commit 30aba6656f61ed44cba445a3c0d38b296fa9e8f5 upstream.
Disallows open of FIFOs or regular files not owned by the user in world
writable sticky directories, unless the owner is the same as that of the
directory or the file is opened without the O_CREAT flag. The purpose
is to make data spoofing attacks harder. This protection can be turned
on and off separately for FIFOs and regular files via sysctl, just like
the symlinks/hardlinks protection. This patch is based on Openwall's
"HARDEN_FIFO" feature by Solar Designer.
This is a brief list of old vulnerabilities that could have been prevented
by this feature, some of them even allow for privilege escalation:
CVE-2000-1134
CVE-2007-3852
CVE-2008-0525
CVE-2009-0416
CVE-2011-4834
CVE-2015-1838
CVE-2015-7442
CVE-2016-7489
This list is not meant to be complete. It's difficult to track down all
vulnerabilities of this kind because they were often reported without any
mention of this particular attack vector. In fact, before
hardlinks/symlinks restrictions, fifos/regular files weren't the favorite
vehicle to exploit them.
[s.mesoraca16@gmail.com: fix bug reported by Dan Carpenter]
Link: https://lkml.kernel.org/r/20180426081456.GA7060@mwanda
Link: http://lkml.kernel.org/r/1524829819-11275-1-git-send-email-s.mesoraca16@gmail.com
[keescook@chromium.org: drop pr_warn_ratelimited() in favor of audit changes in the future]
[keescook@chromium.org: adjust commit subjet]
Link: http://lkml.kernel.org/r/20180416175918.GA13494@beast
Signed-off-by: Salvatore Mesoraca <s.mesoraca16@gmail.com>
Suggested-by: Solar Designer <solar@openwall.com>
Suggested-by: Kees Cook <keescook@chromium.org>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Cc: Loic <hackurx@opensec.fr>
commit 30ce4d1903e1d8a7ccd110860a5eef3c638ed8be upstream.
missed it in "kill struct filename.separate" several years ago.
Cc: stable@vger.kernel.org
commit 95dd77580ccd66a0da96e6d4696945b8cea39431 upstream.
On nfsv2 and nfsv3 the nfs server can export subsets of the same
filesystem and report the same filesystem identifier, so that the nfs
client can know they are the same filesystem. The subsets can be from
disjoint directory trees. The nfsv2 and nfsv3 filesystems provides no
way to find the common root of all directory trees exported form the
server with the same filesystem identifier.
The practical result is that in struct super s_root for nfs s_root is
not necessarily the root of the filesystem. The nfs mount code sets
s_root to the root of the first subset of the nfs filesystem that the
kernel mounts.
This effects the dcache invalidation code in generic_shutdown_super
currently called shrunk_dcache_for_umount and that code for years
has gone through an additional list of dentries that might be dentry
trees that need to be freed to accomodate nfs.
When I wrote path_connected I did not realize nfs was so special, and
it's hueristic for avoiding calling is_subdir can fail.
The practical case where this fails is when there is a move of a
directory from the subtree exposed by one nfs mount to the subtree
exposed by another nfs mount. This move can happen either locally or
remotely. With the remote case requiring that the move directory be cached
before the move and that after the move someone walks the path
to where the move directory now exists and in so doing causes the
already cached directory to be moved in the dcache through the magic
of d_splice_alias.
If someone whose working directory is in the move directory or a
subdirectory and now starts calling .. from the initial mount of nfs
(where s_root == mnt_root), then path_connected as a heuristic will
not bother with the is_subdir check. As s_root really is not the root
of the nfs filesystem this heuristic is wrong, and the path may
actually not be connected and path_connected can fail.
The is_subdir function might be cheap enough that we can call it
unconditionally. Verifying that will take some benchmarking and
the result may not be the same on all kernels this fix needs
to be backported to. So I am avoiding that for now.
Filesystems with snapshots such as nilfs and btrfs do something
similar. But as the directory tree of the snapshots are disjoint
from one another and from the main directory tree rename won't move
things between them and this problem will not occur.
