commit 98cf21c61a7f5419d82f847c4d77bf6e96a76f5f upstream.
Fix B-tree corruption when a new record is inserted at position 0 in the
node in hfs_brec_insert(). In this case a hfs_brec_update_parent() is
called to update the parent index node (if exists) and it is passed
hfs_find_data with a search_key containing a newly inserted key instead
of the key to be updated. This results in an inconsistent index node.
The bug reproduces on my machine after an extents overflow record for
the catalog file (CNID=4) is inserted into the extents overflow B-tree.
Because of a low (reserved) value of CNID=4, it has to become the first
record in the first leaf node.
The resulting first leaf node is correct:
| key0.CNID=4 | key1.CNID=123 | key2.CNID=456, ... |
But the parent index key0 still contains the previous key CNID=123:
| key0.CNID=123 | ... |
A change in hfs_brec_insert() makes hfs_brec_update_parent() work
correctly by preventing it from getting fd->record=-1 value from
__hfs_brec_find().
Along the way, I removed duplicate code with unification of the if
condition. The resulting code is equivalent to the original code
because node is never 0.
Also hfs_brec_update_parent() will now return an error after getting a
negative fd->record value. However, the return value of
hfs_brec_update_parent() is not checked anywhere in the file and I'm
leaving it unchanged by this patch. brec.c lacks error checking after
some other calls too, but this issue is of less importance than the one
being fixed by this patch.
Signed-off-by: Sergei Antonov <saproj@gmail.com>
Cc: Joe Perches <joe@perches.com>
Reviewed-by: Vyacheslav Dubeyko <slava@dubeyko.com>
Acked-by: Hin-Tak Leung <htl10@users.sourceforge.net>
Cc: Anton Altaparmakov <aia21@cam.ac.uk>
Adds support for HFSX 'HasFolderCount' flag and a corresponding
'folderCount' field in folder records. (For reference see
HFS_FOLDERCOUNT and kHFSHasFolderCountBit/kHFSHasFolderCountMask in
Apple's source code.)
Ignoring subfolder count leads to fs errors found by Mac:
Checking catalog hierarchy.
HasFolderCount flag needs to be set (id = 105)
(It should be 0x10 instead of 0)
Incorrect folder count in a directory (id = 2)
(It should be 7 instead of 6)
Steps to reproduce:
Format with "newfs_hfs -s /dev/diskXXX".
Mount in Linux.
Create a new directory in root.
Unmount.
Run "fsck_hfs /dev/diskXXX".
The patch handles directory creation, deletion, and rename.
Current implementation of HFS+ driver has small issue with remount
option. Namely, for example, you are unable to remount from RO mode
into RW mode by means of command "mount -o remount,rw /dev/loop0
/mnt/hfsplus". Trying to execute sequence of commands results in an
error message:
mount /dev/loop0 /mnt/hfsplus
mount -o remount,ro /dev/loop0 /mnt/hfsplus
mount -o remount,rw /dev/loop0 /mnt/hfsplus
mount: you must specify the filesystem type
mount -t hfsplus -o remount,rw /dev/loop0 /mnt/hfsplus
mount: /mnt/hfsplus not mounted or bad option
The reason of such issue is failure of mount syscall:
mount("/dev/loop0", "/mnt/hfsplus", 0x2282a60, MS_MGC_VAL|MS_REMOUNT, NULL) = -1 EINVAL (Invalid argument)
Namely, hfsplus_parse_options_remount() method receives empty "input"
argument and return false in such case. As a result, hfsplus_remount()
returns -EINVAL error code.
This patch fixes the issue by means of return true for the case of empty
"input" argument in hfsplus_parse_options_remount() method.
Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com>
Pull vfs fixes from Al Viro:
"Several obvious fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
Fix mountpoint reference leakage in linkat
hfsplus: use xattr handlers for removexattr
Typo in compat_sys_lseek() declaration
fs/super.c: sync ro remount after blocking writers
vfs: unexport the getname() symbol
hfsplus was already using the handlers for get and set operations,
and with the removal of can_set_xattr we've now allow operations that
wouldn't otherwise be allowed.
