path: root/fs/ioctl.c
2009-06-24fs: Add new pre-allocation ioctls to vfs for compatibility with legacy xfs ↵Ankit Jain
ioctls This patch adds ioctls to vfs for compatibility with legacy XFS pre-allocation ioctls (XFS_IOC_*RESVP*). The implementation effectively invokes sys_fallocate for the new ioctls. Also handles the compat_ioctl case. Note: These legacy ioctls are also implemented by OCFS2. [AV: folded fixes from hch] Signed-off-by: Ankit Jain <me@ankitjain.org> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-17No instance of ->bmap() needs BKLAl Viro
2009-05-13vfs: Enable FS_IOC_FIEMAP and FIGETBSZ for all filetypesAneesh Kumar K.V
The fiemap and get_blk_size ioctls should be enabled even for directories. So move it outisde file_ioctl. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-05-06fiemap: fix problem with setting FIEMAP_EXTENT_LASTJosef Bacik
Fix a problem where the generic block based fiemap stuff would not properly set FIEMAP_EXTENT_LAST on the last extent. I've reworked things to keep track if we go past the EOF, and mark the last extent properly. The problem was reported by and tested by Eric Sandeen. Tested-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Josef Bacik <jbacik@redhat.com> Cc: <linux-ext4@vger.kernel.org> Cc: <xfs-masters@oss.sgi.com> Cc: <linux-btrfs@vger.kernel.org> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <Joel.Becker@oracle.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-16Rationalize fasync return valuesJonathan Corbet
Most fasync implementations do something like: return fasync_helper(...); But fasync_helper() will return a positive value at times - a feature used in at least one place. Thus, a number of other drivers do: err = fasync_helper(...); if (err < 0) return err; return 0; In the interests of consistency and more concise code, it makes sense to map positive return values onto zero where ->fasync() is called. Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2009-03-16Move FASYNC bit handling to f_op->fasync()Jonathan Corbet
Removing the BKL from FASYNC handling ran into the challenge of keeping the setting of the FASYNC bit in filp->f_flags atomic with regard to calls to the underlying fasync() function. Andi Kleen suggested moving the handling of that bit into fasync(); this patch does exactly that. As a result, we have a couple of internal API changes: fasync() must now manage the FASYNC bit, and it will be called without the BKL held. As it happens, every fasync() implementation in the kernel with one exception calls fasync_helper(). So, if we make fasync_helper() set the FASYNC bit, we can avoid making any changes to the other fasync() functions - as long as those functions, themselves, have proper locking. Most fasync() implementations do nothing but call fasync_helper() - which has its own lock - so they are easily verified as correct. The BKL had already been pushed down into the rest. The networking code has its own version of fasync_helper(), so that code has been augmented with explicit FASYNC bit handling. Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: David Miller <davem@davemloft.net> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2009-03-16Use f_lock to protect f_flagsJonathan Corbet
Traditionally, changes to struct file->f_flags have been done under BKL protection, or with no protection at all. This patch causes all f_flags changes after file open/creation time to be done under protection of f_lock. This allows the removal of some BKL usage and fixes a number of longstanding (if microscopic) races. Reviewed-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2009-01-14[CVE-2009-0029] System call wrappers part 15Heiko Carstens
2009-01-09filesystem freeze: implement generic freeze featureTakashi Sato
The ioctls for the generic freeze feature are below. o Freeze the filesystem int ioctl(int fd, int FIFREEZE, arg) fd: The file descriptor of the mountpoint FIFREEZE: request code for the freeze arg: Ignored Return value: 0 if the operation succeeds. Otherwise, -1 o Unfreeze the filesystem int ioctl(int fd, int FITHAW, arg) fd: The file descriptor of the mountpoint FITHAW: request code for unfreeze arg: Ignored Return value: 0 if the operation succeeds. Otherwise, -1 Error number: If the filesystem has already been unfrozen, errno is set to EINVAL. [akpm@linux-foundation.org: fix CONFIG_BLOCK=n] Signed-off-by: Takashi Sato <t-sato@yk.jp.nec.com> Signed-off-by: Masayuki Hamaguchi <m-hamaguchi@ys.jp.nec.com> Cc: <xfs-masters@oss.sgi.com> Cc: <linux-ext4@vger.kernel.org> Cc: Christoph Hellwig <hch@lst.de> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Alasdair G Kergon <agk@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-05GFS2: Support for FIEMAP ioctlSteven Whitehouse
This patch implements the FIEMAP ioctl for GFS2. We can use the generic code (aside from a lock order issue, solved as per Ted Tso's suggestion) for which I've introduced a new variant of the generic function. We also have one exception to deal with, namely stuffed files, so we do that "by hand", setting all the required flags. This has been tested with a modified (I could only find an old version) of Eric's test program, and appears to work correctly. This patch does not currently support FIEMAP of xattrs, but the plan is to add that feature at some future point. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Theodore Tso <tytso@mit.edu> Cc: Eric Sandeen <sandeen@redhat.com>
2008-12-05Fix a race condition in FASYNC handlingJonathan Corbet
Changeset a238b790d5f99c7832f9b73ac8847025815b85f7 (Call fasync() functions without the BKL) introduced a race which could leave file->f_flags in a state inconsistent with what the underlying driver/filesystem believes. Revert that change, and also fix the same races in ioctl_fioasync() and ioctl_fionbio(). This is a minimal, short-term fix; the real fix will not involve the BKL. Reported-by: Oleg Nesterov <oleg@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: stable@kernel.org Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-12provide generic_block_fiemap() only with BLOCK=yAdrian Bunk