Reported-by: Al Viro <viro@ZenIV.linux.org.uk>
Fixes: 397d425dc26d ("vfs: Test for and handle paths that are unreachable from their mnt_root")
[ Upstream commit bbc3e471011417598e598707486f5d8814ec9c01 ]
When vfs_submount was added the test to limit automounts from
filesystems that with s_user_ns != &init_user_ns accidentially left
in follow_automount. The test was never about any security concerns
and was always about how do we implement this for filesystems whose
s_user_ns != &init_user_ns.
At the moment this check makes no difference as there are no
filesystems that both set FS_USERNS_MOUNT and implement d_automount.
Remove this check now while I am thinking about it so there will not
be odd booby traps for someone who does want to make this combination
work.
vfs_submount still needs improvements to allow this combination to work,
and vfs_submount contains a check that presents a warning.
The autofs4 filesystem could be modified to set FS_USERNS_MOUNT and it would
need not work on this code path, as userspace performs the mounts.
Fixes: 93faccbbfa95 ("fs: Better permission checking for submounts")
Fixes: aeaa4a79ff6a ("fs: Call d_automount with the filesystems creds")
Acked-by: Ian Kent <raven@themaw.net>
commit 5d38f049cee1e1c4a7ac55aa79d37d01ddcc3860 upstream.
Commit 42f461482178 ("autofs: fix AT_NO_AUTOMOUNT not being honored")
allowed the fstatat(2) system call to properly honor the AT_NO_AUTOMOUNT
flag but introduced a semantic change.
In order to honor AT_NO_AUTOMOUNT a semantic change was made to the
negative dentry case for stat family system calls in follow_automount().
This changed the unconditional triggering of an automount in this case
to no longer be done and an error returned instead.
This has caused more problems than I expected so reverting the change is
needed.
In a discussion with Neil Brown it was concluded that the automount(8)
daemon can implement this change without kernel modifications. So that
will be done instead and the autofs module documentation updated with a
description of the problem and what needs to be done by module users for
this specific case.
Link: http://lkml.kernel.org/r/151174730120.6162.3848002191530283984.stgit@pluto.themaw.net
Fixes: 42f4614821 ("autofs: fix AT_NO_AUTOMOUNT not being honored")
Signed-off-by: Ian Kent <raven@themaw.net>
Cc: Neil Brown <neilb@suse.com>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Cc: Colin Walters <walters@redhat.com>
Cc: Ondrej Holy <oholy@redhat.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Pull mount flag updates from Al Viro:
"Another chunk of fmount preparations from dhowells; only trivial
conflicts for that part. It separates MS_... bits (very grotty
mount(2) ABI) from the struct super_block ->s_flags (kernel-internal,
only a small subset of MS_... stuff).
This does *not* convert the filesystems to new constants; only the
infrastructure is done here. The next step in that series is where the
conflicts would be; that's the conversion of filesystems. It's purely
mechanical and it's better done after the merge, so if you could run
something like
list=$(for i in MS_RDONLY MS_NOSUID MS_NODEV MS_NOEXEC MS_SYNCHRONOUS MS_MANDLOCK MS_DIRSYNC MS_NOATIME MS_NODIRATIME MS_SILENT MS_POSIXACL MS_KERNMOUNT MS_I_VERSION MS_LAZYTIME; do git grep -l $i fs drivers/staging/lustre drivers/mtd ipc mm include/linux; done|sort|uniq|grep -v '^fs/namespace.c$')
sed -i -e 's/\<MS_RDONLY\>/SB_RDONLY/g' \
-e 's/\<MS_NOSUID\>/SB_NOSUID/g' \
-e 's/\<MS_NODEV\>/SB_NODEV/g' \
-e 's/\<MS_NOEXEC\>/SB_NOEXEC/g' \
-e 's/\<MS_SYNCHRONOUS\>/SB_SYNCHRONOUS/g' \
-e 's/\<MS_MANDLOCK\>/SB_MANDLOCK/g' \
-e 's/\<MS_DIRSYNC\>/SB_DIRSYNC/g' \
-e 's/\<MS_NOATIME\>/SB_NOATIME/g' \
-e 's/\<MS_NODIRATIME\>/SB_NODIRATIME/g' \
-e 's/\<MS_SILENT\>/SB_SILENT/g' \
-e 's/\<MS_POSIXACL\>/SB_POSIXACL/g' \
-e 's/\<MS_KERNMOUNT\>/SB_KERNMOUNT/g' \
-e 's/\<MS_I_VERSION\>/SB_I_VERSION/g' \
-e 's/\<MS_LAZYTIME\>/SB_LAZYTIME/g' \
$list
and commit it with something along the lines of 'convert filesystems
away from use of MS_... constants' as commit message, it would save a
quite a bit of headache next cycle"
* 'work.mount' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
VFS: Differentiate mount flags (MS_*) from internal superblock flags
VFS: Convert sb->s_flags & MS_RDONLY to sb_rdonly(sb)
vfs: Add sb_rdonly(sb) to query the MS_RDONLY flag on s_flags
The fstatat(2) and statx() calls can pass the flag AT_NO_AUTOMOUNT which
is meant to clear the LOOKUP_AUTOMOUNT flag and prevent triggering of an
automount by the call. But this flag is unconditionally cleared for all
stat family system calls except statx().
