[ Upstream commit 4fdcfab5b5537c21891e22e65996d4d0dd8ab4ca ]
free the symlink body after the same RCU delay we have for freeing the
struct inode itself, so that traversal during RCU pathwalk wouldn't step
into freed memory.
[ Upstream commit a788c5272769ddbcdbab297cf386413eeac04463 ]
jffs2_sync_fs makes the assumption that if CONFIG_JFFS2_FS_WRITEBUFFER
is defined then a write buffer is available and has been initialized.
However, this does is not the case when the mtd device has no
out-of-band buffer:
int jffs2_nand_flash_setup(struct jffs2_sb_info *c)
if (!c->mtd->oobsize)
return 0;
The resulting call to cancel_delayed_work_sync passing a uninitialized
(but zeroed) delayed_work struct forces lockdep to become disabled.
[ 90.050639] overlayfs: upper fs does not support tmpfile.
[ 90.652264] INFO: trying to register non-static key.
[ 90.662171] the code is fine but needs lockdep annotation.
[ 90.673090] turning off the locking correctness validator.
[ 90.684021] CPU: 0 PID: 1762 Comm: mount_root Not tainted 4.14.63 #0
[ 90.696672] Stack : 00000000 00000000 80d8f6a2 00000038 805f0000 80444600 8fe364f4 805dfbe7
[ 90.713349] 80563a30 000006e2 8068370c 00000001 00000000 00000001 8e2fdc48 ffffffff
[ 90.730020] 00000000 00000000 80d90000 00000000 00000106 00000000 6465746e 312e3420
[ 90.746690] 6b636f6c 03bf0000 f8000000 20676e69 00000000 80000000 00000000 8e2c2a90
[ 90.763362] 80d90000 00000001 00000000 8e2c2a90 00000003 80260dc0 08052098 80680000
[ 90.780033] ...
[ 90.784902] Call Trace:
[ 90.789793] [<8000f0d8>] show_stack+0xb8/0x148
[ 90.798659] [<8005a000>] register_lock_class+0x270/0x55c
[ 90.809247] [<8005cb64>] __lock_acquire+0x13c/0xf7c
[ 90.818964] [<8005e314>] lock_acquire+0x194/0x1dc
[ 90.828345] [<8003f27c>] flush_work+0x200/0x24c
[ 90.837374] [<80041dfc>] __cancel_work_timer+0x158/0x210
[ 90.847958] [<801a8770>] jffs2_sync_fs+0x20/0x54
[ 90.857173] [<80125cf4>] iterate_supers+0xf4/0x120
[ 90.866729] [<80158fc4>] sys_sync+0x44/0x9c
[ 90.875067] [<80014424>] syscall_common+0x34/0x58
Signed-off-by: Daniel Santos <daniel.santos@pobox.com>
Reviewed-by: Hou Tao <houtao1@huawei.com>
Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com>
commit 92e2921f7eee63450a5f953f4b15dc6210219430 upstream.
When an invalid mount option is passed to jffs2, jffs2_parse_options()
will fail and jffs2_sb_info will be freed, but then jffs2_sb_info will
be used (use-after-free) and freeed (double-free) in jffs2_kill_sb().
Fix it by removing the buggy invocation of kfree() when getting invalid
mount options.
Fixes: 92abc475d8de ("jffs2: implement mount option parsing and compression overriding")
Cc: stable@kernel.org
Signed-off-by: Hou Tao <houtao1@huawei.com>
Reviewed-by: Richard Weinberger <richard@nod.at>
[ Upstream commit 5bdd0c6f89fba430e18d636493398389dadc3b17 ]
If jffs2_iget() fails for a newly-allocated inode, jffs2_do_clear_inode()
can get called twice in the error handling path, the first call in
jffs2_iget() itself and the second through iget_failed(). This can result
to a use-after-free error in the second jffs2_do_clear_inode() call, such
as shown by the oops below wherein the second jffs2_do_clear_inode() call
was trying to free node fragments that were already freed in the first
jffs2_do_clear_inode() call.
