path: root/fs/jbd
2012-08-15jbd: don't write superblock when unmounting an ro filesystemJan Kara
This sequence: results in an IO error when unmounting the RO filesystem. The bug was introduced by: commit 9754e39c7bc51328f145e933bfb0df47cd67b6e9 Author: Jan Kara <jack@suse.cz> Date: Sat Apr 7 12:33:03 2012 +0200 jbd: Split updating of journal superblock and marking journal empty which lost some of the magic in journal_update_superblock() which used to test for a journal with no outstanding transactions. This is a port of a jbd2 fix by Eric Sandeen. CC: <stable@vger.kernel.org> # 3.4.x Signed-off-by: Jan Kara <jack@suse.cz>
2012-08-04jbd/jbd2: nuke write_super from commentsArtem Bityutskiy
The '->write_super' superblock method is gone, and this patch removes all the references to 'write_super' from various jbd and jbd2. Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jan Kara <jack@suse.cz> Cc: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-09jbd: Check return value of blkdev_issue_flush()Jan Kara
blkdev_issue_flush() can fail. Make sure the error gets properly propagated. Signed-off-by: Jan Kara <jack@suse.cz>
2012-05-15jbd: Write journal superblock with WRITE_FUA after checkpointingJan Kara
If journal superblock is written only in disk's caches and other transaction starts reusing space of the transaction cleaned from the log, it can happen blocks of a new transaction reach the disk before journal superblock. When power failure happens in such case, subsequent journal replay would still try to replay the old transaction but some of it's blocks may be already overwritten by the new transaction. For this reason we must use WRITE_FUA when updating log tail and we must first write new log tail to disk and update in-memory information only after that. Signed-off-by: Jan Kara <jack@suse.cz>
2012-05-15jbd: protect all log tail updates with j_checkpoint_mutexJan Kara
There are some log tail updates that are not protected by j_checkpoint_mutex. Some of these are harmless because they happen during startup or shutdown but updates in journal_commit_transaction() and journal_flush() can really race with other log tail updates (e.g. someone doing journal_flush() with someone running cleanup_journal_tail()). So protect all log tail updates with j_checkpoint_mutex. Signed-off-by: Jan Kara <jack@suse.cz>
2012-05-15jbd: Split updating of journal superblock and marking journal emptyJan Kara
There are three case of updating journal superblock. In the first case, we want to mark journal as empty (setting s_sequence to 0), in the second case we want to update log tail, in the third case we want to update s_errno. Split these cases into separate functions. It makes the code slightly more straightforward and later patches will make the distinction even more important. Signed-off-by: Jan Kara <jack@suse.cz>
2012-04-11jbd: Refine commit writeout logicJan Kara
Currently we write out all journal buffers in WRITE_SYNC mode. This improves performance for fsync heavy workloads but hinders performance when writes are mostly asynchronous, most noticably it slows down readers and users complain about slow desktop response etc. So submit writes as asynchronous in the normal case and only submit writes as WRITE_SYNC if we detect someone is waiting for current transaction commit. I've gathered some numbers to back this change. The first is the read latency test. It measures time to read 1 MB after several seconds of sleeping in presence of streaming writes. Top 10 times (out of 90) in us: Before After 2131586 697473 1709932 557487 1564598 535642 1480462 347573 1478579 323153 1408496 222181 1388960 181273 1329565 181070 1252486 172832 1223265 172278 Average: 619377 82180 So the improvement in both maximum and average latency is massive. I've measured fsync throughput by: fs_mark -n 100 -t 1 -s 16384 -d /mnt/fsync/ -S 1 -L 4 in presence of streaming reader. The numbers (fsyncs/s) are: Before After 9.9 6.3 6.8 6.0 6.3 6.2 5.8 6.1 So fsync performance seems unharmed by this change. Signed-off-by: Jan Kara <jack@suse.cz>
