path: root/fs/logfs/Kconfig
2016-01-14logfs: fix logfs build errors and dependenciesArnd Bergmann
Fix build errors that happen when CONFIG_LOGFS=y and CONFIG_MTD=m: fs/built-in.o: In function `logfs_mount': super.c:(.text+0x92a6f): undefined reference to `logfs_get_sb_mtd' fs/built-in.o: In function `logfs_get_sb_bdev': (.text+0x93530): undefined reference to `logfs_get_sb_mtd' This patch avoids the error by changing the dependencies of logfs in a way that we can no longer configure logfs as built-in when the MTD core is a loadable module, while leaving the dependency to require at least one of MTD or BLOCK to be enabled. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Cc: Michal Marek <mmarek@suse.cz> Cc: Peter Chen <peter.chen@freescale.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Joern Engel <joern@logfs.org> Cc: Prasad Joshi <prasadjoshi.linux@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-21fs/logfs: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. CC: Joern Engel <joern@logfs.org> CC: Prasad Joshi <prasadjoshi.linux@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2009-11-20[LogFS] add new flash file systemJoern Engel
This is a new flash file system. See Documentation/filesystems/logfs.txt Signed-off-by: Joern Engel <joern@logfs.org>
