path: root/fs/jffs2
2010-10-25new helper: ihold()Al Viro
Clones an existing reference to inode; caller must already hold one. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-04BKL: Remove BKL from jffs2Arnd Bergmann
The BKL is only used in put_super, fill_super and remount_fs that are all three protected by the superblocks s_umount rw_semaphore. Therefore it is safe to remove the BKL entirely. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: David Woodhouse <dwmw2@infradead.org>
2010-10-04BKL: Explicitly add BKL around get_sb/fill_superJan Blunck
This patch is a preparation necessary to remove the BKL from do_new_mount(). It explicitly adds calls to lock_kernel()/unlock_kernel() around get_sb/fill_super operations for filesystems that still uses the BKL. I've read through all the code formerly covered by the BKL inside do_kern_mount() and have satisfied myself that it doesn't need the BKL any more. do_kern_mount() is already called without the BKL when mounting the rootfs and in nfsctl. do_kern_mount() calls vfs_kern_mount(), which is called from various places without BKL: simple_pin_fs(), nfs_do_clone_mount() through nfs_follow_mountpoint(), afs_mntpt_do_automount() through afs_mntpt_follow_link(). Both later functions are actually the filesystems follow_link inode operation. vfs_kern_mount() is calling the specified get_sb function and lets the filesystem do its job by calling the given fill_super function. Therefore I think it is safe to push down the BKL from the VFS to the low-level filesystems get_sb/fill_super operation. [arnd: do not add the BKL to those file systems that already don't use it elsewhere] Signed-off-by: Jan Blunck <jblunck@infradead.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Christoph Hellwig <hch@infradead.org>
2010-08-10Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (79 commits) mtd: Remove obsolete <mtd/compatmac.h> include mtd: Update copyright notices jffs2: Update copyright notices mtd-physmap: add support users can assign the probe type in board files mtd: remove redwood map driver mxc_nand: Add v3 (i.MX51) Support mxc_nand: support 8bit ecc mxc_nand: fix correct_data function mxc_nand: add V1_V2 namespace to registers mxc_nand: factor out a check_int function mxc_nand: make some internally used functions overwriteable mxc_nand: rework get_dev_status mxc_nand: remove 0xe00 offset from registers mtd: denali: Add multi connected NAND support mtd: denali: Remove set_ecc_config function mtd: denali: Remove unuseful code in get_xx_nand_para functions mtd: denali: Remove device_info_tag structure mtd: m25p80: add support for the Winbond W25Q32 SPI flash chip mtd: m25p80: add support for the Intel/Numonyx {16,32,64}0S33B SPI flash chips mtd: m25p80: add support for the EON EN25P{32, 64} SPI flash chips ... Fix up trivial conflicts in drivers/mtd/maps/{Kconfig,redwood.c} due to redwood driver removal.
