commit 1064f874abc0d05eeed8993815f584d847b72486 upstream.
Ever since mount propagation was introduced in cases where a mount in
propagated to parent mount mountpoint pair that is already in use the
code has placed the new mount behind the old mount in the mount hash
table.
This implementation detail is problematic as it allows creating
arbitrary length mount hash chains.
Furthermore it invalidates the constraint maintained elsewhere in the
mount code that a parent mount and a mountpoint pair will have exactly
one mount upon them. Making it hard to deal with and to talk about
this special case in the mount code.
Modify mount propagation to notice when there is already a mount at
the parent mount and mountpoint where a new mount is propagating to
and place that preexisting mount on top of the new mount.
Modify unmount propagation to notice when a mount that is being
unmounted has another mount on top of it (and no other children), and
to replace the unmounted mount with the mount on top of it.
Move the MNT_UMUONT test from __lookup_mnt_last into
__propagate_umount as that is the only call of __lookup_mnt_last where
MNT_UMOUNT may be set on any mount visible in the mount hash table.
These modifications allow:
- __lookup_mnt_last to be removed.
- attach_shadows to be renamed __attach_mnt and its shadow
handling to be removed.
- commit_tree to be simplified
- copy_tree to be simplified
The result is an easier to understand tree of mounts that does not
allow creation of arbitrary length hash chains in the mount hash table.
The result is also a very slight userspace visible difference in semantics.
The following two cases now behave identically, where before order
mattered:
case 1: (explicit user action)
B is a slave of A
mount something on A/a , it will propagate to B/a
and than mount something on B/a
case 2: (tucked mount)
B is a slave of A
and than mount something on A/a
Histroically umount A/a would fail in case 1 and succeed in case 2.
Now umount A/a succeeds in both configurations.
This very small change in semantics appears if anything to be a bug
fix to me and my survey of userspace leads me to believe that no programs
will notice or care of this subtle semantic change.
v2: Updated to mnt_change_mountpoint to not call dput or mntput
and instead to decrement the counts directly. It is guaranteed
that there will be other references when mnt_change_mountpoint is
called so this is safe.
v3: Moved put_mountpoint under mount_lock in attach_recursive_mnt
As the locking in fs/namespace.c changed between v2 and v3.
v4: Reworked the logic in propagate_mount_busy and __propagate_umount
that detects when a mount completely covers another mount.
v5: Removed unnecessary tests whose result is alwasy true in
find_topper and attach_recursive_mnt.
v6: Document the user space visible semantic difference.
Fixes: b90fa9ae8f51 ("[PATCH] shared mount handling: bind and rbind")
Tested-by: Andrei Vagin <avagin@virtuozzo.com>
CAI Qian <caiqian@redhat.com> pointed out that the semantics
of shared subtrees make it possible to create an exponentially
increasing number of mounts in a mount namespace.
mkdir /tmp/1 /tmp/2
mount --make-rshared /
for i in $(seq 1 20) ; do mount --bind /tmp/1 /tmp/2 ; done
Will create create 2^20 or 1048576 mounts, which is a practical problem
as some people have managed to hit this by accident.
As such CVE-2016-6213 was assigned.
Ian Kent <raven@themaw.net> described the situation for autofs users
as follows:
> The number of mounts for direct mount maps is usually not very large because of
> the way they are implemented, large direct mount maps can have performance
> problems. There can be anywhere from a few (likely case a few hundred) to less
> than 10000, plus mounts that have been triggered and not yet expired.
> Indirect mounts have one autofs mount at the root plus the number of mounts that
> The number of autofs indirect map entries can range from a few to the common
> case of several thousand and in rare cases up to between 30000 and 50000. I've
> not heard of people with maps larger than 50000 entries.
> The larger the number of map entries the greater the possibility for a large
> number of active mounts so it's not hard to expect cases of a 1000 or somewhat
> more active mounts.
So I am setting the default number of mounts allowed per mount
namespace at 100,000. This is more than enough for any use case I
know of, but small enough to quickly stop an exponential increase
in mounts. Which should be perfect to catch misconfigurations and
malfunctioning programs.
