path: root/fs/hostfs
2014-01-26um: hostfs: make functions staticJames Hogan
The hostfs_*() callback functions are all only used within hostfs_kern.c, so make them static. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: user-mode-linux-devel@lists.sourceforge.net Signed-off-by: Richard Weinberger <richard@nod.at>
2013-11-15consolidate simple ->d_delete() instancesAl Viro
Rename simple_delete_dentry() to always_delete_dentry() and export it. Export simple_dentry_operations, while we are at it, and get rid of their duplicates Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-09-07um: hostfs: Fix writebackRichard Weinberger
We have to implement ->release() and trigger writeback from it. Otherwise we might lose dirty pages at munmap(). Signed-off-by: Richard Weinberger <richard@nod.at>
2013-06-29[readdir] convert hostfsAl Viro
2013-05-04hostfs: use kmalloc instead of kzallocJames Hogan
The inode info structure is zeroed at allocation with kzalloc, and then all but one of the fields (including the largest, vfs_inode) are initialised explicitly. Switch to using kmalloc and initialise the remaining field too. Reported-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-04hostfs: move HOSTFS_SUPER_MAGIC to <linux/magic.h>James Hogan
Move HOSTFS_SUPER_MAGIC to <linux/magic.h> to be with it's magical friends from other file systems. Reported-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-04hostfs: remove "will unlock" commentJames Hogan
A "will unlock" comment was added to hostfs in the following commit, along with a spinlock: Commit e9193059b1b3733695d5b80e667778311695aa73 ("hostfs: fix races in dentry_name() and inode_name()"). But the spinlock was subsequently removed in the following commit: Commit ec2447c278ee973d35f38e53ca16ba7f965ae33d ("hostfs: simplify locking"). Since the comment is no longer applicable, remove it. Reported-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Nick Piggin <npiggin@kernel.dk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-03-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull namespace bugfixes from Eric Biederman: "This tree includes a partial revert for "fs: Limit sys_mount to only request filesystem modules." When I added the new style module aliases to the filesystems I deleted the old ones. A bad move. It turns out that distributions like Arch linux use module aliases when constructing ramdisks. Which meant ultimately that an ext3 filesystem mounted with ext4 would not result in the ext4 module being put into the ramdisk. The other change in this tree adds a handful of filesystem module alias I simply failed to add the first time. Which inconvinienced a few folks using cifs. I don't want to inconvinience folks any longer than I have to so here are these trivial fixes." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: fs: Readd the fs module aliases. fs: Limit sys_mount to only request filesystem modules. (Part 3)
2013-03-11fs: Limit sys_mount to only request filesystem modules. (Part 3)Eric W. Biederman
Somehow I failed to add the MODULE_ALIAS_FS for cifs, hostfs, hpfs, squashfs, and udf despite what I thought were my careful checks :( Add them now. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-03-11hostfs: fix a not needed double checkMarco Stornelli
With the commit 3be2be0a32c18b0fd6d623cda63174a332ca0de1 we removed vmtruncate, but actaully there is no need to call inode_newsize_ok() because the checks are already done in inode_change_ok() at the begin of the function. Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com> Signed-off-by: Richard Weinberger <richard@nod.at>
2013-02-22hostfs: directory methods have no business in non-directory inode_operationsAl Viro
2013-02-22new helper: file_inode(file)Al Viro
2012-10-10Merge branch 'for-linus-37rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rw/uml Pull UML changes from Richard Weinberger: "UML receives this time only cleanups. The most outstanding change is the 'include "foo.h"' do 'include <foo.h>' conversion done by Al Viro. It touches many files, that's why the diffstat is rather big." * 'for-linus-37rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/uml: typo in UserModeLinux-HOWTO hppfs: fix the return value of get_inode() hostfs: drop vmtruncate um: get rid of pointless include "..." where include <...> will do um: move sysrq.h out of include/shared um/x86: merge 32 and 64 bit variants of ptrace.h um/x86: merge 32 and 64bit variants of checksum.h
2012-10-09hostfs: drop vmtruncateMarco Stornelli
Removed vmtruncate. Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com> Signed-off-by: Richard Weinberger <richard@nod.at>
2012-10-09um: get rid of pointless include "..." where include <...> will doAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Richard Weinberger <richard@nod.at>
2012-09-21userns: Convert hostfs to use kuid and kgid where appropriateEric W. Biederman
Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-07-14don't pass nameidata to ->create()Al Viro
boolean "does it have to be exclusive?" flag is passed instead; Local filesystem should just ignore it - the object is guaranteed not to be there yet. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14stop passing nameidata to ->lookup()Al Viro