2010-08-09convert remaining ->clear_inode() to ->evict_inode()Al Viro
2010-08-09jffs2: don't open-code iget_failed()Al Viro
2010-08-09check ATTR_SIZE contraints in inode_change_okChristoph Hellwig
Make sure we check the truncate constraints early on in ->setattr by adding those checks to inode_change_ok. Also clean up and document inode_change_ok to make this obvious. As a fallout we don't have to call inode_newsize_ok from simple_setsize and simplify it down to a truncate_setsize which doesn't return an error. This simplifies a lot of setattr implementations and means we use truncate_setsize almost everywhere. Get rid of fat_setsize now that it's trivial and mark ext2_setsize static to make the calling convention obvious. Keep the inode_newsize_ok in vmtruncate for now as all callers need an audit for its removal anyway. Note: setattr code in ecryptfs doesn't call inode_change_ok at all and needs a deeper audit, but that is left for later. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-08mtd: Remove obsolete <mtd/compatmac.h> includeDavid Woodhouse
2010-08-08jffs2: Update copyright noticesDavid Woodhouse
2010-07-21Fix up trivial spelling errors ('taht' -> 'that')Linus Torvalds
Pointed out by Lucas who found the new one in a comment in setup_percpu.c. And then I fixed the others that I grepped for. Reported-by: Lucas <canolucas@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-07Merge git://git.infradead.org/~dwmw2/mtd-2.6.35Linus Torvalds
* git://git.infradead.org/~dwmw2/mtd-2.6.35: jffs2: update ctime when changing the file's permission by setfacl jffs2: Fix NFS race by using insert_inode_locked() jffs2: Fix in-core inode leaks on error paths mtd: Fix NAND submenu mtd/r852: update card detect early. mtd/r852: Fixes in case of DMA timeout mtd/r852: register IRQ as last step drivers/mtd: Use memdup_user docbook: make mtd nand module init static
2010-06-06jffs2: update ctime when changing the file's permission by setfaclJan Kara
jffs2 didn't update the ctime of the file when its permission was changed. Steps to reproduce: # touch aaa # stat -c %Z aaa 1275289822 # setfacl -m 'u::x,g::x,o::x' aaa # stat -c %Z aaa 1275289822 <- unchanged But, according to the spec of the ctime, jffs2 must update it. Port of ext3 patch by Miao Xie <miaox@cn.fujitsu.com>. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-06-03jffs2: Fix NFS race by using insert_inode_locked()David Woodhouse
New inodes need to be locked as we're creating them, so they don't get used by other things (like NFSd) before they're ready. Pointed out by Al Viro. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-06-03jffs2: Fix in-core inode leaks on error pathsDavid Woodhouse
2010-05-27kill spurious reference to vmtruncatenpiggin@suse.de
Lots of filesystems calls vmtruncate despite not implementing the old ->truncate method. Switch them to use simple_setsize and add some comments about the truncate code where it seems fitting. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27drop unused dentry argument to ->fsyncChristoph Hellwig
2010-05-21jffs2: constify xattr_handlerStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-19jffs2: Stop triggering block erases from jffs2_write_super()Joakim Tjernlund
This is the culmination of this sequence of patches. By moving the block erasing from jffs2_write_super() into the GC code, we avoid huge latencies on unmount where it waits for _all_ pending blocks to be erased, and we allow better control for time-critical tasks by stopping the GC thread. Signed-off-by: Joakim Tjernlund <joakim.tjernlund@transmode.se> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-05-19jffs2: Rename jffs2_erase_pending_trigger() to jffs2_dirty_trigger()Joakim Tjernlund
Now that we do erases from GC and trigger the GC thread to do them instead of using kupdated, this function is misnamed. It's only used for triggering wbuf flush on NAND flash now. Rename it accordingly. Signed-off-by: Joakim Tjernlund <joakim.tjernlund@transmode.se> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-05-19jffs2: Use jffs2_garbage_collect_trigger() to trigger pending erasesDavid Woodhouse
This is now done in a GC pass; we don't need to trigger kupdated to do it. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-05-19jffs2: Require jffs2_garbage_collect_trigger() to be called with lock heldDavid Woodhouse
We're about to call this from a bunch of places which already hold c->erase_completion_lock, so add an assertion and change its existing callers to do the same. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-05-19jffs2: Wake GC thread when there are blocks to be erasedJoakim Tjernlund
Now that we trigger block erases from jffs2_garbage_collect_pass(), adjust jffs2_thread_should_wake() to return 1 when there are blocks to erase. Signed-off-by: Joakim Tjernlund <joakim.tjernlund@transmode.se> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-05-19jffs2: Erase pending blocks in GC pass, avoid invalid -EIO returnDavid Woodhouse
jffs2_garbage_collect_pass() would previously return -EAGAIN if it couldn't find anything to garbage collect from, and there were blocks on the erase_pending_list. If the blocks were actually in the process of being erased, though, then they wouldn't be on that list. Check for nr_erasing_blocks being non-zero instead. Fix jffs2_reserve_space() to wait for the in-progress erases to complete, when jffs2_garbage_collect_pass() returns -EAGAIN. And fix jffs2_erase_succeeded() to actually wake up the erase_wait wq that jffs2_reserve_space() is now using. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-05-19jffs2: Add 'work_done' return value from jffs2_erase_pending_blocks()Joakim Tjernlund
We're about to start calling this from the jffs2_garbage_collect_pass(), and we'll want to know whether it actually did anything or not. Signed-off-by: Joakim Tjernlund <joakim.tjernlund@transmode.se> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-05-10Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/mtd/mtdcore.c Pull in the bdi fixes and ARM platform changes that other outstanding patches depend on.
