file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
It was recently pointed out that the NFSERR_SERVERFAULT error, which is
designed to inform the user of a serious internal error on the server, was
being mapped to an error value that is internal to the kernel.
This patch maps it to the error EREMOTEIO, which is exported to userland
through errno.h.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: stable@kernel.org
* remove asm/atomic.h inclusion from linux/utsname.h --
not needed after kref conversion
* remove linux/utsname.h inclusion from files which do not need it
NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however
due to some personality stuff it _is_ needed -- cowardly leave ELF-related
headers and files alone.
There is no point in using anything other than umode_t, since we copy the
content pretty much directly into inode->i_mode.
Currently, filling struct nfs_fattr is more or less an all or nothing
operation, since NFSv2 and NFSv3 have only mandatory attributes.
In NFSv4, some attributes are optional, and so we may simply not be able to
fill in those fields. Furthermore, NFSv4 allows you to specify which
attributes you are interested in retrieving, thus permitting you to
optimise away retrieval of attributes that you know will no change...
All use sites for nfs{,4}_stat_to_errno negate their return value.
It's more efficient to return a negative error from the stat_to_errno convertors
rather than negating its return value everywhere. This also produces slightly
smaller code.
Signed-off-by: Benny Halevy <bhalevy@panasas.com>
Currently, the NFS readdir decoders have a workaround for buggy servers
that send an empty readdir response with the EOF bit unset. If the
server sends a malformed response in some cases, this workaround kicks
in and just returns an empty response rather than returning a proper
error to the caller.
This patch does 3 things:
1) have malformed responses with no entries return error (-EIO)
2) preserve existing workaround for servers that send empty
responses with the EOF marker unset.
3) Add some comments to clarify the logic in nfs_xdr_readdirres().
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Clean up: prevent length underflow and mixed sign comparisons when
unmarshalling NFS version 2 read, readdir, and readlink replies.
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Adds a flag word to the xdrbuf struct which indicates any bulk
disposition of the data. This enables RPC transport providers to
marshal it efficiently/appropriately, and may enable other
optimizations.
Signed-off-by: Tom Talpey <tmt@netapp.com>
Due to recent edict to replace or remove printk's that can be triggered en
masse by remote misbehavior. Left a few that only occur just before a BUG.
We need a common structure for setting up an unlink() rpc call in order to
fix the asynchronous unlink code.
We should almost always be deferencing the rpc_auth struct by means of the
credential's cr_auth field instead of the rpc_clnt->cl_auth anyway. Fix up
that historical mistake, and remove the macro that propagated it.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com>
The RPC buffer size estimation logic in net/sunrpc/clnt.c always
significantly overestimates the requirements for the buffer size.
A little instrumentation demonstrated that in fact rpc_malloc was never
allocating the buffer from the mempool, but almost always called kmalloc.
To compute the size of the RPC buffer more precisely, split p_bufsiz into
two fields; one for the argument size, and one for the result size.
Then, compute the sum of the exact call and reply header sizes, and split
the RPC buffer precisely between the two. That should keep almost all RPC
buffers within the 2KiB buffer mempool limit.
And, we can finally be rid of RPC_SLACK_SPACE!
on-the-wire data is big-endian
[in large part pulled from Alexey's patch]
Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no>
Acked-by: Neil Brown <neilb@suse.de>
Now that we have a copy of the symlink path in the page cache, we can pass
a struct page down to the XDR routines instead of a string buffer.
Test plan:
Connectathon, all NFS versions.
Trond had apparently merged the same patch twice, causing a duplicate
include of the "internal.h" file, with resulting obvious confusion.
Tssk. I'm the only one allowed to send out trees that don't even
compile! Who does this Trond guy think he is?
Fix various problems with nfs4 disabled. And various other things.
In file included from fs/nfs/inode.c:50:
fs/nfs/internal.h:24: error: static declaration of 'nfs_do_refmount' follows non-static declaration
include/linux/nfs_fs.h:320: error: previous declaration of 'nfs_do_refmount' was here
fs/nfs/internal.h:65: warning: 'struct nfs4_fs_locations' declared inside parameter list
fs/nfs/internal.h:65: warning: its scope is only this definition or declaration, which is probably not what you want
fs/nfs/internal.h: In function 'nfs4_path':
fs/nfs/internal.h:97: error: 'struct nfs_server' has no member named 'mnt_path'
fs/nfs/inode.c: In function 'init_once':
fs/nfs/inode.c:1116: error: 'struct nfs_inode' has no member named 'open_states'
fs/nfs/inode.c:1116: error: 'struct nfs_inode' has no member named 'delegation'
fs/nfs/inode.c:1116: error: 'struct nfs_inode' has no member named 'delegation_state'
fs/nfs/inode.c:1116: error: 'struct nfs_inode' has no member named 'rwsem'
distcc[26452] ERROR: compile fs/nfs/inode.c on g5/64 failed
make[1]: *** [fs/nfs/inode.o] Error 1
make: *** [fs/nfs/inode.o] Error 2
make: *** Waiting for unfinished jobs....
