path: root/fs/hpfs/super.c
2011-05-09HPFS: Fix endianity. Make hpfs work on big-endian machinesMikulas Patocka
Fix endianity. Make hpfs work on big-endian machines. Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-09HPFS: Fix a bug that filesystem was not marked dirty when remounting itMikulas Patocka
Fix a bug that filesystem was not marked dirty when remounting it Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-09HPFS: When marking or clearing the dirty bit, sync the filesystemMikulas Patocka
When marking or clearing the dirty bit, sync the filesystem Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-09HPFS: Remove CR/LF conversion optionMikulas Patocka
Remove CR/LF conversion option It is unused anyway. It was used on 2.2 kernels or so. Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-09HPFS: Remove remaining locksMikulas Patocka
Remove remaining locks Because of a new global per-fs lock, no other locks are needed Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-09HPFS: Introduce a global mutex and lock it on every callback from VFS.Mikulas Patocka
Introduce a global mutex and lock it on every callback from VFS. Performance doesn't matter, reviewing the whole code for locking correctness would be too complicated, so simply lock it all. Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-09HPFS: Make HPFS compile on preempt and SMPMikulas Patocka
Make HPFS compile on preempt and SMP Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-02hpfs: remove the BKLArnd Bergmann
This removes the BKL in hpfs in a rather awful way, by making the code only work on uniprocessor systems without kernel preemption, as suggested by Andi Kleen. The HPFS code probably has close to zero remaining users on current kernels, all archeological uses of the file system can probably be done with the significant restrictions. The hpfs_lock/hpfs_unlock functions are left in the code, sincen Mikulas has indicated that he is still interested in fixing it in a better way. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Andi Kleen <ak@linux.intel.com> Cc: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Cc: linux-fsdevel@vger.kernel.org
2011-01-12switch hpfsAl Viro
2011-01-07fs: icache RCU free inodesNick Piggin
RCU free the struct inode. This will allow: - Subsequent store-free path walking patch. The inode must be consulted for permissions when walking, so an RCU inode reference is a must. - sb_inode_list_lock to be moved inside i_lock because sb list walkers who want to take i_lock no longer need to take sb_inode_list_lock to walk the list in the first place. This will simplify and optimize locking. - Could remove some nested trylock loops in dcache code - Could potentially simplify things a bit in VM land. Do not need to take the page lock to follow page->mapping. The downsides of this is the performance cost of using RCU. In a simple creat/unlink microbenchmark, performance drops by about 10% due to inability to reuse cache-hot slab objects. As iterations increase and RCU freeing starts kicking over, this increases to about 20%. In cases where inode lifetimes are longer (ie. many inodes may be allocated during the average life span of a single inode), a lot of this cache reuse is not applicable, so the regression caused by this patch is smaller. The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU, however this adds some complexity to list walking and store-free path walking, so I prefer to implement this at a later date, if it is shown to be a win in real situations. I haven't found a regression in any non-micro benchmark so I doubt it will be a problem. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-10-31Merge branches 'irq-core-for-linus' and 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: genirq: Fix up irq_node() for irq_data changes. genirq: Add single IRQ reservation helper genirq: Warn if enable_irq is called before irq is set up * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: semaphore: Remove mutex emulation staging: Final semaphore cleanup jbd2: Convert jbd2_slab_create_sem to mutex hpfs: Convert sbi->hpfs_creation_de to mutex Fix up trivial change/delete conflicts with deleted 'dream' drivers (drivers/staging/dream/camera/{mt9d112.c,mt9p012_fox.c,mt9t013.c,s5k3e2fx.c})
2010-10-30hpfs: Convert sbi->hpfs_creation_de to mutexThomas Gleixner
sbi->hpfs_creation_de is used as mutex so make it a mutex. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Christoph Hellwig <hch@infradead.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: linux-fsdevel@vger.kernel.org LKML-Reference: <20100907125056.228874895@linutronix.de>
2010-10-29new helper: mount_bdev()Al Viro
