path: root/fs/libfs.c
2011-07-19fs/libfs.c: fix simple_attr_write() on 32bit machinesAkinobu Mita
Assume that /sys/kernel/debug/dummy64 is debugfs file created by debugfs_create_x64(). # cd /sys/kernel/debug # echo 0x1234567812345678 > dummy64 # cat dummy64 0x0000000012345678 # echo 0x80000000 > dummy64 # cat dummy64 0xffffffff80000000 A value larger than INT_MAX cannot be written to the debugfs file created by debugfs_create_u64 or debugfs_create_x64 on 32bit machine. Because simple_attr_write() uses simple_strtol() for the conversion. To fix this, use simple_strtoll() instead. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-12pass default dentry_operations to mount_pseudo()Al Viro
2011-01-07fs: dcache reduce branches in lookup pathNick Piggin
Reduce some branches and memory accesses in dcache lookup by adding dentry flags to indicate common d_ops are set, rather than having to check them. This saves a pointer memory access (dentry->d_op) in common path lookup situations, and saves another pointer load and branch in cases where we have d_op but not the particular operation. Patched with: git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache remove dcache_lockNick Piggin
dcache_lock no longer protects anything. remove it. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache scale subdirsNick Piggin
Protect d_subdirs and d_child with d_lock, except in filesystems that aren't using dcache_lock for these anyway (eg. using i_mutex). Note: if we change the locking rule in future so that ->d_child protection is provided only with ->d_parent->d_lock, it may allow us to reduce some locking. But it would be an exception to an otherwise regular locking scheme, so we'd have to see some good results. Probably not worthwhile. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache scale d_unhashedNick Piggin
Protect d_unhashed(dentry) condition with d_lock. This means keeping DCACHE_UNHASHED bit in synch with hash manipulations. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_delete semanticsNick Piggin
Change d_delete from a dentry deletion notification to a dentry caching advise, more like ->drop_inode. Require it to be constant and idempotent, and not take d_lock. This is how all existing filesystems use the callback anyway. This makes fine grained dentry locking of dput and dentry lru scanning much simpler. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-10-29convert get_sb_pseudo() usersAl Viro
2010-10-25new helper: ihold()Al Viro
Clones an existing reference to inode; caller must already hold one. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25fs: add sync_inode_metadataChristoph Hellwig
Add a new helper to write out the inode using the writeback code, that is including the correct dirty bit and list manipulation. A few of filesystems already opencode this, and a lot of others should be using it instead of using write_inode_now which also writes out the data. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-09-10libfs: Fix shift bug in generic_check_addressable()Joel Becker
generic_check_addressable() erroneously shifts pages down by a block factor when it should be shifting up. To prevent overflow, we shift blocks down to pages. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-09-10ext3/ext4: Factor out disk addressability checkPatrick J. LoPresti
As part of adding support for OCFS2 to mount huge volumes, we need to check that the sector_t and page cache of the system are capable of addressing the entire volume. An identical check already appears in ext3 and ext4. This patch moves the addressability check into its own function in fs/libfs.c and modifies ext3 and ext4 to invoke it. [Edited to -EINVAL instead of BUG_ON() for bad blocksize_bits -- Joel] Signed-off-by: Patrick LoPresti <lopresti@gmail.com> Cc: linux-ext4@vger.kernel.org Acked-by: Andreas Dilger <adilger@dilger.ca> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-08-09check ATTR_SIZE contraints in inode_change_okChristoph Hellwig
Make sure we check the truncate constraints early on in ->setattr by adding those checks to inode_change_ok. Also clean up and document inode_change_ok to make this obvious. As a fallout we don't have to call inode_newsize_ok from simple_setsize and simplify it down to a truncate_setsize which doesn't return an error. This simplifies a lot of setattr implementations and means we use truncate_setsize almost everywhere. Get rid of fat_setsize now that it's trivial and mark ext2_setsize static to make the calling convention obvious. Keep the inode_newsize_ok in vmtruncate for now as all callers need an audit for its removal anyway. Note: setattr code in ecryptfs doesn't call inode_change_ok at all and needs a deeper audit, but that is left for later. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09default to simple_setattrChristoph Hellwig
