commit 9b7eecdcfeb943f130d86bbc249fde4994b6fe30 upstream.
For pnfs pagelist read failure, we need to pg_recoalesce and resend IO to
mds.
Signed-off-by: Peng Tao <peng_tao@emc.com>
Signed-off-by: Jim Rees <rees@umich.edu>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
vfs/nfs: fixup for nfs_open_context change
just dentry, please...
Use nfs_pageio_reset_read_mds and nfs_pageio_reset_write_mds instead of
completely reinitialising the struct nfs_pageio_descriptor.
...and ensure that we recoalese to take into account differences in
block sizes when falling back to read through the MDS.
Instead of looking up the rsize and wsize, the routines that generate the
RPC requests should really be using the pg_bsize, since that is what we
use when deciding whether or not to coalesce write requests...
...and do the same for nfs_flush_multi/one.
Split them up into two parts: one which sets up the struct nfs_read/write_data,
the other which sets up the actual RPC call or pNFS call.
Ask for whole file layouts. Until support for layout segments is fully
supported in the file layout code, discard non-whole file layouts.
Signed-off-by: Andy Adamson <andros@netapp.com>
Signed-off-by: Fred Isaman <iisaman@netapp.com>
Ensure that we always get a layout before setting up the i/o request.
We need to ensure that the layouts are set up before we can decide to
coalesce requests. To do so, we want to further split up the struct
nfs_pageio_descriptor operations into an initialisation callback, a
coalescing test callback, and a 'do i/o' callback.
This patch cleans up the existing callback methods before adding the
'initialisation' callback.
Use common code for pnfs_pageio_init_{read,write} and use
a common generic pg_test function.
Note that this function always assumes the the layout driver's
pg_test method is implemented.
[Fix BUG]
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
Signed-off-by: Benny Halevy <bhalevy@panasas.com>
Add offset and count parameters to pnfs_update_layout and use them to get
the layout in the pageio path.
Order cache layout segments in the following order:
* offset (ascending)
* length (descending)
* iomode (RW before READ)
Test byte range against the layout segment in use in pnfs_{read,write}_pg_test
so not to coalesce pages not using the same layout segment.
[fix lseg ordering]
[clean up pnfs_find_lseg lseg arg]
[remove unnecessary FIXME]
[fix ordering in pnfs_insert_layout]
[clean up pnfs_insert_layout]
Currently, writebacks may end up recursing back into the filesystem due to
GFP_KERNEL direct reclaims in the pnfs subsystem.
Now that we have access to the pointer, clear it immediately after
the put, instead of in caller.
This will make it possible to clear the lseg pointer in the same
function as it is put, instead of in the caller nfs_pageio_doio().
Use our own async error handler.
Mark the layout as failed and retry i/o through the MDS on specified errors.
Update the mds_offset in nfs_readpage_retry so that a failed short-read retry
to a DS gets correctly resent through the MDS.
Attempt a pNFS file layout read by setting up the nfs_read_data struct and
calling nfs_initiate_read with the data server rpc client and the
filelayout rpc call ops.
Error handling is implemented in a subsequent patch.
Signed-off-by: Andy Adamson <andros@citi.umich.edu>
Signed-off-by: Dean Hildebrand <dhildeb@us.ibm.com>
Signed-off-by: Fred Isaman <iisaman@citi.umich.edu>
Signed-off-by: Mingyang Guo <guomingyang@nrchpc.ac.cn>
Signed-off-by: Oleg Drokin <green@linuxhacker.ru>
Signed-off-by: Ricardo Labiaga <Ricardo.Labiaga@netapp.com>
Tested-by: Guo Mingyang <guomingyang@nrchpc.ac.cn>
Separate the rpc run portion of nfs_read_rpcsetup into a new function
nfs_initiate_read that is called for normal NFS I/O.
Add a pNFS read_pagelist function that is called instead of nfs_intitate_read
for pNFS reads.
