path: root/fs/hfsplus/bitmap.c
2010-12-16hfsplus: over 80 character lines clean-upAnton Salikhmetov
Match coding style line length limitation where checkpatch.pl reported over-80-character-line warnings. Signed-off-by: Anton Salikhmetov <alexo@tuxera.com> Signed-off-by: Christoph Hellwig <hch@tuxera.com>
2010-10-01hfsplus: fix HFSPLUS_SB calling conventionChristoph Hellwig
HFSPLUS_SB doesn't return a pointer to the hfsplus-specific superblock information like all other FOO_SB macros, but dereference the pointer in a way that made it look like a direct struct derefence. This only works as long as the HFSPLUS_SB macro is used directly and prevents us from keepig a local hfsplus_sb_info pointer. Fix the calling convention and introduce a local sbi variable in all functions that use it constantly. Signed-off-by: Christoph Hellwig <hch@tuxera.com>
2010-10-01hfsplus: introduce alloc_mutexChristoph Hellwig
Use a new per-sb alloc_mutex instead of abusing i_mutex of the alloc_file to protect block allocations. This gets rid of lockdep nesting warnings and prepares for extending the scope of alloc_mutex. Signed-off-by: Christoph Hellwig <hch@tuxera.com>
2008-10-16hfsplus: check read_mapping_page() return valueEric Sesterhenn
While testing more corrupted images with hfsplus, i came across one which triggered the following bug: [15840.675016] BUG: unable to handle kernel paging request at fffffffb [15840.675016] IP: [<c0116a4f>] kmap+0x15/0x56 [15840.675016] *pde = 00008067 *pte = 00000000 [15840.675016] Oops: 0000 [#1] PREEMPT DEBUG_PAGEALLOC [15840.675016] Modules linked in: [15840.675016] [15840.675016] Pid: 11575, comm: ln Not tainted (2.6.27-rc4-00123-gd3ee1b4-dirty #29) [15840.675016] EIP: 0060:[<c0116a4f>] EFLAGS: 00010202 CPU: 0 [15840.675016] EIP is at kmap+0x15/0x56 [15840.675016] EAX: 00000246 EBX: fffffffb ECX: 00000000 EDX: cab919c0 [15840.675016] ESI: 000007dd EDI: cab0bcf4 EBP: cab0bc98 ESP: cab0bc94 [15840.675016] DS: 007b ES: 007b FS: 0000 GS: 0033 SS: 0068 [15840.675016] Process ln (pid: 11575, ti=cab0b000 task=cab919c0 task.ti=cab0b000) [15840.675016] Stack: 00000000 cab0bcdc c0231cfb 00000000 cab0bce0 00000800 ca9290c0 fffffffb [15840.675016] cab145d0 cab919c0 cab15998 22222222 22222222 22222222 00000001 cab15960 [15840.675016] 000007dd cab0bcf4 cab0bd04 c022cb3a cab0bcf4 cab15a6c ca9290c0 00000000 [15840.675016] Call Trace: [15840.675016] [<c0231cfb>] ? hfsplus_block_allocate+0x6f/0x2d3 [15840.675016] [<c022cb3a>] ? hfsplus_file_extend+0xc4/0x1db [15840.675016] [<c022ce41>] ? hfsplus_get_block+0x8c/0x19d [15840.675016] [<c06adde4>] ? sub_preempt_count+0x9d/0xab [15840.675016] [<c019ece6>] ? __block_prepare_write+0x147/0x311 [15840.675016] [<c0161934>] ? __grab_cache_page+0x52/0x73 [15840.675016] [<c019ef4f>] ? block_write_begin+0x79/0xd5 [15840.675016] [<c022cdb5>] ? hfsplus_get_block+0x0/0x19d [15840.675016] [<c019f22a>] ? cont_write_begin+0x27f/0x2af [15840.675016] [<c022cdb5>] ? hfsplus_get_block+0x0/0x19d [15840.675016] [<c0139ebe>] ? tick_program_event+0x28/0x4c [15840.675016] [<c013bd35>] ? trace_hardirqs_off+0xb/0xd [15840.675016] [<c022b723>] ? hfsplus_write_begin+0x2d/0x32 [15840.675016] [<c022cdb5>] ? hfsplus_get_block+0x0/0x19d [15840.675016] [<c0161988>] ? pagecache_write_begin+0x33/0x107 [15840.675016] [<c01879e5>] ? __page_symlink+0x3c/0xae [15840.675016] [<c019ad34>] ? __mark_inode_dirty+0x12f/0x137 [15840.675016] [<c0187a70>] ? page_symlink+0x19/0x1e [15840.675016] [<c022e6eb>] ? hfsplus_symlink+0x41/0xa6 [15840.675016] [<c01886a9>] ? vfs_symlink+0x99/0x101 [15840.675016] [<c018a2f6>] ? sys_symlinkat+0x6b/0xad [15840.675016] [<c018a348>] ? sys_symlink+0x10/0x12 [15840.675016] [<c01038bd>] ? sysenter_do_call+0x12/0x31 [15840.675016] ======================= [15840.675016] Code: 00 00 75 10 83 3d 88 2f ec c0 02 75 07 89 d0 e8 12 56 05 00 5d c3 55 ba 06 00 00 00 89 e5 53 89 c3 b8 3d eb 7e c0 e8 16 74 00 00 <8b> 03 c1 e8 1e 69 c0 d8 02 00 00 05 b8 69 8e c0 2b 80 c4 02 00 [15840.675016] EIP: [<c0116a4f>] kmap+0x15/0x56 SS:ESP 0068:cab0bc94 [15840.675016] ---[ end trace 4fea40dad6b70e5f ]--- This happens because the return value of read_mapping_page() is passed on to kmap unchecked. The bug is triggered after the first read_mapping_page() in hfsplus_block_allocate(), this patch fixes all three usages in this functions but leaves the ones further down in the file unchanged. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-06-23[PATCH] read_mapping_page for address spacePekka Enberg
Add read_mapping_page() which is used for callers that pass mapping->a_ops->readpage as the filler for read_cache_page. This removes some duplication from filesystem code. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
