path: root/fs/jbd
2013-12-04jbd: Revise KERN_EMERG error messagesJan Kara
Some of KERN_EMERG printk messages do not really deserve this log level and the one in log_wait_commit() is even rather useless (the journal has been previously aborted and *that* is where we should have been complaining). So make some messages just KERN_ERR and remove the useless message. Signed-off-by: Jan Kara <jack@suse.cz>
2013-10-31jbd: Revert "jbd: remove dependency on __GFP_NOFAIL"Jan Kara
This reverts commit 05713082ab7690a2b22b044cfc867f346c39cd2d. The idea to remove __GFP_NOFAIL was opposed by Andrew Morton. Although mm guys do want to get rid of __GFP_NOFAIL users, opencoding the allocation retry is even worse. See emails following http://www.gossamer-threads.com/lists/linux/kernel/1809153#1809153 Signed-off-by: Jan Kara <jack@suse.cz>
2013-08-09jbd: use a single printk for jbd_debug()Paul Gortmaker
Backport of jbd2 commit 169f1a2a87aae44034da4b9f81be1683d33de6d0 ("jbd2: use a single printk for jbd_debug()") Since the jbd_debug() is implemented with two separate printk() calls, it can lead to corrupted and misleading debug output like the following (see lines marked with "*"): [ 290.339362] (fs/jbd2/journal.c, 203): kjournald2: kjournald2 wakes [ 290.339365] (fs/jbd2/journal.c, 155): kjournald2: commit_sequence=42103, commit_request=42104 [ 290.339369] (fs/jbd2/journal.c, 158): kjournald2: OK, requests differ [* 290.339376] (fs/jbd2/journal.c, 648): jbd2_log_wait_commit: [* 290.339379] (fs/jbd2/commit.c, 370): jbd2_journal_commit_transaction: JBD2: want 42104, j_commit_sequence=42103 [* 290.339382] JBD2: starting commit of transaction 42104 [ 290.339410] (fs/jbd2/revoke.c, 566): jbd2_journal_write_revoke_records: Wrote 0 revoke records [ 290.376555] (fs/jbd2/commit.c, 1088): jbd2_journal_commit_transaction: JBD2: commit 42104 complete, head 42079 i.e. the debug output from log_wait_commit and journal_commit_transaction have become interleaved. The output should have been: (fs/jbd2/journal.c, 648): jbd2_log_wait_commit: JBD2: want 42104, j_commit_sequence=42103 (fs/jbd2/commit.c, 370): jbd2_journal_commit_transaction: JBD2: starting commit of transaction 42104 It is expected that this is not easy to replicate -- I was only able to cause it on preempt-rt kernels, and even then only under heavy I/O load. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Jan Kara <jack@suse.cz>
2013-08-01jbd: relocate assert after state lock in journal_commit_transaction()Paul Gortmaker
The state lock is taken after we are doing an assert on the state value, not before. So we might in fact be doing an assert on a transient value. Ensure the state check is within the scope of the state lock being taken. Backport of jbd2 commit 3ca841c106fd6cd2c942985977a5d126434a8dd6 ("jbd2: relocate assert after state lock in journal_commit_transaction()") Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Jan Kara <jack@suse.cz>
2013-05-21jbd: change journal_invalidatepage() to accept lengthLukas Czerner
->invalidatepage() aop now accepts range to invalidate so we can make use of it in journal_invalidatepage() and all the users in ext3 file system. Also update ext3 trace point to print out length argument. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Reviewed-by: Jan Kara <jack@suse.cz>
2013-05-03Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs Pull ext3/jbd fixes from Jan Kara: "A couple of ext3/jbd fixes" * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: jbd: use kmem_cache_zalloc for allocating journal head jbd: use kmem_cache_zalloc instead of kmem_cache_alloc/memset jbd: don't wait (forever) for stale tid caused by wraparound ext3: fix data=journal fast mount/umount hang
2013-04-29fs/buffer.c: remove unnecessary init operation after allocating buffer_head.majianpeng