Signed-off-by: Mike Sager <sager@netapp.com>
Signed-off-by: Tao Guo <guotao@nrchpc.ac.cn>
Move the pnfs_update_layout call location to nfs_pageio_do_add_request().
Grab the lseg sent in the doio function to nfs_read_rpcsetup and attach
it to each nfs_read_data so it can be sent to the layout driver.
Add a pg_test layout driver hook which is used to avoid coelescing I/O across
layout stripes.
When a nfs_page is freed, nfs_free_request is called which also calls
nfs_clear_request to clean out the lock and open contexts and free the
pagecache page.
However, a couple of places in the nfs code call nfs_clear_request
themselves. What happens here if the refcount on the request is still high?
We'll be releasing contexts and freeing pointers while the request is
possibly still in use.
Remove those bare calls to nfs_clear_context. That should only be done when
the request is being freed.
Note that when doing this, we need to watch out for tests of req->wb_page.
Previously, nfs_set_page_tag_locked() and nfs_clear_page_tag_locked()
would check the value of req->wb_page to figure out if the page is mapped
into the nfsi->nfs_page_tree. We now indicate the page is mapped using
the new bit PG_MAPPED in req->wb_flags .
Reported-by: Jeff Layton <jlayton@redhat.com>
At the start of the io paths, try to grab the relevant layout
information. This will initiate the inode's layout cache, but
stubs ensure the cache stays empty.
Signed-off-by: Dean Hildebrand <dhildebz@umich.edu>
Signed-off-by: Marc Eshel <eshel@almaden.ibm.com>
Signed-off-by: Ricardo Labiaga <ricardo.labiaga@netapp.com>
Having to explicitly initialize sr_slotid to NFS4_MAX_SLOT_TABLE
resulted in numerous bugs. Keeping the current slot as a pointer
to the slot table is more straight forward and robust as it's
implicitly set up to NULL wherever the seq_res member is initialized
to zeroes.
This patch fixes bugzilla entry 14501:
https://bugzilla.kernel.org/show_bug.cgi?id=14501
In anticipation of the day when we have per-filesystem sessions, and also
in order to allow the session to change in the event of a filesystem
migration event.
There is no danger of deadlock should the allocation trigger page
writeback.
Also rename it: it is used in generic code, and so should not have a 'nfs4'
prefix.
We no longer need to maintain a distinction between nfs41_sequence_done and
nfs41_sequence_free_slot.
This fixes a number of slot table leakages in the NFSv4.1 code.
nfs41_sequence_free_slot can be called multiple times on SEQUENCE operation
errors.
No reason to inline nfs4_restart_rpc
Reported-by: Trond Myklebust <trond.myklebust@netapp.com>
nfs_writeback_done and nfs_readpage_retry call nfs4_restart_rpc outside the
error handler, and the slot is not freed prior to restarting in the rpc_prepare
state during session reset.
Fix this by moving the call to nfs41_sequence_free_slot from the error
path of nfs41_sequence_done into nfs4_restart_rpc, and by removing the test
for NFS4CLNT_SESSION_SETUP.
Always free slot and goto the rpc prepare state on async errors.
We can't call nfs_readdata_release()/nfs_writedata_release() without
first initialising and referencing args.context. Doing so inside
nfs_direct_read_schedule_segment()/nfs_direct_write_schedule_segment()
causes an Oops.
We should rather be calling nfs_readdata_free()/nfs_writedata_free() in
those cases.
Looking at the O_DIRECT code, the "struct nfs_direct_req" is already
referencing the nfs_open_context for us. Since the readdata and writedata
structures carry a reference to that, we can simplify things by getting rid
of the extra nfs_open_context references, so that we can replace all
instances of nfs_readdata_release()/nfs_writedata_release().
Reported-by: Catalin Marinas <catalin.marinas@arm.com>
Tested-by: Catalin Marinas <catalin.marinas@arm.com>
Cc: stable@kernel.org
* Remove smp_lock.h from files which don't need it (including some headers!)
