path: root/fs/nfs/proc.c
2014-05-28NFS: Create a common pgio_rpc_prepare functionAnna Schumaker
The read and write paths do exactly the same thing for the rpc_prepare rpc_op. This patch combines them together into a single function. Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-05-28NFS: Create a common read and write data structAnna Schumaker
At this point, the only difference between nfs_read_data and nfs_write_data is the write verifier. Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-05-28nfs: remove ->read_pageio_init from rpc opsChristoph Hellwig
The read_pageio_init method is just a very convoluted way to grab the right nfs_pageio_ops vector. The vector to chose is not a choice of protocol version, but just a pNFS vs MDS I/O choice that can simply be done inside nfs_pageio_init_read based on the presence of a layout driver, and a new force_mds flag to the special case of falling back to MDS I/O on a pNFS-capable volume. Signed-off-by: Christoph Hellwig <hch@lst.de> Tested-by: Anna Schumaker <Anna.Schumaker@Netapp.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-05-28nfs: remove ->write_pageio_init from rpc opsChristoph Hellwig
The write_pageio_init method is just a very convoluted way to grab the right nfs_pageio_ops vector. The vector to chose is not a choice of protocol version, but just a pNFS vs MDS I/O choice that can simply be done inside nfs_pageio_init_write based on the presence of a layout driver, and a new force_mds flag to the special case of falling back to MDS I/O on a pNFS-capable volume. Signed-off-by: Christoph Hellwig <hch@lst.de> Tested-by: Anna Schumaker <Anna.Schumaker@Netapp.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-03-17nfs: remove synchronous rename codeJeff Layton
Now that nfs_rename uses the async infrastructure, we can remove this. Signed-off-by: Jeff Layton <jlayton@redhat.com> Tested-by: Anna Schumaker <Anna.Schumaker@netapp.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2013-10-24nfs: use %p[dD] instead of open-coded (and often racy) equivalentsAl Viro
2013-09-04NFSv4: Don't try to recover NFSv4 locks when they are lost.NeilBrown
When an NFSv4 client loses contact with the server it can lose any locks that it holds. Currently when it reconnects to the server it simply tries to reclaim those locks. This might succeed even though some other client has held and released a lock in the mean time. So the first client might think the file is unchanged, but it isn't. This isn't good. If, when recovery happens, the locks cannot be claimed because some other client still holds the lock, then we get a message in the kernel logs, but the client can still write. So two clients can both think they have a lock and can both write at the same time. This is equally not good. There was a patch a while ago http://comments.gmane.org/gmane.linux.nfs/41917 which tried to address some of this, but it didn't seem to go anywhere. That patch would also send a signal to the process. That might be useful but for now this patch just causes writes to fail. For NFSv4 (unlike v2/v3) there is a strong link between the lock and the write request so we can fairly easily fail any IO of the lock is gone. While some applications might not expect this, it is still safer than allowing the write to succeed. Because this is a fairly big change in behaviour a module parameter, "recover_locks", is introduced which defaults to true (the current behaviour) but can be set to "false" to tell the client not to try to recover things that were lost. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-06-08NFS:Add labels to client function prototypesDavid Quigley
After looking at all of the nfsv4 operations the label structure has been added to the prototypes of the functions which can transmit label data. Signed-off-by: Matthew N. Dodd <Matthew.Dodd@sparta.com> Signed-off-by: Miguel Rodel Felipe <Rodel_FM@dsi.a-star.edu.sg> Signed-off-by: Phua Eu Gene <PHUA_Eu_Gene@dsi.a-star.edu.sg> Signed-off-by: Khin Mi Mi Aung <Mi_Mi_AUNG@dsi.a-star.edu.sg> Signed-off-by: Steve Dickson <steved@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-02-22new helper: file_inode(file)Al Viro
2012-12-12SUNRPC handle EKEYEXPIRED in call_refreshresultAndy Adamson
Currently, when an RPCSEC_GSS context has expired or is non-existent and the users (Kerberos) credentials have also expired or are non-existent, the client receives the -EKEYEXPIRED error and tries to refresh the context forever. If an application is performing I/O, or other work against the share, the application hangs, and the user is not prompted to refresh/establish their credentials. This can result in a denial of service for other users. Users are expected to manage their Kerberos credential lifetimes to mitigate this issue. Move the -EKEYEXPIRED handling into the RPC layer. Try tk_cred_retry number of times to refresh the gss_context, and then return -EACCES to the application. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-07-30NFS: Only initialize the ACL client in the v3 caseBryan Schumaker
v2 and v4 don't use it, so I create two new nfs_rpc_ops functions to initialize the ACL client only when we are using v3. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-07-30NFS: Create a try_mount rpc opBryan Schumaker
I'm already looking up the nfs subversion in nfs_fs_mount(), so I have easy access to rpc_ops that used to be difficult to reach. This allows me to set up a different mount path for NFS v2/3 and NFS v4. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-07-17NFS: Split out NFS v2 inode operationsBryan Schumaker
