[ Upstream commit df3accb849607a86278a37c35e6b313635ccc48b ]
Allow the caller to pass error information when cleaning up a failed
I/O request so that we can conditionally take action to cancel the
request altogether if the error turned out to be fatal.
Signed-off-by: Trond Myklebust <trond.myklebust@hammerspace.com>
Tools like tcpdump and rpcdebug can be very useful. But there are
plenty of environments where they are difficult or impossible to
use. For example, we've had customers report I/O failures during
workloads so heavy that collecting network traffic or enabling
RPC debugging are themselves onerous.
The kernel's static tracepoints are lightweight (less likely to
introduce timing changes) and efficient (the trace data is compact).
They also work in scenarios where capturing network traffic is not
possible due to lack of hardware support (some InfiniBand HCAs) or
where data or network privacy is a concern.
Introduce tracepoints that show when an NFS READ, WRITE, or COMMIT
is initiated, and when it completes. Record the arguments and
results of each operation, which are not shown by existing sunrpc
module's tracepoints.
For instance, the recorded offset and count can be used to match an
"initiate" event to a "done" event. If an NFS READ result returns
fewer bytes than requested or zero, seeing the EOF flag can be
probative. Seeing an NFS4ERR_BAD_STATEID result is also indication
of a particular class of problems. The timing information attached
to each event record can often be useful as well.
Usage example:
[root@manet tmp]# trace-cmd record -e nfs:*initiate* -e nfs:*done
/sys/kernel/debug/tracing/events/nfs/*initiate*/filter
/sys/kernel/debug/tracing/events/nfs/*done/filter
Hit Ctrl^C to stop recording
^CKernel buffer statistics:
Note: "entries" are the entries left in the kernel ring buffer and are not
recorded in the trace data. They should all be zero.
CPU: 0
entries: 0
overrun: 0
commit overrun: 0
bytes: 3680
oldest event ts: 78.367422
now ts: 100.124419
dropped events: 0
read events: 74
... and so on.
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
Now that the mirror allocation has been moved, the parameter can go.
Also remove the redundant symbol export.
Let's try to have it in a cacheline in nfs4_proc_pgio_rpc_prepare().
Signed-off-by: Benjamin Coddington <bcodding@redhat.com>
After using the offset of the swap entry as the key of the swap cache,
the page_index() becomes exactly same as page_file_index(). So the
page_file_index() is removed and the callers are changed to use
page_index() instead.
Link: http://lkml.kernel.org/r/1473270649-27229-2-git-send-email-ying.huang@intel.com
Signed-off-by: "Huang, Ying" <ying.huang@intel.com>
Cc: Trond Myklebust <trond.myklebust@primarydata.com>
Cc: Anna Schumaker <anna.schumaker@netapp.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
Cc: Eric Dumazet <edumazet@google.com>
Since commit 0bcbf039f6b2, nfs_readpage_release() has been used to
unlock the page in the read code.
Fixes: 0bcbf039f6b2 ("nfs: handle request add failure properly")
Cc: stable@vger.kernel.org # v4.5+
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time
ago with promise that one day it will be possible to implement page
cache with bigger chunks than PAGE_SIZE.
This promise never materialized. And unlikely will.
We have many places where PAGE_CACHE_SIZE assumed to be equal to
PAGE_SIZE. And it's constant source of confusion on whether
PAGE_CACHE_* or PAGE_* constant should be used in a particular case,
especially on the border between fs and mm.
Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much
breakage to be doable.
Let's stop pretending that pages in page cache are special. They are
not.
The changes are pretty straight-forward:
- <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN};
- page_cache_get() -> get_page();
- page_cache_release() -> put_page();
This patch contains automated changes generated with coccinelle using
script below. For some reason, coccinelle doesn't patch header files.
I've called spatch for them manually.
The only adjustment after coccinelle is revert of changes to
PAGE_CAHCE_ALIGN definition: we are going to drop it later.
There are few places in the code where coccinelle didn't reach. I'll
fix them manually in a separate patch. Comments and documentation also
will be addressed with the separate patch.
virtual patch
expression E;
- E << (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
expression E;
- E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
- PAGE_CACHE_SHIFT
+ PAGE_SHIFT
- PAGE_CACHE_SIZE
+ PAGE_SIZE
- PAGE_CACHE_MASK
+ PAGE_MASK
expression E;
- PAGE_CACHE_ALIGN(E)
+ PAGE_ALIGN(E)
expression E;
- page_cache_get(E)
+ get_page(E)
expression E;
- page_cache_release(E)
+ put_page(E)
When we fail to queue a read page to IO descriptor,
we need to clean it up otherwise it is hanging around
preventing nfs module from being removed.
When we fail to queue a write page to IO descriptor,
we need to clean it up and also save the failure status
to open context. Then at file close, we can try to write
pages back again and drop the page if it fails to writeback
in .launder_page, which will be done in the next patch.
Signed-off-by: Peng Tao <tao.peng@primarydata.com>
For ERESTARTSYS/EIO/EROFS/ENOSPC/E2BIG in layoutget, we
should just bail out instead of hiding the error and
retrying inband IO.
Change all the call sites to pop the error all the way up.
If non rpc-based layout driver return bad length of data, nfs retries
by calling rpc_restart_call_prepare() that cause an NULL reference panic.
