path: root/fs/nfs/nfs3acl.c
2010-05-14NFS: Reduce stack footprint of nfs3_proc_getacl() and nfs3_proc_setacl()Trond Myklebust
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-06-17nfs: remove unnecessary NFS_INO_INVALID_ACL checksJames Morris
Unless I'm mistaken, NFS_INO_INVALID_ACL is being checked twice during getacl calls (i.e. first via nfs_revalidate_inode() and then by each all site). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-10NFSv3: Fix posix ACL codeTrond Myklebust
Fix a memory leak due to allocation in the XDR layer. In cases where the RPC call needs to be retransmitted, we end up allocating new pages without clearing the old ones. Fix this by moving the allocation into nfs3_proc_setacls(). Also fix an issue discovered by Kevin Rudd, whereby the amount of memory reserved for the acls in the xdr_buf->head was miscalculated, and causing corruption. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-10-07NFS: missing nfs_fattr_init in nfs3_proc_getacl and nfs3_proc_setacls ↵Jeff Layton
(resend #2) The fattrs used in the NFSv3 getacl/setacl calls are not being properly initialized. This occasionally causes nfs_update_inode to fall into NFSv4 specific codepaths when handling post-op attrs from these calls. Thanks to Cai Qian for noticing the spurious NFSv4 messages in debug output from a v3 mount... Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-07-09NFS: Ensure we zap only the access and acl caches when setting new aclsTrond Myklebust
...and ensure that we obey the NFS_INO_INVALID_ACL flag when retrieving the acls. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09NFS: Remove nfs_begin_data_update/nfs_end_data_updateTrond Myklebust
The lower level routines in fs/nfs/proc.c, fs/nfs/nfs3proc.c and fs/nfs/nfs4proc.c should already be dealing with the revalidation issues. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-06-09NFSv3: Client-side nfsacl caching fixAndreas Gruenbacher
Fix two errors in the client-side acl cache: First, when nfs3_proc_getacl requests only the default acl of a file and the access acl is not cached already, a NULL access acl entry is cached instead of ERR_PTR(-EAGAIN) ("not cached"). Second, update the cached acls in nfs3_proc_setacls: nfs_refresh_inode does not always invalidate the cached acls, and when it does not, the cached acls get out of sync. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20SUNRPC: eliminate rpc_call()Chuck Lever
Clean-up: replace rpc_call() helper with direct call to rpc_call_sync. This makes NFSv2 and NFSv3 synchronous calls more computationally efficient, and reduces stack consumption in functions that used to invoke rpc_call more than once. Test plan: Compile kernel with CONFIG_NFS enabled. Connectathon on NFS version 2, version 3, and version 4 mount points. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-08-18[PATCH] NFS: Introduce the use of inode->i_lock to protect fields in nfsiChuck Lever
Down the road we want to eliminate the use of the global kernel lock entirely from the NFS client. To do this, we need to protect the fields in the nfs_inode structure adequately. Start by serializing updates to the "cache_validity" field. Note this change addresses an SMP hang found by njw@osdl.org, where processes deadlock because nfs_end_data_update and nfs_revalidate_mapping update the "cache_validity" field without proper serialization. Test plan: Millions of fsx ops on SMP clients. Run Nick Wilson's breaknfs program on large SMP clients. Signed-off-by: Chuck Lever <cel@netapp.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-18[PATCH] NFS: split nfsi->flags into two fieldsChuck Lever
Certain bits in nfsi->flags can be manipulated with atomic bitops, and some are better manipulated via logical bitmask operations. This patch splits the flags field into two. The next patch introduces atomic bitops for one of the fields. Test plan: Millions of fsx ops on SMP clients. Signed-off-by: Chuck Lever <cel@netapp.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-28[PATCH] really remove xattr_acl.hChristoph Hellwig
Looks like it sneaked back with the NFS ACL merge.. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-22[PATCH] NFS: Fix up v3 ACL caching codeTrond Myklebust
Initialize the inode cache values correctly. Clean up __nfs3_forget_cached_acls() Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFS: Cache the NFSv3 acls.Andreas Gruenbacher
Attach acls to inodes in the icache to avoid unnecessary GETACL RPC round-trips. As long as the client doesn't retrieve any acls itself, only the default acls of exiting directories and the default and access acls of new directories will end up in the cache, which preserves some memory compared to always caching the access and default acl of all files. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Olaf Kirch <okir@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFS: Fix handling of the umask when an NFSv3 default acl is present.Andreas Gruenbacher
NFSv3 has no concept of a umask on the server side: The client applies the umask locally, and sends the effective permissions to the server. This behavior is wrong when files are created in a directory that has a default ACL. In this case, the umask is supposed to be ignored, and only the default ACL determines the file's effective permissions. Usually its the server's task to conditionally apply the umask. But since the server knows nothing about the umask, we have to do it on the client side. This patch tries to fetch the parent directory's default ACL before creating a new file, computes the appropriate create mode to send to the server, and finally sets the new file's access and default acl appropriately. Many thanks to Buck Huppmann <buchk@pobox.com> for sending the initial version of this patch, as well as for arguing why we need this change. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Olaf Kirch <okir@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFS: Add support for NFSv3 ACLsAndreas Gruenbacher
This adds acl support fo nfs clients via the NFSACL protocol extension, by implementing the getxattr, listxattr, setxattr, and removexattr iops for the system.posix_acl_access and system.posix_acl_default attributes. This patch implements a dumb version that uses no caching (and thus adds some overhead). (Another patch in this patchset adds caching as well.) Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Olaf Kirch <okir@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
