Instead of always creating a huge (268K) deflate_workspace with the
maximum compression parameters (windowBits=15, memLevel=8), allow the
caller to obtain a smaller workspace by specifying smaller parameter
values.
For example, when capturing oops and panic reports to a medium with
limited capacity, such as NVRAM, compression may be the only way to
capture the whole report. In this case, a small workspace (24K works
fine) is a win, whether you allocate the workspace when you need it (i.e.,
during an oops or panic) or at boot time.
I've verified that this patch works with all accepted values of windowBits
(positive and negative), memLevel, and compression level.
Signed-off-by: Jim Keniston <jkenisto@us.ibm.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Chris Mason <chris.mason@oracle.com>
* 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-block: (43 commits)
block: ensure that completion error gets properly traced
blktrace: add missing probe argument to block_bio_complete
block cfq: don't use atomic_t for cfq_group
block cfq: don't use atomic_t for cfq_queue
block: trace event block fix unassigned field
block: add internal hd part table references
block: fix accounting bug on cross partition merges
kref: add kref_test_and_get
bio-integrity: mark kintegrityd_wq highpri and CPU intensive
block: make kblockd_workqueue smarter
Revert "sd: implement sd_check_events()"
block: Clean up exit_io_context() source code.
Fix compile warnings due to missing removal of a 'ret' variable
fs/block: type signature of major_to_index(int) to major_to_index(unsigned)
block: convert !IS_ERR(p) && p to !IS_ERR_NOR_NULL(p)
cfq-iosched: don't check cfqg in choose_service_tree()
fs/splice: Pull buf->ops->confirm() from splice_from_pipe actors
cdrom: export cdrom_check_events()
sr: implement sr_check_events()
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
RCU free the struct inode. This will allow:
- Subsequent store-free path walking patch. The inode must be consulted for
permissions when walking, so an RCU inode reference is a must.
- sb_inode_list_lock to be moved inside i_lock because sb list walkers who want
to take i_lock no longer need to take sb_inode_list_lock to walk the list in
the first place. This will simplify and optimize locking.
- Could remove some nested trylock loops in dcache code
- Could potentially simplify things a bit in VM land. Do not need to take the
page lock to follow page->mapping.
The downsides of this is the performance cost of using RCU. In a simple
creat/unlink microbenchmark, performance drops by about 10% due to inability to
reuse cache-hot slab objects. As iterations increase and RCU freeing starts
kicking over, this increases to about 20%.
In cases where inode lifetimes are longer (ie. many inodes may be allocated
during the average life span of a single inode), a lot of this cache reuse is
not applicable, so the regression caused by this patch is smaller.
The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU,
however this adds some complexity to list walking and store-free path walking,
so I prefer to implement this at a later date, if it is shown to be a win in
real situations. I haven't found a regression in any non-micro benchmark so I
doubt it will be a problem.
This happens when __logfs_create() tries to write a new inode to the disk
which is full.
__logfs_create() associates the transaction pointer with inode. During
the logfs_write_inode() function call chain this transaction pointer is
moved from inode to page->private using function move_inode_to_page
(do_write_inode() -> inode_to_page() -> move_inode_to_page)
When the write inode fails, the transaction is aborted and iput is called
on the failed inode. During delete_inode the same transaction pointer
associated with the page is getting used. Thus causing kernel BUG.
The patch checks for error in write_inode() and restores the page->private
to NULL.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=20162
Signed-off-by: Prasad Joshi <prasadjoshi124@gmail.com>
Cc: Joern Engel <joern@logfs.org>
Cc: Florian Mickler <florian@mickler.org>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Maciej Rutecki <maciej.rutecki@gmail.com>
do_logfs_journal_wl_pass() should use GFP_NOFS for memory allocation GC
code calls btree_insert32 with GFP_KERNEL while holding a mutex
super->s_write_mutex.
The same mutex is used in address_space_operations->writepage(), and a
call to writepage() could be triggered as a result of memory allocation
in btree_insert32, causing a deadlock.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=20342
After recent blkdev_get() modifications, open_by_devnum() and
open_bdev_exclusive() are simple wrappers around blkdev_get().
Replace them with blkdev_get_by_dev() and blkdev_get_by_path().
blkdev_get_by_dev() is identical to open_by_devnum().
blkdev_get_by_path() is slightly different in that it doesn't
automatically add %FMODE_EXCL to @mode.
All users are converted. Most conversions are mechanical and don't
introduce any behavior difference. There are several exceptions.
* btrfs now sets FMODE_EXCL in btrfs_device->mode, so there's no
reason to OR it explicitly on blkdev_put().
* gfs2, nilfs2 and the generic mount_bdev() now set FMODE_EXCL in
sb->s_mode.