This fixes the following compile error with CONFIG_BLOCK=n caused by commit 68c9d702bb72f367f3b148963ec6cf5e07ff7f65 ("generic block based fiemap implementation"): CC fs/ioctl.o fs/ioctl.c: In function 'generic_block_fiemap': fs/ioctl.c:249: error: storage size of 'tmp' isn't known fs/ioctl.c:272: error: invalid application of 'sizeof' to incomplete type 'struct buffer_head' fs/ioctl.c:280: error: implicit declaration of function 'buffer_mapped' fs/ioctl.c:249: warning: unused variable 'tmp' make[2]: *** [fs/ioctl.o] Error 1 Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Josef Bacik <jbacik@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-03generic block based fiemap implementationJosef Bacik
Any block based fs (this patch includes ext3) just has to declare its own fiemap() function and then call this generic function with its own get_block_t. This works well for block based filesystems that will map multiple contiguous blocks at one time, but will work for filesystems that only map one block at a time, you will just end up with an "extent" for each block. One gotcha is this will not play nicely where there is hole+data after the EOF. This function will assume its hit the end of the data as soon as it hits a hole after the EOF, so if there is any data past that it will not pick that up. AFAIK no block based fs does this anyway, but its in the comments of the function anyway just in case. Signed-off-by: Josef Bacik <jbacik@redhat.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: linux-fsdevel@vger.kernel.org
2008-10-08vfs: vfs-level fiemap interfaceMark Fasheh
Basic vfs-level fiemap infrastructure, which sets up a new ->fiemap inode operation. Userspace can get extent information on a file via fiemap ioctl. As input, the fiemap ioctl takes a struct fiemap which includes an array of struct fiemap_extent (fm_extents). Size of the extent array is passed as fm_extent_count and number of extents returned will be written into fm_mapped_extents. Offset and length fields on the fiemap structure (fm_start, fm_length) describe a logical range which will be searched for extents. All extents returned will at least partially contain this range. The actual extent offsets and ranges returned will be unmodified from their offset and range on-disk. The fiemap ioctl returns '0' on success. On error, -1 is returned and errno is set. If errno is equal to EBADR, then fm_flags will contain those flags which were passed in which the kernel did not understand. On all other errors, the contents of fm_extents is undefined. As fiemap evolved, there have been many authors of the vfs patch. As far as I can tell, the list includes: Kalpak Shah <kalpak.shah@sun.com> Andreas Dilger <adilger@sun.com> Eric Sandeen <sandeen@redhat.com> Mark Fasheh <mfasheh@suse.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: linux-api@vger.kernel.org Cc: linux-fsdevel@vger.kernel.org
2008-04-29make vfs_ioctl() staticAdrian Bunk
Make the needlessly global vfs_ioctl() static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-09fix up kerneldoc in fs/ioctl.c a little bitChristoph Hellwig
- remove non-standard in/out markers - use tabs for formatting Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Cc: Erez Zadok <ezk@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07VFS: factor out three helpers for FIBMAP/FIONBIO/FIOASYNC file ioctlsErez Zadok
Factor out file-specific ioctl code into smaller helper functions, away from file_ioctl(). This helps code readability and also reduces indentation inside case statements. Signed-off-by: Erez Zadok <ezk@cs.sunysb.edu> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07VFS: swap do_ioctl and vfs_ioctl namesErez Zadok
Rename old vfs_ioctl to do_ioctl, because the comment above it clearly indicates that it is an internal function not to be exported to modules; therefore it should have a more traditional do_XXX name. The new do_ioctl is exported in fs.h but not to modules. Rename the old do_ioctl to vfs_ioctl because the names vfs_XXX should preferably be reserved to callable VFS functions which modules may call, as many other vfs_XXX functions already do. Export the new vfs_ioctl to GPL modules so others can use it (including Unionfs and eCryptfs). Add DocBook for new vfs_ioctl. [akpm@linux-foundation.org: fix build] Signed-off-by: Erez Zadok <ezk@cs.sunysb.edu> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07VFS: apply coding standards to fs/ioctl.cErez Zadok
2007-07-16drop obsolete sys_ioctl exportChristoph Hellwig
sys_ioctl() was only exported for our first version of compat ioctl handling. Now that the whole compat ioctl handling mess is more or less sorted out there are no more modular users left and we can kill it. There's one exception and that's sparc64's solaris compat module, but sparc64 has it's own export predating the generic one by years for that which this patch leaves untouched. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16revert "vanishing ioctl handler debugging"Andrew Morton
Revert my do_ioctl() debugging patch: Paul fixed the bug. Cc: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-04vanishing ioctl handler debuggingAndrew Morton
We've had several reoprts of the CPU jumping to 0x00000000 is do_ioctl(). I assume that there's a race and someone is zeroing out the ioctl handler while this CPU waits for the lock_kernel(). The patch adds code to detect this, then emits stuff which will hopefuly lead us to the culprit. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08vfs: remove superflous sb == NULL checksChristoph Hellwig
inode->i_sb is always set, not need to check for it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] VFS: change struct file to use struct pathJosef "Jeff" Sipek
This patch changes struct file to use struct path instead of having independent pointers to struct dentry and struct vfsmount, and converts all users of f_{dentry,vfsmnt} in fs/ to use f_path.{dentry,mnt}. Additionally, it adds two #define's to make the transition easier for users of the f_dentry and f_vfsmnt. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] capable/capability.h (fs/)Randy Dunlap
fs: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
