path: root/fs/nfs/callback_xdr.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-08nfs4: Make the v4 callback service hiddenSteve Dickson
To avoid hangs in the svc_unregister(), on version 4 mounts (and unmounts), when rpcbind is not running, make the nfs4 callback program an 'hidden' service by setting the 'vs_hidden' flag in the nfs4_callback_version structure. Signed-off-by: Steve Dickson <steved@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-02-10nfs41: cleanup callback code to use __be32 typeAndy Adamson
Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-02-10nfs41: implement cb_recall_slotAndy Adamson
Drain the fore channel and reset the max_slots to the new value. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-02-10nfs41: back channel drc minimal implementationAndy Adamson
For now the back channel ca_maxresponsesize_cached is 0 and there is no backchannel DRC. Return NFS4ERR_REP_TOO_BIG_TO_CACHE when a cb_sequence cachethis is true. When it is false, return NFS4ERR_RETRY_UNCACHED_REP as the next operation error. Remember the replay error accross compound operation processing. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-02-10nfs41: remove uneeded checks in callback processingAndy Adamson
All callback operations have arguments to decode and require processing. The preprocess_nfs4X_op functions catch unsupported or illegal ops so decode_args and process_op pointers are always non NULL. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-02-10nfs41: directly encode back channel errorAndy Adamson
Skip all other processing when error is encountered. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-02-10nfs41: fix wrong error on callback header xdr overflowAndy Adamson
Set NFS4ERR_RESOURCE as CB_COMPOUND status and do not return an op on decode_op_hdr or encode_op_hdr buffer overflow. NFS4ERR_RESOURCE is correct for v4.0. Will fix the return for v4.1 along with all the other NFS4ERR_RESOURCE errors in a later patch. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-12-05nfs41: V2 initial support for CB_RECALL_ANYAlexandros Batsakis
For now the clients returns _all_ the delegations of the specificed type it holds Signed-off-by: Alexandros Batsakis <batsakis@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-12-05nfs41: add support for callback with RPC version number 4Alexandros Batsakis
The NFSv4.1 spec-29 (18.36.3) says that the server MUST use an ONC RPC (program) version number equal to 4 in callbacks sent to the client. For now we allow both versions 1 and 4. Signed-off-by: Alexandros Batsakis <batsakis@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-09-21trivial: remove unnecessary semicolonsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-17nfs41: Backchannel: update cb_sequence args and resultsRicardo Labiaga
Change the type of cs_addr and csr_status to 'struct sockaddr' and '__be32' since the cb_sequence processing function will use existing functionality that expects these types. Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17nfs41: verify CB_SEQUENCE position in callback compoundBenny Halevy
CB_SEQUENCE must appear first in the callback compound RPC. If it is not the first operation NFS4ERR_SEQUENCE_POS must be returned. If the first operation ni the CB_COMPOUND is not CB_SEQUENCE then NFS4ERR_OP_NOT_IN_SESSION must be returned. Signed-off-by: Ricardo Labiaga <ricardo.labiaga@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: refactor op preprocessing out of process_op] Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17nfs41: cb_sequence xdr implementationBenny Halevy
[nfs41: get rid of READMEM and COPYMEM for callback_xdr.c] Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: get rid of READ64 in callback_xdr.c] See http://linux-nfs.org/pipermail/pnfs/2009-June/007846.html Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17nfs41: consider minorversion in callback_xdr:process_opBenny Halevy
Note that this patch changes the nfsv4.0 behavior also when CONFIG_NFS_V4_1 is not defined where NFS4ERR_MINOR_VERS_MISMATCH will be returned if the client received a CB_COMPOUND with minorversion != 0. Previously, it would have returned NFS4ERR_OP_ILLEGAL for CB_SEQUENCE. (or if the server is broken and sent OP_CB_GETATTR or OP_CB_RECALL with minorversion!=0, they would have been processed normally. Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: refactor op preprocessing out of process_op] See http://linux-nfs.org/pipermail/pnfs/2009-June/007845.html [nfs41: define CB_NOTIFY_DEVICEID as not supported] Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17nfs41: decode minorversion 1 cb_compound headerBenny Halevy