With this we can also centralize the special-casing of the osx.
attrs that don't have prefixes on disk in the osx xattr handlers.
Pull core block IO changes from Jens Axboe:
"The major piece in here is the immutable bio_ve series from Kent, the
rest is fairly minor. It was supposed to go in last round, but
various issues pushed it to this release instead. The pull request
contains:
- Various smaller blk-mq fixes from different folks. Nothing major
here, just minor fixes and cleanups.
- Fix for a memory leak in the error path in the block ioctl code
from Christian Engelmayer.
- Header export fix from CaiZhiyong.
- Finally the immutable biovec changes from Kent Overstreet. This
enables some nice future work on making arbitrarily sized bios
possible, and splitting more efficient. Related fixes to immutable
bio_vecs:
- dm-cache immutable fixup from Mike Snitzer.
- btrfs immutable fixup from Muthu Kumar.
- bio-integrity fix from Nic Bellinger, which is also going to stable"
* 'for-3.14/core' of git://git.kernel.dk/linux-block: (44 commits)
xtensa: fixup simdisk driver to work with immutable bio_vecs
block/blk-mq-cpu.c: use hotcpu_notifier()
blk-mq: for_each_* macro correctness
block: Fix memory leak in rw_copy_check_uvector() handling
bio-integrity: Fix bio_integrity_verify segment start bug
block: remove unrelated header files and export symbol
blk-mq: uses page->list incorrectly
blk-mq: use __smp_call_function_single directly
btrfs: fix missing increment of bi_remaining
Revert "block: Warn and free bio if bi_end_io is not set"
blk-mq: fix initializing request's start time
block: blk-mq: don't export blk_mq_free_queue()
block: blk-mq: make blk_sync_queue support mq
block: blk-mq: support draining mq queue
dm cache: increment bi_remaining when bi_end_io is restored
block: fixup for generic bio chaining
block: Really silence spurious compiler warnings
block: Silence spurious compiler warnings
block: Kill bio_pair_split()
Pull vfs updates from Al Viro:
"Assorted stuff; the biggest pile here is Christoph's ACL series. Plus
assorted cleanups and fixes all over the place...
There will be another pile later this week"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (43 commits)
__dentry_path() fixes
vfs: Remove second variable named error in __dentry_path
vfs: Is mounted should be testing mnt_ns for NULL or error.
Fix race when checking i_size on direct i/o read
hfsplus: remove can_set_xattr
nfsd: use get_acl and ->set_acl
fs: remove generic_acl
nfs: use generic posix ACL infrastructure for v3 Posix ACLs
gfs2: use generic posix ACL infrastructure
jfs: use generic posix ACL infrastructure
xfs: use generic posix ACL infrastructure
reiserfs: use generic posix ACL infrastructure
ocfs2: use generic posix ACL infrastructure
jffs2: use generic posix ACL infrastructure
hfsplus: use generic posix ACL infrastructure
f2fs: use generic posix ACL infrastructure
ext2/3/4: use generic posix ACL infrastructure
btrfs: use generic posix ACL infrastructure
fs: make posix_acl_create more useful
fs: make posix_acl_chmod more useful
When using the per-superblock xattr handlers permission checking is
done by the generic code. hfsplus just needs to check for the magic
osx attribute not to leak into protected namespaces.
Also given that the code was obviously copied from JFS the proper
attribution was missing.
Rename the current posix_acl_created to __posix_acl_create and add
a fully featured helper to set up the ACLs on file creation that
uses get_acl().
Rename the current posix_acl_chmod to __posix_acl_chmod and add
a fully featured ACL chmod helper that uses the ->set_acl inode
operation.
