path: root/fs/hfsplus/brec.c
2015-03-25hfsplus: fix B-tree corruption after insertion at position 0Sergei Antonov
Fix B-tree corruption when a new record is inserted at position 0 in the node in hfs_brec_insert(). In this case a hfs_brec_update_parent() is called to update the parent index node (if exists) and it is passed hfs_find_data with a search_key containing a newly inserted key instead of the key to be updated. This results in an inconsistent index node. The bug reproduces on my machine after an extents overflow record for the catalog file (CNID=4) is inserted into the extents overflow B-tree. Because of a low (reserved) value of CNID=4, it has to become the first record in the first leaf node. The resulting first leaf node is correct: ---------------------------------------------------- | key0.CNID=4 | key1.CNID=123 | key2.CNID=456, ... | ---------------------------------------------------- But the parent index key0 still contains the previous key CNID=123: ----------------------- | key0.CNID=123 | ... | ----------------------- A change in hfs_brec_insert() makes hfs_brec_update_parent() work correctly by preventing it from getting fd->record=-1 value from __hfs_brec_find(). Along the way, I removed duplicate code with unification of the if condition. The resulting code is equivalent to the original code because node is never 0. Also hfs_brec_update_parent() will now return an error after getting a negative fd->record value. However, the return value of hfs_brec_update_parent() is not checked anywhere in the file and I'm leaving it unchanged by this patch. brec.c lacks error checking after some other calls too, but this issue is of less importance than the one being fixed by this patch. Signed-off-by: Sergei Antonov <saproj@gmail.com> Cc: Joe Perches <joe@perches.com> Reviewed-by: Vyacheslav Dubeyko <slava@dubeyko.com> Acked-by: Hin-Tak Leung <htl10@users.sourceforge.net> Cc: Anton Altaparmakov <aia21@cam.ac.uk> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@infradead.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30hfs/hfsplus: convert printks to pr_<level>Joe Perches
Use a more current logging style. Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt hfsplus now uses "hfsplus: " for all messages. Coalesce formats. Prefix debugging messages too. Signed-off-by: Joe Perches <joe@perches.com> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Hin-Tak Leung <htl10@users.sourceforge.net> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30hfs/hfsplus: convert dprint to hfs_dbgJoe Perches
Use a more current logging style. Rename macro and uses. Add do {} while (0) to macro. Add DBG_ to macro. Add and use hfs_dbg_cont variant where appropriate. Signed-off-by: Joe Perches <joe@perches.com> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Cc: Hin-Tak Leung <htl10@users.sourceforge.net> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27hfsplus: add support of manipulation by attributes fileVyacheslav Dubeyko
Add support of manipulation by attributes file. Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com> Reported-by: Hin-Tak Leung <htl10@users.sourceforge.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-22hfsplus: Add additional range check to handle on-disk corruptionsNaohiro Aota
'recoff' is read from disk and used for an argument to memcpy, so if the value read from disk is larger than the page size, it result to "general protection fault". This patch add additional range check for the value, so that disk fuzz won't cause such fault. Signed-off-by: Naohiro Aota <naota@elisp.net> Signed-off-by: Christoph Hellwig <hch@lst.de>
2010-12-16hfsplus: over 80 character lines clean-upAnton Salikhmetov
Match coding style line length limitation where checkpatch.pl reported over-80-character-line warnings. Signed-off-by: Anton Salikhmetov <alexo@tuxera.com> Signed-off-by: Christoph Hellwig <hch@tuxera.com>
2010-11-23hfsplus: silence a few debug printksChristoph Hellwig
Turn a few noisy debug printks that show up during xfstests into complied out debug print statements. Signed-off-by: Christoph Hellwig <hch@tuxera.com>
2010-10-14hfsplus: validate btree flagsChristoph Hellwig
2010-10-14hfsplus: handle more on-disk corruptions without oopsingEric Sandeen
hfs seems prone to bad things when it encounters on disk corruption. Many values are read from disk, and used as lengths to memcpy, as an example. This patch fixes up several of these problematic cases. o sanity check the on-disk maximum key lengths on mount (these are set to a defined value at mkfs time and shouldn't differ) o check on-disk node keylens against the maximum key length for each tree o fix hfs_btree_open so that going out via free_tree: doesn't wind up in hfs_releasepage, which wants to follow the very pointer we were trying to set up: HFS_SB(sb)->cat_tree = hfs_btree_open() . failure gets to hfs_releasepage and tries to follow HFS_SB(sb)->cat_tree Tested with the fsfuzzer; it survives more than it used to. [hch: ported of commit cf0594625083111ae522496dc1c256f7476939c2 from hfs] [hch: added the fixes from 5581d018ed3493d226e7a4d645d9c8a5af6c36b] Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Christoph Hellwig <hch@tuxera.com>
2010-10-14hfsplus: hfs_bnode_find() can fail, resulting in hfs_bnode_split() breakageAl Viro
oops and fs corruption; the latter can happen even on valid fs in case of oom. [hch: port of commit 3d10a15d6919488204bdb264050d156ced20d9aa from hfs] Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Christoph Hellwig <hch@tuxera.com>
2006-01-18[PATCH] hfs: cleanup HFS+ printsRoman Zippel
Add the log level and a "hfs: " prefix to all kernel prints. (HFS and HFS+ will use the same prefix, as they share some code and could be merged at some point.) Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
