path: root/fs/nfs/direct.c
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-20nfs_open_context doesn't need struct path eitherAl Viro
just dentry, please... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-11NFS: account direct-io into task io accountingKonstantin Khlebnikov
Account NFS direct-io reads and writes into Task I/O Accounting. Do it before complition to handle aio. NFS have unusual direct-io implementation, thus accounting in generic code does not work. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-11NFS: remove pointless if statement in nfs_direct_write_resultFred Isaman
The code was doing nothing more in either branch of the if. Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-25NFS: Fix "kernel BUG at fs/aio.c:554!"Chuck Lever
Nick Piggin reports: > I'm getting use after frees in aio code in NFS > > [ 2703.396766] Call Trace: > [ 2703.396858] [<ffffffff8100b057>] ? native_sched_clock+0x27/0x80 > [ 2703.396959] [<ffffffff8108509e>] ? put_lock_stats+0xe/0x40 > [ 2703.397058] [<ffffffff81088348>] ? lock_release_holdtime+0xa8/0x140 > [ 2703.397159] [<ffffffff8108a2a5>] lock_acquire+0x95/0x1b0 > [ 2703.397260] [<ffffffff811627db>] ? aio_put_req+0x2b/0x60 > [ 2703.397361] [<ffffffff81039701>] ? get_parent_ip+0x11/0x50 > [ 2703.397464] [<ffffffff81612a31>] _raw_spin_lock_irq+0x41/0x80 > [ 2703.397564] [<ffffffff811627db>] ? aio_put_req+0x2b/0x60 > [ 2703.397662] [<ffffffff811627db>] aio_put_req+0x2b/0x60 > [ 2703.397761] [<ffffffff811647fe>] do_io_submit+0x2be/0x7c0 > [ 2703.397895] [<ffffffff81164d0b>] sys_io_submit+0xb/0x10 > [ 2703.397995] [<ffffffff8100307b>] system_call_fastpath+0x16/0x1b > > Adding some tracing, it is due to nfs completing the request then > returning something other than -EIOCBQUEUED, so aio.c > also completes the request. To address this, prevent the NFS direct I/O engine from completing async iocbs when the forward path returns an error without starting any I/O. This fix appears to survive ^C during both "xfstest no. 208" and "fsx -Z." It's likely this bug has existed for a very long while, as we are seeing very similar symptoms in OEL 5. Copying stable. Cc: Stable <stable@kernel.org> Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-11-22Pure nfs client performance using odirect.Arun Bharadwaj
When an application opens a file with O_DIRECT flag, if the size of the data that is written is equal to wsize, the client sends a WRITE RPC with stable flag set to UNSTABLE followed by a single COMMIT RPC rather than sending a single WRITE RPC with the stable flag set to FILE_SYNC. This a bug. Patch to fix this. Signed-off-by: Arun R Bharadwaj <arun@linux.vnet.ibm.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-10-28Fixed Regression in NFS Direct I/O pathSteve Dickson
A typo, introduced by commit f11ac8db, in the nfs_direct_write() routine causes writes with O_DIRECT set to fail with a ENOMEM error. Found-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve Dickson <steved@redhat.com> Cc: stable@kernel.org Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-07-30NFSv4: Ensure that we track the NFSv4 lock state in read/write requests.Trond Myklebust
This patch fixes bugzilla entry 14501: https://bugzilla.kernel.org/show_bug.cgi?id=14501 Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-15NFS: Too many GETATTR and ACCESS calls after direct I/OChuck Lever
The cached read and write paths initialize fattr->time_start in their setup procedures. The value of fattr->time_start is propagated to read_cache_jiffies by nfs_update_inode(). Subsequent calls to nfs_attribute_timeout() will then use a good time stamp when computing the attribute cache timeout, and squelch unneeded GETATTR calls. Since the direct I/O paths erroneously leave the inode's fattr->time_start field set to zero, read_cache_jiffies for that inode is set to zero after any direct read or write operation. This triggers an otw GETATTR or ACCESS call to update the file's attribute and access caches properly, even when the NFS READ or WRITE replies have usable post-op attributes. Make sure the direct read and write setup code performs the same fattr initialization as the cached I/O paths to prevent unnecessary GETATTR calls. This was likely introduced by commit 0e574af1 in 2.6.15, which appears to add new nfs_fattr_init() call sites in the cached read and write paths, but not in the equivalent places in fs/nfs/direct.c. A subsequent commit in the same series, 33801147, introduces the fattr->time_start field. Interestingly, the direct write reschedule path already has a call to nfs_fattr_init() in the right place. Reported-by: Quentin Barnes <qbarnes@yahoo-inc.com> Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: stable@kernel.org Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-23nfs: Panic when commit failsTerry Loftin