HFS+ resource fork lookup breaks opendir() library function. Since
opendir first calls open() with O_DIRECTORY flag set. O_DIRECTORY means
"refuse to open if not a directory". The open system call in the kernel
does a check for inode->i_op->lookup and returns -ENOTDIR. So if
hfsplus_file_lookup is set it allows opendir() for plain files.
Also resource fork lookup in HFS+ does not work. Since it is never
invoked after VFS permission checking. It will always return with
-EACCES.
When we call opendir() on a file, it does not return NULL. opendir()
library call is based on open with O_DIRECTORY flag passed and then
layered on top of getdents() system call. O_DIRECTORY means "refuse to
The open() system call in the kernel does a check for: do_sys_open()
-->..--> can_lookup() i.e it only checks inode->i_op->lookup and returns
ENOTDIR if this function pointer is not set.
In OSX, we can open "file/rsrc" to get the resource fork of "file". This
behavior is emulated inside hfsplus on Linux, which means that to some
degree every file acts like a directory. That is the reason lookup()
inode operations is supported for files, and it is possible to do a lookup
on this specific name. As a result of this open succeeds without
returning ENOTDIR for HFS+
Please see the LKML discussion thread on this issue:
http://marc.info/?l=linux-fsdevel&m=122823343730412&w=2
I tried to test file/rsrc lookup in HFS+ driver and the feature does not
work. From OSX:
$ touch test
$ echo "1234" > test/..namedfork/rsrc
$ ls -l test..namedfork/rsrc
--rw-r--r-- 1 tuxera staff 5 10 dec 12:59 test/..namedfork/rsrc
[sougata@ultrabook tmp]$ id
uid=1000(sougata) gid=1000(sougata) groups=1000(sougata),5(tty),18(dialout),1001(vboxusers)
[sougata@ultrabook tmp]$ mount
/dev/sdb1 on /mnt/tmp type hfsplus (rw,relatime,umask=0,uid=1000,gid=1000,nls=utf8)
[sougata@ultrabook tmp]$ ls -l test/rsrc
ls: cannot access test/rsrc: Permission denied
According to this LKML thread it is expected behavior.
http://marc.info/?t=121139033800008&r=1&w=4
I guess now that permission checking happens in vfs generic_permission() ?
So it turns out that even though the lookup() inode_operation exists for
HFS+ files. It cannot really get invoked ?. So if we can disable this
feature to make opendir() work for HFS+.
Signed-off-by: Sougata Santra <sougata@tuxera.com>
Acked-by: Christoph Hellwig <hch@lst.de>
Cc: Vyacheslav Dubeyko <slava@dubeyko.com>
It was being open coded in a few places.
Signed-off-by: Kent Overstreet <kmo@daterainc.com>
Cc: Joern Engel <joern@logfs.org>
Cc: Prasad Joshi <prasadjoshi.linux@gmail.com>
Cc: Neil Brown <neilb@suse.de>
Cc: Chris Mason <chris.mason@fusionio.com>
Acked-by: NeilBrown <neilb@suse.de>
Immutable biovecs are going to require an explicit iterator. To
implement immutable bvecs, a later patch is going to add a bi_bvec_done
member to this struct; for now, this patch effectively just renames
things.
