path: root/fs/gfs2
2010-10-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (52 commits) split invalidate_inodes() fs: skip I_FREEING inodes in writeback_sb_inodes fs: fold invalidate_list into invalidate_inodes fs: do not drop inode_lock in dispose_list fs: inode split IO and LRU lists fs: switch bdev inode bdi's correctly fs: fix buffer invalidation in invalidate_list fsnotify: use dget_parent smbfs: use dget_parent exportfs: use dget_parent fs: use RCU read side protection in d_validate fs: clean up dentry lru modification fs: split __shrink_dcache_sb fs: improve DCACHE_REFERENCED usage fs: use percpu counter for nr_dentry and nr_dentry_unused fs: simplify __d_free fs: take dcache_lock inside __d_path fs: do not assign default i_ino in new_inode fs: introduce a per-cpu last_ino allocator new helper: ihold() ...
2010-10-26writeback: remove nonblocking/encountered_congestion referencesWu Fengguang
This removes more dead code that was somehow missed by commit 0d99519efef (writeback: remove unused nonblocking and congestion checks). There are no behavior change except for the removal of two entries from one of the ext4 tracing interface. The nonblocking checks in ->writepages are no longer used because the flusher now prefer to block on get_request_wait() than to skip inodes on IO congestion. The latter will lead to more seeky IO. The nonblocking checks in ->writepage are no longer used because it's redundant with the WB_SYNC_NONE check. We no long set ->nonblocking in VM page out and page migration, because a) it's effectively redundant with WB_SYNC_NONE in current code b) it's old semantic of "Don't get stuck on request queues" is mis-behavior: that would skip some dirty inodes on congestion and page out others, which is unfair in terms of LRU age. Inspired by Christoph Hellwig. Thanks! Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: David Howells <dhowells@redhat.com> Cc: Sage Weil <sage@newdream.net> Cc: Steve French <sfrench@samba.org> Cc: Chris Mason <chris.mason@oracle.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-25new helper: ihold()Al Viro
Clones an existing reference to inode; caller must already hold one. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25gfs2: invalidate_inodes() is no-op thereAl Viro
In fill_super() we hadn't MS_ACTIVE set yet, so there won't be any inodes with zero i_count sitting around. In put_super() we already have MS_ACTIVE removed *and* we had called invalidate_inodes() since then. So again there won't be any inodes with zero i_count... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25fs: kill block_prepare_writeChristoph Hellwig
__block_write_begin and block_prepare_write are identical except for slightly different calling conventions. Convert all callers to the __block_write_begin calling conventions and drop block_prepare_write. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-22Merge branch 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: remove in_workqueue_context() workqueue: Clarify that schedule_on_each_cpu is synchronous memory_hotplug: drop spurious calls to flush_scheduled_work() shpchp: update workqueue usage pciehp: update workqueue usage isdn/eicon: don't call flush_scheduled_work() from diva_os_remove_soft_isr() workqueue: add and use WQ_MEM_RECLAIM flag workqueue: fix HIGHPRI handling in keep_working() workqueue: add queue_work and activate_work trace points workqueue: prepare for more tracepoints workqueue: implement flush[_delayed]_work_sync() workqueue: factor out start_flush_work() workqueue: cleanup flush/cancel functions workqueue: implement alloc_ordered_workqueue() Fix up trivial conflict in fs/gfs2/main.c as per Tejun
2010-10-22Merge branch 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-block: (46 commits) xen-blkfront: disable barrier/flush write support Added blk-lib.c and blk-barrier.c was renamed to blk-flush.c block: remove BLKDEV_IFL_WAIT aic7xxx_old: removed unused 'req' variable block: remove the BH_Eopnotsupp flag block: remove the BLKDEV_IFL_BARRIER flag block: remove the WRITE_BARRIER flag swap: do not send discards as barriers fat: do not send discards as barriers ext4: do not send discards as barriers jbd2: replace barriers with explicit flush / FUA usage jbd2: Modify ASYNC_COMMIT code to not rely on queue draining on barrier jbd: replace barriers with explicit flush / FUA usage nilfs2: replace barriers with explicit flush / FUA usage reiserfs: replace barriers with explicit flush / FUA usage gfs2: replace barriers with explicit flush / FUA usage btrfs: replace barriers with explicit flush / FUA usage xfs: replace barriers with explicit flush / FUA usage block: pass gfp_mask and flags to sb_issue_discard dm: convey that all flushes are processed as empty ...