With the new truncate sequence every filesystem that wants to support file size changes on disk needs to implement its own ->setattr. So instead of calling inode_setattr which supports size changes call into a simple method that doesn't support this. simple_setattr is almost what we want except that it does not mark the inode dirty after changes. Given that marking the inode dirty is a no-op for the simple in-memory filesystems that use simple_setattr currently just add the mark_inode_dirty call. Also add a WARN_ON for the presence of a truncate method to simple_setattr to catch new instances of it during the transition period. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09rename generic_setattrChristoph Hellwig
Despite its name it's now a generic implementation of ->setattr, but rather a helper to copy attributes from a struct iattr to the inode. Rename it to setattr_copy to reflect this fact. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-06-04wrong type for 'magic' argument in simple_fill_super()Roberto Sassu
It's used to superblock ->s_magic, which is unsigned long. Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Reviewed-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: Eric Paris <eparis@redhat.com> CC: stable@kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27fs: introduce new truncate sequencenpiggin@suse.de
Introduce a new truncate calling sequence into fs/mm subsystems. Rather than setattr > vmtruncate > truncate, have filesystems call their truncate sequence from ->setattr if filesystem specific operations are required. vmtruncate is deprecated, and truncate_pagecache and inode_newsize_ok helpers introduced previously should be used. simple_setattr is introduced for simple in-ram filesystems to implement the new truncate sequence. Eventually all filesystems should be converted to implement a setattr, and the default code in notify_change should go away. simple_setsize is also introduced to perform just the ATTR_SIZE portion of simple_setattr (ie. changing i_size and trimming pagecache). To implement the new truncate sequence: - filesystem specific manipulations (eg freeing blocks) must be done in the setattr method rather than ->truncate. - vmtruncate can not be used by core code to trim blocks past i_size in the event of write failure after allocation, so this must be performed in the fs code. - convert usage of helpers block_write_begin, nobh_write_begin, cont_write_begin, and *blockdev_direct_IO* to use _newtrunc postfixed variants. These avoid calling vmtruncate to trim blocks (see previous). - inode_setattr should not be used. generic_setattr is a new function to be used to copy simple attributes into the generic inode. - make use of the better opportunity to handle errors with the new sequence. Big problem with the previous calling sequence: the filesystem is not called until i_size has already changed. This means it is not allowed to fail the call, and also it does not know what the previous i_size was. Also, generic code calling vmtruncate to truncate allocated blocks in case of error had no good way to return a meaningful error (or, for example, atomically handle block deallocation). Cc: Christoph Hellwig <hch@lst.de> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27rename the generic fsync implementationsChristoph Hellwig
We don't name our generic fsync implementations very well currently. The no-op implementation for in-memory filesystems currently is called simple_sync_file which doesn't make too much sense to start with, the the generic one for simple filesystems is called simple_fsync which can lead to some confusion. This patch renames the generic file fsync method to generic_file_fsync to match the other generic_file_* routines it is supposed to be used with, and the no-op implementation to noop_fsync to make it obvious what to expect. In addition add some documentation for both methods. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27drop unused dentry argument to ->fsyncChristoph Hellwig
2010-05-10FS / libfs: Implement simple_write_to_bufferJiri Slaby
It will be used in suspend code and serves as an easy wrap around copy_from_user. Similar to simple_read_from_buffer, it takes care of transfers with proper lengths depending on available and count parameters and advances ppos appropriately. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-03libfs: Unexport and kill simple_prepare_writeBoaz Harrosh
Remove the EXPORT_UNUSED_SYMBOL of simple_prepare_write Collapse simple_prepare_write into it's only caller, though making it simpler and clearer to understand. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-03-03libfs: Open code simple_commit_write into only userBoaz Harrosh
* simple_commit_write was only called by simple_write_end. Open coding it makes it tiny bit less heavy on the arithmetic and much more readable. * While at it use zero_user() for clearing a partial page. * While at it add a docbook comment for simple_write_end. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16libfs: move EXPORT_SYMBOL for d_alloc_nameH Hartley Sweeten