Cc: "Ed L. Cashin" <ecashin@coraid.com>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Lars Ellenberg <drbd-dev@lists.linbit.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Matthew Wilcox <willy@linux.intel.com>
Cc: Geoff Levand <geoff@infradead.org>
Cc: Yehuda Sadeh <yehuda@inktank.com>
Cc: Sage Weil <sage@inktank.com>
Cc: Alex Elder <elder@inktank.com>
Cc: ceph-devel@vger.kernel.org
Cc: Joshua Morris <josh.h.morris@us.ibm.com>
Cc: Philip Kelleher <pjk1939@linux.vnet.ibm.com>
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Alasdair Kergon <agk@redhat.com>
Cc: Mike Snitzer <snitzer@redhat.com>
Cc: dm-devel@redhat.com
Cc: linux390@de.ibm.com
Cc: Boaz Harrosh <bharrosh@panasas.com>
Cc: Benny Halevy <bhalevy@tonian.com>
Cc: "James E.J. Bottomley" <JBottomley@parallels.com>
Cc: "Nicholas A. Bellinger" <nab@linux-iscsi.org>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: Andreas Dilger <adilger.kernel@dilger.ca>
Cc: Jaegeuk Kim <jaegeuk.kim@samsung.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Dave Kleikamp <shaggy@kernel.org>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Ben Myers <bpm@sgi.com>
Cc: xfs@oss.sgi.com
Cc: Len Brown <len.brown@intel.com>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: Guo Chao <yan@linux.vnet.ibm.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Asai Thambi S P <asamymuthupa@micron.com>
Cc: Selvan Mani <smani@micron.com>
Cc: Sam Bradshaw <sbradshaw@micron.com>
Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Cc: "Roger Pau Monné" <roger.pau@citrix.com>
Cc: Jan Beulich <jbeulich@suse.com>
Cc: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Cc: Ian Campbell <Ian.Campbell@citrix.com>
Cc: Sebastian Ott <sebott@linux.vnet.ibm.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Jiang Liu <jiang.liu@huawei.com>
Cc: Nitin Gupta <ngupta@vflare.org>
Cc: Jerome Marchand <jmarchand@redhat.com>
Cc: Peng Tao <tao.peng@emc.com>
Cc: Andy Adamson <andros@netapp.com>
Cc: fanchaoting <fanchaoting@cn.fujitsu.com>
Cc: Jie Liu <jeff.liu@oracle.com>
Cc: Sunil Mushran <sunil.mushran@gmail.com>
Cc: "Martin K. Petersen" <martin.petersen@oracle.com>
Cc: Namjae Jeon <namjae.jeon@samsung.com>
Cc: Pankaj Kumar <pankaj.km@samsung.com>
Cc: Dan Magenheimer <dan.magenheimer@oracle.com>
Cc: Mel Gorman <mgorman@suse.de>6
ERROR: "__divdi3" [fs/hfsplus/hfsplus.ko] undefined!
Introduced by commit 099e9245e04d ("hfsplus: implement attributes file's
header node initialization code").
i_size_read() returns loff_t, which is long long, i.e. 64-bit. node_size
is size_t, which is either 32-bit or 64-bit. Hence
"i_size_read(attr_file) / node_size" is a 64-by-32 or 64-by-64 division,
causing (some versions of) gcc to emit a call to __divdi3().
Fortunately node_size is actually 16-bit, as the sole caller of
hfsplus_init_header_node() passes a u16. Hence change its type from
size_t to u16, and use do_div() to perform a 64-by-32 division.
Not seen in m68k/allmodconfig in -next, so it really depends on the
verion of gcc.
Implement functionality of creation AttributesFile metadata file on HFS+
volume in the case of absence of it.
It makes trying to open AttributesFile's B-tree during mount of HFS+
volume. If HFS+ volume hasn't AttributesFile then a pointer on
AttributesFile's B-tree keeps as NULL. Thereby, when it is discovered
absence of AttributesFile on HFS+ volume in the begin of xattr creation
operation then AttributesFile will be created.
The creation of AttributesFile will have success in the case of
availability (2 * clump) free blocks on HFS+ volume. Otherwise,
creation operation is ended with error (-ENOSPC).
Implement functionality of AttributesFile's header node initialization.
Cc: Hin-Tak Leung <htl10@users.sourceforge.net>
There are situation when HFS+ volume had been created without
AttributesFile. Such situation can take place because of using old
mkfs.hfs utility or creation HFS+ volume without taking in mind
necessity to use xattrs. For example, Mac OS X 10.4 (Tiger) doesn't
create AttributesFile during mkfs phase. Also it is a very frequent
situation for the case of users that created HFS+ volumes under Linux.