2010-10-22Merge branch 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: vfs: make no_llseek the default vfs: don't use BKL in default_llseek llseek: automatically add .llseek fop libfs: use generic_file_llseek for simple_attr mac80211: disallow seeks in minstrel debug code lirc: make chardev nonseekable viotape: use noop_llseek raw: use explicit llseek file operations ibmasmfs: use generic_file_llseek spufs: use llseek in all file operations arm/omap: use generic_file_llseek in iommu_debug lkdtm: use generic_file_llseek in debugfs net/wireless: use generic_file_llseek in debugfs drm: use noop_llseek
2010-10-22Merge branch 'vfs' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'vfs' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: (30 commits) BKL: remove BKL from freevxfs BKL: remove BKL from qnx4 autofs4: Only declare function when CONFIG_COMPAT is defined autofs: Only declare function when CONFIG_COMPAT is defined ncpfs: Lock socket in ncpfs while setting its callbacks fs/locks.c: prepare for BKL removal BKL: Remove BKL from ncpfs BKL: Remove BKL from OCFS2 BKL: Remove BKL from squashfs BKL: Remove BKL from jffs2 BKL: Remove BKL from ecryptfs BKL: Remove BKL from afs BKL: Remove BKL from USB gadgetfs BKL: Remove BKL from autofs4 BKL: Remove BKL from isofs BKL: Remove BKL from fat BKL: Remove BKL from ext2 filesystem BKL: Remove BKL from do_new_mount() BKL: Remove BKL from cgroup BKL: Remove BKL from NTFS ...
2010-10-19Merge branch 'v2.6.36-rc8' into for-2.6.37/barrierJens Axboe
Conflicts: block/blk-core.c drivers/block/loop.c mm/swapfile.c Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-18GFS2: fixed typoAndrea Gelmini
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-10-11workqueue: add and use WQ_MEM_RECLAIM flagTejun Heo
Add WQ_MEM_RECLAIM flag which currently maps to WQ_RESCUER, mark WQ_RESCUER as internal and replace all external WQ_RESCUER usages to WQ_MEM_RECLAIM. This makes the API users express the intent of the workqueue instead of indicating the internal mechanism used to guarantee forward progress. This is also to make it cleaner to add more semantics to WQ_MEM_RECLAIM. For example, if deemed necessary, memory reclaim workqueues can be made highpri. This patch doesn't introduce any functional change. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Steven Whitehouse <swhiteho@redhat.com>
2010-10-06GFS2: Fix type mapping for demote_rq interfaceSteven Whitehouse
Mostly the glock operations follow the type of the glock. The one exception is the transaction glock, so we need to check for that directly. Reported-by: Dr. David Alan Gilbert <linux@treblig.org> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2010-10-05fs/locks.c: prepare for BKL removalArnd Bergmann
This prepares the removal of the big kernel lock from the file locking code. We still use the BKL as long as fs/lockd uses it and ceph might sleep, but we can flip the definition to a private spinlock as soon as that's done. All users outside of fs/lockd get converted to use lock_flocks() instead of lock_kernel() where appropriate. Based on an earlier patch to use a spinlock from Matthew Wilcox, who has attempted this a few times before, the earliest patch from over 10 years ago turned it into a semaphore, which ended up being slower than the BKL and was subsequently reverted. Someone should do some serious performance testing when this becomes a spinlock, since this has caused problems before. Using a spinlock should be at least as good as the BKL in theory, but who knows... Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Matthew Wilcox <willy@linux.intel.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Miklos Szeredi <mszeredi@suse.cz> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: John Kacur <jkacur@redhat.com> Cc: Sage Weil <sage@newdream.net> Cc: linux-kernel@vger.kernel.org Cc: linux-fsdevel@vger.kernel.org
2010-09-30GFS2 fatal: filesystem consistency error on renameBob Peterson
This patch fixes a GFS2 problem whereby the first rename after a mount can result in a file system consistency error being flagged improperly and cause the file system to withdraw. The problem is that the rename code tries to run the rgrp list with function gfs2_blk2rgrpd before the rgrp list is guaranteed to be read in from disk. The patch makes the rename function hold the rindex glock (as the gfs2_unlink code does today) which reads in the rgrp list if need be. There were a total of three places in the rename code that improperly referenced the rgrp list without the rindex glock and this patch fixes all three. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2010-09-29GFS2: Improve journal allocation via sysfsSteven Whitehouse
