path: root/fs/minix
2010-10-25new helper: ihold()Al Viro
Clones an existing reference to inode; caller must already hold one. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-09-09minix: fix regression in minix_mkdir()Jorge Boncompte [DTI2]
Commit 9eed1fb721c ("minix: replace inode uid,gid,mode init with helper") broke directory creation on minix filesystems. Fix it by passing the needed mode flag to inode init helper. Signed-off-by: Jorge Boncompte [DTI2] <jorge@dti2.net> Cc: Dmitry Monakhov <dmonakhov@openvz.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: <stable@kernel.org> [2.6.35.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09switch minix to ->evict_inode(), fix write_inode/delete_inode raceAl Viro
We need to wait for completion of possible writeback in progress before we clear on-disk inode during deletion. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09remove inode_setattrChristoph Hellwig
Replace inode_setattr with opencoded variants of it in all callers. This moves the remaining call to vmtruncate into the filesystem methods where it can be replaced with the proper truncate sequence. In a few cases it was obvious that we would never end up calling vmtruncate so it was left out in the opencoded variant: spufs: explicitly checks for ATTR_SIZE earlier btrfs,hugetlbfs,logfs,dlmfs: explicitly clears ATTR_SIZE earlier ufs: contains an opencoded simple_seattr + truncate that sets the filesize just above In addition to that ncpfs called inode_setattr with handcrafted iattrs, which allowed to trim down the opencoded variant. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09add missing setattr methodsChristoph Hellwig
For the new truncate sequence every filesystem that wants to truncate on-disk state needs a seattr method. Convert the remaining filesystems that implement the truncate inode operation to have its own setattr method. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09get rid of block_write_begin_newtruncChristoph Hellwig
Move the call to vmtruncate to get rid of accessive blocks to the callers in preparation of the new truncate sequence and rename the non-truncating version to block_write_begin. While we're at it also remove several unused arguments to block_write_begin. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09introduce __block_write_beginChristoph Hellwig
Split up the block_write_begin implementation - __block_write_begin is a new trivial wrapper for block_prepare_write that always takes an already allocated page and can be either called from block_write_begin or filesystem code that already has a page allocated. Remove the handling of already allocated pages from block_write_begin after switching all callers that do it to __block_write_begin. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09clean up write_begin usage for directories in pagecacheChristoph Hellwig
For filesystem that implement directories in pagecache we call block_write_begin with an already allocated page for this code, while the normal regular file write path uses the default block_write_begin behaviour. Get rid of the __foofs_write_begin helper and opencode the normal write_begin call in foofs_write_begin, while adding a new foofs_prepare_chunk helper for the directory code. The added benefit is that foofs_prepare_chunk has a much saner calling convention. Note that the interruptible flag passed into block_write_begin is always ignored if we already pass in a page (see next patch for details), and we never were doing truncations of exessive blocks for this case either so we can switch directly to block_write_begin_newtrunc. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-06-04Minix: Clean up left over labelAndrew Hendry
Remove a left over fail label. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-28remove detritus left by "mm: make read_cache_page synchronous"Al Viro
gets minix get_dir_page() in sync with its analogs; back in 2007 Nick has switched read_cache_page() and friends to sync behaviour (i.e. they wait for the page to get unlocked, check if it's uptodate and if it isn't return ERR_PTR(-EIO) instead) and removed the duplicate logics from the callers. In case of fs/minix/dir.c he'd removed only half of that... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27fs/minix: bugfix, number of indirect block ptrs per block depends on block sizeErik van der Kouwe
The MINIX filesystem driver used a constant number of indirect block pointers in an indirect block. This worked only for filesystems with 1kb block, while the MINIX default block size is now 4kb. As a consequence, large files were read incorrectly on such filesystems and writing a large file would cause the filesystem to become corrupted. This patch computes the number of indirect block pointers based on the block size, making the driver work for each block size. I would like to thank Feiran Zheng ('Fam') for pointing out the cause of the corruption. Signed-off-by: Erik van der Kouwe <vdkouwe@cs.vu.nl> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27rename the generic fsync implementationsChristoph Hellwig