As a result, xattrs and POSIX ACLs on HFS+ volume are unavailable for
such users.
This patchset implements functionality of AttributesFile creation on
HFS+ volume in the case of this metadata file absence during operation
of xattr creation.
This patch:
Add functionality of metadata file's clump size calculation. Operation
of AttributesFile creation needs in clump size setting. This value will
be used when AttributesFile will be extended.
This code is adopted from code of newfs_hfs utility of diskdev_cmds packet
http://opensource.apple.com/tarballs/diskdev_cmds/.
This patch removes duplicate defines from fs/hfs/btree.h
[akpm@linux-foundation.org: retain the comments]
Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com>
truncate_pagecache() doesn't care about old size since commit
cedabed49b39 ("vfs: Fix vmtruncate() regression"). Let's drop it.
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Integrate implemented POSIX ACLs support into hfsplus driver.
Implement POSIX ACLs support in hfsplus driver.
This patchset implements POSIX ACLs support in hfsplus driver.
Mac OS X beginning with version 10.4 ("Tiger") support NFSv4 ACLs, which
are part of the NFSv4 standard. HFS+ stores ACLs in the form of
specially named extended attributes (com.apple.system.Security).
But this patchset doesn't use "com.apple.system.Security" extended
attributes. It implements support of POSIX ACLs in the form of extended
attributes with names "system.posix_acl_access" and
"system.posix_acl_default". These xattrs are treated only under Linux.
POSIX ACLs doesn't mean something under Mac OS X. Thereby, this patch
set provides opportunity to use POSIX ACLs under Linux on HFS+
filesystem.
This patch:
Add CONFIG_HFSPLUS_FS_POSIX_ACL kernel configuration option, DBG_ACL_MOD
debugging flag and acl.h file with declaration of essential functions
for support POSIX ACLs in hfsplus driver.
Instances either don't look at it at all (the majority of cases) or
only want it to find the superblock (which can be had as dentry->d_sb).
A few cases that want more are actually safe with dentry->d_inode -
the only precaution needed is the check that it hadn't been replaced with
NULL by rmdir() or by overwriting rename(), which case should be simply
treated as cache miss.
Faster kernel compiles by way of fewer unnecessary includes.
[akpm@linux-foundation.org: fix fallout]
[akpm@linux-foundation.org: fix build]
Signed-off-by: Kent Overstreet <koverstreet@google.com>
Cc: Zach Brown <zab@redhat.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Jeff Moyer <jmoyer@redhat.com>
Cc: Benjamin LaHaise <bcrl@kvack.org>
Reviewed-by: "Theodore Ts'o" <tytso@mit.edu>
__hfsplus_ext_write_extent() suppresses errors coming from
hfs_brec_find(). The patch implements error code propagation.
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Use a more current logging style.
Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt
hfsplus now uses "hfsplus: " for all messages.
Coalesce formats.
Prefix debugging messages too.
Rename macro and uses.
Add do {} while (0) to macro.
Add DBG_ to macro.
Add and use hfs_dbg_cont variant where appropriate.
fs/hfsplus/bfind.c: In function 'hfs_find_1st_rec_by_cnid':
(1) include/uapi/linux/swab.h:60:2: warning: 'search_cnid' may be used uninitialized in this function [-Wmaybe-uninitialized]
(2) include/uapi/linux/swab.h:60:2: warning: 'cur_cnid' may be used uninitialized in this function [-Wmaybe-uninitialized]
[akpm@linux-foundation.org: make the workaround more explicit]
Change a u32 to loff_t hfsplus_file_truncate().
Modify the request_module to prefix the file system type with "fs-"
and add aliases to all of the filesystems that can be built as modules
to match.
A common practice is to build all of the kernel code and leave code
that is not commonly needed as modules, with the result that many
users are exposed to any bug anywhere in the kernel.
Looking for filesystems with a fs- prefix limits the pool of possible
modules that can be loaded by mount to just filesystems trivially
making things safer with no real cost.
