path: root/fs/nfs/nfs4renewd.c
2014-09-30NFSv4.1: Fix an NFSv4.1 state renewal regressionAndy Adamson
Commit 2f60ea6b8ced ("NFSv4: The NFSv4.0 client must send RENEW calls if it holds a delegation") set the NFS4_RENEW_TIMEOUT flag in nfs4_renew_state, and does not put an nfs41_proc_async_sequence call, the NFSv4.1 lease renewal heartbeat call, on the wire to renew the NFSv4.1 state if the flag was not set. The NFS4_RENEW_TIMEOUT flag is set when "now" is after the last renewal (cl_last_renewal) plus the lease time divided by 3. This is arbitrary and sometimes does the following: In normal operation, the only way a future state renewal call is put on the wire is via a call to nfs4_schedule_state_renewal, which schedules a nfs4_renew_state workqueue task. nfs4_renew_state determines if the NFS4_RENEW_TIMEOUT should be set, and the calls nfs41_proc_async_sequence, which only gets sent if the NFS4_RENEW_TIMEOUT flag is set. Then the nfs41_proc_async_sequence rpc_release function schedules another state remewal via nfs4_schedule_state_renewal. Without this change we can get into a state where an application stops accessing the NFSv4.1 share, state renewal calls stop due to the NFS4_RENEW_TIMEOUT flag _not_ being set. The only way to recover from this situation is with a clientid re-establishment, once the application resumes and the server has timed out the lease and so returns NFS4ERR_BAD_SESSION on the subsequent SEQUENCE operation. An example application: open, lock, write a file. sleep for 6 * lease (could be less) ulock, close. In the above example with NFSv4.1 delegations enabled, without this change, there are no OP_SEQUENCE state renewal calls during the sleep, and the clientid is recovered due to lease expiration on the close. This issue does not occur with NFSv4.1 delegations disabled, nor with NFSv4.0, with or without delegations enabled. Signed-off-by: Andy Adamson <andros@netapp.com> Link: http://lkml.kernel.org/r/1411486536-23401-1-git-send-email-andros@netapp.com Fixes: 2f60ea6b8ced (NFSv4: The NFSv4.0 client must send RENEW calls...) Cc: stable@vger.kernel.org # 3.2.x Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2012-08-13workqueue: use mod_delayed_work() instead of cancel + queueTejun Heo
Convert delayed_work users doing cancel_delayed_work() followed by queue_delayed_work() to mod_delayed_work(). Most conversions are straight-forward. Ones worth mentioning are, * drivers/edac/edac_mc.c: edac_mc_workq_setup() converted to always use mod_delayed_work() and cancel loop in edac_mc_reset_delay_period() is dropped. * drivers/platform/x86/thinkpad_acpi.c: No need to remember whether watchdog is active or not. @fan_watchdog_active and related code dropped. * drivers/power/charger-manager.c: Seemingly a lot of delayed_work_pending() abuse going on here. [delayed_]work_pending() are unsynchronized and racy when used like this. I converted one instance in fullbatt_handler(). Please conver the rest so that it invokes workqueue APIs for the intended target state rather than trying to game work item pending state transitions. e.g. if timer should be modified - call mod_delayed_work(), canceled - call cancel_delayed_work[_sync](). * drivers/thermal/thermal_sys.c: thermal_zone_device_set_polling() simplified. Note that round_jiffies() calls in this function are meaningless. round_jiffies() work on absolute jiffies not delta delay used by delayed_work. v2: Tomi pointed out that __cancel_delayed_work() users can't be safely converted to mod_delayed_work(). They could be calling it from irq context and if that happens while delayed_work_timer_fn() is running, it could deadlock. __cancel_delayed_work() users are dropped. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Acked-by: Anton Vorontsov <cbouatmailru@gmail.com> Acked-by: David Howells <dhowells@redhat.com> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Doug Thompson <dougthompson@xmission.com> Cc: David Airlie <airlied@linux.ie> Cc: Roland Dreier <roland@kernel.org> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Len Brown <len.brown@intel.com> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Johannes Berg <johannes@sipsolutions.net>
2012-05-22NFS: Add NFSDBG_STATEChuck Lever
fs/nfs/nfs4state.c does not yet have any dprintk() call sites, and I'm about to introduce some. We will need a new flag for enabling them. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-08-24NFSv4: The NFSv4.0 client must send RENEW calls if it holds a delegationTrond Myklebust