Actually pass the NFS_FILE_SYNC option to the server to avoid a Panic in nfs_direct_write_complete() when a commit fails. At the end of an nfs write, if the nfs commit fails, all the writes will be rescheduled. They are supposed to be rescheduled as NFS_FILE_SYNC writes, but the rpc_task structure is not completely intialized and so the option is not passed. When the rescheduled writes complete, the return indicates that they are NFS_UNSTABLE and we try to do another commit. This leads to a Panic because the commit data structure pointer was set to null in the initial (failed) commit attempt. Signed-off-by: Terry Loftin <terry.loftin@hp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-08-19nfs: Remove reference to generic_osync_inode from a commentJan Kara
generic_file_direct_write() no longer calls generic_osync_inode() so remove the comment. CC: linux-nfs@vger.kernel.org CC: Neil Brown <neilb@suse.de> CC: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-08-12NFS: Fix an O_DIRECT Oops...Trond Myklebust
We can't call nfs_readdata_release()/nfs_writedata_release() without first initialising and referencing args.context. Doing so inside nfs_direct_read_schedule_segment()/nfs_direct_write_schedule_segment() causes an Oops. We should rather be calling nfs_readdata_free()/nfs_writedata_free() in those cases. Looking at the O_DIRECT code, the "struct nfs_direct_req" is already referencing the nfs_open_context for us. Since the readdata and writedata structures carry a reference to that, we can simplify things by getting rid of the extra nfs_open_context references, so that we can replace all instances of nfs_readdata_release()/nfs_writedata_release(). Reported-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Tested-by: Catalin Marinas <catalin.marinas@arm.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-17nfs41 commit sequence setup done supportAndy Adamson
Separate commit calls from nfs41: sequence setup/done support Implement the commit rpc_call_prepare method for asynchronuos nfs rpcs, call nfs41_setup_sequence from respective rpc_call_validate_args methods. Call nfs4_sequence_done from respective rpc_call_done methods. Note that we need to pass a pointer to the nfs_server in calls data for passing on to nfs4_sequence_done. Signed-off-by: Andy Adamson<andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [pnfs: client data server write validate and release] Signed-off-by: Andy Adamson<andros@umich.edu> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: Support sessions with O_DIRECT.] Signed-off-by: Dean Hildebrand <dhildeb@us.ibm.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: separate free slot from sequence done] [nfs41: nfs4_sequence_free_slot use nfs_client for data server] Signed-off-by: Andy Adamson<andros@umich.edu> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17nfs41 write sequence setup done supportAndy Adamson
Separate write calls from nfs41: sequence setup/done support Implement the write rpc_call_prepare method for asynchronuos nfs rpcs, call nfs41_setup_sequence from respective rpc_call_validate_args methods. Call nfs4_sequence_done from respective rpc_call_done methods. Note that we need to pass a pointer to the nfs_server in calls data for passing on to nfs4_sequence_done. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [pnfs: client data server write validate and release] Signed-off-by: Andy Adamson <andros@umich.edu> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [move the nfs4_sequence_free_slot call in nfs_readpage_retry from] [nfs41: separate free slot from sequence done Signed-off-by: Andy Adamson <andros@umich.edu> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: Support sessions with O_DIRECT.] Signed-off-by: Dean Hildebrand <dhildeb@us.ibm.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: nfs4_sequence_free_slot use nfs_client for data server] Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17nfs41: read sequence setup/done supportAndy Adamson
Implement the read rpc_call_prepare method for asynchronuos nfs rpcs, call nfs41_setup_sequence from respective rpc_call_validate_args methods. Call nfs4_sequence_done from respective rpc_call_done methods. Note that we need to pass a pointer to the nfs_server in calls data for passing on to nfs4_sequence_done. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [pnfs: client data server write validate and release] Signed-off-by: Andy Adamson <andros@umich.edu> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [move the nfs4_sequence_free_slot call in nfs_readpage_retry from] [nfs41: separate free slot from sequence done] [remove nfs_readargs.nfs_server, use calldata->inode instead] Signed-off-by: Andy Adamson <andros@umich.edu> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: Support sessions with O_DIRECT] Signed-off-by: Dean Hildebrand <dhildeb@us.ibm.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: nfs4_sequence_free_slot use nfs_client for data server] Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-07-09NFS: Use NFSDBG_FILE for all fopsChuck Lever