stat family system calls have always triggered mount requests for the
negative dentry case in follow_automount() which is intended but prevents
the fstatat(2) and statx() AT_NO_AUTOMOUNT case from being handled.
In order to handle the AT_NO_AUTOMOUNT for both system calls the negative
dentry case in follow_automount() needs to be changed to return ENOENT
when the LOOKUP_AUTOMOUNT flag is clear (and the other required flags are
clear).
AFAICT this change doesn't have any noticable side effects and may, in
some use cases (although I didn't see it in testing) prevent unnecessary
callbacks to the automount daemon.
It's also possible that a stat family call has been made with a path that
is in the process of being mounted by some other process. But stat family
calls should return the automount state of the path as it is "now" so it
shouldn't wait for mount completion.
This is the same semantic as the positive dentry case already handled.
Link: http://lkml.kernel.org/r/150216641255.11652.4204561328197919771.stgit@pluto.themaw.net
Fixes: deccf497d804a4c5fca ("Make stat/lstat/fstatat pass AT_NO_AUTOMOUNT to vfs_statx()")
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux
Pull structure randomization updates from Kees Cook:
"Now that IPC and other changes have landed, enable manual markings for
randstruct plugin, including the task_struct.
This is the rest of what was staged in -next for the gcc-plugins, and
comes in three patches, largest first:
- mark "easy" structs with __randomize_layout
- mark task_struct with an optional anonymous struct to isolate the
__randomize_layout section
- mark structs to opt _out_ of automated marking (which will come
later)
And, FWIW, this continues to pass allmodconfig (normal and patched to
enable gcc-plugins) builds of x86_64, i386, arm64, arm, powerpc, and
s390 for me"
* tag 'gcc-plugins-v4.13-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux:
randstruct: opt-out externally exposed function pointer structs
task_struct: Allow randomized layout
randstruct: Mark various structs for randomization
Firstly by applying the following with coccinelle's spatch:
@@ expression SB; @@
-SB->s_flags & MS_RDONLY
+sb_rdonly(SB)
to effect the conversion to sb_rdonly(sb), then by applying:
@@ expression A, SB; @@
-(!sb_rdonly(SB)) && A
+!sb_rdonly(SB) && A
-A != (sb_rdonly(SB))
+A != sb_rdonly(SB)
-A == (sb_rdonly(SB))
+A == sb_rdonly(SB)
-!(sb_rdonly(SB))
+!sb_rdonly(SB)
-A && (sb_rdonly(SB))
+A && sb_rdonly(SB)
-A || (sb_rdonly(SB))
+A || sb_rdonly(SB)
-(sb_rdonly(SB)) != A
+sb_rdonly(SB) != A
-(sb_rdonly(SB)) == A
+sb_rdonly(SB) == A
-(sb_rdonly(SB)) && A
+sb_rdonly(SB) && A
-(sb_rdonly(SB)) || A
+sb_rdonly(SB) || A
@@ expression A, B, SB; @@
-(sb_rdonly(SB)) ? 1 : 0
+sb_rdonly(SB)
-(sb_rdonly(SB)) ? A : B
+sb_rdonly(SB) ? A : B
to remove left over excess bracketage and finally by applying:
-(A & MS_RDONLY) != sb_rdonly(SB)
+(bool)(A & MS_RDONLY) != sb_rdonly(SB)
-(A & MS_RDONLY) == sb_rdonly(SB)
+(bool)(A & MS_RDONLY) == sb_rdonly(SB)
to make comparisons against the result of sb_rdonly() (which is a bool)
work correctly.