RFC3530 states that if the client holds a delegation, then it is obliged to continue to send RENEW calls once every lease period in order to allow the server to return NFS4ERR_CB_PATH_DOWN if the callback path is unreachable. This is not required for NFSv4.1, since the server can at any time set the SEQ4_STATUS_CB_PATH_DOWN_SESSION in any SEQUENCE operation. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-11NFSv4.1: new flag for state renewal checkAndy Adamson
Data servers not sharing a session with the mount MDS always have an empty cl_superblocks list. Replace the cl_superblocks empty list check to see if it is time to shut down renewd with the NFS_CS_STOP_RENEW bit which is not set by such a data server. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-06NFS: Move cl_delegations to the nfs_server structChuck Lever
Delegations are per-inode, not per-nfs_client. When a server file system is migrated, delegations on the client must be moved from the source to the destination nfs_server. Make it easier to manage a mount point's delegation list across a migration event by moving the list to the nfs_server struct. Clean up: I added documenting comments to public functions I changed in this patch. For consistency I added comments to all the other public functions in fs/nfs/delegation.c. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-06NFS: Allow walking nfs_client.cl_superblocks list outside client.cChuck Lever
We're about to move some fields from struct nfs_client to struct nfs_server. There is a many-to-one relationship between nfs_servers and nfs_clients. After these fields are moved to the nfs_server struct, to visit all of the data in these fields that is owned by one nfs_client, code will need to visit each nfs_server on the cl_superblocks list for that nfs_client. To serialize changes to the cl_superblocks list during these little expeditions, protect the list with RCU. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-06-22NFSv41: Convert the various reboot recovery ops etc to minor version opsTrond Myklebust
2010-03-02nfs: prevent backlogging of renewd requestsAlexandros Batsakis
If the renewd send queue gets backlogged (e.g., if the server goes down), we will keep filling the queue with periodic RENEW/SEQUENCE requests. This patch schedules a new renewd request if and only if the previous one returns (either success or failure) Signed-off-by: Alexandros Batsakis <batsakis@netapp.com> [Trond.Myklebust@netapp.com: moved nfs4_schedule_state_renewal() into separate nfs4_renew_release() and nfs41_sequence_release() callbacks to ensure correct behaviour on call setup failure] Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-10-08NFSv4: Kill nfs4_renewd_prepare_shutdown()Trond Myklebust
The NFSv4 renew daemon is shared between all active super blocks that refer to a particular NFS server, so it is wrong to be shutting it down in nfs4_kill_super every time a super block is destroyed. This patch therefore kills nfs4_renewd_prepare_shutdown altogether, and leaves it up to nfs4_shutdown_client() to also shut down the renew daemon by means of the existing call to nfs4_kill_renewd(). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17nfs41: introduce get_state_renewal_credAndy Adamson
Use the machine cred for sending SEQUENCE to renew the client's lease. [revamp patch for new state management design starting 2.6.29] [nfs41: support minorversion 1 for nfs4_check_lease] Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: get cred in exchange_id when cred arg is NULL] Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: use cl_machined_cred instead of cl_ex_cred] Since EXCHANGE_ID insists on using the machine credential, cl_ex_cred is not needed. nfs4_proc_exchange_id() is only called if the machine credential is available. Remove the credential logic from nfs4_proc_exchange_id. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-17nfs41: lease renewalBenny Halevy
