path: root/fs/lockd/svclock.c
2011-07-20locks: rename lock-manager opsJ. Bruce Fields
Both the filesystem and the lock manager can associate operations with a lock. Confusingly, one of them (fl_release_private) actually has the same name in both operation structures. It would save some confusion to give the lock-manager ops different names. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-12-16lockd: Split nlm_release_call()Chuck Lever
The nlm_release_call() function is invoked from both the server and the client side. We're about to introduce a distinct server- and client-side nlm_release_host(), so nlm_release_call() must first be split into a client-side and a server-side version. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16lockd: Move nlmdbg_cookie2a() to svclock.cChuck Lever
Clean up. nlmdbg_cookie2a() is used only in svclock.c. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27lockd: fix nlmsvc_notify_blocked lockingJ. Bruce Fields
nlmsvc_notify_blocked walks the nlm_blocked list, which requires nlm_blocked_lock. Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-09-22lockd: Mostly remove BKL from the serverBryan Schumaker
This patch removes all but one call to lock_kernel() from the server. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-09-22const: make lock_manager_operations constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-24lockd: call locks_release_private to cleanup per-filesystem stateFelix Blyakher
For every lock request lockd creates a new file_lock object in nlmsvc_setgrantargs() by copying the passed in file_lock with locks_copy_lock(). A filesystem can attach it's own lock_operations vector to the file_lock. It has to be cleaned up at the end of the file_lock's life. However, lockd doesn't do it today, yet it asserts in nlmclnt_release_lockargs() that the per-filesystem state is clean. This patch fixes it by exporting locks_release_private() and adding it to nlmsvc_freegrantargs(), to be symmetrical to creating a file_lock in nlmsvc_setgrantargs(). Signed-off-by: Felix Blyakher <felixb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-03-18lockd: clean up blocking lock cases of nlsmvc_lock()Miklos Szeredi
No change in behavior, just rearranging the switch so that we break out of the switch if and only if we're in the wait case. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-02-09lockd: fix regression in lockd's handling of blocked locksJ. Bruce Fields
If a client requests a blocking lock, is denied, then requests it again, then here in nlmsvc_lock() we will call vfs_lock_file() without FL_SLEEP set, because we've already queued a block and don't need the locks code to do it again. But that means vfs_lock_file() will return -EAGAIN instead of FILE_LOCK_DENIED. So we still need to translate that -EAGAIN return into a nlm_lck_blocked error in this case, and put ourselves back on lockd's block list. The bug was introduced by bde74e4bc64415b1 "locks: add special return value for asynchronous locks". Thanks to Frank van Maarseveen for the report; his original test case was essentially for i in `seq 30`; do flock /nfsmount/foo sleep 10 & done Tested-by: Frank van Maarseveen <frankvm@frankvm.com> Reported-by: Frank van Maarseveen <frankvm@frankvm.com> Cc: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-10-03lockd: reject reclaims outside the grace periodJ. Bruce Fields
The current lockd does not reject reclaims that arrive outside of the grace period. Accepting a reclaim means promising to the client that no conflicting locks were granted since last it held the lock. We can meet that promise if we assume the only lockers are nfs clients, and that they are sufficiently well-behaved to reclaim only locks that they held before, and that only reclaim locks have been permitted so far. Once we leave the grace period (and start permitting non-reclaims), we can no longer keep that promise. So we must start rejecting reclaims at that point. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-10-03lockd: move grace period checks to common codeJ. Bruce Fields
Do all the grace period checks in svclock.c. This simplifies the code a bit, and will ease some later changes. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-07-25locks: add special return value for asynchronous locksMiklos Szeredi
