path: root/fs/nfs/delegation.h
2011-01-06NFS: Move cl_delegations to the nfs_server structChuck Lever
Delegations are per-inode, not per-nfs_client. When a server file system is migrated, delegations on the client must be moved from the source to the destination nfs_server. Make it easier to manage a mount point's delegation list across a migration event by moving the list to the nfs_server struct. Clean up: I added documenting comments to public functions I changed in this patch. For consistency I added comments to all the other public functions in fs/nfs/delegation.c. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-06-22NFSv41: Fix nfs_async_inode_return_delegation() uglinessTrond Myklebust
2010-03-10NFSv4: Don't ignore the NFS_INO_REVAL_FORCED flag in nfs_revalidate_inode()Trond Myklebust
If the NFS_INO_REVAL_FORCED flag is set, that means that we don't yet have an up to date attribute cache. Even if we hold a delegation, we must put a GETATTR on the wire. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: stable@kernel.org
2009-12-05nfs41: v2 fix cb_recall bugAlexandros Batsakis
in NFSv4.1 the seqid part of a stateid in CB_RECALL must be 0 Signed-off-by: Alexandros Batsakis <batsakis@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-12-05nfs41: V2 initial support for CB_RECALL_ANYAlexandros Batsakis
For now the clients returns _all_ the delegations of the specificed type it holds Signed-off-by: Alexandros Batsakis <batsakis@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-12-03NFSv4: Fix a potential state manager deadlock when returning delegationsTrond Myklebust
The nfsv4 state manager could potentially deadlock inside __nfs_inode_return_delegation() if the server reboots, so that the calls to nfs_msync_inode() end up waiting on state recovery to complete. Also ensure that if a server reboot or network partition causes us to have to stop returning delegations, that NFS4CLNT_DELEGRETURN is set so that the state manager can resume any outstanding delegation returns after it has dealt with the state recovery situation. Finally, ensure that the state manager doesn't wait for the DELEGRETURN call to complete. It doesn't need to, and that too can cause a deadlock. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-12-23NFSv4: Convert delegation->type field to fmode_tTrond Myklebust
2008-12-23NFSv4: Return unreferenced delegations more promptlyTrond Myklebust
If the client is not using a delegation, the right thing to do is to return it as soon as possible. This helps reduce the amount of state the server has to track, as well as reducing the potential for conflicts with other clients. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-12-23NFSv4: Clean up NFS4ERR_CB_PATH_DOWN error management...Trond Myklebust
Add a delegation cleanup phase to the state management loop, and do the NFS4ERR_CB_PATH_DOWN recovery there. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-12-23NFSv4: Clean up the support for returning multiple delegationsTrond Myklebust
Add a flag to mark delegations as requiring return, then run a garbage collector. In the future, this will allow for more flexible delegation management, where delegations may be marked for return if it turns out that they are not being referenced. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-12-23NFS: Use atomic bitops when changing struct nfs_delegation->flagsTrond Myklebust
2008-12-23NFSv4: Fix up another delegation related raceTrond Myklebust
When we can update_open_stateid(), we need to be certain that we don't race with a delegation return. While we could do this by grabbing the nfs_client->cl_lock, a dedicated spin lock in the delegation structure will scale better. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFS: Add an asynchronous delegreturn operation for use in nfs_clear_inodeTrond Myklebust
Otherwise, there is a potential deadlock if the last dput() from an NFSv4 close() or other asynchronous operation leads to nfs_clear_inode calling the synchronous delegreturn. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10NFSv4: Use RCU to protect delegationsTrond Myklebust
2007-07-10NFSv4: Support recalling delegations by stateid part 2Trond Myklebust
2007-07-10NFSv4: Support recalling delegations by stateidTrond Myklebust
There appear to be some rogue servers out there that issue multiple delegations with different stateids for the same file. Ensure that when we return delegations, we do so on a per-stateid basis rather than a per-file basis. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10NFSv4: Cleanup: pass the nfs_open_context to open recovery codeTrond Myklebust
2006-09-22NFS: Rename struct nfs4_client to struct nfs_clientDavid Howells
Rename struct nfs4_client to struct nfs_client so that it can become the basis for a general client record for NFS2 and NFS3 in addition to NFS4. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20NFSv4: Send the delegation stateid for SETATTR callsTrond Myklebust
In the case where we hold a delegation stateid, use that in for inside SETATTR calls. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-01-06NFSv4: Ensure change attribute returned by GETATTR callback conforms to specTrond Myklebust
According to RFC3530 we're supposed to cache the change attribute at the time the client receives a write delegation. If the inode is clean, a CB_GETATTR callback by the server to the client is supposed to return the cached change attribute. If, OTOH, the inode is dirty, the client should bump the cached change attribute by 1. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-01-06NFSv4: Send RENEW requests to the server only when we're holding stateTrond Myklebust
2005-11-04NFSv4: Recover locks too when returning a delegationTrond Myklebust
Delegations allow us to cache posix and BSD locks, however when the delegation is recalled, we need to "flush the cache" and send the cached LOCK requests to the server. This patch sets up the mechanism for doing so. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-10-18NFSv4: Return delegation upon rename or removal of file.Trond Myklebust
