path: root/fs/jffs2/writev.c
2012-01-09mtd: harmonize mtd_writev usageArtem Bityutskiy
This patch makes the 'mtd_writev()' function more usable and logical. We first teach it to fall-back to the 'default_mtd_writev()' function if the MTD driver does not define its own '->writev()' method. Then we make block2mtd and JFFS2 just 'mtd_writev()' instead of 'default_mtd_writev()' function. This means we can now stop exporting 'default_mtd_writev()' and instead, export 'mtd_writev()'. This is much cleaner and more logical, as well as allows us to get read of another direct 'mtd->writev' access in JFFS2. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-01-09jffs: remove custom mtd_fake_writev functionArtem Bityutskiy
Instead, use 'default_mtd_writev()' function which MTD provides. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-01-09mtd: introduce mtd_writev interfaceArtem Bityutskiy
2012-01-09mtd: introduce mtd_write interfaceArtem Bityutskiy
2007-04-25[JFFS2] Tidy up licensing/copyright boilerplate.David Woodhouse
In particular, remove the bit in the LICENCE file about contacting Red Hat for alternative arrangements. Their errant IS department broke that arrangement a long time ago -- the policy of collecting copyright assignments from contributors came to an end when the plug was pulled on the servers hosting the project, without notice or reason. We do still dual-license it for use with eCos, with the GPL+exception licence approved by the FSF as being GPL-compatible. It's just that nobody has the right to license it differently. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-11-06[JFFS2] Call summary collector for all mtd devices with writev supportFerenc Havasi
Do the summary collection in the right place. If the device was not writebuffered but had c->mtd->writev function (e.g. blkmtd) the summary collector function was not called. Signed-off-by: Ferenc Havasi <havasi@inf.u-szeged.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-06[JFFS2] Add erase block summary support (mount time improvement)Ferenc Havasi
The goal of summary is to speed up the mount time. Erase block summary (EBS) stores summary information at the end of every (closed) erase block. It is no longer necessary to scan all nodes separetly (and read all pages of them) just read this "small" summary, where every information is stored which is needed at mount time. This summary information is stored in a JFFS2_FEATURE_RWCOMPAT_DELETE. During the mount process if there is no summary info the orignal scan process will be executed. EBS works with NAND and NOR flashes, too. There is a user space tool called sumtool to generate this summary information for a JFFS2 image. Signed-off-by: Ferenc Havasi <havasi@inf.u-szeged.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
