path: root/fs/jfs/jfs_unicode.c
2006-10-02JFS: White space cleanupDave Kleikamp
Removed trailing spaces & tabs, and spaces preceding tabs. Also a couple very minor comment cleanups. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> (cherry picked from f74156539964d7b3d5164fdf8848e6a682f75b97 commit)
2006-10-02[PATCH] JFS: return correct error when i-node allocation failedAkinobu Mita
I have seen confusing behavior on JFS when I injected many intentional slab allocation errors. The cp command failed with no disk space error with enough disk space. This patch makes: - change the return value in case slab allocation failures happen from -ENOSPC to -ENOMEM - ialloc() return error code so that the caller can know the reason of failures Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> (cherry picked from 2b46f77976f798f3fe800809a1d0ed38763c71c8 commit)
2005-06-23JFS: performance patchSonny Rao
Basically, we saw a large amount of time spent in the jfs_strfromUCS_le() function, mispredicting the branch inside the loop, so I just added some unlikely modifiers to the if statements to re-ordered the code. Again, these simple changes provided > 2 % on spec-sfs, so please consider it for inclusion. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