[ 78.178860] jffs2: error: (1904) jffs2_do_read_inode_internal: CRC failed for read_inode of inode 24 at physical location 0x1fc00c
[ 78.178914] Unable to handle kernel paging request at virtual address 6b6b6b6b6b6b6b7b
[ 78.185871] pgd = ffffffc03a567000
[ 78.188794] [6b6b6b6b6b6b6b7b] *pgd=0000000000000000, *pud=0000000000000000
[ 78.194968] Internal error: Oops: 96000004 [#1] PREEMPT SMP
[ 78.513147] PC is at rb_first_postorder+0xc/0x28
[ 78.516503] LR is at jffs2_kill_fragtree+0x28/0x90 [jffs2]
[ 78.520672] pc : [<ffffff8008323d28>] lr : [<ffffff8000eb1cc8>] pstate: 60000105
[ 78.526757] sp : ffffff800cea38f0
[ 78.528753] x29: ffffff800cea38f0 x28: ffffffc01f3f8e80
[ 78.532754] x27: 0000000000000000 x26: ffffff800cea3c70
[ 78.536756] x25: 00000000dc67c8ae x24: ffffffc033d6945d
[ 78.540759] x23: ffffffc036811740 x22: ffffff800891a5b8
[ 78.544760] x21: 0000000000000000 x20: 0000000000000000
[ 78.548762] x19: ffffffc037d48910 x18: ffffff800891a588
[ 78.552764] x17: 0000000000000800 x16: 0000000000000c00
[ 78.556766] x15: 0000000000000010 x14: 6f2065646f6e695f
[ 78.560767] x13: 6461657220726f66 x12: 2064656c69616620
[ 78.564769] x11: 435243203a6c616e x10: 7265746e695f6564
[ 78.568771] x9 : 6f6e695f64616572 x8 : ffffffc037974038
[ 78.572774] x7 : bbbbbbbbbbbbbbbb x6 : 0000000000000008
[ 78.576775] x5 : 002f91d85bd44a2f x4 : 0000000000000000
[ 78.580777] x3 : 0000000000000000 x2 : 000000403755e000
[ 78.584779] x1 : 6b6b6b6b6b6b6b6b x0 : 6b6b6b6b6b6b6b6b
[ 79.038551] [<ffffff8008323d28>] rb_first_postorder+0xc/0x28
[ 79.042962] [<ffffff8000eb5578>] jffs2_do_clear_inode+0x88/0x100 [jffs2]
[ 79.048395] [<ffffff8000eb9ddc>] jffs2_evict_inode+0x3c/0x48 [jffs2]
[ 79.053443] [<ffffff8008201ca8>] evict+0xb0/0x168
[ 79.056835] [<ffffff8008202650>] iput+0x1c0/0x200
[ 79.060228] [<ffffff800820408c>] iget_failed+0x30/0x3c
[ 79.064097] [<ffffff8000eba0c0>] jffs2_iget+0x2d8/0x360 [jffs2]
[ 79.068740] [<ffffff8000eb0a60>] jffs2_lookup+0xe8/0x130 [jffs2]
[ 79.073434] [<ffffff80081f1a28>] lookup_slow+0x118/0x190
[ 79.077435] [<ffffff80081f4708>] walk_component+0xfc/0x28c
[ 79.081610] [<ffffff80081f4dd0>] path_lookupat+0x84/0x108
[ 79.085699] [<ffffff80081f5578>] filename_lookup+0x88/0x100
[ 79.089960] [<ffffff80081f572c>] user_path_at_empty+0x58/0x6c
[ 79.094396] [<ffffff80081ebe14>] vfs_statx+0xa4/0x114
[ 79.098138] [<ffffff80081ec44c>] SyS_newfstatat+0x58/0x98
[ 79.102227] [<ffffff800808354c>] __sys_trace_return+0x0/0x4
[ 79.106489] Code: d65f03c0 f9400001 b40000e1 aa0103e0 (f9400821)
The jffs2_do_clear_inode() call in jffs2_iget() is unnecessary since
iget_failed() will eventually call jffs2_do_clear_inode() if needed, so
just remove it.
Fixes: 5451f79f5f81 ("iget: stop JFFS2 from using iget() and read_inode()")
Signed-off-by: Jake Daryll Obina <jake.obina@gmail.com>
commit 1e2e547a93a00ebc21582c06ca3c6cfea2a309ee upstream.
