path: root/fs/nfs/mount_clnt.c
2010-12-21NFS: Remove redundant unlikely()Tobias Klauser
IS_ERR() already implies unlikely(), so it can be omitted here. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16SUNRPC: New xdr_streams XDR decoder APIChuck Lever
Now that all client-side XDR decoder routines use xdr_streams, there should be no need to support the legacy calling sequence [rpc_rqst *, __be32 *, RPC res *] anywhere. We can construct an xdr_stream in the generic RPC code, instead of in each decoder function. This is a refactoring change. It should not cause different behavior. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16SUNRPC: New xdr_streams XDR encoder APIChuck Lever
Now that all client-side XDR encoder routines use xdr_streams, there should be no need to support the legacy calling sequence [rpc_rqst *, __be32 *, RPC arg *] anywhere. We can construct an xdr_stream in the generic RPC code, instead of in each encoder function. Also, all the client-side encoder functions return 0 now, making a return value superfluous. Take this opportunity to convert them to return void instead. This is a refactoring change. It should not cause different behavior. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16NFS: Remove unused UMNT response data structureChuck Lever
Clean up. The UMNT request has a NULL response. There's no need to set up a mountres structure for it. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16NFS: Avoid return code checking in mount XDR encoder functionsChuck Lever
Clean up. The trend in the other XDR encoder functions is to BUG() when encoding problems occur, since a problem here is always due to a local coding error. Then, instead of a status, zero is unconditionally returned. Update the mount client XDR encoders to behave this way. To finish the update, use the new-style be32_to_cpup() and cpu_to_be32() macros, and compute the buffer sizes using raw integers instead of sizeof(). This matches the conventions used in other XDR functions. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-10NFS: Fix panic after nfs_umount()Chuck Lever
After a few unsuccessful NFS mount attempts in which the client and server cannot agree on an authentication flavor both support, the client panics. nfs_umount() is invoked in the kernel in this case. Turns out nfs_umount()'s UMNT RPC invocation causes the RPC client to write off the end of the rpc_clnt's iostat array. This is because the mount client's nrprocs field is initialized with the count of defined procedures (two: MNT and UMNT), rather than the size of the client's proc array (four). The fix is to use the same initialization technique used by most other upper layer clients in the kernel. Introduced by commit 0b524123, which failed to update nrprocs when support was added for UMNT in the kernel. BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=24302 BugLink: http://bugs.launchpad.net/bugs/683938 Reported-by: Stefan Bader <stefan.bader@canonical.com> Tested-by: Stefan Bader <stefan.bader@canonical.com> Cc: stable@kernel.org # >= 2.6.32 Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-10-26Merge branch 'for-2.6.37' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.37' of git://linux-nfs.org/~bfields/linux: (99 commits) svcrpc: svc_tcp_sendto XPT_DEAD check is redundant svcrpc: no need for XPT_DEAD check in svc_xprt_enqueue svcrpc: assume svc_delete_xprt() called only once svcrpc: never clear XPT_BUSY on dead xprt nfsd4: fix connection allocation in sequence() nfsd4: only require krb5 principal for NFSv4.0 callbacks nfsd4: move minorversion to client nfsd4: delay session removal till free_client nfsd4: separate callback change and callback probe nfsd4: callback program number is per-session nfsd4: track backchannel connections nfsd4: confirm only on succesful create_session nfsd4: make backchannel sequence number per-session nfsd4: use client pointer to backchannel session nfsd4: move callback setup into session init code nfsd4: don't cache seq_misordered replies SUNRPC: Properly initialize sock_xprt.srcaddr in all cases SUNRPC: Use conventional switch statement when reclassifying sockets sunrpc/xprtrdma: clean up workqueue usage sunrpc: Turn list_for_each-s into the ..._entry-s ... Fix up trivial conflicts (two different deprecation notices added in separate branches) in Documentation/feature-removal-schedule.txt
2010-10-01sunrpc: Add net to rpc_create_argsPavel Emelyanov
Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-09-17NFS: Remove \t from mount debugging messageChuck Lever
During boot, a random character is displayed instead of a tab. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-02-09NFS: Fix the mapping of the NFSERR_SERVERFAULT errorTrond Myklebust
It was recently pointed out that the NFSERR_SERVERFAULT error, which is designed to inform the user of a serious internal error on the server, was being mapped to an error value that is internal to the kernel. This patch maps it to the error EREMOTEIO, which is exported to userland through errno.h. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: stable@kernel.org
2009-08-10Merge branch 'patches_cel-for-2.6.32' into nfs-for-2.6.32Trond Myklebust
2009-08-09NFS: Add ability to send MOUNTPROC_UMNT to the kernel's mountd clientChuck Lever
After certain failure modes of an NFS mount, an NFS client should send a MOUNTPROC_UMNT request to remove the just-added mount entry from the server's mount table. While no-one should rely on the accuracy of the server's mount table, sending a UMNT is simply being a good internet neighbor. Since NFS mount processing is handled in the kernel now, we will need a function in the kernel's mountd client that can post a MOUNTRPC_UMNT request, in order to handle these failure modes. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-08-09nfs: Keep index within mnt_errtbl[]Roel Kluin