Recently a feature was added to GFS2 to allow journal id allocation via sysfs. This patch builds upon that so that a negative journal id will be treated as an error code to be passed back as the return code from mount. This allows termination of the mount process if there is a failure. Also, the process has been updated so that the kernel will wait for a journal id, even in the "spectator" case. This is required in order to avoid mounting a filesystem in case there is an error while joining the cluster. In the spectator case, 0 is written into the file to indicate that all is well, and that mount should continue. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2010-09-29GFS2: Add "norecovery" mount option as a synonym for "spectator"Steven Whitehouse
XFS supports the "norecovery" mount option which is basically the same as the GFS2 spectator mode. This adds support for "norecovery" as a synonym for spectator mode, which is hopefully a more obvious description of what it actually does. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2010-09-29GFS2: Fix spectator umount issueSteven Whitehouse
The tests further down the recovery function relating to unlocking the journal need to be updated to match the intial test. Also, a test in the umount code which was surplus to requirements has been removed. Umounting spectator mounts now works correctly, as expected. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2010-09-28GFS2: Fix compiler warning from previous patchSteven Whitehouse
This shouldn't really be required, but gcc can't tell that "al" is only accessed when initialised. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2010-09-28GFS2: reserve more blocks for transactionsBenjamin Marzinski
Some of the functions in GFS2 were not reserving space in the transaction for the resource group header and the resource groups bitblocks that get added when you do allocation. GFS2 now makes sure to reserve space for the resource group header and either all the bitblocks in the resource group, or one for each block that it may allocate, whichever is smaller using the new gfs2_rg_blocks() inline function. Signed-off-by: Benjamin Marzinski <bmarzins@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2010-09-27GFS2: Fix journal check for spectator mountsSteven Whitehouse
When checking journals for spectator mounts, we cannot rely on the journal being locked, whatever its jid might be. This patch ensures that we always get the journal locks when checking journals for a spectator mount. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2010-09-24GFS2: Remove upgrade mount optionSteven Whitehouse
This option has never done anything useful. Also at the same time this cleans up the sb checks which are done at mount time. The debug option will be accepted, but ignored in future. Since it didn't do anything, there didn't seem much point in retaining it. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2010-09-23GFS2: Remove localcaching mount optionSteven Whitehouse
This option defaulted to on for lock_nolock mounts and off otherwise. The only function was to avoid the revalidation of dentries. In the cluster case, that is entirely pointless and liable to cause coherency problems. The patch changes the revalidation to depend upon whether the fs is a local or cluster fs (i.e. it follows the existing default behaviour). I very much doubt anybody ever used this option as there is no reason to. Even so we will continue to accept it on the mount command line, but ignore it. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2010-09-23GFS2: Remove ignore_local_fs mount argumentSteven Whitehouse
This is been a no-op for a very long time now. I'm pretty sure nobody uses it, but just in case we'll still accept it on the command line, but ignore it. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2010-09-20GFS2: Make . and .. qstrs constantSteven Whitehouse
Rather than calculating the qstrs for . and .. each time we need them, its better to keep a constant version of these and just refer to them when required. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Reviewed-by: Christoph Hellwig <hch@infradead.org>
2010-09-20GFS2: Use new workqueue schemeSteven Whitehouse