bh allocation uses kmem_cache_zalloc() so we needn't call 'init_buffer(bh, NULL, NULL)' and perform other set-zero-operations. Signed-off-by: Jianpeng Ma <majianpeng@gmail.com> Cc: Jan Kara <jack@suse.cz> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29mm: make snapshotting pages for stable writes a per-bio operationDarrick J. Wong
Walking a bio's page mappings has proved problematic, so create a new bio flag to indicate that a bio's data needs to be snapshotted in order to guarantee stable pages during writeback. Next, for the one user (ext3/jbd) of snapshotting, hook all the places where writes can be initiated without PG_writeback set, and set BIO_SNAP_STABLE there. We must also flag journal "metadata" bios for stable writeout, since file data can be written through the journal. Finally, the MS_SNAP_STABLE mount flag (only used by ext3) is now superfluous, so get rid of it. [akpm@linux-foundation.org: rename _submit_bh()'s `flags' to `bio_flags', delobotomize the _submit_bh declaration] [akpm@linux-foundation.org: teeny cleanup] Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Artem Bityutskiy <dedekind1@gmail.com> Reviewed-by: Jan Kara <jack@suse.cz> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29jbd: use kmem_cache_zalloc for allocating journal headZheng Liu
This commit tries to use kmem_cache_zalloc instead of kmem_cache_alloc/ memset when a new journal head is alloctated. Signed-off-by: Zheng Liu <wenqing.lz@taobao.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Jan Kara <jack@suse.cz>
2013-04-25jbd: use kmem_cache_zalloc instead of kmem_cache_alloc/memsetZheng Liu
Now jbd_alloc_handle is only called by new_handle. So this commit uses kmem_cache_zalloc instead of kmem_cache_alloc/memset. Signed-off-by: Zheng Liu <wenqing.lz@taobao.com> Signed-off-by: Jan Kara <jack@suse.cz>
2013-03-27jbd: don't wait (forever) for stale tid caused by wraparoundJan Kara
In the case where an inode has a very stale transaction id (tid) in i_datasync_tid or i_sync_tid, it's possible that after a very large (2**31) number of transactions, that the tid number space might wrap, causing tid_geq()'s calculations to fail. Commit d9b0193 "jbd: fix fsync() tid wraparound bug" attempted to fix this problem, but it only avoided kjournald spinning forever by fixing the logic in jbd_log_start_commit(). Signed-off-by: Jan Kara <jack@suse.cz>
2013-01-14jbd: don't wake kjournald unnecessarilyEric Sandeen
Don't send an extra wakeup to kjournald in the case where we already have the proper target in j_commit_request, i.e. that commit has already been requested for commit. commit d9b0193 "jbd: fix fsync() tid wraparound bug" changed the logic leading to a wakeup, but it caused some extra wakeups which were found to lead to a measurable performance regression. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz>
2012-12-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial branch from Jiri Kosina: "Usual stuff -- comment/printk typo fixes, documentation updates, dead code elimination." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) HOWTO: fix double words typo x86 mtrr: fix comment typo in mtrr_bp_init propagate name change to comments in kernel source doc: Update the name of profiling based on sysfs treewide: Fix typos in various drivers treewide: Fix typos in various Kconfig wireless: mwifiex: Fix typo in wireless/mwifiex driver messages: i2o: Fix typo in messages/i2o scripts/kernel-doc: check that non-void fcts describe their return value Kernel-doc: Convention: Use a "Return" section to describe return values radeon: Fix typo and copy/paste error in comments doc: Remove unnecessary declarations from Documentation/accounting/getdelays.c various: Fix spelling of "asynchronous" in comments. Fix misspellings of "whether" in comments. eisa: Fix spelling of "asynchronous". various: Fix spelling of "registered" in comments. doc: fix quite a few typos within Documentation target: iscsi: fix comment typos in target/iscsi drivers treewide: fix typo of "suport" in various comments and Kconfig treewide: fix typo of "suppport" in various comments ...
