path: root/fs/jfs/jfs_txnmgr.c
2011-07-25jfs: clean up some compiler warningsDave Kleikamp
jfs has a few variables being set but never used. Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
2010-10-25new helper: ihold()Al Viro
Clones an existing reference to inode; caller must already hold one. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-17kill I_LOCKChristoph Hellwig
After I_SYNC was split from I_LOCK the leftover is always used together with I_NEW and thus superflous. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-05-13JFS: switch to seq_filesAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
2007-10-17introduce I_SYNCJoern Engel
I_LOCK was used for several unrelated purposes, which caused deadlock situations in certain filesystems as a side effect. One of the purposes now uses the new I_SYNC bit. Also document the various bits and change their order from historical to logical. [bunk@stusta.de: make fs/inode.c:wake_up_inode() static] Signed-off-by: Joern Engel <joern@wohnheim.fh-wedel.de> Cc: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Cc: David Chinner <dgc@sgi.com> Cc: Anton Altaparmakov <aia21@cam.ac.uk> Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-13JFS: Update print_hex_dump() syntaxDave Kleikamp
2007-06-06JFS: use print_hex_dump() rather than private dump_mem() functionDave Kleikamp
2007-06-06JFS: Whitespace cleanup and remove some dead codeDave Kleikamp
2007-05-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/shaggy/jfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/shaggy/jfs-2.6: JFS: Fix race waking up jfsIO kernel thread JFS: use __set_current_state() Copy i_flags to jfs inode flags on write JFS: document uid, gid, and umask mount options in jfs.txt
2007-04-26JFS: use __set_current_state()Milind Arun Choudhary
use __set_current_state(TASK_*) instead of current->state = TASK_* Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
2007-02-09JFS: Get rid of "may be used uninitialized" warningsDave Kleikamp
Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2007-01-17JFS: call io_schedule() instead of schedule() to avoid deadlockDave Kleikamp
The introduction of Jens Axboe's explicit i/o plugging patches introduced a deadlock in jfs. This was caused by the process initiating I/O not unplugging the queue before waiting on the commit thread. The commit thread itself was waiting for that I/O to complete. Calling io_schedule() rather than schedule() unplugs the I/O queue avoiding the deadlock, and it appears to be the right function to call in any case. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-12-07[PATCH] Add include/linux/freezer.h and move definitions from sched.hNigel Cunningham
Move process freezing functions from include/linux/sched.h to freezer.h, so that modifications to the freezer or the kernel configuration don't require recompiling just about everything. [akpm@osdl.org: fix ueagle driver] Signed-off-by: Nigel Cunningham <nigel@suspend2.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02JFS: White space cleanupDave Kleikamp
Removed trailing spaces & tabs, and spaces preceding tabs. Also a couple very minor comment cleanups. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> (cherry picked from f74156539964d7b3d5164fdf8848e6a682f75b97 commit)
2006-10-02JFS: Remove shadow variable from fs/jfs/jfs_txnmgr.c:xtLog()Tony Breeds
Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> (cherry picked from bdc3d9e5af7d9c105be734dd7b5c3f1d9425a15a commit)
2006-10-01[PATCH] fs/jfs: Conversion to generic booleanRichard Knutsson
Conversion of booleans to: generic-boolean.patch (2006-08-23) Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] fs: Removing useless castsPanagiotis Issaris
* Removing useless casts * Removing useless wrapper * Conversion from kmalloc+memset to kzalloc Signed-off-by: Panagiotis Issaris <takis@issaris.org> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/shaggy/jfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/shaggy/jfs-2.6: JFS: commit_mutex cleanups
2006-06-30typo fixes: aquire -> acquireAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-05JFS: commit_mutex cleanupsEvgeniy Dushistov
I look at code, and see that 1)locks wasn't release in the opposite order in which they were taken 2)in jfs_rename we lock new_ip, and in "error path" we didn't unlock it 3)I see strange expression: "! !" May be this worth to fix? Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-02-15JFS: Use the kthread_ APIChristoph Hellwig
Use the kthread_ API instead of opencoding lots of hairy code for kernel thread creation and teardown. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-01-24JFS: semaphore to mutex conversion.Ingo Molnar
the conversion was generated via scripts, and the result was validated automatically via a script as well. build and boot tested. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-01-08[PATCH] Fix and add EXPORT_SYMBOL(filemap_write_and_wait)OGAWA Hirofumi