The recovery workqueue can be freezable since we want it to finish what it is doing if the system is to be frozen (although why you'd want to freeze a cluster node is beyond me since it will result in it being ejected from the cluster). It does still make sense for single node GFS2 filesystems though. The glock workqueue will benefit from being able to run more work items concurrently. A test running postmark shows improved performance and multi-threaded workloads are likely to benefit even more. It needs to be high priority because the latency directly affects the latency of filesystem glock operations. The delete workqueue is similar to the recovery workqueue in that it must not get blocked by memory allocations, and may run for a long time. Potentially other GFS2 threads might also be converted to workqueues, but I'll leave that for a later patch. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Acked-by: Tejun Heo <tj@kernel.org>
2010-09-20GFS2: Update handling of DLM return codes to match realitySteven Whitehouse
GFS2's idea of which return codes it needs to handle was based upon those listed in dlm.h. Those didn't cover all the possible codes and listed some which never happen. This updates GFS2 to handle all the codes which can actually be returned from the DLM under various circumstances. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2010-09-20GFS2: Don't enforce min hold time when two demotes occur in rapid successionSteven Whitehouse
Due to the design of the VFS, it is quite usual for operations on GFS2 to consist of a lookup (requiring a shared lock) followed by an operation requiring an exclusive lock. If a remote node has cached an exclusive lock, then it will receive two demote events in rapid succession firstly for a shared lock and then to unlocked. The existing min hold time code was triggering in this case, even if the node was otherwise idle since the state change time was being updated by the initial demote. This patch introduces logic to skip the min hold timer in the case that a "double demote" of this kind has occurred. The min hold timer will still be used in all other cases. A new glock flag is introduced which is used to keep track of whether there have been any newly queued holders since the last glock state change. The min hold time is only applied if the flag is set. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Tested-by: Abhijith Das <adas@redhat.com>
2010-09-20GFS2: Fix whitespace in previous patchSteven Whitehouse
Removes the offending space Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2010-09-20GFS2: fallocate supportBenjamin Marzinski
This patch adds support for fallocate to gfs2. Since the gfs2 does not support uninitialized data blocks, it must write out zeros to all the blocks. However, since it does not need to lock any pages to read from, gfs2 can write out the zero blocks much more efficiently. On a moderately full filesystem, fallocate works around 5 times faster on average. The fallocate call also allows gfs2 to add blocks to the file without changing the filesize, which will make it possible for gfs2 to preallocate space for the rindex file, so that gfs2 can grow a completely full filesystem. Signed-off-by: Benjamin Marzinski <bmarzins@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2010-09-20GFS2: Add a bug trap in allocation codeSteven Whitehouse
This adds a check to ensure that if we reach the block allocator that we don't try and proceed if there is no alloc structure hanging off the inode. This should only happen if there is a bug in GFS2. The error return code is distinctive in order that it will be easily spotted. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2010-09-20GFS2: No longer experimentalSteven Whitehouse
I think the time has arrvied to remove the experimental tag from GFS2. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2010-09-20GFS2: Remove i_disksizeSteven Whitehouse
With the update of the truncate code, ip->i_disksize and inode->i_size are merely copies of each other. This means we can remove ip->i_disksize and use inode->i_size exclusively reducing the size of a GFS2 inode by 8 bytes. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2010-09-20GFS2: New truncate sequenceSteven Whitehouse
This updates GFS2's truncate code to use the new truncate sequence correctly. This is a stepping stone to being able to remove ip->i_disksize in favour of using i_size everywhere now that the two sizes are always identical. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Christoph Hellwig <hch@lst.de>
2010-09-17GFS2: gfs2_logd should be using interruptible waitsSteven Whitehouse
Looks like this crept in, in a recent update. Reported-by: Krzysztof Urbaniak <urban@bash.org.pl> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2010-09-16block: remove BLKDEV_IFL_WAITChristoph Hellwig