This patch moves the NFS v2 file and directory inode functions into files that are only compiled whet CONFIG_NFS_V2 is enabled. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-07-16Merge commit '9249e17fe094d853d1ef7475dd559a2cc7e23d42' into nfs-for-3.6Trond Myklebust
Resolve conflicts with the VFS atomic open and sget changes. Conflicts: fs/nfs/nfs4proc.c
2012-07-14nfs: clean up ->create in nfs_rpc_opsMiklos Szeredi
Don't pass nfs_open_context() to ->create(). Only the NFS4 implementation needed that and only because it wanted to return an open file using open intents. That task has been replaced by ->atomic_open so it is not necessary anymore to pass the context to the create rpc operation. Despite nfs4_proc_create apparently being okay with a NULL context it Oopses somewhere down the call chain. So allocate a context here. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> CC: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-29NFS: Create an write_pageio_init() functionBryan Schumaker
pNFS needs to select a write function based on the layout driver currently in use, so I let each NFS version decide how to best handle initializing writes. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-06-29NFS: Create an read_pageio_init() functionBryan Schumaker
pNFS needs to select a read function based on the layout driver currently in use, so I let each NFS version decide how to best handle initializing reads. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-06-29NFS: Create an alloc_client rpc_opBryan Schumaker
This gives NFS v4 a way to set up callbacks and sessions without v2 or v3 having to do them as well. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-06-29NFS: Create a free_client rpc_opBryan Schumaker
NFS v4 needs a way to shut down callbacks and sessions, but v2 and v3 don't. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-06-29NFS: Create a return_delegation rpc opBryan Schumaker
Delegations are a v4 feature, so push return_delegation out of the generic client by creating a new rpc_op and renaming the old function to be in the nfs v4 "namespace" Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-06-29NFS: Create a have_delegation rpc_opBryan Schumaker
Delegations are a v4 feature, so push them out of the generic code. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-06-11NFSv2: EOF incorrectly set on short readSachin Prabhu
In cases where the server returns fewer bytes then those requested, we can incorrectly set the eof flag for the file. Fixing this allows the request to be retried with updated offset and count arguments. Signed-off-by: Sachin Prabhu <sprabhu@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-05-29Merge tag 'nfs-for-3.5-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client updates from Trond Myklebust: "New features include: - Rewrite the O_DIRECT code so that it can share the same coalescing and pNFS functionality as the page cache code. - Allow the server to provide hints as to when we should use pNFS, and when it is more efficient to read and write through the metadata server. - NFS cache consistency updates: * Use the ctime to emulate a change attribute for NFSv2/v3 so that all NFS versions can share the same cache management code. * New cache management code will only look at the change attribute and size attribute when deciding whether or not our cached data is still valid or not. * Don't request NFSv4 post-op attributes on writes in cases such as O_DIRECT, where we don't care about data cache consistency, or when we have a write delegation, and know that our cache is still consistent. * Don't request NFSv4 post-op attributes on operations such as COMMIT, where there are no expected metadata updates. * Don't request NFSv4 directory post-op attributes in cases where the operations themselves already return change attribute updates: i.e. operations such as OPEN, CREATE, REMOVE, LINK and RENAME. - Speed up 'ls' and friends by using READDIR rather than READDIRPLUS if we detect no attempts to lookup filenames. - Improve the code sharing between NFSv2/v3 and v4 mounts - NFSv4.1 state management efficiency improvements - More patches in preparation for NFSv4/v4.1 migration functionality." Fix trivial conflict in fs/nfs/nfs4proc.c that was due to the dcache qstr name initialization changes (that made the length/hash a 64-bit union) * tag 'nfs-for-3.5-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (146 commits) NFSv4: Add debugging printks to state manager NFSv4: Map NFS4ERR_SHARE_DENIED into an EACCES error instead of EIO NFSv4: update_changeattr does not need to set NFS_INO_REVAL_PAGECACHE NFSv4.1: nfs4_reset_session should use nfs4_handle_reclaim_lease_error NFSv4.1: Handle other occurrences of NFS4ERR_CONN_NOT_BOUND_TO_SESSION NFSv4.1: Handle NFS4ERR_CONN_NOT_BOUND_TO_SESSION in the state manager NFSv4.1: Handle errors in nfs4_bind_conn_to_session NFSv4.1: nfs4_bind_conn_to_session should drain the session NFSv4.1: Don't clobber the seqid if exchange_id returns a confirmed clientid NFSv4.1: Add DESTROY_CLIENTID NFSv4.1: Ensure we use the correct credentials for bind_conn_to_session NFSv4.1: Ensure we use the correct credentials for session create/destroy NFSv4.1: Move NFSPROC4_CLNT_BIND_CONN_TO_SESSION to the end of the operations NFSv4.1: Handle NFS4ERR_SEQ_MISORDERED when confirming the lease NFSv4: When purging the lease, we must clear NFS4CLNT_LEASE_CONFIRM NFSv4: Clean up the error handling for nfs4_reclaim_lease NFSv4.1: Exchange ID must use GFP_NOFS allocation mode nfs41: Use BIND_CONN_TO_SESSION for CB_PATH_DOWN* nfs4.1: add BIND_CONN_TO_SESSION operation NFSv4.1 test the mdsthreshold hint parameters ...
