path: root/fs/jffs2/jffs2_fs_sb.h
2010-12-03jffs2: typo in commentDan Carpenter
It says FB instead of FS (file system). Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-10-25jffs2: Dynamically choose inocache hash sizeDaniel Drake
When JFFS2 is used for large volumes, the mount times are quite long. Increasing the hash size provides a significant speed boost on the OLPC XO-1 laptop. Add logic that dynamically selects a hash size based on the size of the medium. A 64mb medium will result in a hash size of 128, and a 512mb medium will result in a hash size of 1024. Signed-off-by: Daniel Drake <dsd@laptop.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-08-08jffs2: Update copyright noticesDavid Woodhouse
2008-04-23[JFFS2] Add erase_checking_list to hold blocks being marked.David Woodhouse
Just to keep the debug code happy when it's adding all the blocks up. Otherwise, they disappear for a while while the locks are dropped to check them and write the cleanmarker. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-04-22[JFFS2] semaphore->mutex conversionDavid Woodhouse
2008-04-18Convert asm/semaphore.h users to linux/semaphore.hMatthew Wilcox
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2007-10-06[JFFS2] Trigger garbage collection when very_dirty_list size becomes excessiveDavid Woodhouse
With huge amounts of free space, we weren't bothering to GC for while a while, and pathological numbers of obsolete nodes were accumulating, seriously affecting performance on NAND flash (OLPC trac #3978) Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-07-11[JFFS2] Add support for write-buffer verification.David Woodhouse
We've seen some evil corruption issues, where the corruption seems to be introduced after the JFFS2 crc32 is calculated but before the NAND controller calculates the ECC. So it's in RAM or in the PCI DMA transfer; not on the flash. Attempt to catch it earlier by (optionally) reading back from the flash immediately after writing it. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-04-25[JFFS2] Tidy up licensing/copyright boilerplate.David Woodhouse
In particular, remove the bit in the LICENCE file about contacting Red Hat for alternative arrangements. Their errant IS department broke that arrangement a long time ago -- the policy of collecting copyright assignments from contributors came to an end when the plug was pulled on the servers hosting the project, without notice or reason. We do still dual-license it for use with eCos, with the GPL+exception licence approved by the FSF as being GPL-compatible. It's just that nobody has the right to license it differently. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-02-09[JFFS2] Use MTD_OOB_AUTO to automatically place cleanmarker on NANDArtem Bityutskiy
Nowadays MTD supports an MTD_OOB_AUTO option which allows users to access free bytes in NAND's OOB as a contiguous buffer, although it may be highly discontinuous. This patch teaches JFFS2 to use this nice feature instead of the old MTD_OOB_PLACE option. This for example caused problems with OneNAND. Now JFFS2 does not care how are the free bytes situated. This may change position of the clean marker on some flashes, but this is not a problem. JFFS2 will just re-erase the empty eraseblocks and write the new (correct) clean marker. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-06-27[JFFS2][XATTR] using 'delete marker' for xdatum/xref deletionKaiGai Kohei
- When xdatum is removed, a new xdatum with 'delete marker' is written. (version==0xffffffff means 'delete marker') - When xref is removed, a new xref with 'delete marker' is written. (odd-numbered xseqno means 'delete marker') - delete_xattr_(datum/xref)_delay() are new deletion functions are added. We can only use them if we can detect the target obsolete xdatum/xref as a orphan or errir one. (e.g when inode deletion, or detecting crc error) [1/3] jffs2-xattr-v6-01-delete_marker.patch Signed-off-by: KaiGai Kohei <kaigai@ak.jp.nec.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-29[MTD] Rework the out of band handling completelyThomas Gleixner