2012-03-21Merge tag 'pm-for-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management updates for 3.4 from Rafael Wysocki: "Assorted extensions and fixes including: * Introduction of early/late suspend/hibernation device callbacks. * Generic PM domains extensions and fixes. * devfreq updates from Axel Lin and MyungJoo Ham. * Device PM QoS updates. * Fixes of concurrency problems with wakeup sources. * System suspend and hibernation fixes." * tag 'pm-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (43 commits) PM / Domains: Check domain status during hibernation restore of devices PM / devfreq: add relation of recommended frequency. PM / shmobile: Make MTU2 driver use pm_genpd_dev_always_on() PM / shmobile: Make CMT driver use pm_genpd_dev_always_on() PM / shmobile: Make TMU driver use pm_genpd_dev_always_on() PM / Domains: Introduce "always on" device flag PM / Domains: Fix hibernation restore of devices, v2 PM / Domains: Fix handling of wakeup devices during system resume sh_mmcif / PM: Use PM QoS latency constraint tmio_mmc / PM: Use PM QoS latency constraint PM / QoS: Make it possible to expose PM QoS latency constraints PM / Sleep: JBD and JBD2 missing set_freezable() PM / Domains: Fix include for PM_GENERIC_DOMAINS=n case PM / Freezer: Remove references to TIF_FREEZE in comments PM / Sleep: Add more wakeup source initialization routines PM / Hibernate: Enable usermodehelpers in hibernate() error path PM / Sleep: Make __pm_stay_awake() delete wakeup source timers PM / Sleep: Fix race conditions related to wakeup source timer function PM / Sleep: Fix possible infinite loop during wakeup source destruction PM / Hibernate: print physical addresses consistently with other parts of kernel ...
2012-03-20jbd: remove the second argument of k[un]map_atomic()Cong Wang
Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Cong Wang <amwang@redhat.com>
2012-03-13PM / Sleep: JBD and JBD2 missing set_freezable()Nigel Cunningham
With the latest and greatest changes to the freezer, I started seeing panics that were caused by jbd2 running post-process freezing and hitting the canary BUG_ON for non-TuxOnIce I/O submission. I've traced this back to a lack of set_freezable calls in both jbd and jbd2. Since they're clearly meant to be frozen (there are tests for freezing()), I submit the following patch to add the missing calls. Signed-off-by: Nigel Cunningham <nigel@tuxonice.net> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-01-11jbd: Issue cache flush after checkpointingJan Kara
When we reach cleanup_journal_tail(), there is no guarantee that checkpointed buffers are on a stable storage - especially if buffers were written out by log_do_checkpoint(), they are likely to be only in disk's caches. Thus when we update journal superblock, effectively removing old transaction from journal, this write of superblock can get to stable storage before those checkpointed buffers which can result in filesystem corruption after a crash. A similar problem can happen if we replay the journal and wipe it before flushing disk's caches. Thus we must unconditionally issue a cache flush before we update journal superblock in these cases. The fix is slightly complicated by the fact that we have to get log tail before we issue cache flush but we can store it in the journal superblock only after the cache flush. Otherwise we risk races where new tail is written before appropriate cache flush is finished. I managed to reproduce the corruption using somewhat tweaked Chris Mason's barrier-test scheduler. Also this should fix occasional reports of 'Bit already freed' filesystem errors which are totally unreproducible but inspection of several fs images I've gathered over time points to a problem like this. CC: stable@kernel.org Signed-off-by: Jan Kara <jack@suse.cz>
2012-01-09Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: ext2/3/4: delete unneeded includes of module.h ext{3,4}: Fix potential race when setversion ioctl updates inode udf: Mark LVID buffer as uptodate before marking it dirty ext3: Don't warn from writepage when readonly inode is spotted after error jbd: Remove j_barrier mutex reiserfs: Force inode evictions before umount to avoid crash reiserfs: Fix quota mount option parsing udf: Treat symlink component of type 2 as / udf: Fix deadlock when converting file from in-ICB one to normal one udf: Cleanup calling convention of inode_getblk() ext2: Fix error handling on inode bitmap corruption ext3: Fix error handling on inode bitmap corruption ext3: replace ll_rw_block with other functions ext3: NULL dereference in ext3_evict_inode() jbd: clear revoked flag on buffers before a new transaction started ext3: call ext3_mark_recovery_complete() when recovery is really needed