The EXPORT_SYMBOL for d_alloc_name is in fs/libfs.c but the function is in fs/dcache.c. Move the EXPORT_SYMBOL to the line immediately after the closing function brace line in fs/dcache.c as mentioned in Documentation/CodingStyle. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-09-24libfs: return error code on failed attr setWu Fengguang
Currently all simple_attr.set handlers return 0 on success and negative codes on error. Fix simple_attr_write() to return these error codes. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Cc: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-09-24libfs: make simple_read_from_buffer conventionalSteven Rostedt
Impact: have simple_read_from_buffer conform to standards It was brought to my attention by Andrew Morton, Theodore Tso, and H. Peter Anvin that a read from userspace should only return -EFAULT if nothing was actually read. Looking at the simple_read_from_buffer I noticed that this function does not conform to that rule. This patch fixes that function. [akpm@linux-foundation.org: simplification suggested by hpa] [hpa@zytor.com: fix count==0 handling] Signed-off-by: Steven Rostedt <srostedt@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-08-18vfs: make get_sb_pseudo set s_maxbytes to value that can be cast to signedJeff Layton
get_sb_pseudo sets s_maxbytes to ~0ULL which becomes negative when cast to a signed value. Fix it to use MAX_LFS_FILESIZE which casts properly to a positive signed value. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Steve French <smfrench@gmail.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Robert Love <rlove@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11New helper - simple_fsync()Al Viro
writes associated buffers, then does sync_inode() to write the inode itself (and to make it clean). Depends on ->write_inode() honouring the second argument. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-05-09Convert obvious places to deactivate_locked_super()Al Viro
2009-04-03kmemtrace, fs: uninline simple_transaction_set()Ingo Molnar
Impact: cleanup We want to remove percpu.h from rcupdate.h (for upcoming kmemtrace changes), but this is not possible currently without breaking the build because fs.h has an implicit include file depedency: it uses PAGE_SIZE but does not include asm/page.h which defines it. This problem gets masked in practice because most fs.h using sites use rcupreempt.h (and other headers) which includes percpu.h which brings in asm/page.h indirectly. We cannot add asm/page.h to asm/fs.h because page.h is not an exported header. Move simple_transaction_set() to the other simple-transaction file helpers in fs/libfs.c. This removes the include file hell and also reduces kernel size a bit. Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: paulmck@linux.vnet.ibm.com LKML-Reference: <1237898630.25315.83.camel@penberg-laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-27vfs: simple_set_mnt() should return voidSukadev Bhattiprolu
simple_set_mnt() is defined as returning 'int' but always returns 0. Callers assume simple_set_mnt() never fails and don't properly cleanup if it were to _ever_ fail. For instance, get_sb_single() and get_sb_nodev() should: up_write(sb->s_unmount); deactivate_super(sb); if simple_set_mnt() fails. Since simple_set_mnt() never fails, would be cleaner if it did not return anything. [akpm@linux-foundation.org: fix build] Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-27constify dentry_operations: restAl Viro
2009-01-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: inotify: fix type errors in interfaces fix breakage in reiserfs_new_inode() fix the treatment of jfs special inodes vfs: remove duplicate code in get_fs_type() add a vfs_fsync helper sys_execve and sys_uselib do not call into fsnotify zero i_uid/i_gid on inode allocation inode->i_op is never NULL ntfs: don't NULL i_op isofs check for NULL ->i_op in root directory is dead code affs: do not zero ->i_op kill suid bit only for regular files vfs: lseek(fd, 0, SEEK_CUR) race condition
2009-01-05zero i_uid/i_gid on inode allocationAl Viro
... and don't bother in callers. Don't bother with zeroing i_blocks, while we are at it - it's already been zeroed. i_mode is not worth the effort; it has no common default value. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-04fs: symlink write_begin allocation context fixNick Piggin