For anyone who needs a higher limit this can be changed by writing
to the new /proc/sys/fs/mount-max sysctl.
Tested-by: CAI Qian <caiqian@redhat.com>
v2: Fixed the very obvious lack of setting ucounts
on struct mnt_ns reported by Andrei Vagin, and the kbuild
test report.
Reported-by: Andrei Vagin <avagin@openvz.org>
A patchset to remove support for passing pre-allocated struct seq_file to
seq_open(). Such feature is undocumented and prone to error.
In particular, if seq_release() is used in release handler, it will
kfree() a pointer which was not allocated by seq_open().
So this patchset drops support for pre-allocated struct seq_file: it's
only of use in proc_namespace.c and can be easily replaced by using
seq_open_private()/seq_release_private().
Additionally, it documents the use of file->private_data to hold pointer
to struct seq_file by seq_open().
This patch (of 3):
Since patch described below, from v2.6.15-rc1, seq_open() could use a
struct seq_file already allocated by the caller if the pointer to the
structure is stored in file->private_data before calling the function.
Commit 1abe77b0fc4b485927f1f798ae81a752677e1d05
Author: Al Viro <viro@zeniv.linux.org.uk>
Date: Mon Nov 7 17:15:34 2005 -0500
[PATCH] allow callers of seq_open do allocation themselves
Allow caller of seq_open() to kmalloc() seq_file + whatever else they
want and set ->private_data to it. seq_open() will then abstain from
doing allocation itself.
Such behavior is only used by mounts_open_common().
In order to drop support for such uncommon feature, proc_mounts is
converted to use seq_open_private(), which take care of allocating the
proc_mounts structure, making it available through ->private in struct
seq_file.
Conversely, proc_mounts is converted to use seq_release_private(), in
order to release the private structure allocated by seq_open_private().
Then, ->private is used directly instead of proc_mounts() macro to access
to the proc_mounts structure.
Link: http://lkml.kernel.org/r/cover.1433193673.git.ydroneaud@opteya.com
Signed-off-by: Yann Droneaud <ydroneaud@opteya.com>
same as legitimize_mnt(), except that it does *not* drop and regain
rcu_read_lock; return values are
0 => grabbed a reference, we are fine
1 => failed, just go away
-1 => failed, go away and mntput(bastard) when outside of rcu_read_lock
for now - just move corresponding ->proc_inum instances over there
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
The new function detach_mounts comes in two pieces. The first piece
is a static inline test of d_mounpoint that returns immediately
without taking any locks if d_mounpoint is not set. In the common
case when mountpoints are absent this allows the vfs to continue
running with it's same cacheline foot print.
The second piece of detach_mounts __detach_mounts actually does the
work and it assumes that a mountpoint is present so it is slow and
takes namespace_sem for write, and then locks the mount hash (aka
mount_lock) after a struct mountpoint has been found.
With those two locks held each entry on the list of mounts on a
mountpoint is selected and lazily unmounted until all of the mount
have been lazily unmounted.
v7: Wrote a proper change description and removed the changelog
documenting deleted wrong turns.
Signed-off-by: Eric W. Biederman <ebiederman@twitter.com>
To spot any possible problems call BUG if a mountpoint
is put when it's list of mounts is not empty.
AV: use hlist instead of list_head
Reviewed-by: Miklos Szeredi <miklos@szeredi.hu>
In preparation for allowing mountpoints to be renamed and unlinked
in remote filesystems and in other mount namespaces test if on a dentry
there is a mount in the local mount namespace before allowing it to
be renamed or unlinked.
The primary motivation here are old versions of fusermount unmount
which is not safe if the a path can be renamed or unlinked while it is
verifying the mount is safe to unmount. More recent versions are simpler
and safer by simply using UMOUNT_NOFOLLOW when unmounting a mount
in a directory owned by an arbitrary user.
Miklos Szeredi <miklos@szeredi.hu> reports this is approach is good
enough to remove concerns about new kernels mixed with old versions
of fusermount.