We don't name our generic fsync implementations very well currently. The no-op implementation for in-memory filesystems currently is called simple_sync_file which doesn't make too much sense to start with, the the generic one for simple filesystems is called simple_fsync which can lead to some confusion. This patch renames the generic file fsync method to generic_file_fsync to match the other generic_file_* routines it is supposed to be used with, and the no-op implementation to noop_fsync to make it obvious what to expect. In addition add some documentation for both methods. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21minix: replace inode uid,gid,mode init with helperDmitry Monakhov
- also redesign minix_new_inode interface Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-05pass writeback_control to ->write_inodeChristoph Hellwig
This gives the filesystem more information about the writeback that is happening. Trond requested this for the NFS unstable write handling, and other filesystems might benefit from this too by beeing able to distinguish between the different callers in more detail. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-09-23V3 minixfs: add missing directory type checkingDoug Graham
There are a few places in the Minix FS code where the "inode" field of a minix_dir_entry is used without checking first to see if the dirent is really a minix3_dir_entry. The inode number in a V1/V2 dirent is 16 bits, whereas that in a V3 dirent is 32 bits. Accessing it as a 16 bit field when it really should be accessed as a 32 bit field probably kinda sorta works on a little-endian machine, but leads to some rather odd behaviour on big-endian machines. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Doug Graham <dgraham@nortel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-22Making fs/minix/minix.h double including safeHitoshi Mitake
I happened to find that fs/minix/minix.h doesn't guard double include. Yes, I know this never cause something destructive because this is self-evidence that no source file includes minix.h twice, but I think fixing this is better than disregarding it. Signed-off-by: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-17get rid of BKL in fs/minixAl Viro
2009-06-11switch minix to simple_fsync()Al Viro
* get minix_write_inode() to honour the second argument * now we can use simple_fsync() for minixfs Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11push BKL down into ->put_superChristoph Hellwig
Move BKL into ->put_super from the only caller. A couple of filesystems had trivial enough ->put_super (only kfree and NULLing of s_fs_info + stuff in there) to not get any locking: coda, cramfs, efs, hugetlbfs, omfs, qnx4, shmem, all others got the full treatment. Most of them probably don't need it, but I'd rather sort that out individually. Preferably after all the other BKL pushdowns in that area. [AV: original used to move lock_super() down as well; these changes are removed since we don't do lock_super() at all in generic_shutdown_super() now] [AV: fuse, btrfs and xfs are known to need no damn BKL, exempt] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-02fs/minix: return f_fsid for statfs(2)Coly Li
Make minix file system return f_fsid info for statfs(2). Signed-off-by: Coly Li <coly.li@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-22Update my email addressGertjan van Wingerde
Update all previous incarnations of my email address to the correct one. Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-22fs/Kconfig: move minix outAlexey Dobriyan
2009-01-06minix: fix add link's wrong position calculationEvgeniy Dushistov
Fix the add link method. The oosition in the directory was calculated in wrong way - it had the incorrect shift direction. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: <stable@kernel.org> [2.6.lots] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-14CRED: Wrap task credential accesses in the Minix filesystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-07-26SL*B: drop kmem cache argument from constructorAlexey Dobriyan
Kmem cache passed to constructor is only needed for constructors that are themselves multiplexeres. Nobody uses this "feature", nor does anybody uses passed kmem cache in non-trivial way, so pass only pointer to object. Non-trivial places are: arch/powerpc/mm/init_64.c arch/powerpc/mm/hugetlbpage.c This is flag day, yes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Matt Mackall <mpm@selenic.com> [akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c] [akpm@linux-foundation.org: fix mm/slab.c] [akpm@linux-foundation.org: fix ubifs] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25minix: remove !NO_TRUNCATE codeAdrian Bunk
This patch removes the !NO_TRUNCATE code that anyway required a manual editing of the code for being used. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07iget: stop the MINIX filesystem from using iget() and read_inode()David Howells
Stop the MINIX filesystem from using iget() and read_inode(). Replace minix_read_inode() with minix_iget(), and call that instead of iget(). minix_iget() then uses iget_locked() directly and returns a proper error code instead of an inode in the event of an error. minix_fill_super() returns any error incurred when getting the root inode instead of EINVAL. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17limit minixfs printks on corrupted dir i_sizeEric Sandeen