Pull ->s_options removal from Al Viro:
"Preparations for fsmount/fsopen stuff (coming next cycle). Everything
gets moved to explicit ->show_options(), killing ->s_options off +
some cosmetic bits around fs/namespace.c and friends. Basically, the
stuff needed to work with fsmount series with minimum of conflicts
with other work.
It's not strictly required for this merge window, but it would reduce
the PITA during the coming cycle, so it would be nice to have those
bits and pieces out of the way"
isofs: Fix isofs_show_options()
VFS: Kill off s_options and helpers
orangefs: Implement show_options
9p: Implement show_options
isofs: Implement show_options
afs: Implement show_options
affs: Implement show_options
befs: Implement show_options
spufs: Implement show_options
bpf: Implement show_options
ramfs: Implement show_options
pstore: Implement show_options
omfs: Implement show_options
hugetlbfs: Implement show_options
VFS: Don't use save/replace_mount_options if not using generic_show_options
VFS: Provide empty name qstr
VFS: Make get_filesystem() return the affected filesystem
VFS: Clean up whitespace in fs/namespace.c and fs/super.c
Provide a function to create a NUL-terminated string from unterminated data
Pull misc filesystem updates from Al Viro:
"Assorted normal VFS / filesystems stuff..."
* 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
dentry name snapshots
Make statfs properly return read-only state after emergency remount
fs/dcache: init in_lookup_hashtable
minix: Deinline get_block, save 2691 bytes
fs: Reorder inode_owner_or_capable() to avoid needless
fs: warn in case userspace lied about modprobe return
take_dentry_name_snapshot() takes a safe snapshot of dentry name;
if the name is a short one, it gets copied into caller-supplied
structure, otherwise an extra reference to external name is grabbed
(those are never modified). In either case the pointer to stable
string is stored into the same structure.
dentry must be held by the caller of take_dentry_name_snapshot(),
but may be freely dropped afterwards - the snapshot will stay
until destroyed by release_dentry_name_snapshot().
Intended use:
struct name_snapshot s;
take_dentry_name_snapshot(&s, dentry);
access s.name
release_dentry_name_snapshot(&s);
Replaces fsnotify_oldname_...(), gets used in fsnotify to obtain the name
to pass down with event.
Provide an empty name (ie. "") qstr for general use.
This marks many critical kernel structures for randomization. These are
structures that have been targeted in the past in security exploits, or
contain functions pointers, pointers to function pointer tables, lists,
workqueues, ref-counters, credentials, permissions, or are otherwise
sensitive. This initial list was extracted from Brad Spengler/PaX Team's
code in the last public patch of grsecurity/PaX based on my understanding
of the code. Changes or omissions from the original code are mine and
don't reflect the original grsecurity/PaX code.
Left out of this list is task_struct, which requires special handling
and will be covered in a subsequent patch.
Checking for capabilities should be the last operation when performing
access control tests so that PF_SUPERPRIV is set only when it was required
for success (implying that the capability was needed for the operation).
Reported-by: Solar Designer <solar@openwall.com>
Acked-by: Serge Hallyn <serge@hallyn.com>
Reviewed-by: Andy Lutomirski <luto@kernel.org>
Mauro says:
This patch series convert the remaining DocBooks to ReST.