Just the flags; only NFS cares even about that, but there are legitimate uses for such argument. And getting rid of that completely would require splitting ->lookup() into a couple of methods (at least), so let's leave that alone for now... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-06vfs: Rename end_writeback() to clear_inode()Jan Kara
After we moved inode_sync_wait() from end_writeback() it doesn't make sense to call the function end_writeback() anymore. Rename it to clear_inode() which well says what the function really does - set I_CLEAR flag. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
2012-03-27Merge branch 'for-linus-3.4-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rw/uml Pull UML changes from Richard Weinberger: "Mostly bug fixes and cleanups" * 'for-linus-3.4-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/uml: (35 commits) um: Update defconfig um: Switch to large mcmodel on x86_64 MTD: Relax dependencies um: Wire CONFIG_GENERIC_IO up um: Serve io_remap_pfn_range() Introduce CONFIG_GENERIC_IO um: allow SUBARCH=x86 um: most of the SUBARCH uses can be killed um: deadlock in line_write_interrupt() um: don't bother trying to rebuild CHECKFLAGS for USER_OBJS um: use the right ifdef around exports in user_syms.c um: a bunch of headers can be killed by using generic-y um: ptrace-generic.h doesn't need user.h um: kill HOST_TASK_PID um: remove pointless include of asm/fixmap.h from asm/pgtable.h um: asm-offsets.h might as well come from underlying arch... um: merge processor_{32,64}.h a bit... um: switch close_chan() to struct line um: race fix: initialize delayed_work *before* registering IRQ um: line->have_irq is never checked... ...
2012-03-25uml/hostfs: Propagate dirent.d_type to filldir()Geert Uytterhoeven
Currently the (optional) d_type member in struct dirent is always DT_UNKNOWN on hostfs, which may confuse buggy software using readdir(). Make sure to propagate its value from the underlying filesystem if it's available there. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Richard Weinberger <richard@nod.at>
2012-03-20switch open-coded instances of d_make_root() to new helperAl Viro
2012-01-06vfs: switch ->show_options() to struct dentry *Al Viro
2012-01-03switch hostfs_iattr to explicit unsigned shortAl Viro
It's shared between kernel-compiled hostfs_kern and userland-compiled hostfs_user (it's uml stuff). Use explicit type instead of playing silly buggers with mode_t. It's not a userland API per se; it interacts between code compiled with types same as for host kernel and, directly linked to it, code talking to libc. Both sides come from the same kernel source... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03switch ->mknod() to umode_tAl Viro
2012-01-03switch ->create() to umode_tAl Viro
vfs_create() ignores everything outside of 16bit subset of its mode argument; switching it to umode_t is obviously equivalent and it's the only caller of the method Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03switch vfs_mkdir() and ->mkdir() to umode_tAl Viro
vfs_mkdir() gets int, but immediately drops everything that might not fit into umode_t and that's the only caller of ->mkdir()... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03vfs: fix the stupidity with i_dentry in inode destructorsAl Viro
Seeing that just about every destructor got that INIT_LIST_HEAD() copied into it, there is no point whatsoever keeping this INIT_LIST_HEAD in inode_init_once(); the cost of taking it into inode_init_always() will be negligible for pipes and sockets and negative for everything else. Not to mention the removal of boilerplate code from ->destroy_inode() instances... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-11-02Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/hch/vfs-queue * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/hch/vfs-queue: vfs: add d_prune dentry operation vfs: protect i_nlink filesystems: add set_nlink() filesystems: add missing nlink wrappers logfs: remove unnecessary nlink setting ocfs2: remove unnecessary nlink setting jfs: remove unnecessary nlink setting hypfs: remove unnecessary nlink setting vfs: ignore error on forced remount readlinkat: ensure we return ENOENT for the empty pathname for normal lookups vfs: fix dentry leak in simple_fill_super()
2011-11-02um: kill useless include of user.hAl Viro
everything in USER_OBJ gets it via -include user.h Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Richard Weinberger <richard@nod.at>
2011-11-02filesystems: add set_nlink()Miklos Szeredi
Replace remaining direct i_nlink updates with a new set_nlink() updater function. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-07-20fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlersJosef Bacik
Btrfs needs to be able to control how filemap_write_and_wait_range() is called in fsync to make it less of a painful operation, so push down taking i_mutex and the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some file systems can drop taking the i_mutex altogether it seems, like ext3 and ocfs2. For correctness sake I just pushed everything down in all cases to make sure that we keep the current behavior the same for everybody, and then each individual fs maintainer can make up their mind about what to do from there. Thanks, Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20->permission() sanitizing: don't pass flags to ->permission()Al Viro
