path: root/fs/mpage.c
2011-05-26mm/fs: add hooks to support cleancacheDan Magenheimer
This fourth patch of eight in this cleancache series provides the core hooks in VFS for: initializing cleancache per filesystem; capturing clean pages reclaimed by page cache; attempting to get pages from cleancache before filesystem read; and ensuring coherency between pagecache, disk, and cleancache. Note that the placement of these hooks was stable from 2.6.18 to 2.6.38; a minor semantic change was required due to a patchset in 2.6.39. All hooks become no-ops if CONFIG_CLEANCACHE is unset, or become a check of a boolean global if CONFIG_CLEANCACHE is set but no cleancache "backend" has claimed cleancache_ops. Details and a FAQ can be found in Documentation/vm/cleancache.txt [v8: minchan.kim@gmail.com: adapt to new remove_from_page_cache function] Signed-off-by: Chris Mason <chris.mason@oracle.com> Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Reviewed-by: Jeremy Fitzhardinge <jeremy@goop.org> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik Van Riel <riel@redhat.com> Cc: Jan Beulich <JBeulich@novell.com> Cc: Andreas Dilger <adilger@sun.com> Cc: Ted Ts'o <tytso@mit.edu> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <joel.becker@oracle.com> Cc: Nitin Gupta <ngupta@vflare.org>
2011-03-10fs: make mpage read/write_pages() plugJens Axboe
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-13fs/mpage.c: consolidate codeHai Shan
Merge mpage_end_io_read() and mpage_end_io_write() into mpage_end_io() to eliminate code duplication. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Hai Shan <shan.hai@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-04Fix misspellings of "invocation" in comments.Adam Buchbinder
Some comments misspell "invocation"; this fixes them. No code changes. Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-05-13ext4: Properly initialize the buffer_head stateAneesh Kumar K.V
These struct buffer_heads are allocated on the stack (and hence are initialized with stack garbage). They are only used to call a get_blocks() function, so that's mostly OK, but b_state must be initialized to be 0 so we don't have any unexpected BH_* flags set by accident, such as BH_Unwritten or BH_Delay. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-04-01Remove two unneeded exports and make two symbols static in fs/mpage.cDmitri Vorobiev
Commit 29a814d2ee0e43c2980f33f91c1311ec06c0aa35 (vfs: add hooks for ext4's delayed allocation support) exported the following functions mpage_bio_submit() __mpage_writepage() for the benefit of ext4's delayed allocation support. Since commit a1d6cc563bfdf1bf2829d3e6ce4d8b774251796b (ext4: Rework the ext4_da_writepages() function), these functions are not used by the ext4 driver anymore. However, the now unnecessary exports still remain, and this patch removes those. Moreover, these two functions can become static again. The issue was spotted by namespacecheck. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.com> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-06do_mpage_readpage(): remove useless clear_buffer_mapped() callFranck Bui-Huu
It is known that buffer_mapped() is false in this code path. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06do_mpage_readpage(): don't submit lots of small bios on boundaryMiquel van Smoorenburg
While tracing I/O patterns with blktrace (a great tool) a few weeks ago I identified a minor issue in fs/mpage.c As the comment above mpage_readpages() says, a fs's get_block function will set BH_Boundary when it maps a block just before a block for which extra I/O is required. Since get_block() can map a range of pages, for all these pages the BH_Boundary flag will be set. But we only need to push what I/O we have accumulated at the last block of this range. This makes do_mpage_readpage() send out the largest possible bio instead of a bunch of page-sized ones in the BH_Boundary case. Signed-off-by: Miquel van Smoorenburg <mikevs@xs4all.net> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16Remove Andrew Morton's old email accountsFrancois Cami
People can use the real name an an index into MAINTAINERS to find the current email address. Signed-off-by: Francois Cami <francois.cami@free.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-11vfs: add hooks for ext4's delayed allocation supportAlex Tomas
Export mpage_bio_submit() and __mpage_writepage() for the benefit of ext4's delayed allocation support. Also change __block_write_full_page so that if buffers that have the BH_Delay flag set it will call get_block() to get the physical block allocated, just as in the !BH_Mapped case. Signed-off-by: Alex Tomas <alex@clusterfs.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-03-03docbook: fix filesystems.tmpl source filesRandy Dunlap
Fix docbook problems in filesystems.tmpl. These cause the generated docbook to be incorrect. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05Pagecache zeroing: zero_user_segment, zero_user_segments and zero_userChristoph Lameter