Send a NFSv4.1 SEQUENCE op rather than RENEW that was deprecated in minorversion 1. Use the nfs_client minorversion to select reboot_recover/ network_partition_recovery/state_renewal ops. Note: we use reclaimer to create the nfs41 session before there are any cl_superblocks for the nfs_client. Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: check for session not minorversion] Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> [revamped patch for new nfs4_state_manager design] Signed-off-by: Benny Halevy <bhalevy@panasas.com> [nfs41: obliterate nfs4_state_recovery_ops.renew_lease method] moved to nfs4_state_maintenance_ops [also undid per-minorversion nfs4_state_recovery_ops here] Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-12-23NFSv4: Return unreferenced delegations more promptlyTrond Myklebust
If the client is not using a delegation, the right thing to do is to return it as soon as possible. This helps reduce the amount of state the server has to track, as well as reducing the potential for conflicts with other clients. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-12-23NFSv4: Clean up nfs_expire_all_delegations()Trond Myklebust
Let the actual delegreturn stuff be run in the state manager thread rather than allocating a separate kthread. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-12-23NFSv4: Remove nfs_client->cl_semTrond Myklebust
Now that we're using the flags to indicate state that needs to be recovered, as well as having implemented proper refcounting and spinlocking on the state and open_owners, we can get rid of nfs_client->cl_sem. The only remaining case that was dubious was the file locking, and that case is now covered by the nfsi->rwsem. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-12-23NFSv4: Callers to nfs4_get_renew_cred() need to hold nfs_client->cl_lockTrond Myklebust
Ditto for nfs4_get_setclientid_cred(). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-05-16nfs: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-03NFSv4: Fix circular locking dependency in nfs4_kill_renewdTrond Myklebust
Erez Zadok reports: ======================================================= [ INFO: possible circular locking dependency detected ] 2.6.24-rc6-unionfs2 #80 ------------------------------------------------------- umount.nfs4/4017 is trying to acquire lock: (&(&clp->cl_renewd)->work){--..}, at: [<c0223e53>] __cancel_work_timer+0x83/0x17f but task is already holding lock: (&clp->cl_sem){----}, at: [<f8879897>] nfs4_kill_renewd+0x17/0x29 [nfs] which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #1 (&clp->cl_sem){----}: [<c0230699>] __lock_acquire+0x9cc/0xb95 [<c0230c39>] lock_acquire+0x5f/0x78 [<c0397cb8>] down_read+0x3a/0x4c [<f88798e6>] nfs4_renew_state+0x1c/0x1b8 [nfs] [<c0223821>] run_workqueue+0xd9/0x1ac [<c0224220>] worker_thread+0x7a/0x86 [<c0226b49>] kthread+0x3b/0x62 [<c02033a3>] kernel_thread_helper+0x7/0x10 [<ffffffff>] 0xffffffff -> #0 (&(&clp->cl_renewd)->work){--..}: [<c0230589>] __lock_acquire+0x8bc/0xb95 [<c0230c39>] lock_acquire+0x5f/0x78 [<c0223e87>] __cancel_work_timer+0xb7/0x17f [<c0223f5a>] cancel_delayed_work_sync+0xb/0xd [<f887989e>] nfs4_kill_renewd+0x1e/0x29 [nfs] [<f885a8f6>] nfs_free_client+0x37/0x9e [nfs] [<f885ab20>] nfs_put_client+0x5d/0x62 [nfs] [<f885ab9a>] nfs_free_server+0x75/0xae [nfs] [<f8862672>] nfs4_kill_super+0x27/0x2b [nfs] [<c0258aab>] deactivate_super+0x3f/0x51 [<c0269668>] mntput_no_expire+0x42/0x67 [<c025d0e4>] path_release_on_umount+0x15/0x18 [<c0269d30>] sys_umount+0x1a3/0x1cb [<c0269d71>] sys_oldumount+0x19/0x1b [<c02026ca>] sysenter_past_esp+0x5f/0xa5 [<ffffffff>] 0xffffffff Looking at the code, it would seem that taking the clp->cl_sem in nfs4_kill_renewd is completely redundant, since we're already guaranteed to have exclusive access to the nfs_client (we're shutting down). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-08-07NFS: Replace flush_scheduled_work with cancel_work_sync() and friendsTrond Myklebust
This will avoid deadlocks of the form: stack backtrace: [<c0104fda>] show_trace_log_lvl+0x1a/0x30 [<c0105c02>] show_trace+0x12/0x20 [<c0105d15>] dump_stack+0x15/0x20 [<c013ee42>] __lock_acquire+0xc22/0x1030 [<c013f2b1>] lock_acquire+0x61/0x80 [<c012edd9>] flush_workqueue+0x49/0x70 [<c012ee0d>] flush_scheduled_work+0xd/0x10 [<dcf55c0c>] nfs_release_automount_timer+0x2c/0x30 [nfs] [<dcf45d8e>] nfs_free_server+0x9e/0xd0 [nfs] [<dcf4e626>] nfs_kill_super+0x16/0x20 [nfs] [<c017b38d>] deactivate_super+0x7d/0xa0 [<c018f94b>] mntput_no_expire+0x4b/0x80 [<c018fd94>] expire_mount_list+0xe4/0x140 [<c0191219>] mark_mounts_for_expiry+0x99/0xb0 [<dcf55d1d>] nfs_expire_automounts+0xd/0x40 [nfs] [<c012e61b>] run_workqueue+0x12b/0x1e0 [<c012f05b>] worker_thread+0x9b/0x100 [<c0131c72>] kthread+0x42/0x70 [<c0104c0f>] kernel_thread_helper+0x7/0x18 ======================= Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-11-22WorkStruct: Pass the work_struct pointer instead of context dataDavid Howells