For anything NFS-exported we do _not_ want to unlock new inode
before it has grown an alias; original set of fixes got the
ordering right, but missed the nasty complication in case of
lockdep being enabled - unlock_new_inode() does
lockdep_annotate_inode_mutex_key(inode)
which can only be done before anyone gets a chance to touch
->i_mutex. Unfortunately, flipping the order and doing
unlock_new_inode() before d_instantiate() opens a window when
mkdir can race with open-by-fhandle on a guessed fhandle, leading
to multiple aliases for a directory inode and all the breakage
that follows from that.
Correct solution: a new primitive (d_instantiate_new())
combining these two in the right order - lockdep annotate, then
d_instantiate(), then the rest of unlock_new_inode(). All
combinations of d_instantiate() with unlock_new_inode() should
be converted to that.
Cc: stable@kernel.org # 2.6.29 and later
Tested-by: Mike Marshall <hubcap@omnibond.com>
Reviewed-by: Andreas Dilger <adilger@dilger.ca>
commit c66b23c2840446a82c389e4cb1a12eb2a71fa2e4 upstream.
jffs2_fill_super() might fail to allocate jffs2_sb_info;
jffs2_kill_sb() must survive that.
Pull more vfs updates from Al Viro:
">rename2() work from Miklos + current_time() from Deepa"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fs: Replace current_fs_time() with current_time()
fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps
fs: Replace CURRENT_TIME with current_time() for inode timestamps
fs: proc: Delete inode time initializations in proc_alloc_inode()
vfs: Add current_time() api
vfs: add note about i_op->rename changes to porting
fs: rename "rename2" i_op to "rename"
vfs: remove unused i_op->rename
fs: make remaining filesystems use .rename2
libfs: support RENAME_NOREPLACE in simple_rename()
fs: support RENAME_NOREPLACE for local filesystems
ncpfs: fix unused variable warning
Pull vfs xattr updates from Al Viro:
"xattr stuff from Andreas
This completes the switch to xattr_handler ->get()/->set() from
->getxattr/->setxattr/->removexattr"
* 'work.xattr' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
vfs: Remove {get,set,remove}xattr inode operations
xattr: Stop calling {get,set,remove}xattr inode operations
vfs: Check for the IOP_XATTR flag in listxattr
xattr: Add __vfs_{get,set,remove}xattr helpers
libfs: Use IOP_XATTR flag for empty directory handling
vfs: Use IOP_XATTR flag for bad-inode handling
vfs: Add IOP_XATTR inode operations flag
vfs: Move xattr_resolve_name to the front of fs/xattr.c
ecryptfs: Switch to generic xattr handlers
sockfs: Get rid of getxattr iop
sockfs: getxattr: Fail with -EOPNOTSUPP for invalid attribute names
kernfs: Switch to generic xattr handlers
hfs: Switch to generic xattr handlers
jffs2: Remove jffs2_{get,set,remove}xattr macros
xattr: Remove unnecessary NULL attribute name check
These inode operations are no longer used; remove them.
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
When CONFIG_JFFS2_FS_XATTR is off, jffs2_xattr_handlers is defined as
NULL. With sb->s_xattr == NULL, the generic_{get,set,remove}xattr
functions produce the same result as setting the {get,set,remove}xattr
inode operations to NULL, so there is no need for these macros.
CURRENT_TIME_SEC is not y2038 safe. current_time() will
be transitioned to use 64 bit time along with vfs in a
separate patch.
There is no plan to transistion CURRENT_TIME_SEC to use
y2038 safe time interfaces.
current_time() will also be extended to use superblock
range checking parameters when range checking is introduced.
This works because alloc_super() fills in the the s_time_gran
in super block to NSEC_PER_SEC.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
Acked-by: Jan Kara <jack@suse.cz>
Generated patch:
sed -i "s/\.rename2\t/\.rename\t\t/" `git grep -wl rename2`
sed -i "s/\brename2\b/rename/g" `git grep -wl rename2`
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
This is trivial to do:
- add flags argument to foo_rename()
- check if flags doesn't have any other than RENAME_NOREPLACE
- assign foo_rename() to .rename2 instead of .rename
Filesystems converted:
affs, bfs, exofs, ext2, hfs, hfsplus, jffs2, jfs, logfs, minix, msdos,
nilfs2, omfs, reiserfs, sysvfs, ubifs, udf, ufs, vfat.