Ensure that index i remains within array mnt_errtbl[] and mnt3_errtbl[]. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17NFS: Remove unused XDR decoder functionsChuck Lever
Clean up: Remove xdr_decode_fhstatus() and xdr_decode_fhstatus3(), now that they are unused. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17NFS: Update MNT and MNT3 reply decoding functionsChuck Lever
Solder xdr_stream-based XDR decoding functions into the in-kernel mountd client that are more careful about checking data types and watching for buffer overflows. The new MNT3 decoder includes support for auth-flavor list decoding. The "_sz" macro for MNT3 replies was missing the size of the file handle. I've added this back, and included the size of the auth flavor array. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17NFS: add XDR decoder for mountd version 3 auth-flavor listsChuck Lever
Introduce an xdr_stream-based XDR decoder that can unpack the auth- flavor list returned in a MNT3 reply. The nfs_mount() function's caller allocates an array, and passes the size and a pointer to it. The decoder decodes all the flavors it can into the array, and returns the number of decoded flavors. If the caller is not interested in the auth flavors, it can pass a value of zero as the size of the pre-allocated array. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17NFS: add new file handle decoders to in-kernel mountd clientChuck Lever
Introduce xdr_stream-based XDR file handle decoders to the in-kernel mountd client. These are more careful than the existing decoder functions about buffer overflows and data type and range checking. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17NFS: Add separate mountd status code decoders for each mountd versionChuck Lever
Introduce data structures and xdr_stream-based decoding functions for unmarshalling mountd status codes properly. Mountd version 3 uses specific standard error return codes that are not errno values and not NFS3ERR_ values. These have a well-defined standard mapping to local errno values. Introduce data structures and a decoder function that map these status codes to local errno values properly. This is new functionality (but not used yet). Version 1 mountd status values are defined by RFC 1094 as UNIX error values (errno values). Errno values on heterogeneous systems do not necessarily match each other. To avoid exposing possibly incorrect errno values to upper layers, the current XDR decoder converts all non-zero MNT version 1 status codes to -EACCES. The OpenGroup XNFS standard provides a mapping similar to but smaller than the version 3 error codes. Implement a decoder that uses the XNFS error codes, replacing the current decoder. For both mountd protocol versions, map unrecognized errors to -EACCES. Finally we introduce a replacement data structure for mnt_fhstatus at this time, which is used by the new XDR decoders. In addition to documenting that the status value returned by the XDR decoders is always an errno, this new structure will be expanded in subsequent patches. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17NFS: remove unused function in fs/nfs/mount_clnt.cChuck Lever
Clean up: remove xdr_encode_dirpath() now that it has been replaced. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17NFS: Use xdr_stream-based XDR encoder for MNT's dirpath argumentChuck Lever
Check the length of the supplied dirpath, and see that it fits properly in the RPC buffer. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17NFS: Clean up MNT program definitionsChuck Lever
Clean up: Relocate MNT program procedure number definitions to the only file that uses them. Relocate the version number definitions, which are shared, to nfs.h. Remove duplicate program number definitions. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-12-23NFS: "[no]resvport" mount option changes mountd client tooChuck Lever
If the admin has specified the "noresvport" option for an NFS mount point, the kernel's NFS client uses an unprivileged source port for the main NFS transport. The kernel's mountd client should use an unprivileged port in this case as well. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-12-23NFS: introduce nfs_mount_info struct for calling nfs_mount()Chuck Lever
Clean up: convert nfs_mount() to take a single data structure argument to make it simpler to add more arguments. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-10-07NFS: Client mounts hang when exported directory do not existSteve Dickson
This patch fixes a regression that was introduced by the string based mounts. nfs_mount() statically returns -EACCES for every error returned by the remote mounted. This is incorrect because -EACCES is an non-fatal error to the mount.nfs command. This error causes mount.nfs to retry the mount even in the case when the exported directory does not exist. This patch maps the errors returned by the remote mountd into valid errno values, exactly how it was done pre-string based mounts. By returning the correct errno enables mount.nfs to do the right thing. Signed-off-by: Steve Dickson <steved@redhat.com> [Trond.Myklebust@netapp.com: nfs_stat_to_errno() now correctly returns negative errors, so remove the sign change.] Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-06-23NFS: Fix filehandle size comparisons in the mount codeTrond Myklebust
Fix a sign issue in xdr_decode_fhstatus3() Fix incorrect comparison in nfs_validate_mount_data() Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-12-06NFS: Switch from intr mount option to TASK_KILLABLEMatthew Wilcox