* With the above changes, sb->s_mode now always should contain
FMODE_EXCL. WARN_ON_ONCE() added to kill_block_super() to detect
errors.
The new blkdev_get_*() functions are with proper docbook comments.
While at it, add function description to blkdev_get() too.
Cc: Philipp Reisner <philipp.reisner@linbit.com>
Cc: Neil Brown <neilb@suse.de>
Cc: Mike Snitzer <snitzer@redhat.com>
Cc: Joern Engel <joern@lazybastard.org>
Cc: Jan Kara <jack@suse.cz>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp>
Cc: reiserfs-devel@vger.kernel.org
Cc: xfs-masters@oss.sgi.com
Over time, block layer has accumulated a set of APIs dealing with bdev
open, close, claim and release.
* blkdev_get/put() are the primary open and close functions.
* bd_claim/release() deal with exclusive open.
* open/close_bdev_exclusive() are combination of open and claim and
the other way around, respectively.
* bd_link/unlink_disk_holder() to create and remove holder/slave
symlinks.
* open_by_devnum() wraps bdget() + blkdev_get().
The interface is a bit confusing and the decoupling of open and claim
makes it impossible to properly guarantee exclusive access as
in-kernel open + claim sequence can disturb the existing exclusive
open even before the block layer knows the current open if for another
exclusive access. Reorganize the interface such that,
* blkdev_get() is extended to include exclusive access management.
@holder argument is added and, if is @FMODE_EXCL specified, it will
gain exclusive access atomically w.r.t. other exclusive accesses.
* blkdev_put() is similarly extended. It now takes @mode argument and
if @FMODE_EXCL is set, it releases an exclusive access. Also, when
the last exclusive claim is released, the holder/slave symlinks are
removed automatically.
* bd_claim/release() and close_bdev_exclusive() are no longer
necessary and either made static or removed.
* bd_link_disk_holder() remains the same but bd_unlink_disk_holder()
is no longer necessary and removed.
* open_bdev_exclusive() becomes a simple wrapper around lookup_bdev()
and blkdev_get(). It also has an unexpected extra bdev_read_only()
test which probably should be moved into blkdev_get().
* open_by_devnum() is modified to take @holder argument and pass it to
blkdev_get().
Most of bdev open/close operations are unified into blkdev_get/put()
and most exclusive accesses are tested atomically at the open time (as
it should). This cleans up code and removes some, both valid and
invalid, but unnecessary all the same, corner cases.
open_bdev_exclusive() and open_by_devnum() can use further cleanup -
rename to blkdev_get_by_path() and blkdev_get_by_devt() and drop
special features. Well, let's leave them for another day.
Most conversions are straight-forward. drbd conversion is a bit more
involved as there was some reordering, but the logic should stay the
same.
Acked-by: Neil Brown <neilb@suse.de>
Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Acked-by: Mike Snitzer <snitzer@redhat.com>
Acked-by: Philipp Reisner <philipp.reisner@linbit.com>
Cc: Peter Osterlund <petero2@telia.com>
Cc: Andreas Dilger <adilger.kernel@dilger.ca>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Joel Becker <joel.becker@oracle.com>
Cc: Alex Elder <aelder@sgi.com>
Cc: dm-devel@redhat.com
Cc: drbd-dev@lists.linbit.com
Cc: Leo Chen <leochen@broadcom.com>
Cc: Scott Branden <sbranden@broadcom.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
Commit 7d945a3aa760 ("logfs get_sb, part 3") broke the logfs build when
CONFIG_MTD is set due to a mangled logfs_get_sb_mtd() definition.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
a) switch ->put_device() to logfs_super *
b) actually call it on early failures in logfs_get_sb_device()
take logfs_get_sb_device() calls to logfs_get_sb() itself
take setting s_bdev/s_mtd/s_devops to callers of logfs_get_sb_device(),
don't bother passing them separately
move allocation of logfs_super to logfs_get_sb, pass it to
logfs_get_sb_...().
Clones an existing reference to inode; caller must already hold one.
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
logfs does not need the BKL, so use ->unlocked_ioctl instead
of ->ioctl in file operations.
Signed-off-by: Joern Engel <joern@logfs.org>
[ fixed trivial conflict ]
... and let iput_final() do the actual eviction or retention
ordering problems at ->kill_sb() time are solved by doing iput()
of these suckers in ->put_super()
Make sure we call inode_change_ok before doing any changes in ->setattr,
and make sure to call it even if our fs wants to ignore normal UNIX
permissions, but use the ATTR_FORCE to skip those.