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-26Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/mtd/nand/sh_flctl.c Maxim's patch to initialise sysfs attributes depends on the patch which actually adds sysfs_attr_init().
2010-03-17jffs2: fix up rb_root initializations to use RB_ROOTVenkatesh Pallipadi
jffs2 uses rb_node = NULL; to zero rb_root. The problem with this is that 17d9ddc72fb8bba0d4f678 ("rbtree: Add support for augmented rbtrees") in the linux-next tree adds a new field to that struct which needs to be NULL as well. This patch uses RB_ROOT as the intializer so all of the relevant fields will be NULL'd. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Eric Paris <eparis@redhat.com> Acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-26Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 The SmartMedia FTL code depends on new kfifo bits from 2.6.33
2010-02-25JFFS2: avoid using C++ keyword `new' in userspace-visible headerAndrew Morton
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=14995 Reported-by: R. Diez <rdiezmail-kernelbugzilla@yahoo.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-12-16Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (38 commits) direct I/O fallback sync simplification ocfs: stop using do_sync_mapping_range cleanup blockdev_direct_IO locking make generic_acl slightly more generic sanitize xattr handler prototypes libfs: move EXPORT_SYMBOL for d_alloc_name vfs: force reval of target when following LAST_BIND symlinks (try #7) ima: limit imbalance msg Untangling ima mess, part 3: kill dead code in ima Untangling ima mess, part 2: deal with counters Untangling ima mess, part 1: alloc_file() O_TRUNC open shouldn't fail after file truncation ima: call ima_inode_free ima_inode_free IMA: clean up the IMA counts updating code ima: only insert at inode creation time ima: valid return code from ima_inode_alloc fs: move get_empty_filp() deffinition to internal.h Sanitize exec_permission_lite() Kill cached_lookup() and real_lookup() Kill path_lookup_open() ... Trivial conflicts in fs/direct-io.c
2009-12-16Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (90 commits) jffs2: Fix long-standing bug with symlink garbage collection. mtd: OneNAND: Fix test of unsigned in onenand_otp_walk() mtd: cfi_cmdset_0002, fix lock imbalance Revert "mtd: move mxcnd_remove to .exit.text" mtd: m25p80: add support for Macronix MX25L4005A kmsg_dump: fix build for CONFIG_PRINTK=n mtd: nandsim: add support for 4KiB pages mtd: mtdoops: refactor as a kmsg_dumper mtd: mtdoops: make record size configurable mtd: mtdoops: limit the maximum mtd partition size mtd: mtdoops: keep track of used/unused pages in an array mtd: mtdoops: several minor cleanups core: Add kernel message dumper to call on oopses and panics mtd: add ARM pismo support mtd: pxa3xx_nand: Fix PIO data transfer mtd: nand: fix multi-chip suspend problem mtd: add support for switching old SST chips into QRY mode mtd: fix M29W800D dev_id and uaddr mtd: don't use PF_MEMALLOC mtd: Add bad block table overrides to Davinci NAND driver ... Fixed up conflicts (mostly trivial) in drivers/mtd/devices/m25p80.c drivers/mtd/maps/pcmciamtd.c drivers/mtd/nand/pxa3xx_nand.c kernel/printk.c
2009-12-16sanitize xattr handler prototypesChristoph Hellwig
Add a flags argument to struct xattr_handler and pass it to all xattr handler methods. This allows using the same methods for multiple handlers, e.g. for the ACL methods which perform exactly the same action for the access and default ACLs, just using a different underlying attribute. With a little more groundwork it'll also allow sharing the methods for the regular user/trusted/secure handlers in extN, ocfs2 and jffs2 like it's already done for xfs in this patch. Also change the inode argument to the handlers to a dentry to allow using the handlers mechnism for filesystems that require it later, e.g. cifs. [with GFS2 bits updated by Steven Whitehouse <swhiteho@redhat.com>] Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16jffs2: Fix long-standing bug with symlink garbage collection.David Woodhouse