* Add smp_lock.h to files which do need it
* Make smp_lock.h include conditional in hardirq.h
It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT
This will make hardirq.h inclusion cheaper for every PREEMPT=n config
(which includes allmodconfig/allyesconfig, BTW)
[nfs41: change nfs4_restart_rpc argument]
[nfs41: check for session not minorversion]
[nfs41: trigger the state manager for session reset]
[always define nfs4_restart_rpc]
Implement the read rpc_call_prepare method for
asynchronuos nfs rpcs, call nfs41_setup_sequence from
respective rpc_call_validate_args methods.
Call nfs4_sequence_done from respective rpc_call_done methods.
Note that we need to pass a pointer to the nfs_server in calls data
for passing on to nfs4_sequence_done.
[pnfs: client data server write validate and release]
Signed-off-by: Andy Adamson <andros@umich.edu>
[move the nfs4_sequence_free_slot call in nfs_readpage_retry from]
[nfs41: separate free slot from sequence done]
[remove nfs_readargs.nfs_server, use calldata->inode instead]
[nfs41: Support sessions with O_DIRECT]
[nfs41: nfs4_sequence_free_slot use nfs_client for data server]
Initialize nfs4_sequence_res sr_slotid to NFS4_MAX_SLOT_TABLE.
[was nfs41: sequence res use slotid]
[pulled definition of struct nfs4_sequence_res.sr_slotid to here]
Store pages from an NFS inode into the cache data storage object associated
with that inode.
Acked-by: Steve Dickson <steved@redhat.com>
Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
Read pages from an FS-Cache data storage object representing an inode into an
NFS inode.
nfs_readpage_async() needs to be non-static so that it can be used as a
fallback for the local on-disk caching should an EIO crop up when reading the
cache.
aops->readpages() and its NFS helper readpage_async_filler() will only
be called to do readahead I/O for newly allocated pages. So it's not
necessary to test for the always 0 dirty/uptodate page flags.
The removal of nfs_wb_page() call also fixes a readahead bug: the NFS
readahead has been synchronous since 2.6.23, because that call will
clear PG_readahead, which is the reminder for asynchronous readahead.
More background: the PG_readahead page flag is shared with PG_reclaim,
one for read path and the other for write path. clear_page_dirty_for_io()
unconditionally clears PG_readahead to prevent possible readahead residuals,
assuming itself to be always called in the write path. However, NFS is one
and the only exception in that it _always_ calls clear_page_dirty_for_io()
in the read path, i.e. for readpages()/readpage().
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Signed-off-by: Wu Fengguang <wfg@linux.intel.com>
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Cc: "J. Bruce Fields" <bfields@fieldses.org>
In the case of readpage() we need to ensure that the pages get unlocked,
and that the error is flagged.
In the case of O_DIRECT, we need to ensure that the pages are all released.
Ignoring the return value from nfs_pageio_add_request can cause deadlocks.
In read path:
call nfs_pageio_add_request from readpage_async_filler
assume at this point that there are requests already in desc, that
can't be merged with the current request.
so nfs_pageio_doio is fired up to clear out desc.
assume something goes wrong in setting up the io, so desc->pg_error is set.
This causes nfs_pageio_add_request to return 0, *WITHOUT* adding the original
request.
BUT, since return code is ignored, readpage_async_filler assumes it has
been added, and does nothing further, leaving page locked.
do_generic_mapping_read will eventually call lock_page, resulting in deadlock
In write path:
page is marked dirty by generic_perform_write
nfs_writepages is called
call nfs_pageio_add_request from nfs_page_async_flush
This causes nfs_page_async_flush to return 0, *WITHOUT* adding the original
request, yet marking the request as locked (PG_BUSY) and in writeback,
clearing dirty marks.
The next time a write is done to the page, deadlock will result as
nfs_write_end calls nfs_update_request
Now that we've tightened up the locking rules for RPC queue wakeups, we can
remove the RCU-safe kfree calls...