Replace inode_setattr with opencoded variants of it in all callers. This
moves the remaining call to vmtruncate into the filesystem methods where it
can be replaced with the proper truncate sequence.
In a few cases it was obvious that we would never end up calling vmtruncate
so it was left out in the opencoded variant:
spufs: explicitly checks for ATTR_SIZE earlier
btrfs,hugetlbfs,logfs,dlmfs: explicitly clears ATTR_SIZE earlier
ufs: contains an opencoded simple_seattr + truncate that sets the filesize just above
In addition to that ncpfs called inode_setattr with handcrafted iattrs,
which allowed to trim down the opencoded variant.
if kmalloc fails, we still need to drop the inode, as we do
on other failure exits.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (44 commits)
vlynq: make whole Kconfig-menu dependant on architecture
add descriptive comment for TIF_MEMDIE task flag declaration.
EEPROM: max6875: Header file cleanup
EEPROM: 93cx6: Header file cleanup
EEPROM: Header file cleanup
agp: use NULL instead of 0 when pointer is needed
rtc-v3020: make bitfield unsigned
PCI: make bitfield unsigned
jbd2: use NULL instead of 0 when pointer is needed
cciss: fix shadows sparse warning
doc: inode uses a mutex instead of a semaphore.
uml: i386: Avoid redefinition of NR_syscalls
fix "seperate" typos in comments
cocbalt_lcdfb: correct sections
doc: Change urls for sparse
Powerpc: wii: Fix typo in comment
i2o: cleanup some exit paths
Documentation/: it's -> its where appropriate
UML: Fix compiler warning due to missing task_struct declaration
UML: add kernel.h include to signal.c
* git://git.kernel.org/pub/scm/linux/kernel/git/joern/logfs:
logfs: handle powerfail on NAND flash
logfs: handle errors from get_mtd_device()
logfs: remove unused variable
logfs: fix sync
logfs: fix compile failure
logfs: initialize li->li_refcount
logfs: commit reservations under space pressure
logfs: survive logfs_buf_recover read errors
logfs: Close i_ino reuse race
logfs: fix logfs_seek_hole()
logfs: Return -EINVAL if filesystem image doesn't match
LogFS: Fix typo in b6349ac8
logfs: testing the wrong variable
iput() is needed *until* we'd done successful d_alloc_root()
s/seperate/separate
Signed-off-by: Anand Gadiyar <gadiyar@ti.com>
The write buffer may not have been written and may no longer be written
due to an interrupted write in the affected page.
The get_mtd_device() function returns error pointers on failure and if we
don't handle it, it leads to a crash.
Rather self-explanatory.
When CONFIG_BLOCK is not enabled:
fs/logfs/super.c:142: error: implicit declaration of function 'bdev_get_queue'
fs/logfs/super.c:142: error: invalid type argument of '->' (have 'int')
Found by Randy Dunlap <randy.dunlap@oracle.com>
li_refcount was not re-initialized in function logfs_init_inode(), small
patch that will fix the problem
Ensures we only return -ENOSPC when there really is no space.
Refusing to mount beats a kernel crash.
logfs_seek_hole() may return the same offset it is passed as argument.
Found by Prasad Joshi <prasadjoshi124@gmail.com>
logfs_seek_hole(inode, 0x200) would crap itself if the inode contained
just 0x1ff (or fewer) blocks.
There is a typo here. We should test "last" instead of "first".
[LogFS] Split large truncated into smaller chunks
[LogFS] Set s_bdi
[LogFS] Prevent mempool_destroy NULL pointer dereference
[LogFS] Move assertion
[LogFS] Plug 8 byte information leak
[LogFS] Prevent memory corruption on large deletes
[LogFS] Remove unused method
Fix trivial conflict with added header includes in fs/logfs/super.c
Truncate would do an almost limitless amount of work without invoking
the garbage collector in between. Split it up into more manageable,
though still large, chunks.
Since 32a88aa1 sync() was turned into a NOP for logfs. Worse, sync()
would not return an error, giving the illusion that writeout had
actually happened.
Afaics jffs2 was broken as well.
It would probably be better to just accept NULL pointers in
mempool_destroy(). But for the current -rc series let's keep things
simple.
This patch was lost in the cracks for a while.
Kevin Cernekee <cernekee@gmail.com> had to rediscover the problem and
send a similar patch because of it. :(
The assertion is valid independently of the condition.
Within each journal segment, 8 bytes at offset 24 would remain
uninitialized.
Removing sufficiently large files would create aliases for a large
number of segments. This in turn results in a large number of journal
entries and an overflow of s_je_array.
Cheap fix is to add a BUG_ON, turning memory corruption into something
annoying, but less dangerous. Real fix is to count the number of
affected segments and prevent the problem completely.