... and switch of the obvious get_sb_bdev() users to ->mount() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-04BKL: Explicitly add BKL around get_sb/fill_superJan Blunck
This patch is a preparation necessary to remove the BKL from do_new_mount(). It explicitly adds calls to lock_kernel()/unlock_kernel() around get_sb/fill_super operations for filesystems that still uses the BKL. I've read through all the code formerly covered by the BKL inside do_kern_mount() and have satisfied myself that it doesn't need the BKL any more. do_kern_mount() is already called without the BKL when mounting the rootfs and in nfsctl. do_kern_mount() calls vfs_kern_mount(), which is called from various places without BKL: simple_pin_fs(), nfs_do_clone_mount() through nfs_follow_mountpoint(), afs_mntpt_do_automount() through afs_mntpt_follow_link(). Both later functions are actually the filesystems follow_link inode operation. vfs_kern_mount() is calling the specified get_sb function and lets the filesystem do its job by calling the given fill_super function. Therefore I think it is safe to push down the BKL from the VFS to the low-level filesystems get_sb/fill_super operation. [arnd: do not add the BKL to those file systems that already don't use it elsewhere] Signed-off-by: Jan Blunck <jblunck@infradead.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Christoph Hellwig <hch@infradead.org>
2010-08-09switch hpfs to ->evict_inode()Al Viro
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-16hpfs: use bitmap_weight()Akinobu Mita
Use bitmap_weight instead of doing hweight32 for each 32bit in bitmap. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16hpfs: use hweight32Akinobu Mita
Use hweight32 instead of counting for each bit Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11Push BKL down into ->remount_fs()Alessio Igor Bogani
[xfs, btrfs, capifs, shmem don't need BKL, exempt] Signed-off-by: Alessio Igor Bogani <abogani@texware.it> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11Push lock_super() into the ->remount_fs() of filesystems that care about itAl Viro
Note that since we can't run into contention between remount_fs and write_super (due to exclusion on s_umount), we have to care only about filesystems that touch lock_super() on their own. Out of those ext3, ext4, hpfs, sysv and ufs do need it; fat doesn't since its ->remount_fs() only accesses assign-once data (basically, it's "we have no atime on directories and only have atime on files for vfat; force nodiratime and possibly noatime into *flags"). [folded a build fix from hch] Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11push BKL down into ->put_superChristoph Hellwig
Move BKL into ->put_super from the only caller. A couple of filesystems had trivial enough ->put_super (only kfree and NULLing of s_fs_info + stuff in there) to not get any locking: coda, cramfs, efs, hugetlbfs, omfs, qnx4, shmem, all others got the full treatment. Most of them probably don't need it, but I'd rather sort that out individually. Preferably after all the other BKL pushdowns in that area. [AV: original used to move lock_super() down as well; these changes are removed since we don't do lock_super() at all in generic_shutdown_super() now] [AV: fuse, btrfs and xfs are known to need no damn BKL, exempt] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-05-09Fix races around the access to ->s_optionsAl Viro
Put generic_show_options read access to s_options under rcu_read_lock, split save_mount_options() into "we are setting it the first time" (uses in foo_fill_super()) and "we are relacing and freeing the old one", synchronize_rcu() before kfree() in the latter. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: Remove two unneeded exports and make two symbols static in fs/mpage.c Cleanup after commit 585d3bc06f4ca57f975a5a1f698f65a45ea66225 Trim includes of fdtable.h Don't crap into descriptor table in binfmt_som Trim includes in binfmt_elf Don't mess with descriptor table in load_elf_binary() Get rid of indirect include of fs_struct.h New helper - current_umask() check_unsafe_exec() doesn't care about signal handlers sharing New locking/refcounting for fs_struct Take fs_struct handling to new file (fs/fs_struct.c) Get rid of bumping fs_struct refcount in pivot_root(2) Kill unsharing fs_struct in __set_personality()
2009-04-02fs/hpfs: return f_fsid for statfs(2)Coly Li
Make hpfs return f_fsid info for statfs(2). Signed-off-by: Coly Li <coly.li@suse.de> Cc: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-31New helper - current_umask()Al Viro
current->fs->umask is what most of fs_struct users are doing. Put that into a helper function. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-11-14CRED: Wrap task credential accesses in the HPFS filesystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-13vfs: Use const for kernel parser tableSteven Whitehouse