Using aliases means user space can control the policy of which
filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf
with blacklist and alias directives. Allowing simple, safe,
well understood work-arounds to known problematic software.
This also addresses a rare but unfortunate problem where the filesystem
name is not the same as it's module name and module auto-loading
would not work. While writing this patch I saw a handful of such
cases. The most significant being autofs that lives in the module
autofs4.
This is relevant to user namespaces because we can reach the request
module in get_fs_type() without having any special permissions, and
people get uncomfortable when a user specified string (in this case
the filesystem type) goes all of the way to request_module.
After having looked at this issue I don't think there is any
particular reason to perform any filtering or permission checks beyond
making it clear in the module request that we want a filesystem
module. The common pattern in the kernel is to call request_module()
without regards to the users permissions. In general all a filesystem
module does once loaded is call register_filesystem() and go to sleep.
Which means there is not much attack surface exposed by loading a
filesytem module unless the filesystem is mounted. In a user
namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT,
which most filesystems do not set today.
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Reported-by: Kees Cook <keescook@google.com>
The fsck_hfs (under MacOS X) complains about unzeroed unused b-tree nodes
after deletion of folders' tree under Linux.
SYMPTOMS:
Running Disk Utiltiy's "Verify Disk" on "test" gives the following:
Verifying volume “Test”
Checking file systemChecking Journaled HFS Plus volume.
Checking extents overflow file.
Checking catalog file.
Unused node is not erased (node = 3111)
Checking multi-linked files.
Checking extended attributes file.
Checking volume bitmap.
Checking volume information.
The volume Test was found corrupt and needs to be repaired.
Error: This disk needs to be repaired. Click Repair Disk.
REPRODUCING PATH:
1. Prepare HFS+ (non-case sensitive) partition (for example, 5GB)
under MacOS X.
2. Copy linux kernel source tree (for example, 3.7-rc6 version) on
this partition under MacOS X.
3. Then switch to Linux and mount this prepared partition.
4. Execute `sudo rm -r` under prepared directory with linux kernel
source tree.
5. Unmount and boot back into OS X.
6. Open up Disk Utility and verify partition.
REPRODUCIBILITY: 100%
FIX:
It is added code of node clearing in hfs_bnode_put() method for the case
when node has flag HFS_BNODE_DELETED.
Reported-by: Kyle Laracey <kalaracey@gmail.com>
Cc: Jan Kara <jack@suse.cz>
Add support of manipulation by attributes file.
Reported-by: Hin-Tak Leung <htl10@users.sourceforge.net>
attributes
Rework functionality of getting, setting and deleting of extended attributes.
Add functionality of manipulating by records in attributes tree.
Add all necessary on-disk layout declarations related to attributes file.
Merge the rest of Andrew's patches for -rc1:
"A bunch of fixes and misc missed-out-on things.
That'll do for -rc1. I still have a batch of IPC patches which still
have a possible bug report which I'm chasing down."
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (25 commits)
keys: use keyring_alloc() to create module signing keyring
keys: fix unreachable code
sendfile: allows bypassing of notifier events
SGI-XP: handle non-fatal traps
fat: fix incorrect function comment
Documentation: ABI: remove testing/sysfs-devices-node
proc: fix inconsistent lock state
linux/kernel.h: fix DIV_ROUND_CLOSEST with unsigned divisors
memcg: don't register hotcpu notifier from ->css_alloc()
checkpatch: warn on uapi #includes that #include <uapi/...
revert "rtc: recycle id when unloading a rtc driver"
mm: clean up transparent hugepage sysfs error messages
hfsplus: add error message for the case of failure of sync fs in delayed_sync_fs() method
hfsplus: rework processing of hfs_btree_write() returned error
hfsplus: rework processing errors in hfsplus_free_extents()
hfsplus: avoid crash on failed block map free
kcmp: include linux/ptrace.h
drivers/rtc/rtc-imxdi.c: must include <linux/spinlock.h>
mm: cma: WARN if freed memory is still in use
exec: do not leave bprm->interp on stack
Add an error message for the case of failure of sync fs in
delayed_sync_fs() method.