2012-05-10vfs: make it possible to access the dentry hash/len as one 64-bit entryLinus Torvalds
This allows comparing hash and len in one operation on 64-bit architectures. Right now only __d_lookup_rcu() takes advantage of this, since that is the case we care most about. The use of anonymous struct/unions hides the alternate 64-bit approach from most users, the exception being a few cases where we initialize a 'struct qstr' with a static initializer. This makes the problematic cases use a new QSTR_INIT() helper function for that (but initializing just the name pointer with a "{ .name = xyzzy }" initializer remains valid, as does just copying another qstr structure). Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-27NFS: Remove extra rpc_clnt argument to proc_lookupBryan Schumaker
Now that I'm doing secinfo automatically in the v4 code this extra argument isn't needed. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-04-27NFS: Create a submount rpc_opBryan Schumaker
This simplifies the code for v2 and v3 and gives v4 a chance to decide on referrals without needing to modify the generic client. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-04-27NFS: create common nfs_pgio_header for both read and writeFred Isaman
In order to avoid duplicating all the data in nfs_read_data whenever we split it up into multiple RPC calls (either due to a short read result or due to rsize < PAGE_SIZE), we split out the bits that are the same per RPC call into a separate "header" structure. The goal this patch moves towards is to have a single header refcounted by several rpc_data structures. Thus, want to always refer from rpc_data to the header, and not the other way. This patch comes close to that ideal, but the directio code currently needs some special casing, isolated in the nfs_direct_[read_write]hdr_release() functions. This will be dealt with in a future patch. Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-04-27NFS: add a struct nfs_commit_data to replace nfs_write_data in commitsFred Isaman
Commits don't need the vectors of pages, etc. that writes do. Split out a separate structure for the commit operation. Signed-off-by: Fred Isaman <iisaman@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-03-21NFS: Remove nfs4_setup_sequence from generic rename codeBryan Schumaker
This is an NFS v4 specific operation, so it belongs in the NFS v4 code and not the generic client. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2012-03-21NFS: Remove nfs4_setup_sequence from generic unlink codeBryan Schumaker
2012-03-21NFS: Remove nfs4_setup_sequence from generic read codeBryan Schumaker
2012-03-21NFS: Remove nfs4_setup_sequence from generic write codeBryan Schumaker
2011-12-06Freezer / sunrpc / NFS: don't allow TASK_KILLABLE sleeps to block the freezerJeff Layton
Allow the freezer to skip wait_on_bit_killable sleeps in the sunrpc layer. This should allow suspend and hibernate events to proceed, even when there are RPC's pending on the wire. Also, wrap the TASK_KILLABLE sleeps in NFS layer in freezer_do_not_count and freezer_count calls. This allows the freezer to skip tasks that are sleeping while looping on EJUKEBOX or NFS4ERR_DELAY sorts of errors. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-11-04nfs: when attempting to open a directory, fall back on normal lookup (try #5)Jeff Layton
commit d953126 changed how nfs_atomic_lookup handles an -EISDIR return from an OPEN call. Prior to that patch, that caused the client to fall back to doing a normal lookup. When that patch went in, the code began returning that error to userspace. The d_revalidate codepath however never had the corresponding change, so it was still possible to end up with a NULL ctx->state pointer after that. That patch caused a regression. When we attempt to open a directory that does not have a cached dentry, that open now errors out with EISDIR. If you attempt the same open with a cached dentry, it will succeed. Fix this by reverting the change in nfs_atomic_lookup and allowing attempts to open directories to fall back to a normal lookup Also, add a NFSv4-specific f_ops->open routine that just returns -ENOTDIR. This should never be called if things are working properly, but if it ever is, then the dprintk may help in debugging. To facilitate this, a new file_operations field is also added to the nfs_rpc_ops struct. Cc: stable@kernel.org Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-24NFS: lookup supports alternate clientBryan Schumaker
A later patch will need to perform a lookup using an alternate client with a different security flavor. This patch adds support for doing that on NFS v4. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-03-11NFS move nfs_client initialization into nfs_get_clientAndy Adamson
Now nfs_get_client returns an nfs_client ready to be used no matter if it was found or created. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-04NFS: Don't leak in nfs_proc_symlink()Jesper Juhl
