path: root/fs/hpfs/file.c
2016-10-05hpfs: support FIEMAPMikulas Patocka
Support the FIEMAP ioctl that reports extents allocated by a file. Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-09-03hpfs: support hotfixesMikulas Patocka
When the OS/2 driver hits a disk write error, it writes the sector to another location and adds the sector mapping to the hotfix map. This patch makes the hpfs driver understand the hotfix map and remap accesses accoring to it. Signed-off-by: Mikulas Patocka <mikulas@twibright.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-09hpfs: add fstrim supportMikulas Patocka
This patch adds support for fstrim to the HPFS filesystem. Signed-off-by: Mikulas Patocka <mikulas@twibright.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-11make new_sync_{read,write}() staticAl Viro
All places outside of core VFS that checked ->read and ->write for being NULL or called the methods directly are gone now, so NULL {read,write} with non-NULL {read,write}_iter will do the right thing in all cases. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-06write_iter variants of {__,}generic_file_aio_write()Al Viro
2014-05-06switch simple generic_file_aio_read() users to ->read_iter()Al Viro
2013-09-12truncate: drop 'oldsize' truncate_pagecache() parameterKirill A. Shutemov
truncate_pagecache() doesn't care about old size since commit cedabed49b39 ("vfs: Fix vmtruncate() regression"). Let's drop it. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-04hpfs: use mpageMikulas Patocka
Use the mpage interface to improve performance. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-08hpfs: fix warnings when the filesystem fills upMikulas Patocka
This patch fixes warnings due to missing lock on write error path. WARNING: at fs/hpfs/hpfs_fn.h:353 hpfs_truncate+0x75/0x80 [hpfs]() Hardware name: empty Pid: 26563, comm: dd Tainted: P O 3.9.4 #12 Call Trace: hpfs_truncate+0x75/0x80 [hpfs] hpfs_write_begin+0x84/0x90 [hpfs] _hpfs_bmap+0x10/0x10 [hpfs] generic_file_buffered_write+0x121/0x2c0 __generic_file_aio_write+0x1c7/0x3f0 generic_file_aio_write+0x7c/0x100 do_sync_write+0x98/0xd0 hpfs_file_write+0xd/0x50 [hpfs] vfs_write+0xa2/0x160 sys_write+0x51/0xa0 page_fault+0x22/0x30 system_call_fastpath+0x1a/0x1f Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Cc: stable@kernel.org # 2.6.39+ Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-09hpfs: move setting hpfs-private i_dirty to ->write_end()Al Viro
... so that writev(2) doesn't miss it. Get rid of hpfs_file_write(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-22new helper: file_inode(file)Al Viro
2012-12-20hpfs: drop vmtruncateMarco Stornelli
Removed vmtruncate Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlersJosef Bacik
Btrfs needs to be able to control how filemap_write_and_wait_range() is called in fsync to make it less of a painful operation, so push down taking i_mutex and the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some file systems can drop taking the i_mutex altogether it seems, like ext3 and ocfs2. For correctness sake I just pushed everything down in all cases to make sure that we keep the current behavior the same for everybody, and then each individual fs maintainer can make up their mind about what to do from there. Thanks, Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-09HPFS: Implement fsync for hpfsMikulas Patocka
Implement fsync for hpfs. Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-09HPFS: Introduce a global mutex and lock it on every callback from VFS.Mikulas Patocka
Introduce a global mutex and lock it on every callback from VFS. Performance doesn't matter, reviewing the whole code for locking correctness would be too complicated, so simply lock it all. Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-02hpfs: remove the BKLArnd Bergmann
This removes the BKL in hpfs in a rather awful way, by making the code only work on uniprocessor systems without kernel preemption, as suggested by Andi Kleen. The HPFS code probably has close to zero remaining users on current kernels, all archeological uses of the file system can probably be done with the significant restrictions. The hpfs_lock/hpfs_unlock functions are left in the code, sincen Mikulas has indicated that he is still interested in fixing it in a better way. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Andi Kleen <ak@linux.intel.com> Cc: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Cc: linux-fsdevel@vger.kernel.org
2010-08-09get rid of cont_write_begin_newtruncChristoph Hellwig
Move the call to vmtruncate to get rid of accessive blocks to the callers in preparation of the new truncate sequence and rename the non-truncating version to cont_write_begin. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27drop unused dentry argument to ->fsyncChristoph Hellwig
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23[PATCH] hpfs: cleanup ->setattrChristoph Hellwig
Reformat hpfs_notify_change to standard kernel style to make it readable and rename it to hpfs_setattr as that's what the method is called. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2007-10-16hpfs: convert to new aopsNick Piggin
Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10sendfile: remove .sendfile from filesystems that use generic_file_sendfile()Jens Axboe
They can use generic_file_splice_read() instead. Since sys_sendfile() now prefers that, there should be no change in behaviour. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-02-12[PATCH] mark struct inode_operations const 2Arjan van de Ven
2006-12-08[PATCH] struct path: convert hpfsJosef Sipek
2006-10-01[PATCH] Streamline generic_file_* interfaces and filemap cleanupsBadari Pulavarty
This patch cleans up generic_file_*_read/write() interfaces. Christoph Hellwig gave me the idea for this clean ups. In a nutshell, all filesystems should set .aio_read/.aio_write methods and use do_sync_read/ do_sync_write() as their .read/.write methods. This allows us to cleanup all variants of generic_file_* routines. Final available interfaces: generic_file_aio_read() - read handler generic_file_aio_write() - write handler generic_file_aio_write_nolock() - no lock write handler __generic_file_aio_write_nolock() - internal worker routine Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[PATCH] mark address_space_operations constChristoph Hellwig
Same as with already do with the file operations: keep them in .rodata and prevents people from doing runtime patching. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] hpfs: remove spurious mtime updateChristoph Hellwig
Remove mtime update in hpfs_file_write, it's done in generic_file_write already. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