This is a much better version of a previous patch to make the parser tables constant. Rather than changing the typedef, we put the "const" in all the various places where its required, allowing the __initconst exception for nfsroot which was the cause of the previous trouble. This was posted for review some time ago and I believe its been in -mm since then. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Alexander Viro <aviro@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26SL*B: drop kmem cache argument from constructorAlexey Dobriyan
Kmem cache passed to constructor is only needed for constructors that are themselves multiplexeres. Nobody uses this "feature", nor does anybody uses passed kmem cache in non-trivial way, so pass only pointer to object. Non-trivial places are: arch/powerpc/mm/init_64.c arch/powerpc/mm/hugetlbpage.c This is flag day, yes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Matt Mackall <mpm@selenic.com> [akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c] [akpm@linux-foundation.org: fix mm/slab.c] [akpm@linux-foundation.org: fix ubifs] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08mount options: fix hpfsMiklos Szeredi
Add a .show_options super operation to hpfs. Use generic_show_options() and save the complete option string in hpfs_fill_super() and hpfs_remount_fs(). Also add a small fix: hpfs_remount_fs() should return -EINVAL on error, instead of 1, which is not an error value. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Slab API: remove useless ctor parameter and reorder parametersChristoph Lameter
Slab constructors currently have a flags parameter that is never used. And the order of the arguments is opposite to other slab functions. The object pointer is placed before the kmem_cache pointer. Convert ctor(void *object, struct kmem_cache *s, unsigned long flags) to ctor(struct kmem_cache *s, void *object) throughout the kernel [akpm@linux-foundation.org: coupla fixes] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] hpfs: bring hpfs_error() into shapeAlexey Dobriyan
- switch to error message buffer in .bss - missing va_end() (htf it worked before?) - use vsnprintf() - rename variables to understandable "fmt", "args". - "const char *fmt", yes. - add __attribute__((format ... Still, put that coffee down before reading more. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] slab: remove SLAB_NOFSChristoph Lameter
SLAB_NOFS is an alias of GFP_NOFS. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] Really ignore kmem_cache_destroy return valueAlexey Dobriyan
* Rougly half of callers already do it by not checking return value * Code in drivers/acpi/osl.c does the following to be sure: (void)kmem_cache_destroy(cache); * Those who check it printk something, however, slab_error already printed the name of failed cache. * XFS BUGs on failed kmem_cache_destroy which is not the decision low-level filesystem driver should make. Converted to ignore. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] fs: Conversions from kmalloc+memset to k(z|c)allocPanagiotis Issaris
Conversions from kmalloc+memset to kzalloc. Signed-off-by: Panagiotis Issaris <takis@issaris.org> Jffs2-bit-acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-24Move several *_SUPER_MAGIC symbols to include/linux/magic.h.Jeff Garzik
Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-06-23[PATCH] VFS: Permit filesystem to perform statfs with a known root dentryDavid Howells
Give the statfs superblock operation a dentry pointer rather than a superblock pointer. This complements the get_sb() patch. That reduced the significance of sb->s_root, allowing NFS to place a fake root there. However, NFS does require a dentry to use as a target for the statfs operation. This permits the root in the vfsmount to be used instead. linux/mount.h has been added where necessary to make allyesconfig build successfully. Interest has also been expressed for use with the FUSE and XFS filesystems. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to override root dentry on mountDavid Howells