Acked-by: Boaz Harrosh <ooo@electrozaur.com>
Acked-by: Richard Weinberger <richard@nod.at>
Acked-by: Bob Copeland <me@bobcopeland.com>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Jaegeuk Kim <jaegeuk@kernel.org>
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: Mikulas Patocka <mpatocka@redhat.com>
Cc: Dave Kleikamp <shaggy@kernel.org>
Cc: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
inode_change_ok() will be resposible for clearing capabilities and IMA
extended attributes and as such will need dentry. Give it as an argument
to inode_change_ok() instead of an inode. Also rename inode_change_ok()
to setattr_prepare() to better relect that it does also some
modifications in addition to checks.
When file permissions are modified via chmod(2) and the user is not in
the owning group or capable of CAP_FSETID, the setgid bit is cleared in
inode_change_ok(). Setting a POSIX ACL via setxattr(2) sets the file
permissions as well as the new ACL, but doesn't clear the setgid bit in
a similar way; this allows to bypass the check in chmod(2). Fix that.
References: CVE-2016-7097
Reviewed-by: Jeff Layton <jlayton@redhat.com>
We always mixed in the parent pointer into the dentry name hash, but we
did it late at lookup time. It turns out that we can simplify that
lookup-time action by salting the hash with the parent pointer early
instead of late.
A few other users of our string hashes also wanted to mix in their own
pointers into the hash, and those are updated to use the same mechanism.
Hash users that don't have any particular initial salt can just use the
NULL pointer as a no-salt.
Cc: Vegard Nossum <vegard.nossum@oracle.com>
Cc: George Spelvin <linux@sciencehorizons.net>
preparation for similar switch in ->setxattr() (see the next commit for
rationale).
The rest of work.xattr stuff isn't needed for this branch
... and do not assume they are already attached to each other
... and neither can ever be NULL
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time
ago with promise that one day it will be possible to implement page
cache with bigger chunks than PAGE_SIZE.
This promise never materialized. And unlikely will.
We have many places where PAGE_CACHE_SIZE assumed to be equal to
PAGE_SIZE. And it's constant source of confusion on whether
PAGE_CACHE_* or PAGE_* constant should be used in a particular case,
especially on the border between fs and mm.
Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much
breakage to be doable.
Let's stop pretending that pages in page cache are special. They are
not.
The changes are pretty straight-forward:
- <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN};
- page_cache_get() -> get_page();
- page_cache_release() -> put_page();
This patch contains automated changes generated with coccinelle using
script below. For some reason, coccinelle doesn't patch header files.
I've called spatch for them manually.
The only adjustment after coccinelle is revert of changes to
PAGE_CAHCE_ALIGN definition: we are going to drop it later.
There are few places in the code where coccinelle didn't reach. I'll
fix them manually in a separate patch. Comments and documentation also
will be addressed with the separate patch.
virtual patch
expression E;
- E << (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
expression E;
- E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
- PAGE_CACHE_SHIFT
+ PAGE_SHIFT
- PAGE_CACHE_SIZE
+ PAGE_SIZE
- PAGE_CACHE_MASK
+ PAGE_MASK
expression E;
- PAGE_CACHE_ALIGN(E)
+ PAGE_ALIGN(E)
expression E;
- page_cache_get(E)
+ get_page(E)
expression E;
- page_cache_release(E)
+ put_page(E)
When get_acl() is called for an inode whose ACL is not cached yet, the
get_acl inode operation is called to fetch the ACL from the filesystem.
The inode operation is responsible for updating the cached acl with
set_cached_acl(). This is done without locking at the VFS level, so
another task can call set_cached_acl() or forget_cached_acl() before the
get_acl inode operation gets to calling set_cached_acl(), and then
get_acl's call to set_cached_acl() results in caching an outdate ACL.
Prevent this from happening by setting the cached ACL pointer to a
task-specific sentinel value before calling the get_acl inode operation.