Ever since jffs2_garbage_collect_metadata() was first half-written in February 2001, it's been broken on architectures where 'char' is signed. When garbage collecting a symlink with target length above 127, the payload length would end up negative, causing interesting and bad things to happen. Cc: stable@kernel.org Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-12-07Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: kernel/irq/chip.c
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-30jffs2: Fix memory corruption in jffs2_read_inode_range()David Woodhouse
In 2.6.23 kernel, commit a32ea1e1f925399e0d81ca3f7394a44a6dafa12c ("Fix read/truncate race") fixed a race in the generic code, and as a side effect, now do_generic_file_read() can ask us to readpage() past the i_size. This seems to be correctly handled by the block routines (e.g. block_read_full_page() fills the page with zeroes in case if somebody is trying to read past the last inode's block). JFFS2 doesn't handle this; it assumes that it won't be asked to read pages which don't exist -- and thus that there will be at least _one_ valid 'frag' on the page it's being asked to read. It will fill any holes with the following memset: memset(buf, 0, min(end, frag->ofs + frag->size) - offset); When the 'closest smaller match' returned by jffs2_lookup_node_frag() is actually on a previous page and ends before 'offset', that results in: memset(buf, 0, <huge unsigned negative>); Hopefully, in most cases the corruption is fatal, and quickly causing random oopses, like this: root@10.0.0.4:~/ltp-fs-20090531# ./testcases/kernel/fs/ftest/ftest01 Unable to handle kernel paging request for data at address 0x00000008 Faulting instruction address: 0xc01cd980 Oops: Kernel access of bad area, sig: 11 [#1] [...] NIP [c01cd980] rb_insert_color+0x38/0x184 LR [c0043978] enqueue_hrtimer+0x88/0xc4 Call Trace: [c6c63b60] [c004f9a8] tick_sched_timer+0xa0/0xe4 (unreliable) [c6c63b80] [c0043978] enqueue_hrtimer+0x88/0xc4 [c6c63b90] [c0043a48] __run_hrtimer+0x94/0xbc [c6c63bb0] [c0044628] hrtimer_interrupt+0x140/0x2b8 [c6c63c10] [c000f8e8] timer_interrupt+0x13c/0x254 [c6c63c30] [c001352c] ret_from_except+0x0/0x14 --- Exception: 901 at memset+0x38/0x5c LR = jffs2_read_inode_range+0x144/0x17c [c6c63cf0] [00000000] (null) (unreliable) This patch fixes the issue, plus fixes all LTP tests on NAND/UBI with JFFS2 filesystem that were failing since 2.6.23 (seems like the bug above also broke the truncation). Reported-By: Anton Vorontsov <avorontsov@ru.mvista.com> Tested-By: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-30JFFS2: fix min/max confusionRoel Kluin
MAX_SUMMARY_SIZE was meant as a limit, not as a minimum Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-11-30jffs2: Fix error return in jffs2_do_read_inode_internal()Roel Kluin
The returned error should stay negative Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-09-23Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (58 commits) mtd: jedec_probe: add PSD4256G6V id mtd: OneNand support for Nomadik 8815 SoC (on NHK8815 board) mtd: nand: driver for Nomadik 8815 SoC (on NHK8815 board) m25p80: Add Spansion S25FL129P serial flashes jffs2: Use SLAB_HWCACHE_ALIGN for jffs2_raw_{dirent,inode} slabs mtd: sh_flctl: register sh_flctl using platform_driver_probe() mtd: nand: txx9ndfmc: transfer 512 byte at a time if possible mtd: nand: fix tmio_nand ecc correction mtd: nand: add __nand_correct_data helper function mtd: cfi_cmdset_0002: add 0xFF intolerance for M29W128G mtd: inftl: fix fold chain block number mtd: jedec: fix compilation problem with I28F640C3B definition mtd: nand: fix ECC Correction bug for SMC ordering for NDFC driver mtd: ofpart: Check availability of reg property instead of name property driver/Makefile: Initialize "mtd" and "spi" before "net" mtd: omap: adding DMA mode support in nand prefetch/post-write mtd: omap: add support for nand prefetch-read and post-write mtd: add nand support for w90p910 (v2) mtd: maps: add mtd-ram support to physmap_of mtd: pxa3xx_nand: add single-bit error corrections reporting ...