Add to hfs_btree_write() a return of -EIO on failure of b-tree node
searching. Also add logic ofor processing errors from hfs_btree_write()
in hfsplus_system_write_inode() with a message about b-tree writing
failure.
[akpm@linux-foundation.org: reduce scope of `err', print errno on error]
Currently, it doesn't process error codes from the hfsplus_block_free()
call in hfsplus_free_extents() method. Add some error code processing.
If the read fails we kmap an error code. This doesn't end well. Instead
print a critical error and pray. This mirrors the rest of the fs
behaviour with critical error cases.
Acked-by: Vyacheslav Dubeyko <slava@dubeyko.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
Removed vmtruncate
Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com>
Pull vfs update from Al Viro:
- big one - consolidation of descriptor-related logics; almost all of
that is moved to fs/file.c
(BTW, I'm seriously tempted to rename the result to fd.c. As it is,
we have a situation when file_table.c is about handling of struct
file and file.c is about handling of descriptor tables; the reasons
are historical - file_table.c used to be about a static array of
struct file we used to have way back).
A lot of stray ends got cleaned up and converted to saner primitives,
disgusting mess in android/binder.c is still disgusting, but at least
doesn't poke so much in descriptor table guts anymore. A bunch of
relatively minor races got fixed in process, plus an ext4 struct file
leak.
- related thing - fget_light() partially unuglified; see fdget() in
there (and yes, it generates the code as good as we used to have).
- also related - bits of Cyrill's procfs stuff that got entangled into
that work; _not_ all of it, just the initial move to fs/proc/fd.c and
switch of fdinfo to seq_file.
- Alex's fs/coredump.c spiltoff - the same story, had been easier to
take that commit than mess with conflicts. The rest is a separate
pile, this was just a mechanical code movement.
- a few misc patches all over the place. Not all for this cycle,
there'll be more (and quite a few currently sit in akpm's tree)."
Fix up trivial conflicts in the android binder driver, and some fairly
simple conflicts due to two different changes to the sock_alloc_file()
interface ("take descriptor handling from sock_alloc_file() to callers"
vs "net: Providing protocol type via system.sockprotoname xattr of
/proc/PID/fd entries" adding a dentry name to the socket)
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits)
MAX_LFS_FILESIZE should be a loff_t
compat: fs: Generic compat_sys_sendfile implementation
fs: push rcu_barrier() from deactivate_locked_super() to filesystems
btrfs: reada_extent doesn't need kref for refcount
coredump: move core dump functionality into its own file
coredump: prevent double-free on an error path in core dumper
usb/gadget: fix misannotations
fcntl: fix misannotations
ceph: don't abuse d_delete() on failure exits
hypfs: ->d_parent is never NULL or negative
vfs: delete surplus inode NULL check
switch simple cases of fget_light to fdget
new helpers: fdget()/fdput()
switch o2hb_region_dev_write() to fget_light()
proc_map_files_readdir(): don't bother with grabbing files
make get_file() return its argument
vhost_set_vring(): turn pollstart/pollstop into bool
switch prctl_set_mm_exe_file() to fget_light()
switch xfs_find_handle() to fget_light()
switch xfs_swapext() to fget_light()
There's no reason to call rcu_barrier() on every
deactivate_locked_super(). We only need to make sure that all delayed rcu
free inodes are flushed before we destroy related cache.
Removing rcu_barrier() from deactivate_locked_super() affects some fast
paths. E.g. on my machine exit_group() of a last process in IPC
namespace takes 0.07538s. rcu_barrier() takes 0.05188s of that time.
Use -ENOMEM return value instead of -EINVAL when kzalloc() fails.
Signed-off-by: Namjae Jeon <linkinjeon@gmail.com>