Hi, In fs/nfs/proc.c::nfs_proc_symlink() we will leak memory if either nfs_alloc_fhandle() or nfs_alloc_fattr() returns NULL but the other one doesn't. This patch ensures memory allocated by one when the other fails is always released (this is safe since nfs_free_fattr() and nfs_free_fhandle() both call kfree which deals gracefully with NULL pointers). Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16NFS: Introduce new-style XDR decoding functions for NFSv2Chuck Lever
We'd like to prevent local buffer overflows caused by malicious or broken servers. New xdr_stream style decoders can do that. For efficiency, we also eventually want to be able to pass xdr_streams from call_decode() to all XDR decoding functions, rather than building an xdr_stream in every XDR decoding function in the kernel. nfs_decode_dirent() is renamed to follow the naming convention of the other two dirent decoders. Static helper functions are left without the "inline" directive. This allows the compiler to choose automatically how to optimize these for size or speed. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-10-23NFS: readdir with vmapped pagesBryan Schumaker
We can use vmapped pages to read more information from the network at once. This will reduce the number of calls needed to complete a readdir. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> [trondmy: Added #include for linux/vmalloc.h> in fs/nfs/dir.c] Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-09-17nfs: make sillyrename an async operationJeff Layton
A synchronous rename can be interrupted by a SIGKILL. If that happens during a sillyrename operation, it's possible for the rename call to be sent to the server, but the task exits before processing the reply. If this happens, the sillyrenamed file won't get cleaned up during nfs_dentry_iput and the server is left with a dangling .nfs* file hanging around. Fix this problem by turning sillyrename into an asynchronous operation and have the task doing the sillyrename just wait on the reply. If the task is killed before the sillyrename completes, it'll still proceed to completion. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-09-17nfs: standardize the rename args containerJeff Layton
Each NFS version has its own version of the rename args container. Standardize them on a common one that's identical to the one NFSv4 uses. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-09-17NFS: Clean up nfs4_proc_create()Trond Myklebust
Remove all remaining references to the struct nameidata from the low level NFS layers. Again pass down a partially initialised struct nfs_open_context when we want to do atomic open+create. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-05-14NFS: Reduce the stack footprint of nfs_proc_symlink()Trond Myklebust
2010-05-14NFS: Reduce the stack footprint of nfs_proc_createTrond Myklebust
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-10nfs: handle NFSv2 -EKEYEXPIRED returns from RPC layer appropriatelyJeff Layton
Add a wrapper around rpc_call_sync that handles -EKEYEXPIRED errors from the RPC layer as it would an -EJUKEBOX error if NFSv2 had such a thing. Also, add a handler for that error for async calls that makes it resubmit the RPC on -EKEYEXPIRED. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-09-23headers: utsname.h reduxAlexey Dobriyan
* remove asm/atomic.h inclusion from linux/utsname.h -- not needed after kref conversion * remove linux/utsname.h inclusion from files which do not need it NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however due to some personality stuff it _is_ needed -- cowardly leave ELF-related headers and files alone. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-19NFS: Optimise NFS close()Trond Myklebust
Close-to-open cache consistency rules really only require us to flush out writes on calls to close(), and require us to revalidate attributes on the very last close of the file. Currently we appear to be doing a lot of extra attribute revalidation and cache flushes. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-10-07nfs: authenticated deep mountingEG Keizer
Allow mount to do authenticated mounts below the root of the exported tree. The wording in RFC 2623, sec 2.3.2. allows fsinfo with UNIX authentication on the root of the export. Mounts are not always done on the root of the exported tree. Especially autoumounts often mount below the root of the exported tree. Some server implementations (justly) require full authentication for the so-called deep mounts. The old code used AUTH_SYS only. This caused deep mounts to fail on systems requiring stronger authentication.. The client should try both authentication types and use the first one that succeeds. This method was already partially implemented. This patch completes the implementation for NFS2 and NFS3. This patch was developed to allow Debian systems to automount home directories on Solaris servers with krb5 authentication. Tested on kernel 2.6.24-etchnhalf.1 Signed-off-by: E.G. Keizer <keie@few.vu.nl> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-07-09NFS: Remove the redundant file_open entry from struct nfs_rpc_opsTrond Myklebust
All instances are set to nfs_open(), so we should just remove the redundant indirection. Ditto for the file_release op Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
