path: root/fs/jffs2/compr_lzo.c
2008-11-05[JFFS2] fix race condition in jffs2_lzo_compress()Geert Uytterhoeven
deflate_mutex protects the globals lzo_mem and lzo_compress_buf. However, jffs2_lzo_compress() unlocks deflate_mutex _before_ it has copied out the compressed data from lzo_compress_buf. Correct this by moving the mutex unlock after the copy. In addition, document what deflate_mutex actually protects. Cc: stable@kernel.org Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Acked-by: Richard Purdie <rpurdie@openedhand.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2007-07-11[JFFS2] Add LZO compression support.Richard Purdie
Add LZO1X compression/decompression support to jffs2. LZO's interface doesn't entirely match that required by jffs2 so a buffer and memcpy is unavoidable. Signed-off-by: Richard Purdie <rpurdie@openedhand.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