With the write_begin/write_end aops, page_symlink was broken because it could no longer pass a GFP_NOFS type mask into the point where the allocations happened. They are done in write_begin, which would always assume that the filesystem can be entered from reclaim. This bug could cause filesystem deadlocks. The funny thing with having a gfp_t mask there is that it doesn't really allow the caller to arbitrarily tinker with the context in which it can be called. It couldn't ever be GFP_ATOMIC, for example, because it needs to take the page lock. The only thing any callers care about is __GFP_FS anyway, so turn that into a single flag. Add a new flag for write_begin, AOP_FLAG_NOFS. Filesystems can now act on this flag in their write_begin function. Change __grab_cache_page to accept a nofs argument as well, to honour that flag (while we're there, change the name to grab_cache_page_write_begin which is more instructive and does away with random leading underscores). This is really a more flexible way to go in the end anyway -- if a filesystem happens to want any extra allocations aside from the pagecache ones in ints write_begin function, it may now use GFP_KERNEL (rather than GFP_NOFS) for common case allocations (eg. ocfs2_alloc_write_ctxt, for a random example). [kosaki.motohiro@jp.fujitsu.com: fix ubifs] [kosaki.motohiro@jp.fujitsu.com: fix fuse] Signed-off-by: Nick Piggin <npiggin@suse.de> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: <stable@kernel.org> [2.6.28.x] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> [ Cleaned up the calling convention: just pass in the AOP flags untouched to the grab_cache_page_write_begin() function. That just simplifies everybody, and may even allow future expansion of the logic. - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-30fs: remove prepare_write/commit_writeNick Piggin
Nothing uses prepare_write or commit_write. Remove them from the tree completely. [akpm@linux-foundation.org: schedule simple_prepare_write() for unexporting] Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23[PATCH] new helper: d_obtain_aliasChristoph Hellwig
The calling conventions of d_alloc_anon are rather unfortunate for all users, and it's name is not very descriptive either. Add d_obtain_alias as a new exported helper that drops the inode reference in the failure case, too and allows to pass-through NULL pointers and inodes to allow for tail-calls in the export operations. Incidentally this helper already existed as a private function in libfs.c as exportfs_d_alloc so kill that one and switch the callers to d_obtain_alias. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-30VFS: increase pseudo-filesystem block size to PAGE_SIZEAlex Nixon
This commit: commit ba52de123d454b57369f291348266d86f4b35070 Author: Theodore Ts'o <tytso@mit.edu> Date: Wed Sep 27 01:50:49 2006 -0700 [PATCH] inode-diet: Eliminate i_blksize from the inode structure caused the block size used by pseudo-filesystems to decrease from PAGE_SIZE to 1024 leading to a doubling of the number of context switches during a kernbench run. Signed-off-by: Alex Nixon <Alex.Nixon@citrix.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Ian Campbell <Ian.Campbell@eu.citrix.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Hugh Dickins <hugh@veritas.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-04add kernel-doc for simple_read_from_buffer and memory_read_from_bufferAkinobu Mita
Add kernel-doc comments describing simple_read_from_buffer and memory_read_from_buffer. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Christoph Hellwig <hch@lst.de> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06introduce memory_read_from_buffer()Akinobu Mita
This patch introduces memory_read_from_buffer(). The only difference between memory_read_from_buffer() and simple_read_from_buffer() is which address space the function copies to. simple_read_from_buffer copies to user space memory. memory_read_from_buffer copies to normal memory. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Doug Warzecha <Douglas_Warzecha@dell.com> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Matt Domsch <Matt_Domsch@dell.com> Cc: Abhay Salunke <Abhay_Salunke@dell.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Markus Rechberger <markus.rechberger@amd.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Bob Moore <robert.moore@intel.com> Cc: Thomas Renninger <trenn@suse.de> Cc: Len Brown <lenb@kernel.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Cc: Michael Holzheu <holzheu@de.ibm.com> Cc: Brian King <brking@us.ibm.com> Cc: James E.J. Bottomley <James.Bottomley@HansenPartnership.com> Cc: Andrew Vasquez <linux-driver@qlogic.com> Cc: Seokmann Ju <seokmann.ju@qlogic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08libfs: rename simple_attr_close to simple_attr_releaseChristoph Hellwig
simple_attr_close implementes ->release so it should be named accordingly. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: <stefano.brivio@polimi.it> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Greg KH <greg@kroah.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08libfs: make simple attributes interruptibleChristoph Hellwig
Use mutex_lock_interruptible in simple_attr_read/write. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: <stefano.brivio@polimi.it> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Greg KH <greg@kroah.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08libfs: allow error return from simple attributesChristoph Hellwig