This attempts to address CVE-2006-6058 http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2006-6058 first reported at http://projects.info-pull.com/mokb/MOKB-17-11-2006.html Essentially a corrupted minix dir inode reporting a very large i_size will loop for a very long time in minix_readdir, minix_find_entry, etc, because on EIO they just move on to try the next page. This is under the BKL, printk-storming as well. This can lock up the machine for a very long time. Simply ratelimiting the printks gets things back under control. Make the message a bit more informative while we're here. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Cc: Bodo Eggert <7eggert@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17fs: mark nibblemap constPhilippe De Muyter
Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Slab API: remove useless ctor parameter and reorder parametersChristoph Lameter
Slab constructors currently have a flags parameter that is never used. And the order of the arguments is opposite to other slab functions. The object pointer is placed before the kmem_cache pointer. Convert ctor(void *object, struct kmem_cache *s, unsigned long flags) to ctor(struct kmem_cache *s, void *object) throughout the kernel [akpm@linux-foundation.org: coupla fixes] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16minixfs: convert to new aopsNick Piggin
Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Andries Brouwer <Andries.Brouwer@cwi.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10sendfile: remove .sendfile from filesystems that use generic_file_sendfile()Jens Axboe
They can use generic_file_splice_read() instead. Since sys_sendfile() now prefers that, there should be no change in behaviour. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07mm: make read_cache_page synchronousNick Piggin
Ensure pages are uptodate after returning from read_cache_page, which allows us to cut out most of the filesystem-internal PageUptodate calls. I didn't have a great look down the call chains, but this appears to fixes 7 possible use-before uptodate in hfs, 2 in hfsplus, 1 in jfs, a few in ecryptfs, 1 in jffs2, and a possible cleared data overwritten with readpage in block2mtd. All depending on whether the filler is async and/or can return with a !uptodate page. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct inode_operations const 2Arjan van de Ven
2007-02-12[PATCH] Minix V3 supportAndries Brouwer
This morning I needed to read a Minix V3 filesystem, but unfortunately my 2.6.19 did not support that, and neither did the downloaded 2.6.20rc4. Fortunately, google told me that Daniel Aragones had already done the work, patch found at http://www.terra.es/personal2/danarag/ Unfortunaly, looking at the patch was painful to my eyes, so I polished it a bit before applying. The resulting kernel boots, and reads the filesystem it needed to read. Signed-off-by: Daniel Aragones <danarag@gmail.com> Signed-off-by: Andries Brouwer <aeb@cwi.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] struct path: convert minixJosef Sipek
2006-10-11[PATCH] fs/*: use BUILD_BUG_ONAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: David Howells <dhowells@redhat.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] r/o bind mounts: unlink: monitor i_nlinkDave Hansen
When a filesystem decrements i_nlink to zero, it means that a write must be performed in order to drop the inode from the filesystem. We're shortly going to have keep filesystems from being remounted r/o between the time that this i_nlink decrement and that write occurs. So, add a little helper function to do the decrements. We'll tie into it in a bit to note when i_nlink hits zero. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Streamline generic_file_* interfaces and filemap cleanupsBadari Pulavarty
This patch cleans up generic_file_*_read/write() interfaces. Christoph Hellwig gave me the idea for this clean ups. In a nutshell, all filesystems should set .aio_read/.aio_write methods and use do_sync_read/ do_sync_write() as their .read/.write methods. This allows us to cleanup all variants of generic_file_* routines. Final available interfaces: generic_file_aio_read() - read handler generic_file_aio_write() - write handler generic_file_aio_write_nolock() - no lock write handler __generic_file_aio_write_nolock() - internal worker routine Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] Really ignore kmem_cache_destroy return valueAlexey Dobriyan
* Rougly half of callers already do it by not checking return value * Code in drivers/acpi/osl.c does the following to be sure: (void)kmem_cache_destroy(cache); * Those who check it printk something, however, slab_error already printed the name of failed cache. * XFS BUGs on failed kmem_cache_destroy which is not the decision low-level filesystem driver should make. Converted to ignore. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] fs: Conversions from kmalloc+memset to k(z|c)allocPanagiotis Issaris
Conversions from kmalloc+memset to kzalloc. Signed-off-by: Panagiotis Issaris <takis@issaris.org> Jffs2-bit-acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