2012-01-09jbd: Remove j_barrier mutexJan Kara
j_barrier mutex is used for serializing different journal lock operations. The problem with it is that e.g. FIFREEZE ioctl results in process leaving kernel with j_barrier mutex held which makes lockdep freak out. Also hibernation code wants to freeze filesystem but it cannot do so because it then cannot hibernate the system because of mutex being locked. So we remove j_barrier mutex and use direct wait on j_barrier_count instead. Since locking journal is a rare operation we don't have to care about fairness or such things. CC: Andrew Morton <akpm@linux-foundation.org> Acked-by: Joel Becker <jlbec@evilplan.org> Signed-off-by: Jan Kara <jack@suse.cz>
2012-01-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (53 commits) Kconfig: acpi: Fix typo in comment. misc latin1 to utf8 conversions devres: Fix a typo in devm_kfree comment btrfs: free-space-cache.c: remove extra semicolon. fat: Spelling s/obsolate/obsolete/g SCSI, pmcraid: Fix spelling error in a pmcraid_err() call tools/power turbostat: update fields in manpage mac80211: drop spelling fix types.h: fix comment spelling for 'architectures' typo fixes: aera -> area, exntension -> extension devices.txt: Fix typo of 'VMware'. sis900: Fix enum typo 'sis900_rx_bufer_status' decompress_bunzip2: remove invalid vi modeline treewide: Fix comment and string typo 'bufer' hyper-v: Update MAINTAINERS treewide: Fix typos in various parts of the kernel, and fix some comments. clockevents: drop unknown Kconfig symbol GENERIC_CLOCKEVENTS_MIGR gpio: Kconfig: drop unknown symbol 'CS5535_GPIO' leds: Kconfig: Fix typo 'D2NET_V2' sound: Kconfig: drop unknown symbol ARCH_CLPS7500 ... Fix up trivial conflicts in arch/powerpc/platforms/40x/Kconfig (some new kconfig additions, close to removed commented-out old ones)
2011-12-06treewide: Fix comment and string typo 'bufer'Paul Bolle
Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-11-22jbd: clear revoked flag on buffers before a new transaction startedYongqiang Yang
Currently, we clear revoked flag only when a block is reused. However, this can tigger a false journal error. Consider a situation when a block is used as a meta block and is deleted(revoked) in ordered mode, then the block is allocated as a data block to a file. At this moment, user changes the file's journal mode from ordered to journaled and truncates the file. The block will be considered re-revoked by journal because it has revoked flag still pending from the last transaction and an assertion triggers. We fix the problem by keeping the revoked status more uptodate - we clear revoked flag when switching revoke tables to reflect there is no revoked buffers in current transaction any more. Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-11-21freezer: unexport refrigerator() and update try_to_freeze() slightlyTejun Heo
There is no reason to export two functions for entering the refrigerator. Calling refrigerator() instead of try_to_freeze() doesn't save anything noticeable or removes any race condition. * Rename refrigerator() to __refrigerator() and make it return bool indicating whether it scheduled out for freezing. * Update try_to_freeze() to return bool and relay the return value of __refrigerator() if freezing(). * Convert all refrigerator() users to try_to_freeze(). * Update documentation accordingly. * While at it, add might_sleep() to try_to_freeze(). Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: Chris Mason <chris.mason@oracle.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jan Kara <jack@suse.cz> Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp> Cc: Christoph Hellwig <hch@infradead.org>
2011-11-01jbd/jbd2: validate sb->s_first in journal_get_superblock()Eryu Guan
