path: root/fs/lockd
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-08lockd: don't clear sm_monitored on nsm_reboot_lookupJeff Layton
When lockd gets a notify downcall from statd, it'll search its hosts cache and then clear the sm_monitored bit on the host it finds. The idea is apparently to make lockd redo a SM_MON on the next lock request. This is unnecessary and causes the kernel's NSM cache to go out of sync with statd. statd doesn't stop monitoring a host when it gets a SM_NOTIFY and there's no guarantee that another lock will occur after the reclaim and before the unmount. In that event, no SM_UNMON will occur. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2010-02-08lockd: release reference to nsm_handle in nlm_host_rebootedJeff Layton
nsm_reboot_lookup takes a reference to the nsm_handle that it returns, but nlm_host_rebooted never releases that reference. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2010-01-26SUNRPC: Bury "#ifdef IPV6" in svc_create_xprt()Chuck Lever
Clean up: Bruce observed we have more or less common logic in each of svc_create_xprt()'s callers: the check to create an IPv6 RPC listener socket only if CONFIG_IPV6 is set. I'm about to add another case that does just the same. If we move the ifdefs into __svc_xpo_create(), then svc_create_xprt() call sites can get rid of the "#ifdef" ugliness, and can use the same logic with or without IPv6 support available in the kernel. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-12-16Merge branch 'for-2.6.33' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.33' of git://linux-nfs.org/~bfields/linux: (42 commits) nfsd: remove pointless paths in file headers nfsd: move most of nfsfh.h to fs/nfsd nfsd: remove unused field rq_reffh nfsd: enable V4ROOT exports nfsd: make V4ROOT exports read-only nfsd: restrict filehandles accepted in V4ROOT case nfsd: allow exports of symlinks nfsd: filter readdir results in V4ROOT case nfsd: filter lookup results in V4ROOT case nfsd4: don't continue "under" mounts in V4ROOT case nfsd: introduce export flag for v4 pseudoroot nfsd: let "insecure" flag vary by pseudoflavor nfsd: new interface to advertise export features nfsd: Move private headers to source directory vfs: nfsctl.c un-used nfsd #includes lockd: Remove un-used nfsd headers #includes s390: remove un-used nfsd #includes sparc: remove un-used nfsd #includes parsic: remove un-used nfsd #includes compat.c: Remove dependence on nfsd private headers ...
2009-12-14lockd: Remove un-used nfsd headers #includesBoaz Harrosh
In what history where these ever needed? Well not any more. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-11-18sysctl: Drop & in front of every proc_handler.Eric W. Biederman
For consistency drop & in front of every proc_handler. Explicity taking the address is unnecessary and it prevents optimizations like stubbing the proc_handlers to NULL. Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joe Perches <joe@perches.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-12sysctl fs: Remove dead binary sysctl supportEric W. Biederman
Now that sys_sysctl is a generic wrapper around /proc/sys .ctl_name and .strategy members of sysctl tables are dead code. Remove them. Cc: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-09-23headers: utsname.h reduxAlexey Dobriyan
* remove asm/atomic.h inclusion from linux/utsname.h -- not needed after kref conversion * remove linux/utsname.h inclusion from files which do not need it NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however due to some personality stuff it _is_ needed -- cowardly leave ELF-related headers and files alone. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22Merge branch 'for-2.6.32' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.32' of git://linux-nfs.org/~bfields/linux: (68 commits) nfsd4: nfsv4 clients should cross mountpoints nfsd: revise 4.1 status documentation sunrpc/cache: avoid variable over-loading in cache_defer_req sunrpc/cache: use list_del_init for the list_head entries in cache_deferred_req nfsd: return success for non-NFS4 nfs4_state_start nfsd41: Refactor create_client() nfsd41: modify nfsd4.1 backchannel to use new xprt class nfsd41: Backchannel: Implement cb_recall over NFSv4.1 nfsd41: Backchannel: cb_sequence callback nfsd41: Backchannel: Setup sequence information nfsd41: Backchannel: Server backchannel RPC wait queue nfsd41: Backchannel: Add sequence arguments to callback RPC arguments nfsd41: Backchannel: callback infrastructure nfsd4: use common rpc_cred for all callbacks nfsd4: allow nfs4 state startup to fail SUNRPC: Defer the auth_gss upcall when the RPC call is asynchronous nfsd4: fix null dereference creating nfsv4 callback client nfsd4: fix whitespace in NFSPROC4_CLNT_CB_NULL definition nfsd41: sunrpc: add new xprt class for nfsv4.1 backchannel sunrpc/cache: simplify cache_fresh_locked and cache_fresh_unlocked. ...