Pass the work_struct pointer to the work function rather than context data. The work function can use container_of() to work out the data. For the cases where the container of the work_struct may go away the moment the pending bit is cleared, it is made possible to defer the release of the structure by deferring the clearing of the pending bit. To make this work, an extra flag is introduced into the management side of the work_struct. This governs auto-release of the structure upon execution. Ordinarily, the work queue executor would release the work_struct for further scheduling or deallocation by clearing the pending bit prior to jumping to the work function. This means that, unless the driver makes some guarantee itself that the work_struct won't go away, the work function may not access anything else in the work_struct or its container lest they be deallocated.. This is a problem if the auxiliary data is taken away (as done by the last patch). However, if the pending bit is *not* cleared before jumping to the work function, then the work function *may* access the work_struct and its container with no problems. But then the work function must itself release the work_struct by calling work_release(). In most cases, automatic release is fine, so this is the default. Special initiators exist for the non-auto-release case (ending in _NAR). Signed-Off-By: David Howells <dhowells@redhat.com>
2006-09-22NFSv4: Fix a use-after-free issue with the nfs server.Trond Myklebust
2006-09-22NFS: Share NFS superblocks per-protocol per-server per-FSIDDavid Howells
The attached patch makes NFS share superblocks between mounts from the same server and FSID over the same protocol. It does this by creating each superblock with a false root and returning the real root dentry in the vfsmount presented by get_sb(). The root dentry set starts off as an anonymous dentry if we don't already have the dentry for its inode, otherwise it simply returns the dentry we already have. We may thus end up with several trees of dentries in the superblock, and if at some later point one of anonymous tree roots is discovered by normal filesystem activity to be located in another tree within the superblock, the anonymous root is named and materialises attached to the second tree at the appropriate point. Why do it this way? Why not pass an extra argument to the mount() syscall to indicate the subpath and then pathwalk from the server root to the desired directory? You can't guarantee this will work for two reasons: (1) The root and intervening nodes may not be accessible to the client. With NFS2 and NFS3, for instance, mountd is called on the server to get the filehandle for the tip of a path. mountd won't give us handles for anything we don't have permission to access, and so we can't set up NFS inodes for such nodes, and so can't easily set up dentries (we'd have to have ghost inodes or something). With this patch we don't actually create dentries until we get handles from the server that we can use to set up their inodes, and we don't actually bind them into the tree until we know for sure where they go. (2) Inaccessible symbolic links. If we're asked to mount two exports from the server, eg: mount warthog:/warthog/aaa/xxx /mmm mount warthog:/warthog/bbb/yyy /nnn We may not be able to access anything nearer the root than xxx and yyy, but we may find out later that /mmm/www/yyy, say, is actually the same directory as the one mounted on /nnn. What we might then find out, for example, is that /warthog/bbb was actually a symbolic link to /warthog/aaa/xxx/www, but we can't actually determine that by talking to the server until /warthog is made available by NFS. This would lead to having constructed an errneous dentry tree which we can't easily fix. We can end up with a dentry marked as a directory when it should actually be a symlink, or we could end up with an apparently hardlinked directory. With this patch we need not make assumptions about the type of a dentry for which we can't retrieve information, nor need we assume we know its place in the grand scheme of things until we actually see that place. This patch reduces the possibility of aliasing