Use a special error value FILE_LOCK_DEFERRED to mean that a locking operation returned asynchronously. This is returned by posix_lock_file() for sleeping locks to mean that the lock has been queued on the block list, and will be woken up when it might become available and needs to be retried (either fl_lmops->fl_notify() is called or fl_wait is woken up). f_op->lock() to mean either the above, or that the filesystem will call back with fl_lmops->fl_grant() when the result of the locking operation is known. The filesystem can do this for sleeping as well as non-sleeping locks. This is to make sure, that return values of -EAGAIN and -EINPROGRESS by filesystems are not mistaken to mean an asynchronous locking. This also makes error handling in fs/locks.c and lockd/svclock.c slightly cleaner. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: David Teigland <teigland@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20Merge branch 'for-2.6.27' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.27' of git://linux-nfs.org/~bfields/linux: (51 commits) nfsd: nfs4xdr.c do-while is not a compound statement nfsd: Use C99 initializers in fs/nfsd/nfs4xdr.c lockd: Pass "struct sockaddr *" to new failover-by-IP function lockd: get host reference in nlmsvc_create_block() instead of callers lockd: minor svclock.c style fixes lockd: eliminate duplicate nlmsvc_lookup_host call from nlmsvc_lock lockd: eliminate duplicate nlmsvc_lookup_host call from nlmsvc_testlock lockd: nlm_release_host() checks for NULL, caller needn't file lock: reorder struct file_lock to save space on 64 bit builds nfsd: take file and mnt write in nfs4_upgrade_open nfsd: document open share bit tracking nfsd: tabulate nfs4 xdr encoding functions nfsd: dprint operation names svcrdma: Change WR context get/put to use the kmem cache svcrdma: Create a kmem cache for the WR contexts svcrdma: Add flush_scheduled_work to module exit function svcrdma: Limit ORD based on client's advertised IRD svcrdma: Remove unused wait q from svcrdma_xprt structure svcrdma: Remove unneeded spin locks from __svc_rdma_free svcrdma: Add dma map count and WARN_ON ...
2008-07-15SUNRPC: Remove the BKL from the callback functionsTrond Myklebust
Push it into those callback functions that actually need it. Note that all the NFS operations use their own locking, so don't need the BKL. Ditto for the rpcbind client. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-07-15lockd: get host reference in nlmsvc_create_block() instead of callersJ. Bruce Fields
It may not be obvious (till you look at the definition of nlm_alloc_call()) that a function like nlmsvc_create_block() should consume a reference on success or failure, so I find it clearer if it takes the reference it needs itself. And both callers already do this immediately before the call anyway. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-07-15lockd: minor svclock.c style fixesJ. Bruce Fields
2008-07-15lockd: eliminate duplicate nlmsvc_lookup_host call from nlmsvc_lockJeff Layton
nlmsvc_lock calls nlmsvc_lookup_host to find a nlm_host struct. The callers of this function, however, call nlmsvc_retrieve_args or nlm4svc_retrieve_args, which also return a nlm_host struct. Change nlmsvc_lock to take a host arg instead of calling nlmsvc_lookup_host itself and change the callers to pass a pointer to the nlm_host they've already found. Since nlmsvc_testlock() now just uses the caller's reference, we no longer need to get or release it. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-07-15lockd: eliminate duplicate nlmsvc_lookup_host call from nlmsvc_testlockJeff Layton
nlmsvc_testlock calls nlmsvc_lookup_host to find a nlm_host struct. The callers of this functions, however, call nlmsvc_retrieve_args or nlm4svc_retrieve_args, which also return a nlm_host struct. Change nlmsvc_testlock to take a host arg instead of calling nlmsvc_lookup_host itself and change the callers to pass a pointer to the nlm_host they've already found. We take a reference to host in the place where nlmsvc_testlock() previous did a new lookup, so the reference counting is unchanged from before. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-04-30fs: replace remaining __FUNCTION__ occurrencesHarvey Harrison
2008-04-25locks: don't call ->copy_lock methods on return of conflicting locksJ. Bruce Fields
The file_lock structure is used both as a heavy-weight representation of an active lock, with pointers to reference-counted structures, etc., and as a simple container for parameters that describe a file lock. The conflicting lock returned from __posix_lock_file is an example of the latter; so don't call the filesystem or lock manager callbacks when copying to it. This also saves the need for an unnecessary locks_init_lock in the nfsv4 server. Thanks to Trond for pointing out the error. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-04-23lockd: Fix stale nlmsvc_unlink_block commentJ. Bruce Fields
As of 5996a298da43a03081e9ba2116983d173001c862 ("NLM: don't unlock on cancel requests") we no longer unlock in this case, so the comment is no longer accurate. Thanks to Stuart Friedberg for pointing out the inconsistency. Cc: Stuart Friedberg <sfriedberg@hp.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-04-23NLM: Convert lockd to use kthreadsJeff Layton
Have lockd_up start lockd using kthread_run. With this change, lockd_down now blocks until lockd actually exits, so there's no longer need for the waitqueue code at the end of lockd_down. This also means that only one lockd can be running at a time which simplifies the code within lockd's main loop. This also adds a check for kthread_should_stop in the main loop of nlmsvc_retry_blocked and after that function returns. There's no sense continuing to retry blocks if lockd is coming down anyway. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-10NLM: don't requeue block if it was invalidated while GRANT_MSG was in flightJeff Layton