Hopefully the last iteration on this! The handling of out of band data on NAND was accompanied by tons of fruitless discussions and halfarsed patches to make it work for a particular problem. Sufficiently annoyed by I all those "I know it better" mails and the resonable amount of discarded "it solves my problem" patches, I finally decided to go for the big rework. After removing the _ecc variants of mtd read/write functions the solution to satisfy the various requirements was to refactor the read/write _oob functions in mtd. The major change is that read/write_oob now takes a pointer to an operation descriptor structure "struct mtd_oob_ops".instead of having a function with at least seven arguments. read/write_oob which should probably renamed to a more descriptive name, can do the following tasks: - read/write out of band data - read/write data content and out of band data - read/write raw data content and out of band data (ecc disabled) struct mtd_oob_ops has a mode field, which determines the oob handling mode. Aside of the MTD_OOB_RAW mode, which is intended to be especially for diagnostic purposes and some internal functions e.g. bad block table creation, the other two modes are for mtd clients: MTD_OOB_PLACE puts/gets the given oob data exactly to/from the place which is described by the ooboffs and ooblen fields of the mtd_oob_ops strcuture. It's up to the caller to make sure that the byte positions are not used by the ECC placement algorithms. MTD_OOB_AUTO puts/gets the given oob data automaticaly to/from the places in the out of band area which are described by the oobfree tuples in the ecclayout data structre which is associated to the devicee. The decision whether data plus oob or oob only handling is done depends on the setting of the datbuf member of the data structure. When datbuf == NULL then the internal read/write_oob functions are selected, otherwise the read/write data routines are invoked. Tested on a few platforms with all variants. Please be aware of possible regressions for your particular device / application scenario Disclaimer: Any whining will be ignored from those who just contributed "hot air blurb" and never sat down to tackle the underlying problem of the mess in the NAND driver grown over time and the big chunk of work to fix up the existing users. The problem was not the holiness of the existing MTD interfaces. The problems was the lack of time to go for the big overhaul. It's easy to add more mess to the existing one, but it takes alot of effort to go for a real solution. Improvements and bugfixes are welcome! Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-29[MTD] NAND Replace oobinfo by ecclayoutThomas Gleixner
The nand_oobinfo structure is not fitting the newer error correction demands anymore. Replace it by struct nand_ecclayout and fixup the users all over the place. Keep the nand_oobinfo based ioctl for user space compability reasons. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-05-26[JFFS2] Switch to using an array of jffs2_raw_node_refs instead of a list.David Woodhouse
This allows us to drop another pointer from the struct jffs2_raw_node_ref, shrinking it to 8 bytes on 32-bit machines (if the TEST_TOTLEN) paranoia check is turned off, which will be committed soon). Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-24[JFFS2] Reduce visibility of raw_node_ref to upper layers of JFFS2 code.David Woodhouse
As the first step towards eliminating the ref->next_phys member and saving memory by using an _array_ of struct jffs2_raw_node_ref per eraseblock, stop the write functions from allocating their own refs; have them just _reserve_ the appropriate number instead. Then jffs2_link_node_ref() can just fill them in. Use a linked list of pre-allocated refs in the superblock, for now. Once we switch to an array, it'll just be a case of extending that array. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-13[JFFS2][XATTR] Remove 'struct list_head ilist' from jffs2_inode_cache.KaiGai Kohei
This patch can reduce 4-byte of memory usage per inode_cache. [4/10] jffs2-xattr-v5.1-04-remove_ilist_from_ic.patch Signed-off-by: KaiGai Kohei <kaigai@ak.jp.nec.com>
2006-05-13[JFFS2][XATTR] XATTR support on JFFS2 (version. 5)KaiGai Kohei
This attached patches provide xattr support including POSIX-ACL and SELinux support on JFFS2 (version.5). There are some significant differences from previous version posted at last December. The biggest change is addition of EBS(Erase Block Summary) support. Currently, both kernel and usermode utility (sumtool) can recognize xattr nodes which have JFFS2_NODETYPE_XATTR/_XREF nodetype. In addition, some bugs are fixed. - A potential race condition was fixed. - Unexpected fail when updating a xattr by same name/value pair was fixed. - A bug when removing xattr name/value pair was fixed. The fundamental structures (such as using two new nodetypes and exclusion mechanism by rwsem) are unchanged. But most of implementation were reviewed and updated if necessary. Espacially, we had to change several internal implementations related to load_xattr_datum() to avoid a potential race condition. [1/2] xattr_on_jffs2.kernel.version-5.patch [2/2] xattr_on_jffs2.utils.version-5.patch Signed-off-by: KaiGai Kohei <kaigai@ak.jp.nec.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-03Move jffs2_fs_i.h and jffs2_fs_sb.h from include/linux/ to fs/jffs2/David Woodhouse