In file included from fs/nfs/nfs3xdr.c:26:
distcc[26486] ERROR: compile fs/nfs/nfs3xdr.c on g5/64 failed
make[1]: *** [fs/nfs/nfs3xdr.o] Error 1
make: *** [fs/nfs/nfs3xdr.o] Error 2
In file included from fs/nfs/nfs3proc.c:24:
distcc[26469] ERROR: compile fs/nfs/nfs3proc.c on bix/32 failed
make[1]: *** [fs/nfs/nfs3proc.o] Error 1
make: *** [fs/nfs/nfs3proc.o] Error 2
**FAILED**
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Andreas Gruenbacher <agruen@suse.de>
Cc: Andy Adamson <andros@citi.umich.edu>
Cc: Chuck Lever <cel@netapp.com>
Cc: J. Bruce Fields <bfields@fieldses.org>
Cc: Manoj Naik <manoj@almaden.ibm.com>
Cc: Marc Eshel <eshel@almaden.ibm.com>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
fs/nfs/inode.c
fs/super.c
Fix conflicts between patch 'NFS: Split fs/nfs/inode.c' and patch
'VFS: Permit filesystem to override root dentry on mount'
As fs/nfs/inode.c is rather large, heterogenous and unwieldy, the attached
patch splits it up into a number of files:
(*) fs/nfs/inode.c
Strictly inode specific functions.
(*) fs/nfs/super.c
Superblock management functions for NFS and NFS4, normal access, clones
and referrals. The NFS4 superblock functions _could_ move out into a
separate conditionally compiled file, but it's probably not worth it as
there're so many common bits.
(*) fs/nfs/namespace.c
Some namespace-specific functions have been moved here.
(*) fs/nfs/nfs4namespace.c
NFS4-specific namespace functions (this could be merged into the previous
file). This file is conditionally compiled.
(*) fs/nfs/internal.h
Inter-file declarations, plus a few simple utility functions moved from
fs/nfs/inode.c.
Additionally, all the in-.c-file externs have been moved here, and those
files they were moved from now includes this file.
For the most part, the functions have not been changed, only some multiplexor
functions have changed significantly.
I've also:
(*) Added some extra banner comments above some functions.
(*) Rearranged the function order within the files to be more logical and
better grouped (IMO), though someone may prefer a different order.
(*) Reduced the number of #ifdefs in .c files.
(*) Added missing __init and __exit directives.
Signed-Off-By: David Howells <dhowells@redhat.com>
This should enable us to detect if we are crossing a mountpoint in the
case where the server is exporting "nohide" mounts.
* git://git.linux-nfs.org/pub/linux/nfs-2.6: (103 commits)
SUNRPC,RPCSEC_GSS: spkm3--fix config dependencies
SUNRPC,RPCSEC_GSS: spkm3: import contexts using NID_cast5_cbc
LOCKD: Make nlmsvc_traverse_shares return void
LOCKD: nlmsvc_traverse_blocks return is unused
SUNRPC,RPCSEC_GSS: fix krb5 sequence numbers.
NFSv4: Dont list system.nfs4_acl for filesystems that don't support it.
SUNRPC,RPCSEC_GSS: remove unnecessary kmalloc of a checksum
SUNRPC: Ensure rpc_call_async() always calls tk_ops->rpc_release()
SUNRPC: Fix memory barriers for req->rq_received
NFS: Fix a race in nfs_sync_inode()
NFS: Clean up nfs_flush_list()
NFS: Fix a race with PG_private and nfs_release_page()
NFSv4: Ensure the callback daemon flushes signals
SUNRPC: Fix a 'Busy inodes' error in rpc_pipefs
NFS, NLM: Allow blocking locks to respect signals
NFS: Make nfs_fhget() return appropriate error values
NFSv4: Fix an oops in nfs4_fill_super
lockd: blocks should hold a reference to the nlm_file
NFSv4: SETCLIENTID_CONFIRM should handle NFS4ERR_DELAY/NFS4ERR_RESOURCE
NFSv4: Send the delegation stateid for SETATTR calls
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove a
duplicate of ARRAY_SIZE. Some trailing whitespaces are also deleted.
Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch>
Cc: Dave Kleikamp <shaggy@austin.ibm.com>
Cc: Neil Brown <neilb@cse.unsw.edu.au>
Cc: Chris Mason <mason@suse.com>
Cc: Jeff Mahoney <jeffm@suse.com>
Cc: Nathan Scott <nathans@sgi.com>
Add fields to the rpc_procinfo struct that allow the display of a
human-readable name for each procedure in the rpc_iostats output.
Also fix it so that the NFSv4 stats are broken up correctly by
sub-procedure number. NFSv4 uses only two real RPC procedures:
NULL, and COMPOUND.
Test plan:
Mount with NFSv2, NFSv3, and NFSv4, and do "cat /proc/self/mountstats".
Signed-off-by: Chuck Lever <cel@netapp.com>
Allow nfs_refresh_inode() also to update attributes on the inode if the
RPC call was sent after the last call to nfs_update_inode().
infrastructure for it.
Let it rip!