2009-09-22const: make lock_manager_operations constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22const: make file_lock_operations constAlexey Dobriyan
2009-08-21sunrpc: add routine for comparing addressesJeff Layton
lockd needs these sort of routines, as does the NFSv4 callback code. Move lockd's routines into common code and rename them so that they can be used by others. Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-08-09lockd: Replace nsm_display_address() with rpc_ntop()Chuck Lever
Clean up. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-08-09lockd: Replace nlm_clear_port()Chuck Lever
Clean up: Use shared rpc_set_port() function instead of nlm_clear_port(). Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-22Merge branch 'for-2.6.31' of git://fieldses.org/git/linux-nfsdLinus Torvalds
* 'for-2.6.31' of git://fieldses.org/git/linux-nfsd: (60 commits) SUNRPC: Fix the TCP server's send buffer accounting nfsd41: Backchannel: minorversion support for the back channel nfsd41: Backchannel: cleanup nfs4.0 callback encode routines nfsd41: Remove ip address collision detection case nfsd: optimise the starting of zero threads when none are running. nfsd: don't take nfsd_mutex twice when setting number of threads. nfsd41: sanity check client drc maxreqs nfsd41: move channel attributes from nfsd4_session to a nfsd4_channel_attr struct NFS: kill off complicated macro 'PROC' sunrpc: potential memory leak in function rdma_read_xdr nfsd: minor nfsd_vfs_write cleanup nfsd: Pull write-gathering code out of nfsd_vfs_write nfsd: track last inode only in use_wgather case sunrpc: align cache_clean work's timer nfsd: Use write gathering only with NFSv2 NFSv4: kill off complicated macro 'PROC' NFSv4: do exact check about attribute specified knfsd: remove unreported filehandle stats counters knfsd: fix reply cache memory corruption knfsd: reply cache cleanups ...
2009-06-17lockd: Don't bother with RPC ping for NSM upcallsChuck Lever
Cut NSM upcall RPC traffic in half -- don't do a NULL call first. The cases where a ping would be helpful are rare. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17lockd: Update NSM state from SM_MON repliesChuck Lever
When rpc.statd starts up in user space at boot time, it attempts to write the latest NSM local state number into /proc/sys/fs/nfs/nsm_local_state. If lockd.ko isn't loaded yet (as is the case in most configurations), that file doesn't exist, thus the kernel's NSM state remains set to its initial value of zero during lockd operation. This is a problem because rpc.statd and lockd use the NSM state number to prevent repeated lock recovery on rebooted hosts. If lockd sends a zero NSM state, but then a delayed SM_NOTIFY with a real NSM state number is received, there is no way for lockd or rpc.statd to distinguish that stale SM_NOTIFY from an actual reboot. Thus lock recovery could be performed after the rebooted host has already started reclaiming locks, and those locks will be lost. We could change /etc/init.d/nfslock so it always modprobes lockd.ko before starting rpc.statd. However, if lockd.ko is ever unloaded and reloaded, we are back at square one, since the NSM state is not preserved across an unload/reload cycle. This may happen frequently on clients that use automounter. A period of NFS inactivity causes lockd.ko to be unloaded, and the kernel loses its NSM state setting. Instead, let's use the fact that rpc.statd plants the local system's NSM state in every SM_MON (and SM_UNMON) reply. lockd performs a synchronous SM_MON upcall to the local rpc.statd _before_ sending its first NLM request to a new remote. This would permit rpc.statd to provide the current NSM state to lockd, even after lockd.ko had been unloaded and reloaded. Note that NLMPROC_LOCK arguments are constructed before the nsm_monitor() call, so we have to rearrange argument construction very slightly to make this all work out. And, the kernel appears to treat NSM state as a u32 (see struct nlm_args and nsm_res). Make nsm_local_state a u32 as well, to ensure we don't get bogus comparison results. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17NFSv4/NLM: Push file locking BKL dependencies down into the NLM layerTrond Myklebust
