only holding one copy of the inode in core at once (previous to this we used the glock layer). o We no longer use the unlinked "special" file. We just ignore it completely. This makes unlinking more efficient. o We now use the 4th block allocation state. The previously unused state is used to track unlinked but still open inodes. o gfs2_inoded is no longer needed o Several fields are now no longer needed (and removed) from the in core struct gfs2_inode o Several fields are no longer needed (and removed) from the in core superblock There are a number of future possible optimisations and clean ups which have been made possible by this patch. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-05-18[GFS2] Update copyright date to 2006Steven Whitehouse
2006-01-16[GFS2] The core of GFS2David Teigland
This patch contains all the core files for GFS2. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