The first version was originally
send as 3 patch series:
[PATCH 00/36] Convert DocBook documents to ReST
[PATCH 0/5] Convert more books to ReST
[PATCH 00/13] Get rid of DocBook
The lsm book was added as if it were a text file under
Documentation. The plan is to merge it with another file
under Documentation/security, after both this series and
a security Documentation patch series gets merged.
It also adjusts some Sphinx-pedantic errors/warnings on
some kernel-doc markups.
I also added some patches here to add PDF output for all
existing ReST books.
Sphinx gets confused when it finds identation without a
good reason for it and without a preceding blank line:
./fs/mpage.c:347: ERROR: Unexpected indentation.
./fs/namei.c:4303: ERROR: Unexpected indentation.
./fs/fs-writeback.c:2060: ERROR: Unexpected indentation.
No functional changes.
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
Pull misc vfs updates from Al Viro:
"Making sure that something like a referral point won't end up as pwd
or root.
The main part is the last commit (fixing mntns_install()); that one
fixes a hard-to-hit race. The fchdir() commit is making fchdir(2) a
bit more robust - it should be impossible to get opened files (even
O_PATH ones) for referral points in the first place, so the existing
checks are OK, but checking the same thing as in chdir(2) is just as
cheap.
The path_init() commit removes a redundant check that shouldn't have
been there in the first place"
* 'work.sane_pwd' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
make sure that mntns_install() doesn't end up with referral for root
path_init(): don't bother with checking MAY_EXEC for LOOKUP_ROOT
make sure that fchdir() won't accept referral points, etc.
Commit afddba49d18f ("fs: introduce write_begin, write_end, and
perform_write aops") introduced AOP_FLAG_UNINTERRUPTIBLE flag which was
checked in pagecache_write_begin(), but that check was removed by
4e02ed4b4a2f ("fs: remove prepare_write/commit_write").
Between these two commits, commit d9414774dc0c ("cifs: Convert cifs to
new aops.") added a check in cifs_write_begin(), but that check was soon
removed by commit a98ee8c1c707 ("[CIFS] fix regression in
cifs_write_begin/cifs_write_end").
Therefore, AOP_FLAG_UNINTERRUPTIBLE flag is checked nowhere. Let's
remove this flag. This patch has no functionality changes.
Link: http://lkml.kernel.org/r/1489294781-53494-1-git-send-email-penguin-kernel@I-love.SAKURA.ne.jp
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Cc: Nick Piggin <npiggin@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"Highlights:
IMA:
- provide ">" and "<" operators for fowner/uid/euid rules
KEYS:
- add a system blacklist keyring
- add KEYCTL_RESTRICT_KEYRING, exposes keyring link restriction
functionality to userland via keyctl()
LSM:
- harden LSM API with __ro_after_init
- add prlmit security hook, implement for SELinux
- revive security_task_alloc hook
TPM:
- implement contextual TPM command 'spaces'"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (98 commits)
tpm: Fix reference count to main device
tpm_tis: convert to using locality callbacks
tpm: fix handling of the TPM 2.0 event logs
tpm_crb: remove a cruft constant
keys: select CONFIG_CRYPTO when selecting DH / KDF
apparmor: Make path_max parameter readonly
apparmor: fix parameters so that the permission test is bypassed at boot
apparmor: fix invalid reference to index variable of iterator line 836
apparmor: use SHASH_DESC_ON_STACK
security/apparmor/lsm.c: set debug messages
apparmor: fix boolreturn.cocci warnings
Smack: Use GFP_KERNEL for smk_netlbl_mls().
smack: fix double free in smack_parse_opts_str()
KEYS: add SP800-56A KDF support for DH
KEYS: Keyring asymmetric key restrict method with chaining
KEYS: Restrict asymmetric key linkage using a specific keychain
KEYS: Add a lookup_restriction function for the asymmetric key type
KEYS: Add KEYCTL_RESTRICT_KEYRING
KEYS: Consistent ordering for __key_link_begin and restrict check
KEYS: Add an optional lookup_restriction hook to key_type
new flag: LOOKUP_DOWN. If the starting point is overmounted, cross
into whatever's mounted on top, triggering referrals et.al.