A secondary motivation for restrictions here is that it removing empty
directories that have non-empty mount points on them appears to
violate the rule that rmdir can not remove empty directories. As
Linus Torvalds pointed out this is useful for programs (like git) that
test if a directory is empty with rmdir.
Therefore this patch arranges to enforce the existing mount point
semantics for local mount namespace.
v2: Rewrote the test to be a drop in replacement for d_mountpoint
v3: Use bool instead of int as the return type of is_local_mountpoint
On final mntput() we want fs shutdown to happen before return to
userland; however, the only case where we want it happen right
there (i.e. where task_work_add won't do) is MNT_INTERNAL victim.
Those have to be fully synchronous - failure halfway through module
init might count on having vfsmount killed right there. Fortunately,
final mntput on MNT_INTERNAL vfsmounts happens on shallow stack.
So we handle those synchronously and do an analog of delayed fput
logics for everything else.
As the result, we are guaranteed that fs shutdown will always happen
on shallow stack.
Rather than playing silly buggers with vfsmount refcounts, just have
acct_on() ask fs/namespace.c for internal clone of file->f_path.mnt
and replace it with said clone. Then attach the pin to original
vfsmount. Voila - the clone will be alive until the file gets closed,
making sure that underlying superblock remains active, etc., and
we can drop the original vfsmount, so that it's not kept busy.
If the file lives until the final mntput of the original vfsmount,
we'll notice that there's an fs_pin (one in bsd_acct_struct that
holds that file) and mnt_pin_kill() will take it out. Since
->kill() is synchronous, we won't proceed past that point until
these files are closed (and private clones of our vfsmount are
gone), so we get the same ordering warranties we used to get.
mnt_pin()/mnt_unpin()/->mnt_pinned is gone now, and good riddance -
it never became usable outside of kernel/acct.c (and racy wrt
umount even there).
Put these suckers on per-vfsmount and per-superblock lists instead.
Note: right now it's still acct_lock for everything, but that's
going to change.
fixes RCU bug - walking through hlist is safe in face of element moves,
since it's self-terminating. Cyclic lists are not - if we end up jumping
to another hash chain, we'll loop infinitely without ever hitting the
original list head.
[fix for dumb braino folded]
Spotted by: Max Kellermann <mk@cm4all.com>
Cc: stable@vger.kernel.org
* switch allocation to alloc_large_system_hash()
* make sizes overridable by boot parameters (mhash_entries=, mphash_entries=)
* switch mountpoint_hashtable from list_head to hlist_head
A bug was introduced with the is_mounted helper function in
commit f7a99c5b7c8bd3d3f533c8b38274e33f3da9096e
Date: Sat Jun 9 00:59:08 2012 -0400
get rid of ->mnt_longterm
it's enough to set ->mnt_ns of internal vfsmounts to something
distinct from all struct mnt_namespace out there; then we can
just use the check for ->mnt_ns != NULL in the fast path of
mntput_no_expire()
The intent was to test if the real_mount(vfsmount)->mnt_ns was
NULL_OR_ERR but the code is actually testing real_mount(vfsmount)
and always returning true.
The result is d_absolute_path returning paths it should be hiding.
* RCU-delayed freeing of vfsmounts
* vfsmount_lock replaced with a seqlock (mount_lock)
* sequence number from mount_lock is stored in nameidata->m_seq and
used when we exit RCU mode
* new vfsmount flag - MNT_SYNC_UMOUNT. Set by umount_tree() when its
caller knows that vfsmount will have no surviving references.
* synchronize_rcu() done between unlocking namespace_sem in namespace_unlock()
and doing pending mntput().
* new helper: legitimize_mnt(mnt, seq). Checks the mount_lock sequence
number against seq, then grabs reference to mnt. Then it rechecks mount_lock
again to close the race and either returns success or drops the reference it
has acquired. The subtle point is that in case of MNT_SYNC_UMOUNT we can
simply decrement the refcount and sod off - aforementioned synchronize_rcu()
makes sure that final mntput() won't come until we leave RCU mode. We need
that, since we don't want to end up with some lazy pathwalk racing with
umount() and stealing the final mntput() from it - caller of umount() may
expect it to return only once the fs is shut down and we don't want to break
that. In other cases (i.e. with MNT_SYNC_UMOUNT absent) we have to do
full-blown mntput() in case of mount_lock sequence number mismatch happening
just as we'd grabbed the reference, but in those cases we won't be stealing
the final mntput() from anything that would care.