I hit a J_ASSERT(blocknr != 0) failure in cleanup_journal_tail() when mounting a fsfuzzed ext3 image. It turns out that the corrupted ext3 image has s_first = 0 in journal superblock, and the 0 is passed to journal->j_head in journal_reset(), then to blocknr in cleanup_journal_tail(), in the end the J_ASSERT failed. So validate s_first after reading journal superblock from disk in journal_get_superblock() to ensure s_first is valid. The following script could reproduce it: fstype=ext3 blocksize=1024 img=$fstype.img offset=0 found=0 magic="c0 3b 39 98" dd if=/dev/zero of=$img bs=1M count=8 mkfs -t $fstype -b $blocksize -F $img filesize=`stat -c %s $img` while [ $offset -lt $filesize ] do if od -j $offset -N 4 -t x1 $img | grep -i "$magic";then echo "Found journal: $offset" found=1 break fi offset=`echo "$offset+$blocksize" | bc` done if [ $found -ne 1 ];then echo "Magic \"$magic\" not found" exit 1 fi dd if=/dev/zero of=$img seek=$(($offset+23)) conv=notrunc bs=1 count=1 mkdir -p ./mnt mount -o loop $img ./mnt Cc: Jan Kara <jack@suse.cz> Signed-off-by: Eryu Guan <guaneryu@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-06-28jbd: Use WRITE_SYNC in journal checkpoint.Tao Ma
In journal checkpoint, we write the buffer and wait for its finish. But in cfq, the async queue has a very low priority, and in our test, if there are too many sync queues and every queue is filled up with requests, and the process will hang waiting for the log space. So this patch tries to use WRITE_SYNC in __flush_batch so that the request will be moved into sync queue and handled by cfq timely. We also use the new plug, sot that all the WRITE_SYNC requests can be given as a whole when we unplug it. Reported-by: Robin Dong <sanbai@taobao.com> Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-06-27jbd: Fix oops in journal_remove_journal_head()Jan Kara
journal_remove_journal_head() can oops when trying to access journal_head returned by bh2jh(). This is caused for example by the following race: TASK1 TASK2 journal_commit_transaction() ... processing t_forget list __journal_refile_buffer(jh); if (!jh->b_transaction) { jbd_unlock_bh_state(bh); journal_try_to_free_buffers() journal_grab_journal_head(bh) jbd_lock_bh_state(bh) __journal_try_to_free_buffer() journal_put_journal_head(jh) journal_remove_journal_head(bh); journal_put_journal_head() in TASK2 sees that b_jcount == 0 and buffer is not part of any transaction and thus frees journal_head before TASK1 gets to doing so. Note that even buffer_head can be released by try_to_free_buffers() after journal_put_journal_head() which adds even larger opportunity for oops (but I didn't see this happen in reality). Fix the problem by making transactions hold their own journal_head reference (in b_jcount). That way we don't have to remove journal_head explicitely via journal_remove_journal_head() and instead just remove journal_head when b_jcount drops to zero. The result of this is that [__]journal_refile_buffer(), [__]journal_unfile_buffer(), and __journal_remove_checkpoint() can free journal_head which needs modification of a few callers. Also we have to be careful because once journal_head is removed, buffer_head might be freed as well. So we have to get our own buffer_head reference where it matters. Signed-off-by: Jan Kara <jack@suse.cz>
2011-06-25jbd: fix a bug of leaking jh->b_jcountDing Dinghua
journal_get_create_access should drop jh->b_jcount in error handling path Signed-off-by: Ding Dinghua <dingdinghua@nrchpc.ac.cn> Signed-off-by: Jan Kara <jack@suse.cz>
2011-06-25jbd: remove dependency on __GFP_NOFAILJan Kara
The callers of start_this_handle() (or better ext3_journal_start()) are not really prepared to handle allocation failures. Such failures can for example result in silent data loss when it happens in ext3_..._writepage(). OTOH __GFP_NOFAIL is going away so we just retry allocation in start_this_handle(). This loop is potentially dangerous because the oom killer cannot be invoked for GFP_NOFS allocation, so there is a potential for infinitely looping. But still this is better than silent data loss. Signed-off-by: Jan Kara <jack@suse.cz>
2011-06-25jbd: Add fixed tracepointsLukas Czerner
This commit adds fixed tracepoint for jbd. It has been based on fixed tracepoints for jbd2, however there are missing those for collecting statistics, since I think that it will require more intrusive patch so I should have its own commit, if someone decide that it is needed. Also there are new tracepoints in __journal_drop_transaction() and journal_update_superblock(). The list of jbd tracepoints: jbd_checkpoint jbd_start_commit jbd_commit_locking jbd_commit_flushing jbd_commit_logging jbd_drop_transaction jbd_end_commit jbd_do_submit_data jbd_cleanup_journal_tail jbd_update_superblock_end Signed-off-by: Lukas Czerner <lczerner@redhat.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Jan Kara <jack@suse.cz>