This patch add EXPORT_SYMBOL(filemap_write_and_wait) and use it. See mm/filemap.c: And changes the filemap_write_and_wait() and filemap_write_and_wait_range(). Current filemap_write_and_wait() doesn't wait if filemap_fdatawrite() returns error. However, even if filemap_fdatawrite() returned an error, it may have submitted the partially data pages to the device. (e.g. in the case of -ENOSPC) <quotation> Andrew Morton writes, If filemap_fdatawrite() returns an error, this might be due to some I/O problem: dead disk, unplugged cable, etc. Given the generally crappy quality of the kernel's handling of such exceptions, there's a good chance that the filemap_fdatawait() will get stuck in D state forever. </quotation> So, this patch doesn't wait if filemap_fdatawrite() returns the -EIO. Trond, could you please review the nfs part? Especially I'm not sure, nfs must use the "filemap_fdatawrite(inode->i_mapping) == 0", or not. Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-03JFS: make special inodes play nicely with page balancingDave Kleikamp
This patch fixes up a few problems with jfs's reserved inodes. 1. There is no need for the jfs code setting the I_DIRTY bits in i_state. I am ashamed that the code ever did this, and surprised it hasn't been noticed until now. 2. Make sure special inodes are on an inode hash list. If the inodes are unhashed, __mark_inode_dirty will fail to put the inode on the superblock's dirty list, and the data will not be flushed under memory pressure. 3. Force writing journal data to disk when metapage_writepage is unable to write a metadata page due to pending journal I/O. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2005-09-20JFS: don't dereference tlck->ip from txUpdateMapDave Kleikamp
The inode pointer may no longer be valid Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2005-09-15JFS: Fix sparse warnings, including endian errorDave Kleikamp
The fix in inode.c is a real bug. It could result in undeleted, yet unconnected files on big-endian hardware. The others are trivial. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2005-08-10JFS: Fix race in txLockDave Kleikamp
TxAnchor.anon_list is protected by jfsTxnLock (TXN_LOCK), but there was a place in txLock() that was removing an entry from the list without holding the spinlock. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2005-07-27JFS: Improve sync barrier processingDave Kleikamp
Under heavy load, hot metadata pages are often locked by non-committed transactions, making them difficult to flush to disk. This prevents the sync point from advancing past a transaction that had modified the page. There is a point during the sync barrier processing where all outstanding transactions have been committed to disk, but no new transaction have been allowed to proceed. This is the best time to write the metadata. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2005-06-25[PATCH] Cleanup patch for process freezingChristoph Lameter
1. Establish a simple API for process freezing defined in linux/include/sched.h: frozen(process) Check for frozen process freezing(process) Check if a process is being frozen freeze(process) Tell a process to freeze (go to refrigerator) thaw_process(process) Restart process frozen_process(process) Process is frozen now 2. Remove all references to PF_FREEZE and PF_FROZEN from all kernel sources except sched.h 3. Fix numerous locations where try_to_freeze is manually done by a driver 4. Remove the argument that is no longer necessary from two function calls. 5. Some whitespace cleanup 6. Clear potential race in refrigerator (provides an open window of PF_FREEZE cleared before setting PF_FROZEN, recalc_sigpending does not check PF_FROZEN). This patch does not address the problem of freeze_processes() violating the rule that a task may only modify its own flags by setting PF_FREEZE. This is not clean in an SMP environment. freeze(process) is therefore not SMP safe! Signed-off-by: Christoph Lameter <christoph@lameter.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-04JFS: fix sparse warnings by moving extern declarations to headersDave Kleikamp
2005-05-02[PATCH] JFS: Write journal sync points more oftenDave Kleikamp
This patch adds jfs_syncpt, which calls lmLogSync to write sync points to the journal both in jfs_sync_fs and when sync barrier processing completes. lmLogSync accomplishes two things: 1) it pushes logged-but-dirty metadata pages to disk, and 2) it writes a sync record to the journal so that jfs_fsck doesn't need to replay more transactions than is necessary. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-02[PATCH] JFS: Support page sizes greater than 4KDave Kleikamp
jfs has never worked on architecutures where the page size was not 4K. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-02[PATCH] JFS: reduce number of synchronous transactionsDave Kleikamp
Use an inline pxd list rather than an xad list in the xadlock. When the number of extents being modified can fit with the xadlock, a transaction can be committed asynchronously. Using a list of pxd's instead of xad's allows us to fit 4 extents, rather than 2. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
