Simple filesystems always pass inode->i_sb_bdev as the block device
argument, and never need a end_io handler. Let's simply things for
them and for my grepping activity by dropping these arguments. The
only thing not falling into that scheme is ext4, which passes and
end_io handler without needing special flags (yet), but given how
messy the direct I/O code there is use of __blockdev_direct_IO
in one instead of two out of three cases isn't going to make a large
difference anyway.
Let filesystems handle waiting for direct I/O requests themselves instead
of doing it beforehand. This means filesystem-specific locks to prevent
new dio referenes from appearing can be held. This is important to allow
generalizing i_dio_count to non-DIO_LOCKING filesystems.
hfs does not have problems with references to unlinked directories.
Signed-off-by: Sage Weil <sage@newdream.net>
Only a few file systems need this. Start by pushing it down into each
rename method (except gfs2 and xfs) so that it can be dealt with on a
per-fs basis.
Acked-by: Christoph Hellwig <hch@lst.de>
fs rmdir method (except gfs2 and xfs) so it can be dealt with on a per-fs
basis.
This does not change behavior for any in-tree file systems.
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits)
Documentation/iostats.txt: bit-size reference etc.
cfq-iosched: removing unnecessary think time checking
cfq-iosched: Don't clear queue stats when preempt.
blk-throttle: Reset group slice when limits are changed
blk-cgroup: Only give unaccounted_time under debug
cfq-iosched: Don't set active queue in preempt
block: fix non-atomic access to genhd inflight structures
block: attempt to merge with existing requests on plug flush
block: NULL dereference on error path in __blkdev_get()
cfq-iosched: Don't update group weights when on service tree
fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away
block: Require subsystems to explicitly allocate bio_set integrity mempool
jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
fs: make fsync_buffers_list() plug
mm: make generic_writepages() use plugging
blk-cgroup: Add unaccounted time to timeslice_used.
block: fixup plugging stubs for !CONFIG_BLOCK
block: remove obsolete comments for blkdev_issue_zeroout.
blktrace: Use rq->cmd_flags directly in blk_add_trace_rq.
Fix up conflicts in fs/{aio.c,super.c}
Code has been converted over to the new explicit on-stack plugging,
and delay users have been converted to use the new API for that.
So lets kill off the old plugging along with aops->sync_page().
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
merge hfs_unlink() and hfs_rmdir(), while we are at it.
Require filesystems be aware of .d_revalidate being called in rcu-walk
mode (nd->flags & LOOKUP_RCU). For now do a simple push down, returning
-ECHILD from all implementations.
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
Reduce some branches and memory accesses in dcache lookup by adding dentry
flags to indicate common d_ops are set, rather than having to check them.
This saves a pointer memory access (dentry->d_op) in common path lookup
situations, and saves another pointer load and branch in cases where we
have d_op but not the particular operation.
Patched with:
git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i
RCU free the struct inode. This will allow:
- Subsequent store-free path walking patch. The inode must be consulted for
permissions when walking, so an RCU inode reference is a must.
- sb_inode_list_lock to be moved inside i_lock because sb list walkers who want
to take i_lock no longer need to take sb_inode_list_lock to walk the list in
the first place. This will simplify and optimize locking.
- Could remove some nested trylock loops in dcache code
- Could potentially simplify things a bit in VM land. Do not need to take the
page lock to follow page->mapping.
The downsides of this is the performance cost of using RCU. In a simple
creat/unlink microbenchmark, performance drops by about 10% due to inability to
reuse cache-hot slab objects. As iterations increase and RCU freeing starts
kicking over, this increases to about 20%.
In cases where inode lifetimes are longer (ie. many inodes may be allocated
during the average life span of a single inode), a lot of this cache reuse is
not applicable, so the regression caused by this patch is smaller.
The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU,
however this adds some complexity to list walking and store-free path walking,
so I prefer to implement this at a later date, if it is shown to be a win in
real situations. I haven't found a regression in any non-micro benchmark so I
doubt it will be a problem.
Change d_hash so it may be called from lock-free RCU lookups. See similar
patch for d_compare for details.