Simplify page cache zeroing of segments of pages through 3 functions zero_user_segments(page, start1, end1, start2, end2) Zeros two segments of the page. It takes the position where to start and end the zeroing which avoids length calculations and makes code clearer. zero_user_segment(page, start, end) Same for a single segment. zero_user(page, start, length) Length variant for the case where we know the length. We remove the zero_user_page macro. Issues: 1. Its a macro. Inline functions are preferable. 2. The KM_USER0 macro is only defined for HIGHMEM. Having to treat this special case everywhere makes the code needlessly complex. The parameter for zeroing is always KM_USER0 except in one single case that we open code. Avoiding KM_USER0 makes a lot of code not having to be dealing with the special casing for HIGHMEM anymore. Dealing with kmap is only necessary for HIGHMEM configurations. In those configurations we use KM_USER0 like we do for a series of other functions defined in highmem.h. Since KM_USER0 is depends on HIGHMEM the existing zero_user_page function could not be a macro. zero_user_* functions introduced here can be be inline because that constant is not used when these functions are called. Also extract the flushing of the caches to be outside of the kmap. [akpm@linux-foundation.org: fix nfs and ntfs build] [akpm@linux-foundation.org: fix ntfs build some more] Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Steven French <sfrench@us.ibm.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: <linux-ext4@vger.kernel.org> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: David Chinner <dgc@sgi.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Steven French <sfrench@us.ibm.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16mm: buffered write cleanupNick Piggin
Quite a bit of code is used in maintaining these "cached pages" that are probably pretty unlikely to get used. It would require a narrow race where the page is inserted concurrently while this process is allocating a page in order to create the spare page. Then a multi-page write into an uncached part of the file, to make use of it. Next, the buffered write path (and others) uses its own LRU pagevec when it should be just using the per-CPU LRU pagevec (which will cut down on both data and code size cacheline footprint). Also, these private LRU pagevecs are emptied after just a very short time, in contrast with the per-CPU pagevecs that are persistent. Net result: 7.3 times fewer lru_lock acquisitions required to add the pages to pagecache for a bulk write (in 4K chunks). [this gets rid of some cond_resched() calls in readahead.c and mpage.c due to clashes in -mm. What put them there, and why? ] Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10Drop 'size' argument from bio_endio and bi_end_ioNeilBrown
As bi_end_io is only called once when the reqeust is complete, the 'size' argument is now redundant. Remove it. Now there is no need for bio_endio to subtract the size completed from bi_size. So don't do that either. While we are at it, change bi_end_io to return void. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-05-11consolidate generic_writepages and mpage_writepagesMiklos Szeredi
Clean up massive code duplication between mpage_writepages() and generic_writepages(). The new generic function, write_cache_pages() takes a function pointer argument, which will be called for each page to be written. Maybe cifs_writepages() too can use this infrastructure, but I'm not touching that with a ten-foot pole. The upcoming page writeback support in fuse will also want this. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09fs: convert core functions to zero_user_pageNate Diller
It's very common for file systems to need to zero part or all of a page, the simplist way is just to use kmap_atomic() and memset(). There's actually a library function in include/linux/highmem.h that does exactly that, but it's confusingly named memclear_highpage_flush(), which is descriptive of *how* it does the work rather than what the *purpose* is. So this patchset renames the function to zero_user_page(), and calls it from the various places that currently open code it. This first patch introduces the new function call, and converts all the core kernel callsites, both the open-coded ones and the old memclear_highpage_flush() ones. Following this patch is a series of conversions for each file system individually, per AKPM, and finally a patch deprecating the old call. The diffstat below shows the entire patchset. [akpm@linux-foundation.org: fix a few things] Signed-off-by: Nate Diller <nate.diller@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Factor outstanding I/O error handlingGuillaume Chazarain
Cleanup: setting an outstanding error on a mapping was open coded too many times. Factor it out in mapping_set_error(). Signed-off-by: Guillaume Chazarain <guichaz@yahoo.fr> Cc: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-30[PATCH] BLOCK: Dissociate generic_writepages() from mpage stuff [try #6]David Howells
Dissociate the generic_writepages() function from the mpage stuff, moving its declaration to linux/mm.h and actually emitting a full implementation into mm/page-writeback.c. The implementation is a partial duplicate of mpage_writepages() with all BIO references removed. It is used by NFS to do writeback. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-06-23[PATCH] writeback: fix range handlingOGAWA Hirofumi