2012-11-23jbd: Fix lock ordering bug in journal_unmap_buffer()Jan Kara
Commit 09e05d48 introduced a wait for transaction commit into journal_unmap_buffer() in the case we are truncating a buffer undergoing commit in the page stradding i_size on a filesystem with blocksize < pagesize. Sadly we forgot to drop buffer lock before waiting for transaction commit and thus deadlock is possible when kjournald wants to lock the buffer. Fix the problem by dropping the buffer lock before waiting for transaction commit. Since we are still holding page lock (and that is OK), buffer cannot disappear under us. CC: stable@vger.kernel.org # Wherever commit 09e05d48 was taken Signed-off-by: Jan Kara <jack@suse.cz>
2012-11-19Fix misspellings of "whether" in comments.Adam Buchbinder
"Whether" is misspelled in various comments across the tree; this fixes them. No code changes. Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-09-12jbd: Fix assertion failure in commit code due to lacking transaction creditsJan Kara
ext3 users of data=journal mode with blocksize < pagesize were occasionally hitting assertion failure in journal_commit_transaction() checking whether the transaction has at least as many credits reserved as buffers attached. The core of the problem is that when a file gets truncated, buffers that still need checkpointing or that are attached to the committing transaction are left with buffer_mapped set. When this happens to buffers beyond i_size attached to a page stradding i_size, subsequent write extending the file will see these buffers and as they are mapped (but underlying blocks were freed) things go awry from here. The assertion failure just coincidentally (and in this case luckily as we would start corrupting filesystem) triggers due to journal_head not being properly cleaned up as well. Under some rare circumstances this bug could even hit data=ordered mode users. There the assertion won't trigger and we would end up corrupting the filesystem. We fix the problem by unmapping buffers if possible (in lots of cases we just need a buffer attached to a transaction as a place holder but it must not be written out anyway). And in one case, we just have to bite the bullet and wait for transaction commit to finish. Reviewed-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Jan Kara <jack@suse.cz>
2012-08-15jbd: don't write superblock when unmounting an ro filesystemJan Kara
This sequence: results in an IO error when unmounting the RO filesystem. The bug was introduced by: commit 9754e39c7bc51328f145e933bfb0df47cd67b6e9 Author: Jan Kara <jack@suse.cz> Date: Sat Apr 7 12:33:03 2012 +0200 jbd: Split updating of journal superblock and marking journal empty which lost some of the magic in journal_update_superblock() which used to test for a journal with no outstanding transactions. This is a port of a jbd2 fix by Eric Sandeen. CC: <stable@vger.kernel.org> # 3.4.x Signed-off-by: Jan Kara <jack@suse.cz>
2012-08-04jbd/jbd2: nuke write_super from commentsArtem Bityutskiy
The '->write_super' superblock method is gone, and this patch removes all the references to 'write_super' from various jbd and jbd2. Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jan Kara <jack@suse.cz> Cc: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-09jbd: Check return value of blkdev_issue_flush()Jan Kara
blkdev_issue_flush() can fail. Make sure the error gets properly propagated. Signed-off-by: Jan Kara <jack@suse.cz>
2012-05-15jbd: Write journal superblock with WRITE_FUA after checkpointingJan Kara
If journal superblock is written only in disk's caches and other transaction starts reusing space of the transaction cleaned from the log, it can happen blocks of a new transaction reach the disk before journal superblock. When power failure happens in such case, subsequent journal replay would still try to replay the old transaction but some of it's blocks may be already overwritten by the new transaction. For this reason we must use WRITE_FUA when updating log tail and we must first write new log tail to disk and update in-memory information only after that. Signed-off-by: Jan Kara <jack@suse.cz>
2012-05-15jbd: protect all log tail updates with j_checkpoint_mutexJan Kara
There are some log tail updates that are not protected by j_checkpoint_mutex. Some of these are harmless because they happen during startup or shutdown but updates in journal_commit_transaction() and journal_flush() can really race with other log tail updates (e.g. someone doing journal_flush() with someone running cleanup_journal_tail()). So protect all log tail updates with j_checkpoint_mutex. Signed-off-by: Jan Kara <jack@suse.cz>
2012-05-15jbd: Split updating of journal superblock and marking journal emptyJan Kara
