path: root/fs/iomap.c
2017-09-20iomap: fix integer truncation issues in the zeroing and dirtying helpersChristoph Hellwig
commit e28ae8e428fefe2facd72cea9f29906ecb9c861d upstream. Fix the min_t calls in the zeroing and dirtying helpers to perform the comparisms on 64-bit types, which prevents them from incorrectly being truncated, and larger zeroing operations being stuck in a never ending loop. Special thanks to Markus Stockhausen for spotting the bug. Reported-by: Paul Menzel <pmenzel@molgen.mpg.de> Tested-by: Paul Menzel <pmenzel@molgen.mpg.de> Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Darrick J. Wong <darrick.wong@oracle.com> Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-14fs: add i_blocksize()Fabian Frederick
commit 93407472a21b82f39c955ea7787e5bc7da100642 upstream. Replace all 1 << inode->i_blkbits and (1 << inode->i_blkbits) in fs branch. This patch also fixes multiple checkpatch warnings: WARNING: Prefer 'unsigned int' to bare use of 'unsigned' Thanks to Andrew Morton for suggesting more appropriate function instead of macro. [geliangtang@gmail.com: truncate: use i_blocksize()] Link: http://lkml.kernel.org/r/9c8b2cd83c8f5653805d43debde9fa8817e02fc4.1484895804.git.geliangtang@gmail.com Link: http://lkml.kernel.org/r/1481319905-10126-1-git-send-email-fabf@skynet.be Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Geliang Tang <geliangtang@gmail.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09fs: break out of iomap_file_buffered_write on fatal signalsMichal Hocko
commit d1908f52557b3230fbd63c0429f3b4b748bf2b6d upstream. Tetsuo has noticed that an OOM stress test which performs large write requests can cause the full memory reserves depletion. He has tracked this down to the following path __alloc_pages_nodemask+0x436/0x4d0 alloc_pages_current+0x97/0x1b0 __page_cache_alloc+0x15d/0x1a0 mm/filemap.c:728 pagecache_get_page+0x5a/0x2b0 mm/filemap.c:1331 grab_cache_page_write_begin+0x23/0x40 mm/filemap.c:2773 iomap_write_begin+0x50/0xd0 fs/iomap.c:118 iomap_write_actor+0xb5/0x1a0 fs/iomap.c:190 ? iomap_write_end+0x80/0x80 fs/iomap.c:150 iomap_apply+0xb3/0x130 fs/iomap.c:79 iomap_file_buffered_write+0x68/0xa0 fs/iomap.c:243 ? iomap_write_end+0x80/0x80 xfs_file_buffered_aio_write+0x132/0x390 [xfs] ? remove_wait_queue+0x59/0x60 xfs_file_write_iter+0x90/0x130 [xfs] __vfs_write+0xe5/0x140 vfs_write+0xc7/0x1f0 ? syscall_trace_enter+0x1d0/0x380 SyS_write+0x58/0xc0 do_syscall_64+0x6c/0x200 entry_SYSCALL64_slow_path+0x25/0x25 the oom victim has access to all memory reserves to make a forward progress to exit easier. But iomap_file_buffered_write and other callers of iomap_apply loop to complete the full request. We need to check for fatal signals and back off with a short write instead. As the iomap_apply delegates all the work down to the actor we have to hook into those. All callers that work with the page cache are calling iomap_write_begin so we will check for signals there. dax_iomap_actor has to handle the situation explicitly because it copies data to the userspace directly. Other callers like iomap_page_mkwrite work on a single page or iomap_fiemap_actor do not allocate memory based on the given len. Fixes: 68a9f5e7007c ("xfs: implement iomap based buffered write path") Link: http://lkml.kernel.org/r/20170201092706.9966-2-mhocko@kernel.org Signed-off-by: Michal Hocko <mhocko@suse.com> Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Reviewed-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-24fs: Do to trim high file position bits in iomap_page_mkwrite_actorJan Kara
iomap_page_mkwrite_actor() calls __block_write_begin_int() with position masked as pos & ~PAGE_MASK which is equivalent to pos & (PAGE_SIZE-1). Thus it masks off high bits of file position. However __block_write_begin_int() expects full file position on input. This does not cause any visible issues because all __block_write_begin_int() really cares about are low file position bits but still it is a bug waiting to happen. Signed-off-by: Jan Kara <jack@suse.cz> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Chinner <david@fromorbit.com>
2016-10-20iomap: add IOMAP_REPORTChristoph Hellwig