decode cb_compound header conforming to http://tools.ietf.org/html/draft-ietf-nfsv4-minorversion1-26 Get rid of cb_compound_hdr_arg.callback_ident callback_ident is not used anywhere so we shouldn't waste any memory to store it. Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: no need to break read_buf in decode_compound_hdr_arg] See http://linux-nfs.org/pipermail/pnfs/2009-June/007844.html Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2009-06-17nfs41: store minorversion in cb_compound_hdr_argBenny Halevy
2008-05-16nfs: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-05-16NFSv4: Check the return value of decode_compound_hdr_arg()Trond Myklebust
If decode_compound_hdr_arg() returns a resource error, then we cannot proceed to process the callback. Return a 'GARBAGE_ARGS' rpc-level error to the caller instead. If, however, the minor version field is incorrect, then we need to propagate the resulting NFS4ERR_MINOR_VERS_MISMATCH error back as the compound status field (setting the nops field to 0). Finally, if encode_compound_hdr_res() returns an error, we need to return an RPC_SYSTEM_ERR to the caller. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-20nfs: fix sparse warningsHarvey Harrison
fs/nfs/nfs4state.c:788:34: warning: Using plain integer as NULL pointer fs/nfs/delegation.c:52:34: warning: Using plain integer as NULL pointer fs/nfs/idmap.c:312:12: warning: Using plain integer as NULL pointer fs/nfs/callback_xdr.c:257:6: warning: Using plain integer as NULL pointer fs/nfs/callback_xdr.c:270:6: warning: Using plain integer as NULL pointer fs/nfs/callback_xdr.c:281:6: warning: Using plain integer as NULL pointer Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFS: Change cb_recallargs to pass "struct sockaddr *" instead of sockaddr_inChuck Lever
Change the addr field in the cb_recallargs struct to a "struct sockaddr *" to support non-IPv4 addresses. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Aurelien Charbon <aurelien.charbon@ext.bull.net> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFS: Change cb_getattrargs to pass "struct sockaddr *" instead of sockaddr_inChuck Lever
Change the addr field in the cb_getattrargs struct to a "struct sockaddr *" to support non-IPv4 addresses. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Aurelien Charbon <aurelien.charbon@ext.bull.net> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFS: Remove an unneeded check in decode_compound_header_arg()Chuck Lever
Clean up: The header tag length is unsigned, so checking that it is less than zero is unnecessary. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-19NFSv4: debug print ntohl(status) in nfs client callback xdr codeBenny Halevy
status in nfs client callback xdr code is passed in network order. print it in host order for better readability. Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-02-12[PATCH] knfsd: SUNRPC: Provide room in svc_rqst for larger addressesChuck Lever
Expand the rq_addr field to allow it to contain larger addresses. Specifically, we replace a 'sockaddr_in' with a 'sockaddr_storage', then everywhere the 'sockaddr_in' was referenced, we use instead an accessor function (svc_addr_in) which safely casts the _storage to _in. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Aurelien Charbon <aurelien.charbon@ext.bull.net> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-20[PATCH] xdr annotations: fs/nfs/callback*Al Viro
on-the-wire data is big-endian [mostly pulled from Alexey's patch] Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-20[PATCH] fs/nfs/callback* passes error values big-endianAl Viro
[pulled from Alexey's patch] Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-20[PATCH] fix svc_procfunc declarationAl Viro
svc_procfunc instances return __be32, not int Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-09NFSv4: really return status from decode_recall_args()Alexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20NFSv4: Kill braindead gcc warningsTrond Myklebust
nfs4_open_revalidate: 'res' may be used uninitialized nfs4_callback_compound: ‘hdr_res.nops’ may be used uninitialized 'op_nr’ may be used uninitialized encode_getattr_res: ‘savep’ may be used uninitialized Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFSv4: Fix an Oops in the callback code.Trond Myklebust
The changeset "trond.myklebust@fys.uio.no|ChangeSet|20050322152404|16979" (RPC: Ensure XDR iovec length is initialized correctly in call_header) causes the NFSv4 callback code to BUG() due to an incorrectly initialized scratch buffer. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFS: Header file cleanup...Trond Myklebust
- Move NFSv4 state definitions into a private header file. - Clean up gunk in nfs_fs.h Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