There are three case of updating journal superblock. In the first case, we want to mark journal as empty (setting s_sequence to 0), in the second case we want to update log tail, in the third case we want to update s_errno. Split these cases into separate functions. It makes the code slightly more straightforward and later patches will make the distinction even more important. Signed-off-by: Jan Kara <jack@suse.cz>
2012-04-11jbd: Refine commit writeout logicJan Kara
Currently we write out all journal buffers in WRITE_SYNC mode. This improves performance for fsync heavy workloads but hinders performance when writes are mostly asynchronous, most noticably it slows down readers and users complain about slow desktop response etc. So submit writes as asynchronous in the normal case and only submit writes as WRITE_SYNC if we detect someone is waiting for current transaction commit. I've gathered some numbers to back this change. The first is the read latency test. It measures time to read 1 MB after several seconds of sleeping in presence of streaming writes. Top 10 times (out of 90) in us: Before After 2131586 697473 1709932 557487 1564598 535642 1480462 347573 1478579 323153 1408496 222181 1388960 181273 1329565 181070 1252486 172832 1223265 172278 Average: 619377 82180 So the improvement in both maximum and average latency is massive. I've measured fsync throughput by: fs_mark -n 100 -t 1 -s 16384 -d /mnt/fsync/ -S 1 -L 4 in presence of streaming reader. The numbers (fsyncs/s) are: Before After 9.9 6.3 6.8 6.0 6.3 6.2 5.8 6.1 So fsync performance seems unharmed by this change. Signed-off-by: Jan Kara <jack@suse.cz>
2012-03-21Merge tag 'pm-for-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management updates for 3.4 from Rafael Wysocki: "Assorted extensions and fixes including: * Introduction of early/late suspend/hibernation device callbacks. * Generic PM domains extensions and fixes. * devfreq updates from Axel Lin and MyungJoo Ham. * Device PM QoS updates. * Fixes of concurrency problems with wakeup sources. * System suspend and hibernation fixes." * tag 'pm-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (43 commits) PM / Domains: Check domain status during hibernation restore of devices PM / devfreq: add relation of recommended frequency. PM / shmobile: Make MTU2 driver use pm_genpd_dev_always_on() PM / shmobile: Make CMT driver use pm_genpd_dev_always_on() PM / shmobile: Make TMU driver use pm_genpd_dev_always_on() PM / Domains: Introduce "always on" device flag PM / Domains: Fix hibernation restore of devices, v2 PM / Domains: Fix handling of wakeup devices during system resume sh_mmcif / PM: Use PM QoS latency constraint tmio_mmc / PM: Use PM QoS latency constraint PM / QoS: Make it possible to expose PM QoS latency constraints PM / Sleep: JBD and JBD2 missing set_freezable() PM / Domains: Fix include for PM_GENERIC_DOMAINS=n case PM / Freezer: Remove references to TIF_FREEZE in comments PM / Sleep: Add more wakeup source initialization routines PM / Hibernate: Enable usermodehelpers in hibernate() error path PM / Sleep: Make __pm_stay_awake() delete wakeup source timers PM / Sleep: Fix race conditions related to wakeup source timer function PM / Sleep: Fix possible infinite loop during wakeup source destruction PM / Hibernate: print physical addresses consistently with other parts of kernel ...
2012-03-20jbd: remove the second argument of k[un]map_atomic()Cong Wang
Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Cong Wang <amwang@redhat.com>
2012-03-13PM / Sleep: JBD and JBD2 missing set_freezable()Nigel Cunningham
With the latest and greatest changes to the freezer, I started seeing panics that were caused by jbd2 running post-process freezing and hitting the canary BUG_ON for non-TuxOnIce I/O submission. I've traced this back to a lack of set_freezable calls in both jbd and jbd2. Since they're clearly meant to be frozen (there are tests for freezing()), I submit the following patch to add the missing calls. Signed-off-by: Nigel Cunningham <nigel@tuxonice.net> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-01-11jbd: Issue cache flush after checkpointingJan Kara
When we reach cleanup_journal_tail(), there is no guarantee that checkpointed buffers are on a stable storage - especially if buffers were written out by log_do_checkpoint(), they are likely to be only in disk's caches. Thus when we update journal superblock, effectively removing old transaction from journal, this write of superblock can get to stable storage before those checkpointed buffers which can result in filesystem corruption after a crash. A similar problem can happen if we replay the journal and wipe it before flushing disk's caches. Thus we must unconditionally issue a cache flush before we update journal superblock in these cases. The fix is slightly complicated by the fact that we have to get log tail before we issue cache flush but we can store it in the journal superblock only after the cache flush. Otherwise we risk races where new tail is written before appropriate cache flush is finished. I managed to reproduce the corruption using somewhat tweaked Chris Mason's barrier-test scheduler. Also this should fix occasional reports of 'Bit already freed' filesystem errors which are totally unreproducible but inspection of several fs images I've gathered over time points to a problem like this. CC: stable@kernel.org Signed-off-by: Jan Kara <jack@suse.cz>