Clean up: some fops use NFSDBG_FILE, some use NFSDBG_VFS. Let's use NFSDBG_FILE for all fops, and consistently report file names instead of inode numbers. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-04-19NFS: Ensure that rpc_run_task() errors are propagated back to the callerTrond Myklebust
2008-04-19NFS: Ensure that the write code cleans up properly when rpc_run_task() failsTrond Myklebust
2008-04-19NFS: Ensure that the read code cleans up properly when rpc_run_task() failsTrond Myklebust
In the case of readpage() we need to ensure that the pages get unlocked, and that the error is flagged. In the case of O_DIRECT, we need to ensure that the pages are all released. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-25NFS: Ensure that the asynchronous RPC calls complete on nfsiod.Trond Myklebust
We want to ensure that rpc_call_ops that involve mntput() are run on nfsiod rather than on rpciod, so that they don't deadlock when the resulting umount calls rpc_shutdown_client(). Hence we specify that read, write and commit calls must complete on nfsiod. Ditto for NFSv4 open, lock, locku and close asynchronous calls. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-25NFS: Fix a deadlock with lazy umountTrond Myklebust
We can't allow rpc callback functions like task->tk_ops->rpc_call_prepare() and task->tk_ops->rpc_call_done() to call mntput() in any way, since that will cause a deadlock when the call to rpc_shutdown_client() attempts to wait on 'task' to complete. We can avoid the above deadlock by moving calls to mntput to task->tk_ops->rpc_release() callback, since at that time the task will be marked as completed, and so rpc_shutdown_client won't attempt to wait on it. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-01Merge branch 'task_killable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc * 'task_killable' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc: (22 commits) Remove commented-out code copied from NFS NFS: Switch from intr mount option to TASK_KILLABLE Add wait_for_completion_killable Add wait_event_killable Add schedule_timeout_killable Use mutex_lock_killable in vfs_readdir Add mutex_lock_killable Use lock_page_killable Add lock_page_killable Add fatal_signal_pending Add TASK_WAKEKILL exit: Use task_is_* signal: Use task_is_* sched: Use task_contributes_to_load, TASK_ALL and TASK_NORMAL ptrace: Use task_is_* power: Use task_is_* wait: Use TASK_NORMAL proc/base.c: Use task_is_* proc/array.c: Use TASK_REPORT perfmon: Use task_is_* ... Fixed up conflicts in NFS/sunrpc manually..
2008-01-30NFS: Optimise away the sigmask code in aio/dio reads and writesTrond Myklebust
There are no interruptible waits for asynchronous RPC tasks, so we don't need to wrap calls to rpc_run_task() with an rpc_clnt_sigmask/rpc_clnt_unsigmask pair. Instead we can wrap the wait_for_completion_interruptible() in nfs_direct_wait(). This means that we completely optimise away sigmask setting for the case of non-blocking aio/dio. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFS/SUNRPC: Convert users of rpc_init_task+rpc_execute to rpc_run_task()Trond Myklebust
2008-01-30NFS: Clean up the (commit|read|write)_setup() callback routinesTrond Myklebust
Move the common code for setting up the nfs_write_data and nfs_read_data structures into fs/nfs/read.c, fs/nfs/write.c and fs/nfs/direct.c. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30SUNRPC: Clean up the initialisation of priority queue scheduling info.Trond Myklebust
We want the default scheduling priority (priority == 0) to remain RPC_PRIORITY_NORMAL. Also ensure that the priority wait queue scheduling is per process id instead of sometimes being per thread, and sometimes being per inode. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30SUNRPC: Cleanup of rpc_task initialisationTrond Myklebust
2007-12-12Revert "NFS: Ensure we return zero if applications attempt to write zero bytes"Trond Myklebust
This reverts commit b9148c6b80d802dbc2a7530b29915a80432e50c7. On Wed, 12 Dec 2007 10:57:30 -0500, Chuck Lever wrote > commit b9148c6b should be reverted. It was recently forward-ported > from some years-old patches, and is clearly not needed now. > > On Dec 11, 2007, at 5:21 PM, Adrian Bunk wrote: > >> This code became dead after commit >> b9148c6b80d802dbc2a7530b29915a80432e50c7 >> (which BTW doesn't seem to have changed any behaviour) and can >> therefore >> be removed. >> >> Spotted by the Coverity checker. >> >> Signed-off-by: Adrian Bunk <bunk@kernel.org> >> >> --- >> --- linux-2.6/fs/nfs/direct.c.old 2007-12-02 21:54:53.000000000 +0100 >> +++ linux-2.6/fs/nfs/direct.c 2007-12-02 21:55:10.000000000 +0100 >> @@ -897,15 +897,12 @@ ssize_t nfs_file_direct_write(struct kio >> if (!count) >> goto out; /* return 0 */ >> >> retval = -EINVAL; >> if ((ssize_t) count < 0) >> goto out; >> - retval = 0; >> - if (!count) >> - goto out; >> >> retval = nfs_sync_mapping(mapping); >> if (retval) >> goto out; >> >> retval = nfs_direct_write(iocb, iov, nr_segs, pos, count); >> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-12-06NFS: Switch from intr mount option to TASK_KILLABLEMatthew Wilcox