2009-09-22const: mark remaining export_operations constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-20Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/mtd/mtdcore.c Merged in order that I can apply the Nomadik nand/onenand support patches.
2009-09-19jffs2: Use SLAB_HWCACHE_ALIGN for jffs2_raw_{dirent,inode} slabsDavid Woodhouse
We may end up doing DMA to/from these. Until the new MTD API fixes the issues, this should stop things from falling over. Original idea from Gilles Casse <list@gcasse.net> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-09-08jffs2/jfs/xfs: switch over to 'check_acl' rather than 'permission()'Linus Torvalds
This avoids an indirect call in the VFS for each path component lookup. Well, at least as long as you own the directory in question, and the ACL check is unnecessary. Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-04jffs2: move jffs2_gcd_mtd threads to the new kthread APIGerard Lledo
Move the jffs2 garbage collecting thread to the new kthread API. Signed-off-by: Gerard Lledo <gerard.lledo@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-09-03JFFS2: add missing verify buffer allocation/deallocationMassimo Cirillo
The function jffs2_nor_wbuf_flash_setup() doesn't allocate the verify buffer if CONFIG_JFFS2_FS_WBUF_VERIFY is defined, so causing a kernel panic when that macro is enabled and the verify function is called. Similarly the jffs2_nor_wbuf_flash_cleanup() must free the buffer if CONFIG_JFFS2_FS_WBUF_VERIFY is enabled. The following patch fixes the problem. The following patch applies to 2.6.30 kernel. Signed-off-by: Massimo Cirillo <maxcir@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Cc: stable@kernel.org
2009-08-04jffs2: Fix return value from jffs2_do_readpage_nolock()Anders Grafström
This fixes "kernel BUG at fs/jffs2/file.c:251!". This pseudocode hopefully illustrates the scenario that triggers it: jffs2_write_begin { jffs2_do_readpage_nolock { jffs2_read_inode_range { jffs2_read_dnode { Data CRC 33c102e9 != calculated CRC 0ef77e7b for node at 005d42e4 return -EIO; } } ClearPageUptodate(pg); return 0; } } jffs2_write_end { BUG_ON(!PageUptodate(pg)); } Signed-off-by: Anders Grafström <grfstrm@users.sourceforge.net> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-08Remove multiple KERN_ prefixes from printk formatsJoe Perches
Commit 5fd29d6ccbc98884569d6f3105aeca70858b3e0f ("printk: clean up handling of log-levels and newlines") changed printk semantics. printk lines with multiple KERN_<level> prefixes are no longer emitted as before the patch. <level> is now included in the output on each additional use. Remove all uses of multiple KERN_<level>s in formats. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-01Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: mtd: nand: fix build failure and incorrect return from omap_wait() mtd: Use BLOCK_NIL consistently in NFTL/INFTL mtd: m25p80 timeout too short for worst-case m25p16 devices mtd: atmel_nand: Fix typo s/parititions/partitions/ mtd: cmdlineparts: Use 64-bit format when printing a debug message. mtd: maps: Remove BUS_ID_SIZE from integrator_flash jffs2: fix another potential leak on error path in scan.c