By using the TASK_KILLABLE infrastructure, we can get rid of the 'intr' mount option. We have to use _killable everywhere instead of _interruptible as we get rid of rpc_clnt_sigmask/sigunmask. Signed-off-by: Liam R. Howlett <howlett@gmail.com> Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2007-07-10NFS: Improve debugging output in NFS in-kernel mount clientChuck Lever
2007-07-10NFS: Clean up in-kernel NFS mountChuck Lever
Clean up white space and coding conventions. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10NFS: Remake nfsroot_mount as a permanent part of NFS clientChuck Lever
In preparation for supporting NFSv2 and NFSv3 mount option handling in the kernel NFS client, convert mount_clnt.c to be a permanent part of the NFS client, instead of built only when CONFIG_ROOT_NFS is enabled. In addition, we also replace the "struct sockaddr_in *" argument with something more generic, to help support IPv6 at some later point. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Add a convenient default for the hostname when calling rpc_create()Chuck Lever
A couple of callers just use a stringified IP address for the rpc client's hostname. Move the logic for constructing this into rpc_create(), so it can be shared. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Kill rpc_clnt->cl_oneshotTrond Myklebust
Replace it with explicit calls to rpc_shutdown_client() or rpc_destroy_client() (for the case of asynchronous calls). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-04-30SUNRPC: RPC buffer size estimates are too largeChuck Lever
The RPC buffer size estimation logic in net/sunrpc/clnt.c always significantly overestimates the requirements for the buffer size. A little instrumentation demonstrated that in fact rpc_malloc was never allocating the buffer from the mempool, but almost always called kmalloc. To compute the size of the RPC buffer more precisely, split p_bufsiz into two fields; one for the argument size, and one for the result size. Then, compute the sum of the exact call and reply header sizes, and split the RPC buffer precisely between the two. That should keep almost all RPC buffers within the 2KiB buffer mempool limit. And, we can finally be rid of RPC_SLACK_SPACE! Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-10-20[PATCH] xdr annotations: mount_clntAl Viro
[pulled from Alexey's patch] Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-22NFS: NFS_ROOT should use the new rpc_create APIChuck Lever
Teach NFS_ROOT to use the new rpc_create API instead of the old two-call API for creating an RPC transport. Test plan: Compile the kernel with the NFS client build-in, and set CONFIG_NFS_ROOT. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-22SUNRPC: remove extraneous header inclusionsChuck Lever
include/linux/sunrpc/clnt.h already includes include/linux/sunrpc/xprt.h. We can remove xprt.h from source files that already include clnt.h. Likewise include/linux/sunrpc/timer.h. Test plan: Compile kernel with CONFIG_NFS enabled. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-25Merge git://git.linux-nfs.org/pub/linux/nfs-2.6Linus Torvalds
* git://git.linux-nfs.org/pub/linux/nfs-2.6: (103 commits) SUNRPC,RPCSEC_GSS: spkm3--fix config dependencies SUNRPC,RPCSEC_GSS: spkm3: import contexts using NID_cast5_cbc LOCKD: Make nlmsvc_traverse_shares return void LOCKD: nlmsvc_traverse_blocks return is unused SUNRPC,RPCSEC_GSS: fix krb5 sequence numbers. NFSv4: Dont list system.nfs4_acl for filesystems that don't support it. SUNRPC,RPCSEC_GSS: remove unnecessary kmalloc of a checksum SUNRPC: Ensure rpc_call_async() always calls tk_ops->rpc_release() SUNRPC: Fix memory barriers for req->rq_received NFS: Fix a race in nfs_sync_inode() NFS: Clean up nfs_flush_list() NFS: Fix a race with PG_private and nfs_release_page() NFSv4: Ensure the callback daemon flushes signals SUNRPC: Fix a 'Busy inodes' error in rpc_pipefs NFS, NLM: Allow blocking locks to respect signals NFS: Make nfs_fhget() return appropriate error values NFSv4: Fix an oops in nfs4_fill_super lockd: blocks should hold a reference to the nlm_file NFSv4: SETCLIENTID_CONFIRM should handle NFS4ERR_DELAY/NFS4ERR_RESOURCE NFSv4: Send the delegation stateid for SETATTR calls ...
2006-03-24[PATCH] fs: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove a duplicate of ARRAY_SIZE. Some trailing whitespaces are also deleted. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Cc: David Howells <dhowells@redhat.com> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-20SUNRPC: eliminate rpc_call()Chuck Lever
Clean-up: replace rpc_call() helper with direct call to rpc_call_sync. This makes NFSv2 and NFSv3 synchronous calls more computationally efficient, and reduces stack consumption in functions that used to invoke rpc_call more than once. Test plan: Compile kernel with CONFIG_NFS enabled. Connectathon on NFS version 2, version 3, and version 4 mount points. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20SUNRPC: display human-readable procedure name in rpc_iostats outputChuck Lever
Add fields to the rpc_procinfo struct that allow the display of a human-readable name for each procedure in the rpc_iostats output. Also fix it so that the NFSv4 stats are broken up correctly by sub-procedure number. NFSv4 uses only two real RPC procedures: NULL, and COMPOUND. Test plan: Mount with NFSv2, NFSv3, and NFSv4, and do "cat /proc/self/mountstats". Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-01-06SUNRPC: get rid of cl_chattyChuck Lever
Clean up: Every ULP that uses the in-kernel RPC client, except the NLM client, sets cl_chatty. There's no reason why NLM shouldn't set it, so just get rid of cl_chatty and always be verbose. Test-plan: Compile with CONFIG_NFS enabled. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] RPC: Make rpc_create_client() destroy the transport on failure.Trond Myklebust
This saves us a couple of lines of cleanup code for each call. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