Extend the get_sb() filesystem operation to take an extra argument that permits the VFS to pass in the target vfsmount that defines the mountpoint. The filesystem is then required to manually set the superblock and root dentry pointers. For most filesystems, this should be done with simple_set_mnt() which will set the superblock pointer and then set the root dentry to the superblock's s_root (as per the old default behaviour). The get_sb() op now returns an integer as there's now no need to return the superblock pointer. This patch permits a superblock to be implicitly shared amongst several mount points, such as can be done with NFS to avoid potential inode aliasing. In such a case, simple_set_mnt() would not be called, and instead the mnt_root and mnt_sb would be set directly. The patch also makes the following changes: (*) the get_sb_*() convenience functions in the core kernel now take a vfsmount pointer argument and return an integer, so most filesystems have to change very little. (*) If one of the convenience function is not used, then get_sb() should normally call simple_set_mnt() to instantiate the vfsmount. This will always return 0, and so can be tail-called from get_sb(). (*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the dcache upon superblock destruction rather than shrink_dcache_anon(). This is required because the superblock may now have multiple trees that aren't actually bound to s_root, but that still need to be cleaned up. The currently called functions assume that the whole tree is rooted at s_root, and that anonymous dentries are not the roots of trees which results in dentries being left unculled. However, with the way NFS superblock sharing are currently set to be implemented, these assumptions are violated: the root of the filesystem is simply a dummy dentry and inode (the real inode for '/' may well be inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries with child trees. [*] Anonymous until discovered from another tree. (*) The documentation has been adjusted, including the additional bit of changing ext2_* into foo_* in the documentation. [akpm@osdl.org: convert ipath_fs, do other stuff] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread: slab cache formatPaul Jackson
Rewrap the overly long source code lines resulting from the previous patch's addition of the slab cache flag SLAB_MEM_SPREAD. This patch contains only formatting changes, and no function change. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread: slab cache filesystemsPaul Jackson
Mark file system inode and similar slab caches subject to SLAB_MEM_SPREAD memory spreading. If a slab cache is marked SLAB_MEM_SPREAD, then anytime that a task that's in a cpuset with the 'memory_spread_slab' option enabled goes to allocate from such a slab cache, the allocations are spread evenly over all the memory nodes (task->mems_allowed) allowed to that task, instead of favoring allocation on the node local to the current cpu. The following inode and similar caches are marked SLAB_MEM_SPREAD: file cache ==== ===== fs/adfs/super.c adfs_inode_cache fs/affs/super.c affs_inode_cache fs/befs/linuxvfs.c befs_inode_cache fs/bfs/inode.c bfs_inode_cache fs/block_dev.c bdev_cache fs/cifs/cifsfs.c cifs_inode_cache fs/coda/inode.c coda_inode_cache fs/dquot.c dquot fs/efs/super.c efs_inode_cache fs/ext2/super.c ext2_inode_cache fs/ext2/xattr.c (fs/mbcache.c) ext2_xattr fs/ext3/super.c ext3_inode_cache fs/ext3/xattr.c (fs/mbcache.c) ext3_xattr fs/fat/cache.c fat_cache fs/fat/inode.c fat_inode_cache fs/freevxfs/vxfs_super.c vxfs_inode fs/hpfs/super.c hpfs_inode_cache fs/isofs/inode.c isofs_inode_cache fs/jffs/inode-v23.c jffs_fm fs/jffs2/super.c jffs2_i fs/jfs/super.c jfs_ip fs/minix/inode.c minix_inode_cache fs/ncpfs/inode.c ncp_inode_cache fs/nfs/direct.c nfs_direct_cache fs/nfs/inode.c nfs_inode_cache fs/ntfs/super.c ntfs_big_inode_cache_name fs/ntfs/super.c ntfs_inode_cache fs/ocfs2/dlm/dlmfs.c dlmfs_inode_cache fs/ocfs2/super.c ocfs2_inode_cache fs/proc/inode.c proc_inode_cache fs/qnx4/inode.c qnx4_inode_cache fs/reiserfs/super.c reiser_inode_cache fs/romfs/inode.c romfs_inode_cache fs/smbfs/inode.c smb_inode_cache fs/sysv/inode.c sysv_inode_cache fs/udf/super.c udf_inode_cache fs/ufs/super.c ufs_inode_cache net/socket.c sock_inode_cache net/sunrpc/rpc_pipe.c rpc_inode_cache The choice of which slab caches to so mark was quite simple. I marked those already marked SLAB_RECLAIM_ACCOUNT, except for fs/xfs, dentry_cache, inode_cache, and buffer_head, which were marked in a previous patch. Even though SLAB_RECLAIM_ACCOUNT is for a different purpose, it marks the same potentially large file system i/o related slab caches as we need for memory spreading. Given that the rule now becomes "wherever you would have used a SLAB_RECLAIM_ACCOUNT slab cache flag before (usually the inode cache), use the SLAB_MEM_SPREAD flag too", this should be easy enough to maintain. Future file system writers will just copy one of the existing file system slab cache setups and tend to get it right without thinking. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] sem2mutex: HPFSIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] kfree cleanup: fsJesper Juhl
This is the fs/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in fs/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
