path: root/fs/jffs2/README.Locking
2008-04-22[JFFS2] semaphore->mutex conversionDavid Woodhouse
2007-04-25[JFFS2] Tidy up licensing/copyright boilerplate.David Woodhouse
In particular, remove the bit in the LICENCE file about contacting Red Hat for alternative arrangements. Their errant IS department broke that arrangement a long time ago -- the policy of collecting copyright assignments from contributors came to an end when the plug was pulled on the servers hosting the project, without notice or reason. We do still dual-license it for use with eCos, with the GPL+exception licence approved by the FSF as being GPL-compatible. It's just that nobody has the right to license it differently. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-13[JFFS2][XATTR] Add a description about c->xattr_semKaiGai Kohei
Add a description about the c->xattr_sem read/write semaphore into README.Locking. [3/10] jffs2-xattr-v5.1-03-append_README.Locking.patch Signed-off-by: KaiGai Kohei <kaigai@ak.jp.nec.com>
2005-05-23[JFFS2] Fix inode allocation raceDavid Woodhouse
Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