All the blkdev_issue_* helpers can only sanely be used for synchronous caller. To issue cache flushes or barriers asynchronously the caller needs to set up a bio by itself with a completion callback to move the asynchronous state machine ahead. So drop the BLKDEV_IFL_WAIT flag that is always specified when calling blkdev_issue_* and also remove the now unused flags argument to blkdev_issue_flush and blkdev_issue_zeroout. For blkdev_issue_discard we need to keep it for the secure discard flag, which gains a more descriptive name and loses the bitops vs flag confusion. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10gfs2: replace barriers with explicit flush / FUA usageChristoph Hellwig
Switch to the WRITE_FLUSH_FUA flag for log writes, remove the EOPNOTSUPP detection for barriers and stop setting the barrier flag for discards. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Steven Whitehouse <swhiteho@redhat.com> Acked-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-10Merge branch 'for-2.6.36' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.36' of git://git.kernel.dk/linux-2.6-block: (149 commits) block: make sure that REQ_* types are seen even with CONFIG_BLOCK=n xen-blkfront: fix missing out label blkdev: fix blkdev_issue_zeroout return value block: update request stacking methods to support discards block: fix missing export of blk_types.h writeback: fix bad _bh spinlock nesting drbd: revert "delay probes", feature is being re-implemented differently drbd: Initialize all members of sync_conf to their defaults [Bugz 315] drbd: Disable delay probes for the upcomming release writeback: cleanup bdi_register writeback: add new tracepoints writeback: remove unnecessary init_timer call writeback: optimize periodic bdi thread wakeups writeback: prevent unnecessary bdi threads wakeups writeback: move bdi threads exiting logic to the forker thread writeback: restructure bdi forker loop a little writeback: move last_active to bdi writeback: do not remove bdi from bdi_list writeback: simplify bdi code a little writeback: do not lose wake-ups in bdi threads ... Fixed up pretty trivial conflicts in drivers/block/virtio_blk.c and drivers/scsi/scsi_error.c as per Jens.
2010-08-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits) no need for list_for_each_entry_safe()/resetting with superblock list Fix sget() race with failing mount vfs: don't hold s_umount over close_bdev_exclusive() call sysv: do not mark superblock dirty on remount sysv: do not mark superblock dirty on mount btrfs: remove junk sb_dirt change BFS: clean up the superblock usage AFFS: wait for sb synchronization when needed AFFS: clean up dirty flag usage cifs: truncate fallout mbcache: fix shrinker function return value mbcache: Remove unused features add f_flags to struct statfs(64) pass a struct path to vfs_statfs update VFS documentation for method changes. All filesystems that need invalidate_inode_buffers() are doing that explicitly convert remaining ->clear_inode() to ->evict_inode() Make ->drop_inode() just return whether inode needs to be dropped fs/inode.c:clear_inode() is gone fs/inode.c:evict() doesn't care about delete vs. non-delete paths now ... Fix up trivial conflicts in fs/nilfs2/super.c
2010-08-09Make ->drop_inode() just return whether inode needs to be droppedAl Viro
... and let iput_final() do the actual eviction or retention Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09switch gfs2 to ->evict_inode()Al Viro
2010-08-09simplify checks for I_CLEAR/I_FREEINGAl Viro
add I_CLEAR instead of replacing I_FREEING with it. I_CLEAR is equivalent to I_FREEING for almost all code looking at either; it's there to keep track of having called clear_inode() exactly once per inode lifetime, at some point after having set I_FREEING. I_CLEAR and I_FREEING never get set at the same time with the current code, so we can switch to setting i_flags to I_FREEING | I_CLEAR instead of I_CLEAR without loss of information. As the result of such change, checks become simpler and the amount of code that needs to know about I_CLEAR shrinks a lot. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09check ATTR_SIZE contraints in inode_change_okChristoph Hellwig
Make sure we check the truncate constraints early on in ->setattr by adding those checks to inode_change_ok. Also clean up and document inode_change_ok to make this obvious. As a fallout we don't have to call inode_newsize_ok from simple_setsize and simplify it down to a truncate_setsize which doesn't return an error. This simplifies a lot of setattr implementations and means we use truncate_setsize almost everywhere. Get rid of fat_setsize now that it's trivial and mark ext2_setsize static to make the calling convention obvious. Keep the inode_newsize_ok in vmtruncate for now as all callers need an audit for its removal anyway. Note: setattr code in ecryptfs doesn't call inode_change_ok at all and needs a deeper audit, but that is left for later. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09remove inode_setattrChristoph Hellwig