Use that instead of follow_down_one() loop in mntns_install(), handle
errors properly.
we'll hit that check in link_path_walk() anyway.
Normal pathname lookup doesn't allow empty pathnames, but using
AT_EMPTY_PATH (with name_to_handle_at() or fstatat(), for example) you
can trigger an empty pathname lookup.
And not only is the RCU lookup in that case entirely unnecessary
(because we'll obviously immediately finalize the end result), it is
actively wrong.
Why? An empth path is a special case that will return the original
'dirfd' dentry - and that dentry may not actually be RCU-free'd,
resulting in a potential use-after-free if we were to initialize the
path lazily under the RCU read lock and depend on complete_walk()
finalizing the dentry.
Found by syzkaller and KASAN.
Reported-by: Vegard Nossum <vegard.nossum@gmail.com>
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
generic_permission() presently checks CAP_DAC_OVERRIDE prior to
CAP_DAC_READ_SEARCH. This can cause misleading audit messages when
using a LSM such as SELinux or AppArmor, since CAP_DAC_OVERRIDE
may not be required for the operation. Flip the order of the
tests so that CAP_DAC_OVERRIDE is only checked when required for
the operation.
Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
Acked-by: John Johansen <john.johansen@canonical.com>
Reviewed-by: Serge Hallyn <serge@hallyn.com>
Acked-by: James Morris <james.l.morris@oracle.com>
Signed-off-by: Paul Moore <paul@paul-moore.com>
Overlayfs-related series from Miklos and Amir
Factor out some common vfs bits from do_tmpfile()
to be used by overlayfs for concurrent copy up.
Signed-off-by: Amir Goldstein <amir73il@gmail.com>
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
To support unprivileged users mounting filesystems two permission
checks have to be performed: a test to see if the user allowed to
create a mount in the mount namespace, and a test to see if
the user is allowed to access the specified filesystem.
The automount case is special in that mounting the original filesystem
grants permission to mount the sub-filesystems, to any user who
happens to stumble across the their mountpoint and satisfies the
ordinary filesystem permission checks.
Attempting to handle the automount case by using override_creds
almost works. It preserves the idea that permission to mount
the original filesystem is permission to mount the sub-filesystem.
Unfortunately using override_creds messes up the filesystems
ordinary permission checks.
Solve this by being explicit that a mount is a submount by introducing
vfs_submount, and using it where appropriate.
vfs_submount uses a new mount internal mount flags MS_SUBMOUNT, to let
sget and friends know that a mount is a submount so they can take appropriate
action.
sget and sget_userns are modified to not perform any permission checks
on submounts.
follow_automount is modified to stop using override_creds as that
has proven problemantic.
do_mount is modified to always remove the new MS_SUBMOUNT flag so
that we know userspace will never by able to specify it.
autofs4 is modified to stop using current_real_cred that was put in
there to handle the previous version of submount permission checking.
cifs is modified to pass the mountpoint all of the way down to vfs_submount.
debugfs is modified to pass the mountpoint all of the way down to
trace_automount by adding a new parameter. To make this change easier
a new typedef debugfs_automount_t is introduced to capture the type of
the debugfs automount function.
Fixes: 069d5ac9ae0d ("autofs: Fix automounts by using current_real_cred()->uid")
Reviewed-by: Trond Myklebust <trond.myklebust@primarydata.com>
Reviewed-by: Seth Forshee <seth.forshee@canonical.com>
may_create() rejects creation of inodes with ids which lack a
mapping into s_user_ns. However for O_CREAT may_o_create() is
is used instead. Add a similar check there.
Fixes: 036d523641c6 ("vfs: Don't create inodes with a uid or gid unknown to the vfs")
Signed-off-by: Seth Forshee <seth.forshee@canonical.com>
In all but one case, the last two arguments are NULL and 0 resp.;
almost everyone just wants to switch nameidata to non-RCU mode.
The only exception is lookup_fast(), where we have a child dentry
we want to legitimize as well. Split these two cases.
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs
Pull partial readlink cleanups from Miklos Szeredi.
This is the uncontroversial part of the readlink cleanup patch-set that
simplifies the default readlink handling.