For in-tree filesystems, this is just a mechanical change.
Change d_compare so it may be called from lock-free RCU lookups. This
does put significant restrictions on what may be done from the callback,
however there don't seem to have been any problems with in-tree fses.
If some strange use case pops up that _really_ cannot cope with the
rcu-walk rules, we can just add new rcu-unaware callbacks, which would
cause name lookup to drop out of rcu-walk mode.
... and switch of the obvious get_sb_bdev() users to ->mount()
Use sync_dirty_buffer instead of the incorrect opencoding it.
* 'vfs' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: (30 commits)
BKL: remove BKL from freevxfs
BKL: remove BKL from qnx4
autofs4: Only declare function when CONFIG_COMPAT is defined
autofs: Only declare function when CONFIG_COMPAT is defined
ncpfs: Lock socket in ncpfs while setting its callbacks
fs/locks.c: prepare for BKL removal
BKL: Remove BKL from ncpfs
BKL: Remove BKL from OCFS2
BKL: Remove BKL from squashfs
BKL: Remove BKL from jffs2
BKL: Remove BKL from ecryptfs
BKL: Remove BKL from afs
BKL: Remove BKL from USB gadgetfs
BKL: Remove BKL from autofs4
BKL: Remove BKL from isofs
BKL: Remove BKL from fat
BKL: Remove BKL from ext2 filesystem
BKL: Remove BKL from do_new_mount()
BKL: Remove BKL from cgroup
BKL: Remove BKL from NTFS
tree_lock is used as mutex so make it a mutex.
LKML-Reference: <20100907125056.416332114@linutronix.de>
The BKL is only used in put_super and fill_super that are both protected by
the superblocks s_umount rw_semaphore. Therefore it is safe to remove the
BKL entirely.
Signed-off-by: Jan Blunck <jblunck@infradead.org>
This patch is a preparation necessary to remove the BKL from do_new_mount().
It explicitly adds calls to lock_kernel()/unlock_kernel() around
get_sb/fill_super operations for filesystems that still uses the BKL.
I've read through all the code formerly covered by the BKL inside
do_kern_mount() and have satisfied myself that it doesn't need the BKL
any more.
do_kern_mount() is already called without the BKL when mounting the rootfs
and in nfsctl. do_kern_mount() calls vfs_kern_mount(), which is called
from various places without BKL: simple_pin_fs(), nfs_do_clone_mount()
through nfs_follow_mountpoint(), afs_mntpt_do_automount() through
afs_mntpt_follow_link(). Both later functions are actually the filesystems
follow_link inode operation. vfs_kern_mount() is calling the specified
get_sb function and lets the filesystem do its job by calling the given
fill_super function.
Therefore I think it is safe to push down the BKL from the VFS to the
low-level filesystems get_sb/fill_super operation.
[arnd: do not add the BKL to those file systems that already
don't use it elsewhere]
Cc: Matthew Wilcox <matthew@wil.cx>
Copy and simplify in the only two users remaining.
Replace inode_setattr with opencoded variants of it in all callers. This
moves the remaining call to vmtruncate into the filesystem methods where it
can be replaced with the proper truncate sequence.
In a few cases it was obvious that we would never end up calling vmtruncate
so it was left out in the opencoded variant:
spufs: explicitly checks for ATTR_SIZE earlier
btrfs,hugetlbfs,logfs,dlmfs: explicitly clears ATTR_SIZE earlier
ufs: contains an opencoded simple_seattr + truncate that sets the filesize just above
In addition to that ncpfs called inode_setattr with handcrafted iattrs,
which allowed to trim down the opencoded variant.
Move the call to vmtruncate to get rid of accessive blocks to the callers
in preparation of the new truncate sequence and rename the non-truncating
version to cont_write_begin.
in prepearation of the new truncate calling sequence. This was only done
for DIO_LOCKING filesystems, so the __blockdev_direct_IO_newtrunc variant
was not needed anyway. Get rid of blockdev_direct_IO_no_locking and
its _newtrunc variant while at it as just opencoding the two additional
paramters is shorted than the name suffix.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
This gives the filesystem more information about the writeback that
is happening. Trond requested this for the NFS unstable write handling,
and other filesystems might benefit from this too by beeing able to
distinguish between the different callers in more detail.