By using the TASK_KILLABLE infrastructure, we can get rid of the 'intr' mount option. We have to use _killable everywhere instead of _interruptible as we get rid of rpc_clnt_sigmask/sigunmask. Signed-off-by: Liam R. Howlett <howlett@gmail.com> Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2007-11-26NFS: Clean up new multi-segment direct I/O changesChuck Lever
Simplify calling sequence of nfs_direct_{read,write}_schedule(), and rename them to reflect their new role. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-11-26NFS: Ensure we return zero if applications attempt to write zero bytesChuck Lever
A zero byte count direct write request should be a successful no-op, not an error. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-11-26NFS: Support multiple segment iovecs in the NFS direct I/O pathChuck Lever
Allow applications to perform asynchronous scatter-gather direct I/O to NFS files. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-11-26NFS: Introduce iovec I/O helpers to fs/nfs/direct.cChuck Lever
Add helpers that iterate over multi-segment iovecs. These will be used to support multi-segment scatter/gather direct I/O in a later patch. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-23NFS: Fix for bug in handling of errors for O_DIRECT writesNeil Brown
Commit eda3cef8dd2b83875affe82595db9d0c278879b2 ("NFS: Fix error handling in nfs_direct_write_result()") ensured that if a WRITE returns an error, then data->res.verf->committed is not tested (as it is not initialised). Then commit 60fa3f769f7651a60125a0f44e3ffe3246d7cf39 ("NFS: Fix two bugs in the O_DIRECT write code") inadvertently reverted this while fixing other problems. So move the test so that we never examine ->committed in an error case, and fix a speeling error while we are there. Cc: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Neil Brown <neilb@suse.de> Acked-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-09NFS: Remove nfs_begin_data_update/nfs_end_data_updateTrond Myklebust
The lower level routines in fs/nfs/proc.c, fs/nfs/nfs3proc.c and fs/nfs/nfs4proc.c should already be dealing with the revalidation issues. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: Replace file->private_data with calls to nfs_file_open_context()Trond Myklebust
2007-07-10NFS: Replace vfsmount and dentry in nfs_open_context with struct pathTrond Myklebust
2007-07-10NFS: Don't fail an O_DIRECT read/write if get_user_pages() returns pagesTrond Myklebust
There is no need to fail the entire O_DIRECT read/write just because get_user_pages() returned fewer pages than we requested. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10NFS: Clean ups in fs/nfs/direct.cChuck Lever
2007-05-30NFS: Fix a refcount leakage in O_DIRECTTrond Myklebust
The current code is leaking a reference to dreq->kref when the calls to nfs_direct_read_schedule() and nfs_direct_write_schedule() return an error. This patch moves the call to kref_put() from nfs_direct_wait() back into nfs_direct_read() and nfs_direct_write() (which are the functions that actually took the reference in the first place) fixing the leak. Thanks to Denis V. Lunev for spotting the bug and proposing the original fix. Acked-by: Denis V. Lunev <dlunev@gmail.com> Acked-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-24NFS: Fix nfs_direct_dirty_pages()Trond Myklebust
We only need to dirty the pages that were actually read in. Also convert nfs_direct_dirty_pages() to call set_page_dirty() instead of set_page_dirty_lock(). A call to lock_page() is unacceptable in an rpciod callback function. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-24NFS: Fix handful of compiler warnings in direct.cChuck Lever
This patch fixes a couple of signage issues that were causing an Oops when running the LTP diotest4 test. get_user_pages() returns a signed error, hence we need to be careful when comparing with the unsigned number of pages from data->npages. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-04-30NFS: Fix a buffer overflow in the allocation of struct nfs_read/writedataTrond Myklebust
2007-04-14NFS: Fix two bugs in the O_DIRECT write codeTrond Myklebust
Do not flag an error if the COMMIT call fails and we decide to resend the writes. Let the resend flag the error if it fails. If a write has failed, then nfs_direct_write_result should not attempt to send a commit. It should just exit asap and return the error to the user. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-03NFS: fix print format for tk_pidChuck Lever
The tk_pid field is an unsigned short. The proper print format specifier for that type is %5u, not %4d. Also clean up some miscellaneous print formatting nits. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-12-08[PATCH] nfs: change uses of f_{dentry,vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the nfs client code. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07Merge branch 'master' of /home/trondmy/kernel/linux-2.6/ into merge_linusTrond Myklebust