Move the responsibility for updating the cached ACL from the get_acl
inode operations to get_acl(). There, only set the cached ACL if the
sentinel value hasn't changed.
The sentinel values are chosen to have odd values. Likewise, the value
of ACL_NOT_CACHED is odd. In contrast, ACL object pointers always have
an even value (ACLs are aligned in memory). This allows to distinguish
uncached ACLs values from ACL objects.
In addition, switch from guarding inode->i_acl and inode->i_default_acl
upates by the inode->i_lock spinlock to using xchg() and cmpxchg().
Filesystems that do not want ACLs returned from their get_acl inode
operations to be cached must call forget_cached_acl() to prevent the VFS
from doing so.
(Patch written by Al Viro and Andreas Gruenbacher.)
Pull MTD updates from Brian Norris:
"NAND:
- Add sunxi_nand randomizer support
- begin refactoring NAND ecclayout structs
- fix pxa3xx_nand dmaengine usage
- brcmnand: fix support for v7.1 controller
- add Qualcomm NAND controller driver
SPI NOR:
- add new ls1021a, ls2080a support to Freescale QuadSPI
- add new flash ID entries
- support bottom-block protection for Winbond flash
- support Status Register Write Protect
- remove broken QPI support for Micron SPI flash
JFFS2:
- improve post-mount CRC scan efficiency
General:
- refactor bcm63xxpart parser, to later extend for NAND
- add writebuf size parameter to mtdram
Other minor code quality improvements"
* tag 'for-linus-20160324' of git://git.infradead.org/linux-mtd: (72 commits)
mtd: nand: remove kerneldoc for removed function parameter
mtd: nand: Qualcomm NAND controller driver
dt/bindings: qcom_nandc: Add DT bindings
mtd: nand: don't select chip in nand_chip's block_bad op
mtd: spi-nor: support lock/unlock for a few Winbond chips
mtd: spi-nor: add TB (Top/Bottom) protect support
mtd: spi-nor: add SPI_NOR_HAS_LOCK flag
mtd: spi-nor: use BIT() for flash_info flags
mtd: spi-nor: disallow further writes to SR if WP# is low
mtd: spi-nor: make lock/unlock bounds checks more obvious and robust
mtd: spi-nor: silently drop lock/unlock for already locked/unlocked region
mtd: spi-nor: wait for SR_WIP to clear on initial unlock
mtd: nand: simplify nand_bch_init() usage
mtd: mtdswap: remove useless if (!mtd->ecclayout) test
mtd: create an mtd_oobavail() helper and make use of it
mtd: kill the ecclayout->oobavail field
mtd: nand: check status before reporting timeout
mtd: bcm63xxpart: give width specifier an 'int', not 'size_t'
mtd: mtdram: Add parameter for setting writebuf size
mtd: nand: pxa3xx_nand: kill unused field 'drcmr_cmd'
Pull vfs fixes from Al Viro:
"A couple of fixes: Fix for my dumb braino in ncpfs and a long-standing
breakage on recovery from failed rename() in jffs2"
jffs2: reduce the breakage on recovery from halfway failed rename()
ncpfs: fix a braino in OOM handling in ncp_fill_cache()
d_instantiate(new_dentry, old_inode) is absolutely wrong thing to
do - it will oops if new_dentry used to be positive, for starters.
What we need is d_invalidate() the target and be done with that.
Cc: stable@vger.kernel.org # v3.18+
ecclayout->oobavail is just redundant with the mtd->oobavail field.
Moreover, it prevents static const definition of ecc layouts since the
NAND framework is calculating this value based on the ecclayout->oobfree
field.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
We need to finish doing the CRC checks before we can allow writes to
happen, and we currently process the inodes in order. This means a call
to jffs2_get_ino_cache() for each possible inode# up to c->highest_ino.
There may be a lot of lookups which fail, if the inode# space is used
sparsely. And the inode# space is *often* used sparsely, if a file
system contains a lot of stuff that was put there in the original
image, followed by lots of creation and deletion of new files.
Instead of processing them numerically with a lookup each time, just
walk the hash buckets instead.