Replace inode_setattr with opencoded variants of it in all callers. This moves the remaining call to vmtruncate into the filesystem methods where it can be replaced with the proper truncate sequence. In a few cases it was obvious that we would never end up calling vmtruncate so it was left out in the opencoded variant: spufs: explicitly checks for ATTR_SIZE earlier btrfs,hugetlbfs,logfs,dlmfs: explicitly clears ATTR_SIZE earlier ufs: contains an opencoded simple_seattr + truncate that sets the filesize just above In addition to that ncpfs called inode_setattr with handcrafted iattrs, which allowed to trim down the opencoded variant. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09sort out blockdev_direct_IO variantsChristoph Hellwig
Move the call to vmtruncate to get rid of accessive blocks to the callers in prepearation of the new truncate calling sequence. This was only done for DIO_LOCKING filesystems, so the __blockdev_direct_IO_newtrunc variant was not needed anyway. Get rid of blockdev_direct_IO_no_locking and its _newtrunc variant while at it as just opencoding the two additional paramters is shorted than the name suffix. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-07Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: ext3: Fix dirtying of journalled buffers in data=journal mode ext3: default to ordered mode quota: Use mark_inode_dirty_sync instead of mark_inode_dirty quota: Change quota error message to print out disk and function name MAINTAINERS: Update entries of ext2 and ext3 MAINTAINERS: Update address of Andreas Dilger ext3: Avoid filesystem corruption after a crash under heavy delete load ext3: remove vestiges of nobh support ext3: Fix set but unused variables quota: clean up quota active checks quota: Clean up the namespace in dqblk_xfs.h quota: check quota reservation on remove_dquot_ref
2010-08-07Merge branch 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (55 commits) workqueue: mark init_workqueues() as early_initcall() workqueue: explain for_each_*cwq_cpu() iterators fscache: fix build on !CONFIG_SYSCTL slow-work: kill it gfs2: use workqueue instead of slow-work drm: use workqueue instead of slow-work cifs: use workqueue instead of slow-work fscache: drop references to slow-work fscache: convert operation to use workqueue instead of slow-work fscache: convert object to use workqueue instead of slow-work workqueue: fix how cpu number is stored in work->data workqueue: fix mayday_mask handling on UP workqueue: fix build problem on !CONFIG_SMP workqueue: fix locking in retry path of maybe_create_worker() async: use workqueue for worker pool workqueue: remove WQ_SINGLE_CPU and use WQ_UNBOUND instead workqueue: implement unbound workqueue workqueue: prepare for WQ_UNBOUND implementation libata: take advantage of cmwq and remove concurrency limitations workqueue: fix worker management invocation without pending works ... Fixed up conflicts in fs/cifs/* as per Tejun. Other trivial conflicts in include/linux/workqueue.h, kernel/trace/Kconfig and kernel/workqueue.c
2010-08-07block: unify flags for struct bio and struct requestChristoph Hellwig
Remove the current bio flags and reuse the request flags for the bio, too. This allows to more easily trace the type of I/O from the filesystem down to the block driver. There were two flags in the bio that were missing in the requests: BIO_RW_UNPLUG and BIO_RW_AHEAD. Also I've renamed two request flags that had a superflous RW in them. Note that the flags are in bio.h despite having the REQ_ name - as blkdev.h includes bio.h that is the only way to go for now. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: BARRIER request should imply SYNCChristoph Hellwig
A barrier request should by defintion have priority in get_request and let the queue be unplugged immediately as it's blocking all forward progress due to the queue draining. Most filesystems already get this implicitly by the way how submit_bh treats the buffer_ordered flag, and gfs2 sets it explicitly. But btrfs and XFS are still forgetting to set the flag, as is blkdev_issue_flush and some places in DM/MD. For XFS on metadata heavy workloads this gives a consistent speedup in the 2-3% range. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