in the inode and page caches for inodes that may be accessed by more than one NFS export. It also reduces the number of superblocks required for NFS where there are many NFS exports being used from a server (home directory server + autofs for example). This in turn makes it simpler to do local caching of network filesystems, as it can then be guaranteed that there won't be links from multiple inodes in separate superblocks to the same cache file. Obviously, cache aliasing between different levels of NFS protocol could still be a problem, but at least that gives us another key to use when indexing the cache. This patch makes the following changes: (1) The server record construction/destruction has been abstracted out into its own set of functions to make things easier to get right. These have been moved into fs/nfs/client.c. All the code in fs/nfs/client.c has to do with the management of connections to servers, and doesn't touch superblocks in any way; the remaining code in fs/nfs/super.c has to do with VFS superblock management. (2) The sequence of events undertaken by NFS mount is now reordered: (a) A volume representation (struct nfs_server) is allocated. (b) A server representation (struct nfs_client) is acquired. This may be allocated or shared, and is keyed on server address, port and NFS version. (c) If allocated, the client representation is initialised. The state member variable of nfs_client is used to prevent a race during initialisation from two mounts. (d) For NFS4 a simple pathwalk is performed, walking from FH to FH to find the root filehandle for the mount (fs/nfs/getroot.c). For NFS2/3 we are given the root FH in advance. (e) The volume FSID is probed for on the root FH. (f) The volume representation is initialised from the FSINFO record retrieved on the root FH. (g) sget() is called to acquire a superblock. This may be allocated or shared, keyed on client pointer and FSID. (h) If allocated, the superblock is initialised. (i) If the superblock is shared, then the new nfs_server record is discarded. (j) The root dentry for this mount is looked up from the root FH. (k) The root dentry for this mount is assigned to the vfsmount. (3) nfs_readdir_lookup() creates dentries for each of the entries readdir() returns; this function now attaches disconnected trees from alternate roots that happen to be discovered attached to a directory being read (in the same way nfs_lookup() is made to do for lookup ops). The new d_materialise_unique() function is now used to do this, thus permitting the whole thing to be done under one set of locks, and thus avoiding any race between mount and lookup operations on the same directory. (4) The client management code uses a new debug facility: NFSDBG_CLIENT which is set by echoing 1024 to /proc/net/sunrpc/nfs_debug. (5) Clone mounts are now called xdev mounts. (6) Use the dentry passed to the statfs() op as the handle for retrieving fs statistics rather than the root dentry of the superblock (which is now a dummy). Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-22NFS: Rename nfs_server::nfs4_stateDavid Howells
Rename nfs_server::nfs4_state to nfs_client as it will be used to represent the client state for NFS2 and NFS3 also. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-22NFS: Rename struct nfs4_client to struct nfs_clientDavid Howells
Rename struct nfs4_client to struct nfs_client so that it can become the basis for a general client record for NFS2 and NFS3 in addition to NFS4. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-01-06NFSv4: Remove requirement for machine creds for the "renew" operationTrond Myklebust
In RFC3530, the RENEW operation is allowed to use either the same principal, RPC security flavour and (if RPCSEC_GSS), the same mechanism and service that was used for SETCLIENTID_CONFIRM OR Any principal, RPC security flavour and service combination that currently has an OPEN file on the server. Choose the latter since that doesn't require us to keep credentials for the same principal for the entire duration of the mount. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-01-06NFSv4: Send RENEW requests to the server only when we're holding stateTrond Myklebust
2005-06-22[PATCH] NFS: Header file cleanup...Trond Myklebust
- Move NFSv4 state definitions into a private header file. - Clean up gunk in nfs_fs.h Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