When a writeback_control's `start' and `end' fields are used to indicate a one-byte-range starting at file offset zero, the required values of .start=0,.end=0 mean that the ->writepages() implementation has no way of telling that it is being asked to perform a range request. Because we're currently overloading (start == 0 && end == 0) to mean "this is not a write-a-range request". To make all this sane, the patch changes range of writeback_control. So caller does: If it is calling ->writepages() to write pages, it sets range (range_start/end or range_cyclic) always. And if range_cyclic is true, ->writepages() thinks the range is cyclic, otherwise it just uses range_start and range_end. This patch does, - Add LLONG_MAX, LLONG_MIN, ULLONG_MAX to include/linux/kernel.h -1 is usually ok for range_end (type is long long). But, if someone did, range_end += val; range_end is "val - 1" u64val = range_end >> bits; u64val is "~(0ULL)" or something, they are wrong. So, this adds LLONG_MAX to avoid nasty things, and uses LLONG_MAX for range_end. - All callers of ->writepages() sets range_start/end or range_cyclic. - Fix updates of ->writeback_index. It seems already bit strange. If it starts at 0 and ended by check of nr_to_write, this last index may reduce chance to scan end of file. So, this updates ->writeback_index only if range_cyclic is true or whole-file is scanned. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Nathan Scott <nathans@sgi.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: Steven French <sfrench@us.ibm.com> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] map multiple blocks for mpage_readpages()Badari Pulavarty
This patch changes mpage_readpages() and get_block() to get the disk mapping information for multiple blocks at the same time. b_size represents the amount of disk mapping that needs to mapped. On the successful get_block() b_size indicates the amount of disk mapping thats actually mapped. Only the filesystems who care to use this information and provide multiple disk blocks at a time can choose to do so. No changes are needed for the filesystems who wants to ignore this. [akpm@osdl.org: cleanups] Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Cc: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] pass b_size to ->get_block()Badari Pulavarty
Pass amount of disk needs to be mapped to get_block(). This way one can modify the fs ->get_block() functions to map multiple blocks at the same time. [akpm@osdl.org: performance tweak] [akpm@osdl.org: remove unneeded assignments] Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] fix possible PAGE_CACHE_SHIFT overflowsAndrew Morton
We've had two instances recently of overflows when doing 64_bit_value = (32_bit_value << PAGE_CACHE_SHIFT) I did a tree-wide grep of `<<.*PAGE_CACHE_SHIFT' and this is the result. - afs_rxfs_fetch_descriptor.offset is of type off_t, which seems broken. - jfs and jffs are limited to 4GB anyway. - reiserfs map_block_for_writepage() takes an unsigned long for the block - it should take sector_t. (It'll fail for huge filesystems with blocksize<PAGE_CACHE_SIZE) - cramfs_read() needs to use sector_t (I think cramsfs is busted on large filesystems anyway) - affs is limited in file size anyway. - I generally didn't fix 32-bit overflows in directory operations. - arm's __flush_dcache_page() is peculiar. What if the page lies beyond 4G? - gss_wrap_req_priv() needs checking (snd_buf->page_base) Cc: Oleg Drokin <green@linuxhacker.ru> Cc: David Howells <dhowells@redhat.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: <reiserfs-dev@namesys.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: <linux-fsdevel@vger.kernel.org> Cc: Miklos Szeredi <miklos@szeredi.hu> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[PATCH] add AOP_TRUNCATED_PAGE, prepend AOP_ to WRITEPAGE_ACTIVATEZach Brown
readpage(), prepare_write(), and commit_write() callers are updated to understand the special return code AOP_TRUNCATED_PAGE in the style of writepage() and WRITEPAGE_ACTIVATE. AOP_TRUNCATED_PAGE tells the caller that the callee has unlocked the page and that the operation should be tried again with a new page. OCFS2 uses this to detect and work around a lock inversion in its aop methods. There should be no change in behaviour for methods that don't return AOP_TRUNCATED_PAGE. WRITEPAGE_ACTIVATE is also prepended with AOP_ for consistency and they are made enums so that kerneldoc can be used to document their semantics. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-04[PATCH] mpage_end_io_write() I/O error handling fixQu Fuping
When fsync() runs wait_on_page_writeback_range() it only inspects pages which are actually under I/O (PAGECACHE_TAG_WRITEBACK). If a page completed I/O prior to wait_on_page_writeback_range() looking at it, it is supposed to have recorded its I/O error state in the address_space. But mpage_mpage_end_io_write() forgot to set the address_space error flag in this case. Signed-off-by: Qu Fuping <fs@ercist.iscas.ac.cn> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] make some things staticAdrian Bunk
This patch makes some needlessly global identifiers static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Arjan van de Ven <arjanv@infradead.org> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] revert ext3-writepages-support-for-writeback-modeAndrew Morton
This had a fatal lock ranking bug: we do journal_start outside mpage_writepages()'s lock_page(). Revert the whole thing, think again. Credit-to: Jan Kara <jack@suse.cz> For identifying the bug. Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] DocBook: fix some descriptionsMartin Waitz
Some KernelDoc descriptions are updated to match the current code. No code changes. Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] mpage_writepages() page locking fixNikita Danilov
When ->writepage() returns WRITEPAGE_ACTIVATE, the page is still locked. Explicitly unlock the page in mpage_writepages(). Signed-off-by: Nikita Danilov <nikita@clusterfs.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