It's possible for lockd to catch a SIGKILL while a GRANT_MSG callback is in flight. If this happens we don't want lockd to insert the block back into the nlm_blocked list. This helps that situation, but there's still a possible race. Fixing that will mean adding real locking for nlm_blocked. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-10NLM: don't reattempt GRANT_MSG when there is already an RPC in flightJeff Layton
With the current scheme in nlmsvc_grant_blocked, we can end up with more than one GRANT_MSG callback for a block in flight. Right now, we requeue the block unconditionally so that a GRANT_MSG callback is done again in 30s. If the client is unresponsive, it can take more than 30s for the call already in flight to time out. There's no benefit to having more than one GRANT_MSG RPC queued up at a time, so put it on the list with a timeout of NLM_NEVER before doing the RPC call. If the RPC call submission fails, we requeue it with a short timeout. If it works, then nlmsvc_grant_callback will end up requeueing it with a shorter timeout after it completes. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01Leak in nlmsvc_testlock for async GETFL caseOleg Drokin
Fix nlm_block leak for the case of supplied blocking lock info. Signed-off-by: Oleg Drokin <green@linuxhacker.ru> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01lockd: fix a leak in nlmsvc_testlock asynchronous request handlingOleg Drokin
Without the patch, there is a leakage of nlmblock structure refcount that holds a reference nlmfile structure, that holds a reference to struct file, when async GETFL is used (-EINPROGRESS return from file_ops->lock()), and also in some error cases. Fix up a style nit while we're here. Signed-off-by: Oleg Drokin <green@linuxhacker.ru> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2007-10-09NLM: Fix a memory leak in nlmsvc_testlockTrond Myklebust
The recent fix for a circular lock dependency unfortunately introduced a potential memory leak in the event where the call to nlmsvc_lookup_host fails for some reason. Thanks to Roel Kluin for spotting this. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-26NLM: Fix a circular lock dependency in lockdTrond Myklebust
The problem is that the garbage collector for the 'host' structures nlm_gc_hosts(), holds nlm_host_mutex while calling down to nlmsvc_mark_resources, which, eventually takes the file->f_mutex. We cannot therefore call nlmsvc_lookup_host() from within nlmsvc_create_block, since the caller will already hold file->f_mutex, so the attempt to grab nlm_host_mutex may deadlock. Fix the problem by calling nlmsvc_lookup_host() outside the file->f_mutex. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26lockd and nfsd endianness annotation fixesAl Viro
2007-05-06lockd: add code to handle deferred lock requestsMarc Eshel
Rewrite nlmsvc_lock() to use the asynchronous interface. As with testlock, we answer nlm requests in nlmsvc_lock by first looking up the block and then using the results we find in the block if B_QUEUED is set, and calling vfs_lock_file() otherwise. If this a new lock request and we get -EINPROGRESS return on a non-blocking request then we defer the request. Also modify nlmsvc_unlock() to call the filesystem method if appropriate. Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2007-05-06lockd: always preallocate block in nlmsvc_lock()Marc Eshel
Normally we could skip ever having to allocate a block in the case where the client asks for a non-blocking lock, or asks for a blocking lock that succeeds immediately. However we're going to want to always look up a block first in order to check whether we're revisiting a deferred lock call, and to be prepared to handle the case where the filesystem returns -EINPROGRESS--in that case we want to make sure the lock we've given the filesystem is the one embedded in the block that we'll use to track the deferred request. Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2007-05-06lockd: handle test_lock deferralsMarc Eshel
Rewrite nlmsvc_testlock() to use the new asynchronous interface: instead of immediately doing a posix_test_lock(), we first look for a matching block. If the subsequent test_lock returns anything other than -EINPROGRESS, we then remove the block we've found and return the results. If it returns -EINPROGRESS, then we defer the lock request. In the case where the block we find in the first step has B_QUEUED set, we bypass the vfs_test_lock entirely, instead using the block to decide how to respond: with nlm_lck_denied if B_TIMED_OUT is set. with nlm_granted if B_GOT_CALLBACK is set. by dropping if neither B_TIMED_OUT nor B_GOT_CALLBACK is set Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2007-05-06lockd: pass cookie in nlmsvc_testlockMarc Eshel