A specially-crafted Hierarchical File System (HFS) filesystem could cause
a buffer overflow to occur in a process's kernel stack during a memcpy()
call within the hfs_bnode_read() function (at fs/hfs/bnode.c:24). The
attacker can provide the source buffer and length, and the destination
buffer is a local variable of a fixed length. This local variable (passed
as "&entry" from fs/hfs/dir.c:112 and allocated on line 60) is stored in
the stack frame of hfs_bnode_read()'s caller, which is hfs_readdir().
Because the hfs_readdir() function executes upon any attempt to read a
directory on the filesystem, it gets called whenever a user attempts to
inspect any filesystem contents.
[amwang@redhat.com: modify this patch and fix coding style problems]
Signed-off-by: WANG Cong <amwang@redhat.com>
Cc: Eugene Teo <eteo@redhat.com>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Dave Anderson <anderson@redhat.com>
Cc: <stable@kernel.org>
A particular fsfuzzer run caused an hfs file system to crash on mount.
This is due to a corrupted MDB extent record causing a miscalculation of
HFS_I(inode)->first_blocks for the extent tree. If the extent records are
zereod out, it won't trigger the first_blocks special case. Instead it
falls through to the extent code which we're still in the middle of
initializing.
This patch catches the 0 size extent records, reports the corruption, and
fails the mount.
Reported-by: Ramon de Carvalho Valle <rcvalle@linux.vnet.ibm.com>
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
Cc: Valdis Kletnieks <Valdis.Kletnieks@vt.edu>
Most call sites of unload_nls() do:
if (nls)
unload_nls(nls);
Check the pointer inside unload_nls() like we do in kfree() and
simplify the call sites.
Cc: Steve French <sfrench@us.ibm.com>
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
Cc: Petr Vandrovec <vandrove@vc.cvut.cz>
Cc: Anton Altaparmakov <aia21@cantab.net>
* Remove smp_lock.h from files which don't need it (including some headers!)
* Add smp_lock.h to files which do need it
* Make smp_lock.h include conditional in hardirq.h
It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT
This will make hardirq.h inclusion cheaper for every PREEMPT=n config
(which includes allmodconfig/allyesconfig, BTW)
Add a ->sync_fs method for data integrity syncs.
Push down lock_super into ->write_super instances and remove it from the
caller.
Following filesystem don't need ->s_lock in ->write_super and are skipped:
* bfs, nilfs2 - no other uses of s_lock and have internal locks in
->write_super
* ext2 - uses BKL in ext2_write_super and has internal calls without s_lock
* reiserfs - no other uses of s_lock as has reiserfs_write_lock (BKL) in
->write_super
* xfs - no other uses of s_lock and uses internal lock (buffer lock on
superblock buffer) to serialize ->write_super. Also xfs_fs_write_super
is superflous and will go away in the next merge window
Move BKL into ->put_super from the only caller. A couple of
filesystems had trivial enough ->put_super (only kfree and NULLing of
s_fs_info + stuff in there) to not get any locking: coda, cramfs, efs,
hugetlbfs, omfs, qnx4, shmem, all others got the full treatment. Most
of them probably don't need it, but I'd rather sort that out individually.
Preferably after all the other BKL pushdowns in that area.
[AV: original used to move lock_super() down as well; these changes are
removed since we don't do lock_super() at all in generic_shutdown_super()
now]
[AV: fuse, btrfs and xfs are known to need no damn BKL, exempt]
We just did a full fs writeout using sync_filesystem before, and if
that's not enough for the filesystem it can perform it's own writeout
in ->put_super, which many filesystems already do.
Move a call to foofs_write_super into every foofs_put_super for now to
guarantee identical behaviour until it's cleaned up by the individual
filesystem maintainers.