2012-01-09Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: ext2/3/4: delete unneeded includes of module.h ext{3,4}: Fix potential race when setversion ioctl updates inode udf: Mark LVID buffer as uptodate before marking it dirty ext3: Don't warn from writepage when readonly inode is spotted after error jbd: Remove j_barrier mutex reiserfs: Force inode evictions before umount to avoid crash reiserfs: Fix quota mount option parsing udf: Treat symlink component of type 2 as / udf: Fix deadlock when converting file from in-ICB one to normal one udf: Cleanup calling convention of inode_getblk() ext2: Fix error handling on inode bitmap corruption ext3: Fix error handling on inode bitmap corruption ext3: replace ll_rw_block with other functions ext3: NULL dereference in ext3_evict_inode() jbd: clear revoked flag on buffers before a new transaction started ext3: call ext3_mark_recovery_complete() when recovery is really needed
2012-01-09jbd: Remove j_barrier mutexJan Kara
j_barrier mutex is used for serializing different journal lock operations. The problem with it is that e.g. FIFREEZE ioctl results in process leaving kernel with j_barrier mutex held which makes lockdep freak out. Also hibernation code wants to freeze filesystem but it cannot do so because it then cannot hibernate the system because of mutex being locked. So we remove j_barrier mutex and use direct wait on j_barrier_count instead. Since locking journal is a rare operation we don't have to care about fairness or such things. CC: Andrew Morton <akpm@linux-foundation.org> Acked-by: Joel Becker <jlbec@evilplan.org> Signed-off-by: Jan Kara <jack@suse.cz>
2012-01-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (53 commits) Kconfig: acpi: Fix typo in comment. misc latin1 to utf8 conversions devres: Fix a typo in devm_kfree comment btrfs: free-space-cache.c: remove extra semicolon. fat: Spelling s/obsolate/obsolete/g SCSI, pmcraid: Fix spelling error in a pmcraid_err() call tools/power turbostat: update fields in manpage mac80211: drop spelling fix types.h: fix comment spelling for 'architectures' typo fixes: aera -> area, exntension -> extension devices.txt: Fix typo of 'VMware'. sis900: Fix enum typo 'sis900_rx_bufer_status' decompress_bunzip2: remove invalid vi modeline treewide: Fix comment and string typo 'bufer' hyper-v: Update MAINTAINERS treewide: Fix typos in various parts of the kernel, and fix some comments. clockevents: drop unknown Kconfig symbol GENERIC_CLOCKEVENTS_MIGR gpio: Kconfig: drop unknown symbol 'CS5535_GPIO' leds: Kconfig: Fix typo 'D2NET_V2' sound: Kconfig: drop unknown symbol ARCH_CLPS7500 ... Fix up trivial conflicts in arch/powerpc/platforms/40x/Kconfig (some new kconfig additions, close to removed commented-out old ones)
2011-12-06treewide: Fix comment and string typo 'bufer'Paul Bolle
Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-11-22jbd: clear revoked flag on buffers before a new transaction startedYongqiang Yang
Currently, we clear revoked flag only when a block is reused. However, this can tigger a false journal error. Consider a situation when a block is used as a meta block and is deleted(revoked) in ordered mode, then the block is allocated as a data block to a file. At this moment, user changes the file's journal mode from ordered to journaled and truncates the file. The block will be considered re-revoked by journal because it has revoked flag still pending from the last transaction and an assertion triggers. We fix the problem by keeping the revoked status more uptodate - we clear revoked flag when switching revoke tables to reflect there is no revoked buffers in current transaction any more. Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-11-21freezer: unexport refrigerator() and update try_to_freeze() slightlyTejun Heo