2009-06-15Merge commit 'v2.6.30' into for-2.6.31J. Bruce Fields
2009-05-06lockd: fix list corruption on lockd restartJ. Bruce Fields
If lockd is signalled soon enough after restart then locks_start_grace() will try to re-add an entry to a list and trigger a lock corruption warning. Thanks to Wang Chen for the problem report and diagnosis. WARNING: at lib/list_debug.c:26 __list_add+0x27/0x5c() ... list_add corruption. next->prev should be prev (ef8fe958), but was ef8ff128. (next=ef8ff128). ... Pid: 23062, comm: lockd Tainted: G W 2.6.30-rc2 #3 Call Trace: [<c042d5b5>] warn_slowpath+0x71/0xa0 [<c0422a96>] ? update_curr+0x11d/0x125 [<c044b12d>] ? trace_hardirqs_on_caller+0x18/0x150 [<c044b270>] ? trace_hardirqs_on+0xb/0xd [<c051c61a>] ? _raw_spin_lock+0x53/0xfa [<c051c89f>] __list_add+0x27/0x5c [<ef8f6daa>] locks_start_grace+0x22/0x30 [lockd] [<ef8f34da>] set_grace_period+0x39/0x53 [lockd] [<c06b8921>] ? lock_kernel+0x1c/0x28 [<ef8f3558>] lockd+0x64/0x164 [lockd] [<c044b12d>] ? trace_hardirqs_on_caller+0x18/0x150 [<c04227b0>] ? complete+0x34/0x3e [<ef8f34f4>] ? lockd+0x0/0x164 [lockd] [<ef8f34f4>] ? lockd+0x0/0x164 [lockd] [<c043dd42>] kthread+0x45/0x6b [<c043dcfd>] ? kthread+0x0/0x6b [<c0403c23>] kernel_thread_helper+0x7/0x10 Reported-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Cc: stable@kernel.org
2009-04-24lockd: call locks_release_private to cleanup per-filesystem stateFelix Blyakher
For every lock request lockd creates a new file_lock object in nlmsvc_setgrantargs() by copying the passed in file_lock with locks_copy_lock(). A filesystem can attach it's own lock_operations vector to the file_lock. It has to be cleaned up at the end of the file_lock's life. However, lockd doesn't do it today, yet it asserts in nlmclnt_release_lockargs() that the per-filesystem state is clean. This patch fixes it by exporting locks_release_private() and adding it to nlmsvc_freegrantargs(), to be symmetrical to creating a file_lock in nlmsvc_setgrantargs(). Signed-off-by: Felix Blyakher <felixb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-04-06Merge branch 'for-2.6.30' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.30' of git://linux-nfs.org/~bfields/linux: (81 commits) nfsd41: define nfsd4_set_statp as noop for !CONFIG_NFSD_V4 nfsd41: define NFSD_DRC_SIZE_SHIFT in set_max_drc nfsd41: Documentation/filesystems/nfs41-server.txt nfsd41: CREATE_EXCLUSIVE4_1 nfsd41: SUPPATTR_EXCLCREAT attribute nfsd41: support for 3-word long attribute bitmask nfsd: dynamically skip encoded fattr bitmap in _nfsd4_verify nfsd41: pass writable attrs mask to nfsd4_decode_fattr nfsd41: provide support for minor version 1 at rpc level nfsd41: control nfsv4.1 svc via /proc/fs/nfsd/versions nfsd41: add OPEN4_SHARE_ACCESS_WANT nfs4_stateid bmap nfsd41: access_valid nfsd41: clientid handling nfsd41: check encode size for sessions maxresponse cached nfsd41: stateid handling nfsd: pass nfsd4_compound_state* to nfs4_preprocess_{state,seq}id_op nfsd41: destroy_session operation nfsd41: non-page DRC for solo sequence responses nfsd41: Add a create session replay cache nfsd41: create_session operation ...