* mntput_no_expire() doesn't lock anything on the fast path now. Incidentally,
SMP and UP cases are handled the same way - no ifdefs there.
* normal pathname resolution does *not* do any writes to mount_lock. It does,
of course, bump the refcounts of vfsmount and dentry in the very end, but that's
it.
Instead of passing the direction as argument (and checking it on every
step through the hash chain), just have separate __lookup_mnt() and
__lookup_mnt_last(). And use the standard iterators...
aka br_write_{lock,unlock} of vfsmount_lock. Inlines in fs/mount.h,
vfsmount_lock extern moved over there as well.
Assign a unique proc inode to each namespace, and use that
inode number to ensure we only allocate at most one proc
inode for every namespace in proc.
A single proc inode per namespace allows userspace to test
to see if two processes are in the same namespace.
This has been a long requested feature and only blocked because
a naive implementation would put the id in a global space and
would ultimately require having a namespace for the names of
namespaces, making migration and certain virtualization tricks
impossible.
We still don't have per superblock inode numbers for proc, which
appears necessary for application unaware checkpoint/restart and
migrations (if the application is using namespace file descriptors)
but that is now allowd by the design if it becomes important.
I have preallocated the ipc and uts initial proc inode numbers so
their structures can be statically initialized.
This will allow for support for unprivileged mounts in a new user namespace.
Acked-by: "Serge E. Hallyn" <serge@hallyn.com>
setns support for the mount namespace is a little tricky as an
arbitrary decision must be made about what to set fs->root and
fs->pwd to, as there is no expectation of a relationship between
the two mount namespaces. Therefore I arbitrarily find the root
mount point, and follow every mount on top of it to find the top
of the mount stack. Then I set fs->root and fs->pwd to that
location. The topmost root of the mount stack seems like a
reasonable place to be.
Bind mount support for the mount namespace inodes has the
possibility of creating circular dependencies between mount
namespaces. Circular dependencies can result in loops that
prevent mount namespaces from every being freed. I avoid
creating those circular dependencies by adding a sequence number
to the mount namespace and require all bind mounts be of a
younger mount namespace into an older mount namespace.
Add a helper function proc_ns_inode so it is possible to
detect when we are attempting to bind mound a namespace inode.
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
don't rely on proc_mounts->m being the first field; container_of()
is there for purpose. No need to bother with ->private, while
we are at it - the same container_of will do nicely.
mntput_no_expire()
Keep track of vfsmounts belonging to a superblock. List is protected
by vfsmount_lock.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com>
rationale: that stuff is far tighter bound to fs/namespace.c than to
the guts of procfs proper.
make IS_MNT_SLAVE take struct mount * at the same time
the second victim...
taken out of struct vfsmount into struct mount
switch __lookup_mnt() to returning struct mount *; callers adjusted.
Almost all fields of struct vfsmount are used only by core VFS (and
a fairly small part of it, at that). The plan: embed struct vfsmount
into struct mount, making the latter visible only to core parts of VFS.
Then move fields from vfsmount to mount, eventually leaving only
mnt_root/mnt_sb/mnt_flags in struct vfsmount. Filesystem code still
gets pointers to struct vfsmount and remains unchanged; all such
pointers go to struct vfsmount embedded into the instances of struct
mount allocated by fs/namespace.c. When fs/namespace.c et.al. get
a pointer to vfsmount, they turn it into pointer to mount (using
container_of) and work with that.
This is the first part of series; struct mount is introduced,
allocation switched to using it.
vfsmounts have ->mnt_parent pointing either to a different vfsmount
or to itself; it's never NULL and termination condition in loops
traversing the tree towards root is mnt == mnt->mnt_parent. At least
one place (see the next patch) is confused about what's going on;
let's add an explicit helper checking it right way and use it in
all places where we need it. Not that there had been too many,
but...