There is no reason to export two functions for entering the refrigerator. Calling refrigerator() instead of try_to_freeze() doesn't save anything noticeable or removes any race condition. * Rename refrigerator() to __refrigerator() and make it return bool indicating whether it scheduled out for freezing. * Update try_to_freeze() to return bool and relay the return value of __refrigerator() if freezing(). * Convert all refrigerator() users to try_to_freeze(). * Update documentation accordingly. * While at it, add might_sleep() to try_to_freeze(). Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: Chris Mason <chris.mason@oracle.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jan Kara <jack@suse.cz> Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp> Cc: Christoph Hellwig <hch@infradead.org>
2011-11-01jbd/jbd2: validate sb->s_first in journal_get_superblock()Eryu Guan
I hit a J_ASSERT(blocknr != 0) failure in cleanup_journal_tail() when mounting a fsfuzzed ext3 image. It turns out that the corrupted ext3 image has s_first = 0 in journal superblock, and the 0 is passed to journal->j_head in journal_reset(), then to blocknr in cleanup_journal_tail(), in the end the J_ASSERT failed. So validate s_first after reading journal superblock from disk in journal_get_superblock() to ensure s_first is valid. The following script could reproduce it: fstype=ext3 blocksize=1024 img=$fstype.img offset=0 found=0 magic="c0 3b 39 98" dd if=/dev/zero of=$img bs=1M count=8 mkfs -t $fstype -b $blocksize -F $img filesize=`stat -c %s $img` while [ $offset -lt $filesize ] do if od -j $offset -N 4 -t x1 $img | grep -i "$magic";then echo "Found journal: $offset" found=1 break fi offset=`echo "$offset+$blocksize" | bc` done if [ $found -ne 1 ];then echo "Magic \"$magic\" not found" exit 1 fi dd if=/dev/zero of=$img seek=$(($offset+23)) conv=notrunc bs=1 count=1 mkdir -p ./mnt mount -o loop $img ./mnt Cc: Jan Kara <jack@suse.cz> Signed-off-by: Eryu Guan <guaneryu@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-06-28jbd: Use WRITE_SYNC in journal checkpoint.Tao Ma
In journal checkpoint, we write the buffer and wait for its finish. But in cfq, the async queue has a very low priority, and in our test, if there are too many sync queues and every queue is filled up with requests, and the process will hang waiting for the log space. So this patch tries to use WRITE_SYNC in __flush_batch so that the request will be moved into sync queue and handled by cfq timely. We also use the new plug, sot that all the WRITE_SYNC requests can be given as a whole when we unplug it. Reported-by: Robin Dong <sanbai@taobao.com> Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-06-27jbd: Fix oops in journal_remove_journal_head()Jan Kara
journal_remove_journal_head() can oops when trying to access journal_head returned by bh2jh(). This is caused for example by the following race: TASK1 TASK2 journal_commit_transaction() ... processing t_forget list __journal_refile_buffer(jh); if (!jh->b_transaction) { jbd_unlock_bh_state(bh); journal_try_to_free_buffers() journal_grab_journal_head(bh) jbd_lock_bh_state(bh) __journal_try_to_free_buffer() journal_put_journal_head(jh) journal_remove_journal_head(bh); journal_put_journal_head() in TASK2 sees that b_jcount == 0 and buffer is not part of any transaction and thus frees journal_head before TASK1 gets to doing so. Note that even buffer_head can be released by try_to_free_buffers() after journal_put_journal_head() which adds even larger opportunity for oops (but I didn't see this happen in reality). Fix the problem by making transactions hold their own journal_head reference (in b_jcount). That way we don't have to remove journal_head explicitely via journal_remove_journal_head() and instead just remove journal_head when b_jcount drops to zero. The result of this is that [__]journal_refile_buffer(), [__]journal_unfile_buffer(), and __journal_remove_checkpoint() can free journal_head which needs modification of a few callers. Also we have to be careful because once journal_head is removed, buffer_head might be freed as well. So we have to get our own buffer_head reference where it matters. Signed-off-by: Jan Kara <jack@suse.cz>
2011-06-25jbd: fix a bug of leaking jh->b_jcountDing Dinghua
journal_get_create_access should drop jh->b_jcount in error handling path Signed-off-by: Ding Dinghua <dingdinghua@nrchpc.ac.cn> Signed-off-by: Jan Kara <jack@suse.cz>
2011-06-25jbd: remove dependency on __GFP_NOFAILJan Kara
The callers of start_this_handle() (or better ext3_journal_start()) are not really prepared to handle allocation failures. Such failures can for example result in silent data loss when it happens in ext3_..._writepage(). OTOH __GFP_NOFAIL is going away so we just retry allocation in start_this_handle(). This loop is potentially dangerous because the oom killer cannot be invoked for GFP_NOFS allocation, so there is a potential for infinitely looping. But still this is better than silent data loss. Signed-off-by: Jan Kara <jack@suse.cz>
2011-06-25jbd: Add fixed tracepointsLukas Czerner
