path: root/fs/logfs
2010-08-14logfs: kill BKLArnd Bergmann
logfs does not need the BKL, so use ->unlocked_ioctl instead of ->ioctl in file operations. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Joern Engel <joern@logfs.org> [ fixed trivial conflict ] Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2010-08-09Make ->drop_inode() just return whether inode needs to be droppedAl Viro
... and let iput_final() do the actual eviction or retention Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09convert logfs to ->evict_inode()Al Viro
2010-08-09logfs: get rid of magical inodesAl Viro
ordering problems at ->kill_sb() time are solved by doing iput() of these suckers in ->put_super() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09always call inode_change_ok early in ->setattrChristoph Hellwig
Make sure we call inode_change_ok before doing any changes in ->setattr, and make sure to call it even if our fs wants to ignore normal UNIX permissions, but use the ATTR_FORCE to skip those. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09remove inode_setattrChristoph Hellwig
Replace inode_setattr with opencoded variants of it in all callers. This moves the remaining call to vmtruncate into the filesystem methods where it can be replaced with the proper truncate sequence. In a few cases it was obvious that we would never end up calling vmtruncate so it was left out in the opencoded variant: spufs: explicitly checks for ATTR_SIZE earlier btrfs,hugetlbfs,logfs,dlmfs: explicitly clears ATTR_SIZE earlier ufs: contains an opencoded simple_seattr + truncate that sets the filesize just above In addition to that ncpfs called inode_setattr with handcrafted iattrs, which allowed to trim down the opencoded variant. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09fix leak in __logfs_create()Al Viro
if kmalloc fails, we still need to drop the inode, as we do on other failure exits. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27drop unused dentry argument to ->fsyncChristoph Hellwig
2010-05-21logfs: replace inode uid,gid,mode initialization with helper functionAl Viro
2010-05-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (44 commits) vlynq: make whole Kconfig-menu dependant on architecture add descriptive comment for TIF_MEMDIE task flag declaration. EEPROM: max6875: Header file cleanup EEPROM: 93cx6: Header file cleanup EEPROM: Header file cleanup agp: use NULL instead of 0 when pointer is needed rtc-v3020: make bitfield unsigned PCI: make bitfield unsigned jbd2: use NULL instead of 0 when pointer is needed cciss: fix shadows sparse warning doc: inode uses a mutex instead of a semaphore. uml: i386: Avoid redefinition of NR_syscalls fix "seperate" typos in comments cocbalt_lcdfb: correct sections doc: Change urls for sparse Powerpc: wii: Fix typo in comment i2o: cleanup some exit paths Documentation/: it's -> its where appropriate UML: Fix compiler warning due to missing task_struct declaration UML: add kernel.h include to signal.c ...
2010-05-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/joern/logfsLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/joern/logfs: logfs: handle powerfail on NAND flash logfs: handle errors from get_mtd_device() logfs: remove unused variable logfs: fix sync logfs: fix compile failure logfs: initialize li->li_refcount logfs: commit reservations under space pressure logfs: survive logfs_buf_recover read errors logfs: Close i_ino reuse race logfs: fix logfs_seek_hole() logfs: Return -EINVAL if filesystem image doesn't match LogFS: Fix typo in b6349ac8 logfs: testing the wrong variable
2010-05-15Fix double-free in logfsAl Viro
iput() is needed *until* we'd done successful d_alloc_root() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-10fix "seperate" typos in commentsAnand Gadiyar
s/seperate/separate Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-07logfs: handle powerfail on NAND flashJoern Engel
The write buffer may not have been written and may no longer be written due to an interrupted write in the affected page. Signed-off-by: Joern Engel <joern@logfs.org>