not used by the instances anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20->permission() sanitizing: don't pass flags to generic_permission()Al Viro
redundant; all callers get it duplicated in mask & MAY_NOT_BLOCK and none of them removes that bit. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20kill check_acl callback of generic_permission()Al Viro
its value depends only on inode and does not change; we might as well store it in ->i_op->check_acl and be done with that. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-28hostfs: remove unnecessary dentry_unhash on rmdir, dir renameSage Weil
hostfs does not have problems with references to unlinked directories. CC: Jeff Dike <jdike@addtoit.com> CC: Richard Weinberger <richard@nod.at> CC: user-mode-linux-devel@lists.sourceforge.net Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26vfs: push dentry_unhash on rename_dir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each rename method (except gfs2 and xfs) so that it can be dealt with on a per-fs basis. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26vfs: push dentry_unhash on rmdir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each fs rmdir method (except gfs2 and xfs) so it can be dealt with on a per-fs basis. This does not change behavior for any in-tree file systems. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-12switch hostfsAl Viro
->d_delete() doesn't matter for s_root anyway Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-07fs: provide rcu-walk aware permission i_opsNick Piggin
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache reduce branches in lookup pathNick Piggin
Reduce some branches and memory accesses in dcache lookup by adding dentry flags to indicate common d_ops are set, rather than having to check them. This saves a pointer memory access (dentry->d_op) in common path lookup situations, and saves another pointer load and branch in cases where we have d_op but not the particular operation. Patched with: git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: icache RCU free inodesNick Piggin
RCU free the struct inode. This will allow: - Subsequent store-free path walking patch. The inode must be consulted for permissions when walking, so an RCU inode reference is a must. - sb_inode_list_lock to be moved inside i_lock because sb list walkers who want to take i_lock no longer need to take sb_inode_list_lock to walk the list in the first place. This will simplify and optimize locking. - Could remove some nested trylock loops in dcache code - Could potentially simplify things a bit in VM land. Do not need to take the page lock to follow page->mapping. The downsides of this is the performance cost of using RCU. In a simple creat/unlink microbenchmark, performance drops by about 10% due to inability to reuse cache-hot slab objects. As iterations increase and RCU freeing starts kicking over, this increases to about 20%. In cases where inode lifetimes are longer (ie. many inodes may be allocated during the average life span of a single inode), a lot of this cache reuse is not applicable, so the regression caused by this patch is smaller. The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU, however this adds some complexity to list walking and store-free path walking, so I prefer to implement this at a later date, if it is shown to be a win in real situations. I haven't found a regression in any non-micro benchmark so I doubt it will be a problem. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07hostfs: simplify lockingNick Piggin
Remove dcache_lock locking from hostfs filesystem, and move it into dcache helpers. All that is required is a coherent path name. Protection from concurrent modification of the namespace after path name generation is not provided in current code, because dcache_lock is dropped before the path is used. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_delete semanticsNick Piggin
Change d_delete from a dentry deletion notification to a dentry caching advise, more like ->drop_inode. Require it to be constant and idempotent, and not take d_lock. This is how all existing filesystems use the callback anyway. This makes fine grained dentry locking of dput and dentry lru scanning much simpler. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-10-29convert get_sb_nodev() usersAl Viro
2010-10-26hostfs: code cleanupsRichard Weinberger
Some code cleanups for hostfs. Signed-off-by: Richard Weinberger <richard@nod.at> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26hostfs: fix UML crash: remove f_spare from hostfsRichard Weinberger
365b1818 ("add f_flags to struct statfs(64)") resized f_spare within struct statfs which caused a UML crash. There is no need to copy f_spare. Signed-off-by: Richard Weinberger <richard@nod.at> Reported-by: Toralf Förster <toralf.foerster@gmx.de> Tested-by: Toralf Förster <toralf.foerster@gmx.de> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Jeff Dike <jdike@addtoit.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-08-18hostfs ->follow_link() brainoAl Viro
we want the assignment to err done inside the if () to be visible after it, so (re)declaring err inside if () body is wrong. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