This commit adds fixed tracepoint for jbd. It has been based on fixed tracepoints for jbd2, however there are missing those for collecting statistics, since I think that it will require more intrusive patch so I should have its own commit, if someone decide that it is needed. Also there are new tracepoints in __journal_drop_transaction() and journal_update_superblock(). The list of jbd tracepoints: jbd_checkpoint jbd_start_commit jbd_commit_locking jbd_commit_flushing jbd_commit_logging jbd_drop_transaction jbd_end_commit jbd_do_submit_data jbd_cleanup_journal_tail jbd_update_superblock_end Signed-off-by: Lukas Czerner <lczerner@redhat.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Jan Kara <jack@suse.cz>
2011-05-24jbd: Fix comment to match the code in journal_start()Eryu Guan
journal_start returns an ERR_PTR() value rather than NULL on failure. Cc: Jan Kara <jack@suse.cz> Signed-off-by: Eryu Guan <guaneryu@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-05-17jbd/jbd2: remove obsolete summarise_journal_usage.Tao Ma
summarise_journal_usage seems to be obsolete for a long time, so remove it. Cc: Jan Kara <jack@suse.cz> Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-05-17jbd: Fix forever sleeping process in do_get_write_access()Jan Kara
In do_get_write_access() we wait on BH_Unshadow bit for buffer to get from shadow state. The waking code in journal_commit_transaction() has a bug because it does not issue a memory barrier after the buffer is moved from the shadow state and before wake_up_bit() is called. Thus a waitqueue check can happen before the buffer is actually moved from the shadow state and waiting process may never be woken. Fix the problem by issuing proper barrier. CC: stable@kernel.org Reported-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-05-17jbd: fix fsync() tid wraparound bugTed Ts'o
If an application program does not make any changes to the indirect blocks or extent tree, i_datasync_tid will not get updated. If there are enough commits (i.e., 2**31) such that tid_geq()'s calculations wrap, and there isn't a currently active transaction at the time of the fdatasync() call, this can end up triggering a BUG_ON in fs/jbd/commit.c: J_ASSERT(journal->j_running_transaction != NULL); It's pretty rare that this can happen, since it requires the use of fdatasync() plus *very* frequent and excessive use of fsync(). But with the right workload, it can. We fix this by replacing the use of tid_geq() with an equality test, since there's only one valid transaction id that is valid for us to start: namely, the currently running transaction (if it exists). CC: stable@kernel.org Reported-by: Martin_Zielinski@McAfee.com Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Jan Kara <jack@suse.cz>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-17jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit pluggingJens Axboe
'write_op' was still used, even though it was always WRITE_SYNC now. Add plugging around the cases where it submits IO, and flush them before we end up waiting for that IO. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10block: kill off REQ_UNPLUGJens Axboe
With the plugging now being explicitly controlled by the submitter, callers need not pass down unplugging hints to the block layer. If they want to unplug, it's because they manually plugged on their own - in which case, they should just unplug at will. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-02-28jbd: Remove one to many n's in a word.Justin P. Mattock
The Patch below removes one to many "n's" in a word.. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> CC: Andrew Morton <akpm@linux-foundation.org> CC: linux-ext4@vger.kernel.org Acked-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Jan Kara <jack@suse.cz>
2010-12-10fix comment typos concerning "consistent"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-27Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: (24 commits) quota: Fix possible oops in __dquot_initialize() ext3: Update kernel-doc comments jbd/2: fixed typos ext2: fixed typo. ext3: Fix debug messages in ext3_group_extend() jbd: Convert atomic_inc() to get_bh() ext3: Remove misplaced BUFFER_TRACE() in ext3_truncate() jbd: Fix debug message in do_get_write_access() jbd: Check return value of __getblk() ext3: Use DIV_ROUND_UP() on group desc block counting ext3: Return proper error code on ext3_fill_super() ext3: Remove unnecessary casts on bh->b_data ext3: Cleanup ext3_setup_super() quota: Fix issuing of warnings from dquot_transfer quota: fix dquot_disable vs dquot_transfer race v2 jbd: Convert bitops to buffer fns ext3/jbd: Avoid WARN() messages when failing to write the superblock jbd: Use offset_in_page() instead of manual calculation jbd: Remove unnecessary goto statement jbd: Use printk_ratelimited() in journal_alloc_journal_head() ...