2010-05-07logfs: handle errors from get_mtd_device()Dan Carpenter
The get_mtd_device() function returns error pointers on failure and if we don't handle it, it leads to a crash. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Joern Engel <joern@logfs.org>
2010-05-07logfs: remove unused variableJoern Engel
2010-05-05logfs: fix syncJoern Engel
Rather self-explanatory. Signed-off-by: Joern Engel <joern@logfs.org>
2010-05-05logfs: fix compile failureJoern Engel
When CONFIG_BLOCK is not enabled: fs/logfs/super.c:142: error: implicit declaration of function 'bdev_get_queue' fs/logfs/super.c:142: error: invalid type argument of '->' (have 'int') Found by Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Joern Engel <joern@logfs.org>
2010-05-04logfs: initialize li->li_refcountPrasad Joshi
li_refcount was not re-initialized in function logfs_init_inode(), small patch that will fix the problem Signed-off-by: Prasad Joshi <prasadjoshi124@gmail.com> Signed-off-by: Joern Engel <joern@logfs.org>
2010-05-04logfs: commit reservations under space pressureJoern Engel
Ensures we only return -ENOSPC when there really is no space. Signed-off-by: Joern Engel <joern@logfs.org>
2010-05-04logfs: survive logfs_buf_recover read errorsJoern Engel
Refusing to mount beats a kernel crash. Signed-off-by: Joern Engel <joern@logfs.org>
2010-05-01logfs: Close i_ino reuse raceJoern Engel
logfs_seek_hole() may return the same offset it is passed as argument. Found by Prasad Joshi <prasadjoshi124@gmail.com> Signed-off-by: Joern Engel <joern@logfs.org>
2010-05-01logfs: fix logfs_seek_hole()Joern Engel
logfs_seek_hole(inode, 0x200) would crap itself if the inode contained just 0x1ff (or fewer) blocks. Signed-off-by: Joern Engel <joern@logfs.org>
2010-05-01logfs: Return -EINVAL if filesystem image doesn't matchJoern Engel
2010-04-29LogFS: Fix typo in b6349ac8Joern Engel
2010-04-29logfs: testing the wrong variableDan Carpenter
There is a typo here. We should test "last" instead of "first". Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Joern Engel <joern@logfs.org>
2010-04-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/joern/logfsLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/joern/logfs: [LogFS] Split large truncated into smaller chunks [LogFS] Set s_bdi [LogFS] Prevent mempool_destroy NULL pointer dereference [LogFS] Move assertion [LogFS] Plug 8 byte information leak [LogFS] Prevent memory corruption on large deletes [LogFS] Remove unused method Fix trivial conflict with added header includes in fs/logfs/super.c
2010-04-20[LogFS] Split large truncated into smaller chunksJoern Engel
Truncate would do an almost limitless amount of work without invoking the garbage collector in between. Split it up into more manageable, though still large, chunks. Signed-off-by: Joern Engel <joern@logfs.org>
2010-04-17[LogFS] Set s_bdiJoern Engel
Since 32a88aa1 sync() was turned into a NOP for logfs. Worse, sync() would not return an error, giving the illusion that writeout had actually happened. Afaics jffs2 was broken as well. Signed-off-by: Joern Engel <joern@logfs.org>
2010-04-15[LogFS] Prevent mempool_destroy NULL pointer dereferenceJoern Engel
It would probably be better to just accept NULL pointers in mempool_destroy(). But for the current -rc series let's keep things simple. This patch was lost in the cracks for a while. Kevin Cernekee <cernekee@gmail.com> had to rediscover the problem and send a similar patch because of it. :( Signed-off-by: Joern Engel <joern@logfs.org>
2010-04-13[LogFS] Move assertionJoern Engel
The assertion is valid independently of the condition. Signed-off-by: Joern Engel <joern@logfs.org>
2010-04-13[LogFS] Plug 8 byte information leakJoern Engel
Within each journal segment, 8 bytes at offset 24 would remain uninitialized. Signed-off-by: Joern Engel <joern@logfs.org>
2010-04-13[LogFS] Prevent memory corruption on large deletesJoern Engel