Miklos and Al are still discussing the rest of the series.
* git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs:
vfs: make generic_readlink() static
vfs: remove ".readlink = generic_readlink" assignments
vfs: default to generic_readlink()
vfs: replace calling i_op->readlink with vfs_readlink()
proc/self: use generic_readlink
ecryptfs: use vfs_get_link()
bad_inode: add missing i_op initializers
Pull more vfs updates from Al Viro:
"In this pile:
- autofs-namespace series
- dedupe stuff
- more struct path constification"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (40 commits)
ocfs2: implement the VFS clone_range, copy_range, and dedupe_range features
ocfs2: charge quota for reflinked blocks
ocfs2: fix bad pointer cast
ocfs2: always unlock when completing dio writes
ocfs2: don't eat io errors during _dio_end_io_write
ocfs2: budget for extent tree splits when adding refcount flag
ocfs2: prohibit refcounted swapfiles
ocfs2: add newlines to some error messages
ocfs2: convert inode refcount test to a helper
simple_write_end(): don't zero in short copy into uptodate
exofs: don't mess with simple_write_{begin,end}
9p: saner ->write_end() on failing copy into non-uptodate page
fix gfs2_stuffed_write_end() on short copies
fix ceph_write_end()
nfs_write_end(): fix handling of short copies
vfs: refactor clone/dedupe_file_range common functions
fs: try to clone files first in vfs_copy_file_range
vfs: misc struct path constification
namespace.c: constify struct path passed to a bunch of primitives
quota: constify struct path in quota_on
Pull overlayfs updates from Miklos Szeredi:
"This update contains:
- try to clone on copy-up
- allow renaming a directory
- split source into managable chunks
- misc cleanups and fixes
It does not contain the read-only fd data inconsistency fix, which Al
didn't like. I'll leave that to the next year..."
* 'overlayfs-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs: (36 commits)
ovl: fix reStructuredText syntax errors in documentation
ovl: fix return value of ovl_fill_super
ovl: clean up kstat usage
ovl: fold ovl_copy_up_truncate() into ovl_copy_up()
ovl: create directories inside merged parent opaque
ovl: opaque cleanup
ovl: show redirect_dir mount option
ovl: allow setting max size of redirect
ovl: allow redirect_dir to default to "on"
ovl: check for emptiness of redirect dir
ovl: redirect on rename-dir
ovl: lookup redirects
ovl: consolidate lookup for underlying layers
ovl: fix nested overlayfs mount
ovl: check namelen
ovl: split super.c
ovl: use d_is_dir()
ovl: simplify lookup
ovl: check lower existence of rename target
ovl: rename: simplify handling of lower/merged directory
This reverts commit 9409e22acdfc9153f88d9b1ed2bd2a5b34d2d3ca.
Since commit 51f7e52dc943 ("ovl: share inode for hard link") there's no
need to call d_real_inode() to check two overlay inodes for equality.
If .readlink == NULL implies generic_readlink().
Generated by:
to_del="\.readlink.*=.*generic_readlink"
for i in `git grep -l $to_del`; do sed -i "/$to_del"/d $i; done
If i_op->readlink is NULL, but i_op->get_link is set then vfs_readlink()
defaults to calling generic_readlink().
The IOP_DEFAULT_READLINK flag indicates that the above conditions are met
and the default action can be taken.
Also check d_is_symlink() in callers instead of inode->i_op->readlink
because following patches will allow NULL ->readlink for symlinks.
All callers are followed by the same boilerplate - "if it has returned
0, update nd->path/inode/seq - we are not following a symlink here".
Pull it into the function itself, renaming it into step_into().
Rename WALK_GET to WALK_FOLLOW, while we are at it - more descriptive
name.
... and pull put_link() logics into it.
... turning the condition for put_link() in walk_component() into
"WALK_MORE not passed and depth is non-zero". Again, makes for
simpler arguments.
Simplifies the arguments both for it and for walk_component()
leave the result in nd->path, have caller do follow_mount() and
copy it to the final destination.
direct use of filename_parentat() is just as readable