[fix locking typo reported by Dan Carpenter]
When a directory is deleted, we don't take too much care about killing off
all the dirents that belong to it — on the basis that on remount, the scan
will conclude that the directory is dead anyway.
This doesn't work though, when the deleted directory contained a child
directory which was moved *out*. In the early stages of the fs build
we can then end up with an apparent hard link, with the child directory
appearing both in its true location, and as a child of the original
directory which are this stage of the mount process we don't *yet* know
is defunct.
To resolve this, take out the early special-casing of the "directories
shall not have hard links" rule in jffs2_build_inode_pass1(), and let the
normal nlink processing happen for directories as well as other inodes.
Then later in the build process we can set ic->pino_nlink to the parent
inode#, as is required for directories during normal operaton, instead
of the nlink. And complain only *then* about hard links which are still
in evidence even after killing off all the unreachable paths.
Reported-by: Liu Song <liu.song11@zte.com.cn>
With this fix, all code paths should now be obtaining the page lock before
f->sem.
Reported-by: Szabó Tamás <sztomi89@gmail.com>
Tested-by: Thomas Betker <thomas.betker@rohde-schwarz.com>
This reverts commit 5ffd3412ae55
("jffs2: Fix lock acquisition order bug in jffs2_write_begin").
The commit modified jffs2_write_begin() to remove a deadlock with
jffs2_garbage_collect_live(), but this introduced new deadlocks found
by multiple users. page_lock() actually has to be called before
mutex_lock(&c->alloc_sem) or mutex_lock(&f->sem) because
jffs2_write_end() and jffs2_readpage() are called with the page locked,
and they acquire c->alloc_sem and f->sem, resp.
In other words, the lock order in jffs2_write_begin() was correct, and
it is the jffs2_garbage_collect_live() path that has to be changed.
Revert the commit to get rid of the new deadlocks, and to clear the way
for a better fix of the original deadlock.
Reported-by: Deng Chao <deng.chao1@zte.com.cn>
Reported-by: Ming Liu <liu.ming50@gmail.com>
Reported-by: wangzaiwei <wangzaiwei@top-vision.cn>
Signed-off-by: Thomas Betker <thomas.betker@rohde-schwarz.com>
Pull final vfs updates from Al Viro:
- The ->i_mutex wrappers (with small prereq in lustre)
- a fix for too early freeing of symlink bodies on shmem (they need to
be RCU-delayed) (-stable fodder)
- followup to dedupe stuff merged this cycle
vfs: abort dedupe loop if fatal signals are pending
make sure that freeing shmem fast symlinks is RCU-delayed
wrappers for ->i_mutex access
lustre: remove unused declaration
There are many locations that do
if (memory_was_allocated_by_vmalloc)
vfree(ptr);
else
kfree(ptr);
but kvfree() can handle both kmalloc()ed memory and vmalloc()ed memory
using is_vmalloc_addr(). Unless callers have special reasons, we can
replace this branch with kvfree(). Please check and reply if you found
problems.
Acked-by: Jan Kara <jack@suse.com>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Reviewed-by: Andreas Dilger <andreas.dilger@intel.com>
Acked-by: "Rafael J. Wysocki" <rjw@rjwysocki.net>
Acked-by: David Rientjes <rientjes@google.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Oleg Drokin <oleg.drokin@intel.com>
Cc: Boris Petkov <bp@suse.de>
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested},
inode_foo(inode) being mutex_foo(&inode->i_mutex).
Please, use those for access to ->i_mutex; over the coming cycle
->i_mutex will become rwsem, with ->lookup() done with it held
only shared.
Mark those kmem allocations that are known to be easily triggered from
userspace as __GFP_ACCOUNT/SLAB_ACCOUNT, which makes them accounted to
memcg. For the list, see below:
- threadinfo
- task_struct
- task_delay_info
- pid
- cred
- mm_struct
- vm_area_struct and vm_region (nommu)
- anon_vma and anon_vma_chain
- signal_struct
- sighand_struct
- fs_struct
- files_struct
- fdtable and fdtable->full_fds_bits
- dentry and external_name
- inode for all filesystems. This is the most tedious part, because
most filesystems overwrite the alloc_inode method.
The list is far from complete, so feel free to add more objects.