2011-05-24jbd: Fix comment to match the code in journal_start()Eryu Guan
journal_start returns an ERR_PTR() value rather than NULL on failure. Cc: Jan Kara <jack@suse.cz> Signed-off-by: Eryu Guan <guaneryu@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-05-17jbd/jbd2: remove obsolete summarise_journal_usage.Tao Ma
summarise_journal_usage seems to be obsolete for a long time, so remove it. Cc: Jan Kara <jack@suse.cz> Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-05-17jbd: Fix forever sleeping process in do_get_write_access()Jan Kara
In do_get_write_access() we wait on BH_Unshadow bit for buffer to get from shadow state. The waking code in journal_commit_transaction() has a bug because it does not issue a memory barrier after the buffer is moved from the shadow state and before wake_up_bit() is called. Thus a waitqueue check can happen before the buffer is actually moved from the shadow state and waiting process may never be woken. Fix the problem by issuing proper barrier. CC: stable@kernel.org Reported-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-05-17jbd: fix fsync() tid wraparound bugTed Ts'o
If an application program does not make any changes to the indirect blocks or extent tree, i_datasync_tid will not get updated. If there are enough commits (i.e., 2**31) such that tid_geq()'s calculations wrap, and there isn't a currently active transaction at the time of the fdatasync() call, this can end up triggering a BUG_ON in fs/jbd/commit.c: J_ASSERT(journal->j_running_transaction != NULL); It's pretty rare that this can happen, since it requires the use of fdatasync() plus *very* frequent and excessive use of fsync(). But with the right workload, it can. We fix this by replacing the use of tid_geq() with an equality test, since there's only one valid transaction id that is valid for us to start: namely, the currently running transaction (if it exists). CC: stable@kernel.org Reported-by: Martin_Zielinski@McAfee.com Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Jan Kara <jack@suse.cz>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-17jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit pluggingJens Axboe
'write_op' was still used, even though it was always WRITE_SYNC now. Add plugging around the cases where it submits IO, and flush them before we end up waiting for that IO. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10block: kill off REQ_UNPLUGJens Axboe
With the plugging now being explicitly controlled by the submitter, callers need not pass down unplugging hints to the block layer. If they want to unplug, it's because they manually plugged on their own - in which case, they should just unplug at will. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-02-28jbd: Remove one to many n's in a word.Justin P. Mattock
The Patch below removes one to many "n's" in a word.. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> CC: Andrew Morton <akpm@linux-foundation.org> CC: linux-ext4@vger.kernel.org Acked-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Jan Kara <jack@suse.cz>
2010-12-10fix comment typos concerning "consistent"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-27Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: (24 commits) quota: Fix possible oops in __dquot_initialize() ext3: Update kernel-doc comments jbd/2: fixed typos ext2: fixed typo. ext3: Fix debug messages in ext3_group_extend() jbd: Convert atomic_inc() to get_bh() ext3: Remove misplaced BUFFER_TRACE() in ext3_truncate() jbd: Fix debug message in do_get_write_access() jbd: Check return value of __getblk() ext3: Use DIV_ROUND_UP() on group desc block counting ext3: Return proper error code on ext3_fill_super() ext3: Remove unnecessary casts on bh->b_data ext3: Cleanup ext3_setup_super() quota: Fix issuing of warnings from dquot_transfer quota: fix dquot_disable vs dquot_transfer race v2 jbd: Convert bitops to buffer fns ext3/jbd: Avoid WARN() messages when failing to write the superblock jbd: Use offset_in_page() instead of manual calculation jbd: Remove unnecessary goto statement jbd: Use printk_ratelimited() in journal_alloc_journal_head() ...
