commit e531d0bceb402e643a4499de40dd3fa39d8d2e43 upstream.
The journal revoke block recovery code does not check r_count for
sanity, which means that an evil value of r_count could result in
the kernel reading off the end of the revoke table and into whatever
garbage lies beyond. This could crash the kernel, so fix that.
However, in testing this fix, I discovered that the code to write
out the revoke tables also was not correctly checking to see if the
block was full -- the current offset check is fine so long as the
revoke table space size is a multiple of the record size, but this
is not true when either journal_csum_v[23] are set.
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
The old hash function didn't work well for 64-bit block numbers, and
used undefined (negative) shift right behavior. Use the generic
64-bit hash function instead.
Reported-by: Andrey Ryabinin <a.ryabinin@samsung.com>
It turns out that there are some serious problems with the on-disk
format of journal checksum v2. The foremost is that the function to
calculate descriptor tag size returns sizes that are too big. This
causes alignment issues on some architectures and is compounded by the
fact that some parts of jbd2 use the structure size (incorrectly) to
determine the presence of a 64bit journal instead of checking the
feature flags.
Therefore, introduce journal checksum v3, which enlarges the
descriptor block tag format to allow for full 32-bit checksums of
journal blocks, fix the journal tag function to return the correct
sizes, and fix the jbd2 recovery code to use feature flags to
determine 64bitness.
Add a few function helpers so we don't have to open-code quite so
many pieces.
Switching to a 16-byte block size was found to increase journal size
overhead by a maximum of 0.1%, to convert a 32-bit journal with no
checksumming to a 32-bit journal with checksum v3 enabled.
Reported-by: TR Reardon <thomas_reardon@hotmail.com>
Cc: stable@vger.kernel.org
Similarly as for metadata buffers, also log descriptor buffers don't
really need the journal head. So strip it and remove BJ_LogCtl list.
Reviewed-by: Zheng Liu <wenqing.lz@taobao.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Compute and verify revoke blocks inside the journal.
Signed-off-by: Darrick J. Wong <djwong@us.ibm.com>
Use the KMEM_CACHE helper macro instead of kmem_cache_create().
Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com>
Currently, we clear revoked flag only when a block is reused. However,
this can tigger a false journal error. Consider a situation when a block
is used as a meta block and is deleted(revoked) in ordered mode, then the
block is allocated as a data block to a file. At this moment, user changes
the file's journal mode from ordered to journaled and truncates the file.
The block will be considered re-revoked by journal because it has revoked
flag still pending from the last transaction and an assertion triggers.
We fix the problem by keeping the revoked status more uptodate - we clear
revoked flag when switching revoke tables to reflect there is no revoked
buffers in current transaction any more.
These flags aren't real I/O types, but tell ll_rw_block to always
lock the buffer instead of giving up on a failed trylock.
Instead add a new write_dirty_buffer helper that implements this semantic
and use it from the existing SWRITE* callers. Note that the ll_rw_block
code had a bug where it didn't promote WRITE_SYNC_PLUG properly, which
this patch fixes.
In the ufs code clean up the helper that used to call ll_rw_block
to mirror sync_dirty_buffer, which is the function it implements for
compound buffers.
The revoke records must be written using the same way as the rest of
the blocks during the commit process; that is, either marked as
synchronous writes or as asynchornous writes.
Update information about locking in JBD2 revoke code. Inconsistency in
comments found by Lin Tan <tammy000@gmail.com>.
CC: Lin Tan <tammy000@gmail.com>.
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Cc: <linux-ext4@vger.kernel.org>
The revocation table initialisation/destruction code is repeated for each of
the two revocation tables stored in the journal. Refactoring the duplicated
code into functions is tidier, simplifies the logic in initialisation in
particular, and slightly reduces the code size.
There should not be any functional change.
Signed-off-by: Duane Griffin <duaneg@dghda.com>
Signed-off-by: Mingming Cao <cmm@us.ibm.com>
Make revocation cache destruction safe to call if initialisation fails
partially or entirely. This allows it to be used to cleanup in the case of
initialisation failure, simplifying the code slightly.
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
This patch marks slab allocations by jbd2 as short-lived in support of
Mel Gorman's "Group short-lived and reclaimable kernel allocations"
patch. (Ported from similar changes made to fs/jbd/journal.c and
fs/jbd/revoke.c in Mel's patch.)
change JBD_XXX macros to JBD2_XXX in JBD2/Ext4
Slab destructors were no longer supported after Christoph's
c59def9f222d44bb7e2f0a559f2906191a0862d7 change. They've been
BUGs for both slab and slub, and slob never supported them
either.
This rips out support for the dtor pointer from kmem_cache_create()
completely and fixes up every single callsite in the kernel (there were
about 224, not including the slab allocator definitions themselves,
or the documentation references).
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Replace (n & (n-1)) in the context of power of 2 checks with
is_power_of_2().
Signed-off-by: vignesh babu <vignesh.babu@wipro.com>
Many files include the filename at the beginning, serveral used a wrong one.
Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de>
Remove includes of <linux/smp_lock.h> where it is not used/needed.
Suggested by Al Viro.
Builds cleanly on x86_64, i386, alpha, ia64, powerpc, sparc,
sparc64, and arm (all 59 defconfigs).
Replace all uses of kmem_cache_t with struct kmem_cache.
The patch was generated using the following script:
#!/bin/sh
# Replace one string by another in all the kernel sources.
set -e
for file in `find * -name "*.c" -o -name "*.h"|xargs grep -l $1`; do
quilt add $file
sed -e "1,\$s/$1/$2/g" $file >/tmp/$$
mv /tmp/$$ $file
quilt refresh
done
The script was run like this
sh replace kmem_cache_t "struct kmem_cache"
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Similar to ext4, change blocks in JBD2 from sector_t to unsigned long long.
Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
JBD layer in-kernel block varibles type fixes to support >32 bit block number
and convert to sector_t type.
Here is the patch to JBD to handle 64 bit block numbers, originally from Zach
Brown. This patch is useful only after adding support for 64-bit block
numbers in the filesystem.
Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com>
Signed-off-by: Zach Brown <zach.brown@oracle.com>
jbd and jbd2 currently use the same slab names which must be unique. The
patch below just renames jbd2's slabs.
Signed-off-by: Johann Lombardi <johann.lombardi@bull.net>
Mingming Cao originally did this work, and Shaggy reproduced it using some
scripts from her.
This is a simple copy of the files in fs/jbd to fs/jbd2 and
/usr/incude/linux/[ext4_]jbd.h to /usr/include/[ext4_]jbd2.h