2009-04-01NSM: Fix unaligned accesses in nsm_init_private()Mans Rullgard
This fixes unaligned accesses in nsm_init_private() when creating nlm_reboot keys. Signed-off-by: Mans Rullgard <mans@mansr.com> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-28lockd: Start PF_INET6 listener only if IPv6 support is availableChuck Lever
Apparently a lot of people need to disable IPv6 completely on their distributor-built systems, which have CONFIG_IPV6_MODULE enabled at build time. They do this by blacklisting the ipv6.ko module. This causes the creation of the lockd service listener to fail if CONFIG_IPV6_MODULE is set, but the module cannot be loaded. Now that the kernel's PF_INET6 RPC listeners are completely separate from PF_INET listeners, we can always start PF_INET. Then lockd can try to start PF_INET6, but it isn't required to be available. Note this has the added benefit that NLM callbacks from AF_INET6 servers will never come from AF_INET remotes. We no longer have to worry about matching mapped IPv4 addresses to AF_INET when comparing addresses. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-28NFS: Revert creation of IPv6 listeners for lockd and NFSv4 callbacksChuck Lever
We're about to convert over to using separate PF_INET and PF_INET6 listeners, instead of a single PF_INET6 listener that also receives AF_INET requests and maps them to AF_INET6. Clear the way by removing the logic in lockd and the NFSv4 callback server that creates an AF_INET6 service listener. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-28SUNRPC: Remove @family argument from svc_create() and svc_create_pooled()Chuck Lever
Since an RPC service listener's protocol family is specified now via svc_create_xprt(), it no longer needs to be passed to svc_create() or svc_create_pooled(). Remove that argument from the synopsis of those functions, and remove the sv_family field from the svc_serv struct. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-28SUNRPC: Change svc_create_xprt() to take a @family argumentChuck Lever
The sv_family field is going away. Pass a protocol family argument to svc_create_xprt() instead of extracting the family from the passed-in svc_serv struct. Again, as this is a listener socket and not an address, we make this new argument an "int" protocol family, instead of an "sa_family_t." Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-18lockd: clean up blocking lock cases of nlsmvc_lock()Miklos Szeredi
No change in behavior, just rearranging the switch so that we break out of the switch if and only if we're in the wait case. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-03-10NLM: Fix GRANT callback address comparison when IPv6 is enabledChuck Lever
The NFS mount command may pass an AF_INET server address to lockd. If lockd happens to be using a PF_INET6 listener, the nlm_cmp_addr() in nlmclnt_grant() will fail to match requests from that host because they will all have a mapped IPv4 AF_INET6 address. Adopt the same solution used in nfs_sockaddr_match_ipaddr() for NFSv4 callbacks: if either address is AF_INET, map it to an AF_INET6 address before doing the comparison. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-02-09lockd: fix regression in lockd's handling of blocked locksJ. Bruce Fields
If a client requests a blocking lock, is denied, then requests it again, then here in nlmsvc_lock() we will call vfs_lock_file() without FL_SLEEP set, because we've already queued a block and don't need the locks code to do it again. But that means vfs_lock_file() will return -EAGAIN instead of FILE_LOCK_DENIED. So we still need to translate that -EAGAIN return into a nlm_lck_blocked error in this case, and put ourselves back on lockd's block list. The bug was introduced by bde74e4bc64415b1 "locks: add special return value for asynchronous locks". Thanks to Frank van Maarseveen for the report; his original test case was essentially for i in `seq 30`; do flock /nfsmount/foo sleep 10 & done Tested-by: Frank van Maarseveen <frankvm@frankvm.com> Reported-by: Frank van Maarseveen <frankvm@frankvm.com> Cc: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-07NLM: Clean up flow of control in make_socks() functionChuck Lever
Clean up: Use Bruce's preferred control flow style in make_socks(). Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-07NLM: Refactor make_socks() functionChuck Lever
Clean up: extract common logic in NLM's make_socks() function into a helper. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-06lockd: Enable NLM use of AF_INET6Chuck Lever
If the kernel is configured to support IPv6 and the RPC server can register services via rpcbindv4, we are all set to enable IPv6 support for lockd. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Aime Le Rouzic <aime.le-rouzic@bull.net> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-06NSM: Move nsm_create()Chuck Lever
Clean up: one last thing... relocate nsm_create() to eliminate the forward declaration and group it near the only function that actually uses it. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-06NSM: Move nsm_use_hostnames to mon.cChuck Lever
Clean up. Treat the nsm_use_hostnames global variable like nsm_local_state. Note that the default value of nsm_use_hostnames is still zero. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-06NSM: Move nsm_addr() to fs/lockd/mon.cChuck Lever
Clean up: nsm_addr_in() is no longer used, and nsm_addr() is used only in fs/lockd/mon.c, so move it there. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-06NSM: Remove include/linux/lockd/sm_inter.hChuck Lever
Clean up: The include/linux/lockd/sm_inter.h header is nearly empty now. Remove it. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-06NSM: Replace IP address as our nlm_reboot lookup keyChuck Lever