This allows the file system to tell a FIEMAP from a read operation, and thus avoids the need to report flags that aren't actually used in the read path. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Darrick J. Wong <darrick.wong@oracle.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2016-10-03Merge branch 'iomap-4.9-dax' into for-nextDave Chinner
2016-09-19iomap: expose iomap_apply outside iomap.cChristoph Hellwig
This allows the DAX code to use it. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2016-09-19iomap: add a flag to report shared extentsDarrick J. Wong
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Chinner <david@fromorbit.com>
2016-09-19fs: add iomap_file_dirtyChristoph Hellwig
Originally-From: Christoph Hellwig <hch@lst.de> This function uses the iomap infrastructure to re-write all pages in a given range. This is useful for doing a copy-up of COW ranges, and might be useful for scrubbing in the future. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2016-08-29iomap: don't set FIEMAP_EXTENT_MERGED for extent based filesystemsChristoph Hellwig
Filesystems like XFS that use extents should not set the FIEMAP_EXTENT_MERGED flag in the fiemap extent structures. To allow for both behaviors for the upcoming gfs2 usage split the iomap type field into type and flags, and only set FIEMAP_EXTENT_MERGED if the IOMAP_F_MERGED flag is set. The flags field will also come in handy for future features such as shared extents on reflink-enabled file systems. Reported-by: Andreas Gruenbacher <agruenba@redhat.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Darrick J. Wong <darrick.wong@oracle.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2016-08-17iomap: mark ->iomap_end as optionalChristoph Hellwig
No need to implement it for read-only mappings. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2016-08-17iomap: prepare iomap_fiemap for attribute mappingsDave Chinner
By bassing through an -ENOENT, similar to the old XFS implementation of FIEMAP_FLAG_XATTR. Signed-off-by: Dave Chinner <dchinner@redhat.com> [hch: split from a larger patch] Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2016-08-17iomap: fiemap should honor the FIEMAP_FLAG_SYNC flagDave Chinner
The flag is checked as supported, but then we do an unconditional sync of the file, regardless of whether the flag is set or not. Make the sync conditional on having the FIEMAP_FLAG_SYNC flag set. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Chinner <david@fromorbit.com>
2016-08-17iomap: remove superflous pagefault_disable from iomap_write_actorChristoph Hellwig
iov_iter_copy_from_user_atomic disables page faults internally, no need to do it around the call. This also brings the iomap code in line with the original filemap version. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2016-08-17iomap: remove superflous mark_page_accessed from iomap_write_actorChristoph Hellwig
This catches up with commit 2457ae ("mm: non-atomically mark page accessed during page cache allocation where possible"), which moved the initial access marking into the pagecache allocator. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2016-06-21fs: iomap based fiemap implementationChristoph Hellwig
Add a simple fiemap implementation based on iomap_ops, partially based on a previous implementation from Bob Peterson <rpeterso@redhat.com>. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2016-06-21fs: support DAX based iomap zeroingChristoph Hellwig
This avoid needing a separate inefficient get_block based DAX zero_range implementation in file systems. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2016-06-21fs: introduce iomap infrastructureChristoph Hellwig
Add infrastructure for multipage buffered writes. This is implemented using an main iterator that applies an actor function to a range that can be written. This infrastucture is used to implement a buffered write helper, one to zero file ranges and one to implement the ->page_mkwrite VM operations. All of them borrow a fair amount of code from fs/buffers. for now by using an internal version of __block_write_begin that gets passed an iomap and builds the corresponding buffer head. The file system is gets a set of paired ->iomap_begin and ->iomap_end calls which allow it to map/reserve a range and get a notification once the write code is finished with it. Based on earlier code from Dave Chinner. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