Change NLM internal interface to pass more information for test lock; we need this to make sure the cookie information is pushed down to the place where we do request deferral, which is handled for testlock by the following patch. Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2007-05-06lockd: handle fl_grant callbacksMarc Eshel
Add code to handle file system callback when the lock is finally granted. Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2007-05-06lockd: save lock state on deferralMarc Eshel
We need to keep some state for a pending asynchronous lock request, so this patch adds that state to struct nlm_block. This also adds a function which defers the request, by calling rqstp->rq_chandle.defer and storing the resulting deferred request in a nlm_block structure which we insert into lockd's global block list. That new function isn't called yet, so it's dead code until a later patch. Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2007-05-06locks: allow {vfs,posix}_lock_file to return conflicting lockMarc Eshel
The nfsv4 protocol's lock operation, in the case of a conflict, returns information about the conflicting lock. It's unclear how clients can use this, so for now we're not going so far as to add a filesystem method that can return a conflicting lock, but we may as well return something in the local case when it's easy to. Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu>
2007-05-06locks: give posix_test_lock same interface as ->lockMarc Eshel
posix_test_lock() and ->lock() do the same job but have gratuitously different interfaces. Modify posix_test_lock() so the two agree, simplifying some code in the process. Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu>
2007-02-03NLM: Fix double free in __nlm_async_callTrond Myklebust
rpc_call_async() will always call rpc_release_calldata(), so it is an error for __nlm_async_call() to do so as well. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-12-13[PATCH] lockd endianness annotationsAl Viro
Annotated, all places switched to keeping status net-endian. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] struct path: convert lockdJosef Sipek
2006-10-20[PATCH] lockd endianness annotationsAl Viro
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] Convert lockd to use the newer mutex instead of the older semaphoreNeil Brown
Both the (recently introduces) nsm_sema and the older f_sema are converted over. Cc: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: match GRANTED_RES replies using cookiesOlaf Kirch
When we send a GRANTED_MSG call, we current copy the NLM cookie provided in the original LOCK call - because in 1996, some broken clients seemed to rely on this bug. However, this means the cookies are not unique, so that when the client's GRANTED_RES message comes back, we cannot simply match it based on the cookie, but have to use the client's IP address in addition. Which breaks when you have a multi-homed NFS client. The X/Open spec explicitly mentions that clients should not expect the same cookie; so one may hope that any clients that were broken in 1996 have either been fixed or rendered obsolete. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: lockd: make nlm_traverse_* more flexibleOlaf Kirch
This patch makes nlm_traverse{locks,blocks,shares} and friends use a function pointer rather than a "action" enum. This function pointer is given two nlm_hosts (one given by the caller, the other taken from the lock/block/share currently visited), and is free to do with them as it wants. If it returns a non-zero value, the lockd/block/share is released. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: lockd: Change list of blocked list to list_nodeOlaf Kirch
This patch changes the nlm_blocked list to use a list_node instead of homegrown linked list handling. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: when looking up a lockd host, pass hostname & lengthOlaf Kirch
This patch adds the peer's hostname (and name length) to all calls to nlm*_lookup_host functions. A subsequent patch will make use of these (is requested by a sysctl). Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] namespaces: utsname: switch to using uts namespacesSerge E. Hallyn
Replace references to system_utsname to the per-process uts namespace where appropriate. This includes things like uname. Changes: Per Eric Biederman's comments, use the per-process uts namespace for ELF_PLATFORM, sunrpc, and parts of net/ipv4/ipconfig.c [jdike@addtoit.com: UML fix] [clg@fr.ibm.com: cleanup] [akpm@osdl.org: build fix] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-03NLM/lockd: remove b_doneJ. Bruce Fields
We never actually set the b_done field any more; it's always zero. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> (cherry picked from af8412d4283ef91356e65e0ed9b025b376aebded commit)