Removing sufficiently large files would create aliases for a large number of segments. This in turn results in a large number of journal entries and an overflow of s_je_array. Cheap fix is to add a BUG_ON, turning memory corruption into something annoying, but less dangerous. Real fix is to count the number of affected segments and prevent the problem completely. Signed-off-by: Joern Engel <joern@logfs.org>
2010-04-05Merge branch 'master' into export-slabhTejun Heo
2010-03-30[LogFS] Remove unused methodJoern Engel
All callers are long gone. Signed-off-by: Joern Engel <joern@logfs.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-29[LogFS] Erase new journal segmentsJoern Engel
If the device contains on old logfs image and the journal is moved to segment that have never been used by the current logfs and not all journal segments are erased before the next mount, the old content can confuse mount code. To prevent this, always erase the new journal segments. Signed-off-by: Joern Engel <joern@logfs.org>
2010-03-29[LogFS] Move reserved segments with journalJoern Engel
Fixes a GC livelock. Signed-off-by: Joern Engel <joern@logfs.org>
2010-03-28[LogFS] Clear PagePrivate when moving journalJoern Engel
do_logfs_journal_wl_pass() must call freeseg(), thereby clear PagePrivate on all pages of the current journal segment. Signed-off-by: Joern Engel <joern@logfs.org>
2010-03-28Simplify and fix pad_wbufJoern Engel
A comment in the old code read: /* The math in this function can surely use some love */ And indeed it did. In the case that area->a_used_bytes is exactly 4096 bytes below segment size it fell apart. pad_wbuf is now split into two helpers that are significantly less complicated. Signed-off-by: Joern Engel <joern@logfs.org>
2010-03-28Prevent data corruption in logfs_rewrite_block()Joern Engel
The comment was correct, so make the code match the comment. As the new comment indicates, we might be able to do a little less work. But for the current -rc series let's keep it simple and just fix the bug. Signed-off-by: Joern Engel <joern@logfs.org>
2010-03-27Use deactivate_locked_superJoern Engel
Found by Al Viro. Signed-off-by: Joern Engel <joern@logfs.org>
2010-03-27Fix logfs_get_sb_final error pathJoern Engel
rootdir was already allocated, so we must iput it again. Found by Al Viro. Signed-off-by: Joern Engel <joern@logfs.org>
2010-03-27Write out both superblocks on mismatchJoern Engel
If the first superblock is wrong and the second gets written, there will still be a mismatch on next mount. Write both to make sure they match. Signed-off-by: Joern Engel <joern@logfs.org>
2010-03-27Prevent schedule while atomic in __logfs_readdirJoern Engel
Apparently filldir can sleep, which forbids kmap_atomic. Signed-off-by: Joern Engel <joern@logfs.org>
2010-03-27Plug memory leak in writeseg_end_ioJoern Engel
2010-03-27Limit max_pages for insane devicesJoern Engel
Intel SSDs have a limit of 0xffff as queue_max_hw_sectors(q). Such a limit may make sense from a hardware pov, but it causes bio_alloc() to return NULL. Signed-off-by: Joern Engel <joern@logfs.org>
2010-03-27Open segment file before using itJoern Engel
logfs_recover_sb() needs it open. Signed-off-by: Joern Engel <joern@logfs.org>
2010-03-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/joern/logfsLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/joern/logfs: [LogFS] Change magic number [LogFS] Remove h_version field [LogFS] Check feature flags [LogFS] Only write journal if dirty [LogFS] Fix bdev erases [LogFS] Silence gcc [LogFS] Prevent 64bit divisions in hash_index [LogFS] Plug memory leak on error paths [LogFS] Add MAINTAINERS entry [LogFS] add new flash file system Fixed up trivial conflict in lib/Kconfig, and a semantic conflict in fs/logfs/inode.c introduced by write_inode() being changed to use writeback_control' by commit a9185b41a4f84971b930c519f0c63bd450c4810d ("pass writeback_control to ->write_inode")
2010-03-06[LogFS] Change magic numberJoern Engel
Many changes were made during development that could result in old versions of mklogfs and the kernel code being subtly incompatible. Not being a friend of subtleties, I hereby change the magic number. Any old version of mklogfs is now guaranteed to fail.