2010-10-28jbd/2: fixed typosAndrea Gelmini
"wakup" Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Signed-off-by: Jan Kara <jack@suse.cz>
2010-10-28jbd: Convert atomic_inc() to get_bh()Namhyung Kim
Convert atomic_inc(&bh->b_count) to get_bh(bh) for consistency. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-10-28jbd: Fix debug message in do_get_write_access()Namhyung Kim
'buffer_head' should be 'journal_head'. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-10-28jbd: Check return value of __getblk()Namhyung Kim
Fail journal creation if __getblk() returns NULL. unlikely() is added because it is called in a loop and we've been OK without the check until now. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-10-28jbd: Convert bitops to buffer fnsNamhyung Kim
Convert set/clear_bit(BH_JWrite, ...) to set/clear_buffer_jwrite() for consistency. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-10-28ext3/jbd: Avoid WARN() messages when failing to write the superblockDarrick J. Wong
This fixes a WARN backtrace in mark_buffer_dirty() that occurs during unmount when the underlying block device is removed. This bug has been seen on System Z when removing all paths from a multipath-backed ext3 mount; on System P when injecting enough PCI EEH errors to make the SCSI controller go offline; and similar warnings have been seen (and patched) with ext2/ext4. The super block update from a previous operation has marked the buffer as in error, and the flag has to be cleared before doing the update. Similar changes have been made to ext4 by commit 914258bf2cb22bf4336a1b1d90c551b4b11ca5aa. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-10-28jbd: Use offset_in_page() instead of manual calculationNamhyung Kim
2010-10-28jbd: Remove unnecessary goto statementNamhyung Kim
Remove goto statement which jumps to very next line. Also remove target label because it is no longer used anywhere. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-10-28jbd: Use printk_ratelimited() in journal_alloc_journal_head()Namhyung Kim
Use printk_ratelimited() instead of doing it manually. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-10-28jbd: Move debug message into #ifdef areaNamhyung Kim
Move call to jbd_debug() into #ifdef CONFIG_JBD_DEBUG block because 'dropped' is declared there. The code could be compiled without this change anyway, simply because jbd_debug() expands to nothing if !CONFIG_JBD_DEBUG but IMHO it doesn't look good in general. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-10-22Merge branch 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-block: (46 commits) xen-blkfront: disable barrier/flush write support Added blk-lib.c and blk-barrier.c was renamed to blk-flush.c block: remove BLKDEV_IFL_WAIT aic7xxx_old: removed unused 'req' variable block: remove the BH_Eopnotsupp flag block: remove the BLKDEV_IFL_BARRIER flag block: remove the WRITE_BARRIER flag swap: do not send discards as barriers fat: do not send discards as barriers ext4: do not send discards as barriers jbd2: replace barriers with explicit flush / FUA usage jbd2: Modify ASYNC_COMMIT code to not rely on queue draining on barrier jbd: replace barriers with explicit flush / FUA usage nilfs2: replace barriers with explicit flush / FUA usage reiserfs: replace barriers with explicit flush / FUA usage gfs2: replace barriers with explicit flush / FUA usage btrfs: replace barriers with explicit flush / FUA usage xfs: replace barriers with explicit flush / FUA usage block: pass gfp_mask and flags to sb_issue_discard dm: convey that all flushes are processed as empty ...
2010-09-20cfq: improve fsync performance for small filesCorrado Zoccolo
Fsync performance for small files achieved by cfq on high-end disks is lower than what deadline can achieve, due to idling introduced between the sync write happening in process context and the journal commit. Moreover, when competing with a sequential reader, a process writing small files and fsync-ing them is starved. This patch fixes the two problems by: - marking journal commits as WRITE_SYNC, so that they get the REQ_NOIDLE flag set, - force all queues that have REQ_NOIDLE requests to be put in the noidle tree. Having the queue associated to the fsync-ing process and the one associated to journal commits in the noidle tree allows: - switching between them without idling, - fairness vs. competing idling queues, since they will be serviced only after the noidle tree expires its slice. Acked-by: Vivek Goyal <vgoyal@redhat.com> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Tested-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Corrado Zoccolo <czoccolo@gmail.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10jbd: replace barriers with explicit flush / FUA usageChristoph Hellwig
Switch to the WRITE_FLUSH_FUA flag for journal commits and remove the EOPNOTSUPP detection for barriers. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-18remove SWRITE* I/O typesChristoph Hellwig
These flags aren't real I/O types, but tell ll_rw_block to always lock the buffer instead of giving up on a failed trylock. Instead add a new write_dirty_buffer helper that implements this semantic and use it from the existing SWRITE* callers. Note that the ll_rw_block code had a bug where it didn't promote WRITE_SYNC_PLUG properly, which this patch fixes. In the ufs code clean up the helper that used to call ll_rw_block to mirror sync_dirty_buffer, which is the function it implements for compound buffers. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-18kill BH_Ordered flagChristoph Hellwig
Instead of abusing a buffer_head flag just add a variant of sync_dirty_buffer which allows passing the exact type of write flag required. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-07-21ext3: Fix set but unused variablesAndi Kleen
[tytso@mit.edu: Fix compilation with CONFIG_JBD_DEBUG enabled] Acked-by: tytso@mit.edu cc: linux-ext4@vger.kernel.org Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Jan Kara <jack@suse.cz>