NLM provides file locking services for NFS files. Part of this service includes a second protocol, known as NSM, which is a reboot notification service. NLM uses this service to determine when to reclaim locks or enter a grace period after a client or server reboots. The NLM service (implemented by lockd in the Linux kernel) contacts the local NSM service (implemented by rpc.statd in Linux user space) via NSM protocol upcalls to register a callback when a particular remote peer reboots. To match the callback to the correct remote peer, the NLM service constructs a cookie that it passes in the request. The NSM service passes that cookie back to the NLM service when it is notified that the given remote peer has indeed rebooted. Currently on Linux, the cookie is the raw 32-bit IPv4 address of the remote peer. To support IPv6 addresses, which are larger, we could use all 16 bytes of the cookie to represent a full IPv6 address, although we still can't represent an IPv6 address with a scope ID in just 16 bytes. Instead, to avoid the need for future changes to support additional address types, we'll use a manufactured value for the cookie, and use that to find the corresponding nsm_handle struct in the kernel during the NLMPROC_SM_NOTIFY callback. This should provide complete support in the kernel's NSM implementation for IPv6 hosts, while remaining backwards compatible with older rpc.statd implementations. Note we also deal with another case where nsm_use_hostnames can change while there are outstanding notifications, possibly resulting in the loss of reboot notifications. After this patch, the priv cookie is always used to lookup rebooted hosts in the kernel. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-06NSM: More clean up of nsm_get_handle()Chuck Lever
Clean up: refactor nsm_get_handle() so it is organized the same way that nsm_reboot_lookup() is. There is an additional micro-optimization here. This change moves the "hostname & nsm_use_hostnames" test out of the list_for_each_entry() clause in nsm_get_handle(), since it is loop-invariant. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-06NSM: Refactor nsm_handle creation into a helper functionChuck Lever
Clean up. Refactor the creation of nsm_handles into a helper. Fields are initialized in increasing address order to make efficient use of CPU caches. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-06NLM: Remove "create" argument from nsm_find()Chuck Lever
Clean up: nsm_find() now has only one caller, and that caller unconditionally sets the @create argument. Thus the @create argument is no longer needed. Since nsm_find() now has a more specific purpose, pick a more appropriate name for it. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-06NLM: Call nsm_reboot_lookup() instead of nsm_find()Chuck Lever
Invoke the newly introduced nsm_reboot_lookup() function in nlm_host_rebooted() instead of nsm_find(). This introduces just one behavioral change: debugging messages produced during reboot notification will now appear when the NLMDBG_MONITOR flag is set, but not when the NLMDBG_HOSTCACHE flag is set. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-06NSM: Add nsm_lookup() functionChuck Lever
Introduce a new API to fs/lockd/mon.c that allows nlm_host_rebooted() to lookup up nsm_handles via the contents of an nlm_reboot struct. The new function is equivalent to calling nsm_find() with @create set to zero, but it takes a struct nlm_reboot instead of separate arguments. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-06NLM: Decode "priv" argument of NLMPROC_SM_NOTIFY as an opaqueChuck Lever
The NLM XDR decoders for the NLMPROC_SM_NOTIFY procedure should treat their "priv" argument truly as an opaque, as defined by the protocol, and let the upper layers figure out what is in it. This will make it easier to modify the contents and interpretation of the "priv" argument, and keep knowledge about what's in "priv" local to fs/lockd/mon.c. For now, the NLM and NSM implementations should behave exactly as they did before. The formation of the address of the rebooted host in nlm_host_rebooted() may look a little strange, but it is the inverse of how nsm_init_private() forms the private cookie. Plus, it's going away soon anyway. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-06NLM: Change nlm_host_rebooted() to take a single nlm_reboot argumentChuck Lever
Pass the nlm_reboot data structure directly from the NLMPROC_SM_NOTIFY XDR decoders to nlm_host_rebooted(). This eliminates some packing and unpacking of the NLMPROC_SM_NOTIFY results, and prepares for passing these results, including the "priv" cookie, directly to a lookup routine in fs/lockd/mon.c. This patch changes code organization but should not cause any behavioral change. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-06NSM: Encode the new "priv" cookie for NSMPROC_MON requestsChuck Lever
Pass the new "priv" cookie to NSMPROC_MON's XDR encoder, instead of creating the "priv" argument in the encoder at call time. This patch should not cause a behavioral change: the contents of the cookie remain the same for the time being. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-06NSM: Generate NSMPROC_MON's "priv" argument when nsm_handle is createdChuck Lever
Introduce a new data type, used by both the in-kernel NLM and NSM implementations, that is used to manage the opaque "priv" argument for the NSMPROC_MON and NLMPROC_SM_NOTIFY calls. Construct the "priv" cookie when the nsm_handle is created. The nsm_init_private() function may look a little strange, but it is roughly equivalent to how the XDR encoder formed the "priv" argument. It's going to go away soon. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-06NSM: Remove !nsm check from nsm_release()Chuck Lever
The nsm_release() function should never be called with a NULL handle point. If it is, that's a bug. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
