commit c1225158a8dad9e9d5eee8a17dbbd9c7cda05ab9 upstream.
The same function is used by idmap, gss and blocklayout code. Make it
generic.
Signed-off-by: Peng Tao <peng_tao@emc.com>
Signed-off-by: Jim Rees <rees@umich.edu>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 7542274519b3ba87555410c66e8356ac1e3bc9b3 upstream.
We should check if the sector is already initialized before
trying to grab the page from page cache. Otherwise when two
pages of the same block are written back by two threads each
calling from writepage_locked, it can cause deadlock like bellow.
[ 1080.972099] INFO: task kswapd0:25 blocked for more than 120 seconds.
[ 1080.972377] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 1080.972812] kswapd0 D ffff88000c4926c0 0 25 2 0x00000000
[ 1080.972816] ffff88000df276b0 0000000000000046 ffff88000df27640 ffffffff81013ba7
[ 1080.972821] ffff88000c492310 ffff88000df27fd8 ffff88000df27fd8 00000000001d3440
[ 1080.972824] ffff88000c378000 ffff88000c492310 ffff8800175d3d40 ffff880017fc75a8
[ 1080.972828] Call Trace:
[ 1080.972860] [<ffffffff81013ba7>] ? read_tsc+0x9/0x19
[ 1080.972877] [<ffffffff810e0b23>] ? lock_page+0x2b/0x2b
[ 1080.972899] [<ffffffff81475a1d>] io_schedule+0x63/0x7e
[ 1080.972902] [<ffffffff810e0b31>] sleep_on_page+0xe/0x12
[ 1080.972905] [<ffffffff81475fe8>] __wait_on_bit_lock+0x46/0x8f
[ 1080.972916] [<ffffffff810822d7>] ? lock_release_holdtime.part.7+0x6b/0x72
[ 1080.972919] [<ffffffff810e0af6>] __lock_page+0x66/0x68
[ 1080.972928] [<ffffffff81072705>] ? autoremove_wake_function+0x3d/0x3d
[ 1080.972932] [<ffffffff810e0b1f>] lock_page+0x27/0x2b
[ 1080.972934] [<ffffffff810e0bcf>] find_lock_page+0x34/0x57
[ 1080.972937] [<ffffffff810e1738>] find_or_create_page+0x34/0x8a
[ 1080.972947] [<ffffffffa034245b>] bl_write_pagelist+0x205/0x6da [blocklayoutdriver]
[ 1080.972951] [<ffffffffa034145d>] ? bl_free_lseg+0x38/0x38 [blocklayoutdriver]
[ 1080.972995] [<ffffffffa02e27b9>] ? nfs_write_rpcsetup+0x118/0x123 [nfs]
[ 1080.973033] [<ffffffffa030246b>] pnfs_generic_pg_writepages+0x10b/0x1f4 [nfs]
[ 1080.973089] [<ffffffffa02deaae>] nfs_pageio_doio+0x1a/0x43 [nfs]
[ 1080.973098] [<ffffffffa02df035>] nfs_pageio_complete+0x16/0x2d [nfs]
[ 1080.973108] [<ffffffffa02e2d8f>] nfs_writepage_locked+0xa0/0xbf [nfs]
[ 1080.973119] [<ffffffffa02e36a1>] nfs_writepage+0x16/0x2b [nfs]
[ 1080.973122] [<ffffffff810e8762>] ? clear_page_dirty_for_io+0x87/0x9a
[ 1080.973133] [<ffffffff810efc5b>] shrink_page_list+0x39b/0x6c8
[ 1080.973139] [<ffffffff810f03bb>] shrink_inactive_list+0x22c/0x39e
[ 1080.973144] [<ffffffff810822d7>] ? lock_release_holdtime.part.7+0x6b/0x72
[ 1080.973148] [<ffffffff810f0c33>] shrink_zone+0x445/0x588
[ 1080.973152] [<ffffffff810f1a11>] balance_pgdat+0x2c2/0x56b
[ 1080.973170] [<ffffffff81254208>] ? __bitmap_weight+0x34/0x80
[ 1080.973175] [<ffffffff810f1f78>] kswapd+0x2be/0x2fa
[ 1080.973179] [<ffffffff810726c8>] ? __init_waitqueue_head+0x4b/0x4b
[ 1080.973183] [<ffffffff810f1cba>] ? balance_pgdat+0x56b/0x56b
[ 1080.973187] [<ffffffff81071f69>] kthread+0xa8/0xb0
[ 1080.973200] [<ffffffff814806b4>] kernel_thread_helper+0x4/0x10
[ 1080.973205] [<ffffffff81071ec1>] ? __init_kthread_worker+0x5a/0x5a
[ 1080.973210] [<ffffffff814806b0>] ? gs_change+0x13/0x13
[ 1080.973213] no locks held by kswapd0/25.
commit e6d05a757c314ad88d0649d3835a8a1daa964236 upstream.
bl_add_page_to_bio returns error pointer. bio should be reset to
NULL in failure cases as the out path always calls bl_submit_bio.
commit 1b0ae068779874f54b55aac3a2a992bcf3f2c3c4 upstream.
file layout and block layout both use it to set mark layout io failure
bit. So make it generic.
commit 760383f1ee4d14b0e0bdf0cddee648d9b8633429 upstream.