Exceptions:
- affs already has identical copy & pasted code at the beginning of
affs_put_super so no need to do it twice.
- xfs does the right thing without it and I have changes pending for
the xfs tree touching this are so I don't really need conflicts
here..
When an HFS filesystem is unmounted, it leaks a 2-page bitmap. Also,
under extreme memory pressure, it's possible that hfs_releasepage() may
use a tree pointer that has not been initialized, and if so, the release
request should just be rejected.
[akpm@linux-foundation.org: free_pages(0) is legal, remove obvious comment]
Signed-off-by: Dave Anderson <anderson@redhat.com>
Tested-by: Eugene Teo <eugeneteo@kernel.sg>
Make hfs return f_fsid info for statfs(2).
Signed-off-by: Coly Li <coly.li@suse.de>
Wrap access to task credentials so that they can be separated more easily from
the task_struct during the introduction of COW creds.
Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id().
Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more
sense to use RCU directly rather than a convenient wrapper; these will be
addressed by later patches.
Reviewed-by: James Morris <jmorris@namei.org>
Acked-by: Serge Hallyn <serue@us.ibm.com>
Signed-off-by: James Morris <jmorris@namei.org>
For execute permission on a regular files we need to check if file has
any execute bits at all, regardless of capabilites.
This check is normally performed by generic_permission() but was also
added to the case when the filesystem defines its own ->permission()
method. In the latter case the filesystem should be responsible for
performing this check.
Move the check from inode_permission() inside filesystems which are
not calling generic_permission().
Create a helper function execute_ok() that returns true if the inode
is a directory or if any execute bits are present in i_mode.
Also fix up the following code:
- coda control file is never executable
- sysctl files are never executable
- hfs_permission seems broken on MAY_EXEC, remove
- hfsplus_permission is eqivalent to generic_permission(), remove
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Fix a stack corruption caused by a corrupted hfs filesystem. If the
catalog name length is corrupted the memcpy overwrites the catalog btree
structure. Since the field is limited to HFS_NAMELEN bytes in the
structure and the file format, we throw an error if it is too long.
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
This is a much better version of a previous patch to make the parser
tables constant. Rather than changing the typedef, we put the "const" in
all the various places where its required, allowing the __initconst
exception for nfsroot which was the cause of the previous trouble.
This was posted for review some time ago and I believe its been in -mm
since then.
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
Cc: Alexander Viro <aviro@redhat.com>
make it atomic_long_t; while we are at it, get rid of useless checks in affs,
hfs and hpfs - ->open() always has it equal to 1, ->release() - to 0.
* kill nameidata * argument; map the 3 bits in ->flags anybody cares
about to new MAY_... ones and pass with the mask.
* kill redundant gfs2_iop_permission()
* sanitize ecryptfs_permission()
* fix remaining places where ->permission() instances might barf on new
MAY_... found in mask.
The obvious next target in that direction is permission(9)
folded fix for nfs_permission() breakage from Miklos Szeredi <mszeredi@suse.cz>
Kmem cache passed to constructor is only needed for constructors that are
themselves multiplexeres. Nobody uses this "feature", nor does anybody uses
passed kmem cache in non-trivial way, so pass only pointer to object.
Non-trivial places are:
arch/powerpc/mm/init_64.c
arch/powerpc/mm/hugetlbpage.c
This is flag day, yes.
Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
Acked-by: Christoph Lameter <cl@linux-foundation.org>
Cc: Jon Tollefson <kniht@linux.vnet.ibm.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: Matt Mackall <mpm@selenic.com>
[akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c]
[akpm@linux-foundation.org: fix mm/slab.c]
[akpm@linux-foundation.org: fix ubifs]
Apple Macintosh file system: The semaphore extens_lock is used as a mutex.
Convert it to the mutex API
Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net>
Apple Macintosh file system: The semaphore bitmap_lock is used as a mutex.
fs/hfs/btree.c: In function 'hfs_bmap_alloc':
fs/hfs/btree.c:263: warning: comparison is always false due to limited range of data type
The patch makes the warning go away, but the code might actually be buggy?