Nevertheless, it should be close to "account everything" approach and
keep most workloads within bounds. Malevolent users will be able to
breach the limit, but this was possible even with the former "account
everything" approach (simply because it did not account everything in
fact).
Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
"Generic MTD:
- populate the MTD device 'of_node' field (and get a proper 'of_node'
symlink in sysfs)
This yielded some new helper functions, and changes across a
variety of drivers
- partitioning cleanups, to prepare for better device-tree based
partitioning in the future
Eliminate a lot of boilerplate for drivers that want to use
OF-based partition parsing
The DT bindings for this didn't settle yet, so most non-cleanup
portions are deferred for a future release
NAND:
- embed a struct mtd_info inside struct nand_chip
This is really long overdue; too many drivers have to do the same
silly boilerplate to allocate and link up two "independent"
structs, when in fact, everyone is assuming there is an exact 1:1
relationship between a NAND chips struct and its underlying MTD.
This aids improved helpers and should make certain abstractions
easier in the future.
Also causes a lot of churn, helped along by some automated code
transformations
- add more core support for detecting (and "correcting") bitflips in
erased pages; requires opt-in by drivers, but at least we kill a
few bad implementations and hopefully stave off future ones
- pxa3xx_nand: cleanups, a few fixes, and PM improvements
- new JZ4780 NAND driver
SPI NOR:
- provide default erase function, for controllers that just want to
send the SECTOR_ERASE command directly
- fix some module auto-loading issues with device tree
("jedec,spi-nor")
- error handling fixes
- new Mediatek QSPI flash driver
Other:
- cfi: force valid geometry Kconfig (finally!)
This one used to trip up randconfigs occasionally, since bots
aren't deterred by big scary "advanced configuration" menus
More? Probably. See the commit logs"
* tag 'for-linus-20160112' of git://git.infradead.org/linux-mtd: (168 commits)
mtd: jz4780_nand: replace if/else blocks with switch/case
mtd: nand: jz4780: Update ecc correction error codes
mtd: nandsim: use nand_get_controller_data()
mtd: jz4780_nand: remove useless mtd->priv = chip assignment
staging: mt29f_spinand: make use of nand_set/get_controller_data() helpers
mtd: nand: make use of nand_set/get_controller_data() helpers
ARM: make use of nand_set/get_controller_data() helpers
mtd: nand: add helpers to access ->priv
mtd: nand: jz4780: driver for NAND devices on JZ4780 SoCs
mtd: nand: jz4740: remove custom 'erased check' implementation
mtd: nand: diskonchip: remove custom 'erased check' implementation
mtd: nand: davinci: remove custom 'erased check' implementation
mtd: nand: use nand_check_erased_ecc_chunk in default ECC read functions
mtd: nand: return consistent error codes in ecc.correct() implementations
doc: dt: mtd: new binding for jz4780-{nand,bch}
mtd: cfi_cmdset_0001: fixing memory leak and handling failed kmalloc
mtd: spi-nor: wait until lock/unlock operations are ready
mtd: tests: consolidate kmalloc/memset 0 call to kzalloc
jffs2: use to_delayed_work
mtd: nand: assign reasonable default name for NAND drivers
"Andreas' xattr cleanup series.
It's a followup to his xattr work that went in last cycle; -0.5KLoC"
xattr handlers: Simplify list operation
ocfs2: Replace list xattr handler operations
nfs: Move call to security_inode_listsecurity into nfs_listxattr
xfs: Change how listxattr generates synthetic attributes
tmpfs: listxattr should include POSIX ACL xattrs
tmpfs: Use xattr handler infrastructure
btrfs: Use xattr handler infrastructure
vfs: Distinguish between full xattr names and proper prefixes
posix acls: Remove duplicate xattr name definitions
gfs2: Remove gfs2_xattr_acl_chmod
vfs: Remove vfs_xattr_cmp
Use to_delayed_work() instead of open-coding it.
Signed-off-by: Geliang Tang <geliangtang@163.com>
Change the list operation to only return whether or not an attribute
should be listed. Copying the attribute names into the buffer is moved
to the callers.