Sometimes simple attributes might need to return an error, e.g. for acquiring a mutex interruptibly. In fact we have that situation in spufs already which is the original user of the simple attributes. This patch merged the temporarily forked attributes in spufs back into the main ones and allows to return errors. [akpm@linux-foundation.org: build fix] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: <stefano.brivio@polimi.it> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Greg KH <greg@kroah.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05Pagecache zeroing: zero_user_segment, zero_user_segments and zero_userChristoph Lameter
Simplify page cache zeroing of segments of pages through 3 functions zero_user_segments(page, start1, end1, start2, end2) Zeros two segments of the page. It takes the position where to start and end the zeroing which avoids length calculations and makes code clearer. zero_user_segment(page, start, end) Same for a single segment. zero_user(page, start, length) Length variant for the case where we know the length. We remove the zero_user_page macro. Issues: 1. Its a macro. Inline functions are preferable. 2. The KM_USER0 macro is only defined for HIGHMEM. Having to treat this special case everywhere makes the code needlessly complex. The parameter for zeroing is always KM_USER0 except in one single case that we open code. Avoiding KM_USER0 makes a lot of code not having to be dealing with the special casing for HIGHMEM anymore. Dealing with kmap is only necessary for HIGHMEM configurations. In those configurations we use KM_USER0 like we do for a series of other functions defined in highmem.h. Since KM_USER0 is depends on HIGHMEM the existing zero_user_page function could not be a macro. zero_user_* functions introduced here can be be inline because that constant is not used when these functions are called. Also extract the flushing of the caches to be outside of the kmap. [akpm@linux-foundation.org: fix nfs and ntfs build] [akpm@linux-foundation.org: fix ntfs build some more] Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Steven French <sfrench@us.ibm.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: <linux-ext4@vger.kernel.org> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: David Chinner <dgc@sgi.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Steven French <sfrench@us.ibm.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-22exportfs: add new methodsChristoph Hellwig
Add the guts for the new filesystem API to exportfs. There's now a fh_to_dentry method that returns a dentry for the object looked for given a filehandle fragment, and a fh_to_parent operation that returns the dentry for the encoded parent directory in case the file handle contains it. There are default implementations for these methods that only take a callback for an nfs-enhanced iget variant and implement the rest of the semantics. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: <linux-ext4@vger.kernel.org> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: David Chinner <dgc@sgi.com> Cc: Timothy Shimmin <tes@sgi.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17make fs/libfs.c:simple_commit_write() staticAdrian Bunk
simple_commit_write() can now become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fs: introduce write_begin, write_end, and perform_write aopsNick Piggin
These are intended to replace prepare_write and commit_write with more flexible alternatives that are also able to avoid the buffered write deadlock problems efficiently (which prepare_write is unable to do). [mark.fasheh@oracle.com: API design contributions, code review and fixes] [akpm@linux-foundation.org: various fixes] [dmonakhov@sw.ru: new aop block_write_begin fix] Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Dmitriy Monakhov <dmonakhov@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09fs/libfs.c: >80 columns line break fixRonni Nielsen
Signed-off-by: Ronni Nielsen <theronni@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-08inode numbering: change libfs sb creation routines to avoid collisions with ↵Jeff Layton
their root inodes This patch makes it so that simple_fill_super and get_sb_pseudo assign their root inodes to be number 1. It also fixes up a couple of callers of simple_fill_super that were passing in files arrays that had an index at number 1, and adds a warning for any caller that sends in such an array. It would have been nice to have made it so that it wasn't possible to make such a collision, but some callers need to be able to control what inode number their entries get, so I think this is the best that can be done. Signed-off-by: Jeff Layton <jlayton@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-05[PATCH] shmem and simple const super_operationsHugh Dickins
shmem's super_operations were missed from the recent const-ification; and simple_fill_super()'s, which can share with get_sb_pseudo()'s. Signed-off-by: Hugh Dickins <hugh@veritas.com> Acked-by: Josef 'Jeff' Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