Reviewed-by: Jeff Layton <jlayton@redhat.com>
commit 516f2e24faa7548a61d9ba790958528469c2e284 upstream.
Always return PTR_ERR, not NULL, from nfs4_blk_get_deviceinfo and
nfs4_blk_decode_device.
Check for IS_ERR, not NULL, in bl_set_layoutdriver when calling
nfs4_blk_get_deviceinfo.
Signed-off-by: Benny Halevy <bhalevy@tonian.com>
Fix this compile error on s390:
CC [M] fs/nfs/blocklayout/blocklayout.o
fs/nfs/blocklayout/blocklayout.c: In function 'bl_end_io_read':
fs/nfs/blocklayout/blocklayout.c:201:4: error: implicit declaration of function 'prefetchw'
Introduced with 9549ec01 "pnfsblock: bl_read_pagelist".
Cc: Fred Isaman <iisaman@citi.umich.edu>
For invalid extents, find other pages in the same fsblock and write them out.
[pnfsblock: write_begin]
Signed-off-by: Fred Isaman <iisaman@citi.umich.edu>
Signed-off-by: Benny Halevy <bhalevy@panasas.com>
Note: When upper layer's read/write request cannot be fulfilled, the block
layout driver shouldn't silently mark the page as error. It should do
what can be done and leave the rest to the upper layer. To do so, we
should set rdata/wdata->res.count properly.
When upper layer re-send the read/write request to finish the rest
part of the request, pgbase is the position where we should start at.
[pnfsblock: bl_write_pagelist support functions]
[pnfsblock: bl_write_pagelist adjust for missing PG_USE_PNFS]
[pnfsblock: handle errors when read or write pagelist.]
Signed-off-by: Zhang Jingwang <yyalone@gmail.com>
[pnfs-block: use new write_pagelist api]
[SQUASHME: pnfsblock: mds_offset is set in the generic layer]
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
[pnfsblock: mark IO error with NFS_LAYOUT_{RW|RO}_FAILED]
[pnfsblock: SQUASHME: adjust to API change]
[pnfsblock: fixup blksize alignment in bl_setup_layoutcommit]
[pnfsblock: read path error handling]
[pnfs-block: use new read_pagelist api]
In blocklayout driver. There are two things happening
while layoutcommit/cleanup.
1. the modified extents are encoded.
2. On cleanup the extents are put back on the layout rw
extents list, for reads.
In the new system where actual xdr encoding is done in
encode_layoutcommit() directly into xdr buffer, these are
the new commit stages:
1. On setup_layoutcommit, the range is adjusted as before
and a structure is allocated for communication with
bl_encode_layoutcommit && bl_cleanup_layoutcommit
(Generic layer provides a void-star to hang it on)
2. bl_encode_layoutcommit is called to do the actual
encoding directly into xdr. The commit-extent-list is not
freed and is stored on above structure.
FIXME: The code is not yet converted to the new XDR cleanup
3. On cleanup the commit-extent-list is put back by a call
to set_to_rw() as before, but with no need for XDR decoding
of the list as before. And the commit-extent-list is freed.
Finally allocated structure is freed.
[rm inode and pnfs_layout_hdr args from cleanup_layoutcommit()]
[pnfsblock: introduce bl_committing list]
[blocklayout: encode_layoutcommit implementation]
[pnfsblock: fix bug setting up layoutcommit.]
Signed-off-by: Tao Guo <guotao@nrchpc.ac.cn>
[pnfsblock: cleanup_layoutcommit wants a status parameter]
[pnfsblock: get rid of deprecated xdr macros]
[pnfsblock: prevent commit list corruption]
[pnfsblock: fix layoutcommit with an empty opaque]
Adds working implementations of various support functions
to handle INVAL extents, needed by writes, such as
bl_mark_sectors_init and bl_is_sector_init.
[pnfsblock: fix 64-bit compiler warnings for extent manipulation]
[Implement release_inval_marks]
Signed-off-by: Zhang Jingwang <zhangjingwang@nrchpc.ac.cn>
Call GETDEVICELIST during mount, then call and parse GETDEVICEINFO
for each device returned.
[pnfsblock: fix pnfs_deviceid references]
[pnfsblock: fix print format warnings for sector_t and size_t]
[pnfs-block: #include <linux/vmalloc.h>]
[pnfsblock: no PNFS_NFS_SERVER]
[pnfsblock: fix bug determining size of striped volume]
[pnfsblock: fix oops when using multiple devices]
[pnfsblock: get rid of vmap and deviceid->area structure]
[pnfsblock: fix bug getting pnfs_layout_type in translate_devid().]
Signed-off-by: Zhang Jingwang <Jingwang.Zhang@emc.com>
[upcall bugfixes]
Adds structures and basic create/delete code for extents.
[pnfsblock: use pnfs_generic_pg_init_read/write]
Define a configuration variable to enable/disable compilation of the
block driver code.
Add the minimal structure for a pnfs block layout driver, and empty
list-heads that will hold the extent data
[pnfsblock: make NFS_V4_1 select PNFS_BLOCK]
[pnfs-block: fix CONFIG_PNFS_BLOCK dependencies]
[pnfs: move pnfs_layout_type inline in nfs_inode]
[pnfsblock: layout alloc and free]
[pnfsblock: define module alias]