Since the result only depends on the dentry and not on the attribute
name, we do not pass the attribute name to list operations.
new method: ->get_link(); replacement of ->follow_link(). The differences
are:
* inode and dentry are passed separately
* might be called both in RCU and non-RCU mode;
the former is indicated by passing it a NULL dentry.
* when called that way it isn't allowed to block
and should return ERR_PTR(-ECHILD) if it needs to be called
in non-RCU mode.
It's a flagday change - the old method is gone, all in-tree instances
converted. Conversion isn't hard; said that, so far very few instances
do not immediately bail out when called in RCU mode. That'll change
in the next commits.
Add an additional "name" field to struct xattr_handler. When the name
is set, the handler matches attributes with exactly that name. When the
prefix is set instead, the handler matches attributes with the given
prefix and with a non-empty suffix.
This patch should avoid bugs like the one fixed in commit c361016a in
the future.
Reviewed-by: James Morris <james.l.morris@oracle.com>
The xattr_handler operations are currently all passed a file system
specific flags value which the operations can use to disambiguate between
different handlers; some file systems use that to distinguish the xattr
namespace, for example. In some oprations, it would be useful to also have
access to the handler prefix. To allow that, pass a pointer to the handler
to operations instead of the flags value alone.
The vfs checks if a task has the appropriate access for get and set
operations, but it cannot do that for the list operation; the file system
must check for that itself.
Cc: linux-mtd@lists.infradead.org
Merge second patch-bomb from Andrew Morton:
- most of the rest of MM
- procfs
- lib/ updates
- printk updates
- bitops infrastructure tweaks
- checkpatch updates
- nilfs2 update
- signals
- various other misc bits: coredump, seqfile, kexec, pidns, zlib, ipc,
dma-debug, dma-mapping, ...
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (102 commits)
ipc,msg: drop dst nil validation in copy_msg
include/linux/zutil.h: fix usage example of zlib_adler32()
panic: release stale console lock to always get the logbuf printed out
dma-debug: check nents in dma_sync_sg*
dma-mapping: tidy up dma_parms default handling
pidns: fix set/getpriority and ioprio_set/get in PRIO_USER mode
kexec: use file name as the output message prefix
fs, seqfile: always allow oom killer
seq_file: reuse string_escape_str()
fs/seq_file: use seq_* helpers in seq_hex_dump()
coredump: change zap_threads() and zap_process() to use for_each_thread()
coredump: ensure all coredumping tasks have SIGNAL_GROUP_COREDUMP
signal: remove jffs2_garbage_collect_thread()->allow_signal(SIGCONT)
signal: introduce kernel_signal_stop() to fix jffs2_garbage_collect_thread()
signal: turn dequeue_signal_lock() into kernel_dequeue_signal()
signals: kill block_all_signals() and unblock_all_signals()
nilfs2: fix gcc uninitialized-variable warnings in powerpc build
nilfs2: fix gcc unused-but-set-variable warnings
MAINTAINERS: nilfs2: add header file for tracing
nilfs2: add tracepoints for analyzing reading and writing metadata files
jffs2_garbage_collect_thread() does allow_signal(SIGCONT) for no reason,
SIGCONT will wake a stopped task up even if it is ignored.
Reviewed-by: Tejun Heo <tj@kernel.org>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Markus Pargmann <mpa@pengutronix.de>
jffs2_garbage_collect_thread() can race with SIGCONT and sleep in
TASK_STOPPED state after it was already sent. Add the new helper,
kernel_signal_stop(), which does this correctly.
1. Rename dequeue_signal_lock() to kernel_dequeue_signal(). This
matches another "for kthreads only" kernel_sigaction() helper.
2. Remove the "tsk" and "mask" arguments, they are always current
and current->blocked. And it is simply wrong if tsk != current.
3. We could also remove the 3rd "siginfo_t *info" arg but it looks
potentially useful. However we can simplify the callers if we
change kernel_dequeue_signal() to accept info => NULL.
4. Remove _irqsave, it is never called from atomic context.
Reported-by: Wu Fengguang <fengguang.wu@intel.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
Need to free the memory allocated for 'fd' if failed to read all
of the remainder name.
Signed-off-by: Wei Fang <fangwei1@huawei.com>