This patch lets nfs retry through MDS for non rpc-based layout driver
return bad length of data.
[13034.883329] BUG: unable to handle kernel NULL pointer dereference at (null)
[13034.884902] IP: [<ffffffffa00db372>] rpc_restart_call_prepare+0x62/0x90 [sunrpc]
[13034.886558] PGD 0
[13034.888126] Oops: 0000 [#1] KASAN
[13034.889710] Modules linked in: blocklayoutdriver(OE) nfsv4(OE) nfs(OE) fscache(E) nfsd(OE) xfs libcrc32c coretemp btrfs crct10dif_pclmul crc32_pclmul crc32c_intel ghash_clmulni_intel ppdev vmw_balloon auth_rpcgss shpchp nfs_acl lockd vmw_vmci parport_pc xor raid6_pq grace parport sunrpc i2c_piix4 vmwgfx drm_kms_helper ttm drm mptspi e1000 serio_raw scsi_transport_spi mptscsih mptbase ata_generic pata_acpi [last unloaded: fscache]
[13034.898260] CPU: 0 PID: 10112 Comm: kworker/0:1 Tainted: G OE 4.3.0-rc5+ #279
[13034.899932] Hardware name: VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform, BIOS 6.00 07/02/2015
[13034.903342] Workqueue: events bl_read_cleanup [blocklayoutdriver]
[13034.905059] task: ffff88006a9148c0 ti: ffff880035e90000 task.ti: ffff880035e90000
[13034.906827] RIP: 0010:[<ffffffffa00db372>] [<ffffffffa00db372>] rpc_restart_call_prepare+0x62/0x90 [sunrpc]
[13034.910522] RSP: 0018:ffff880035e97b58 EFLAGS: 00010282
[13034.912378] RAX: fffffbfff04a5a94 RBX: ffff880068fe4858 RCX: 0000000000000003
[13034.914339] RDX: dffffc0000000000 RSI: 0000000000000003 RDI: 0000000000000282
[13034.916236] RBP: ffff880035e97b68 R08: 0000000000000001 R09: 0000000000000001
[13034.918229] R10: 0000000000000000 R11: 0000000000000001 R12: 0000000000000000
[13034.920007] R13: ffff880068fe4858 R14: ffff880068fe4a60 R15: 0000000000001000
[13034.921845] FS: 0000000000000000(0000) GS:ffffffff82247000(0000) knlGS:0000000000000000
[13034.923645] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[13034.925525] CR2: 0000000000000000 CR3: 00000000063dd000 CR4: 00000000001406f0
[13034.932808] Stack:
[13034.934813] ffff880068fe4780 0000000000001000 ffff880035e97ba8 ffffffffa08800d2
[13034.936675] ffffffffa088029d ffff880068fe4780 ffff880068fe4858 ffffffffa089c0a0
[13034.938593] ffff880068fe47e0 ffff88005d59faf0 ffff880035e97be0 ffffffffa087e08f
[13034.940454] Call Trace:
[13034.942388] [<ffffffffa08800d2>] nfs_readpage_result+0x112/0x200 [nfs]
[13034.944317] [<ffffffffa088029d>] ? nfs_readpage_done+0xdd/0x160 [nfs]
[13034.946267] [<ffffffffa087e08f>] nfs_pgio_result+0x9f/0x120 [nfs]
[13034.948166] [<ffffffffa09266cc>] pnfs_ld_read_done+0x7c/0x1e0 [nfsv4]
[13034.950247] [<ffffffffa03b07ee>] bl_read_cleanup+0x2e/0x60 [blocklayoutdriver]
[13034.952156] [<ffffffff810ebf62>] process_one_work+0x412/0x870
[13034.954102] [<ffffffff810ebe84>] ? process_one_work+0x334/0x870
[13034.955949] [<ffffffff810ebb50>] ? queue_delayed_work_on+0x40/0x40
[13034.957985] [<ffffffff810ec441>] worker_thread+0x81/0x6a0
[13034.959817] [<ffffffff810ec3c0>] ? process_one_work+0x870/0x870
[13034.961785] [<ffffffff810f43bd>] kthread+0x17d/0x1a0
[13034.963544] [<ffffffff810f4240>] ? kthread_create_on_node+0x330/0x330
[13034.965479] [<ffffffff81100428>] ? finish_task_switch+0x88/0x220
[13034.967223] [<ffffffff810f4240>] ? kthread_create_on_node+0x330/0x330
[13034.968929] [<ffffffff81b6ae5f>] ret_from_fork+0x3f/0x70
[13034.970534] [<ffffffff810f4240>] ? kthread_create_on_node+0x330/0x330
[13034.972176] Code: c7 43 50 40 84 0d a0 e8 3d fe 1c e1 48 8d 7b 58 c7 83 e4 00 00 00 00 00 00 00 e8 ca fe 1c e1 4c 8b 63 58 4c 89 e7 e8 be fe 1c e1 <49> 83 3c 24 00 74 12 48 c7 43 50 f0 a2 0e a0 b8 01 00 00 00 5b
[13034.977148] RIP [<ffffffffa00db372>] rpc_restart_call_prepare+0x62/0x90 [sunrpc]
[13034.978780] RSP <ffff880035e97b58>
[13034.980399] CR2: 0000000000000000
Signed-off-by: Kinglong Mee <kinglongmee@gmail.com>
There is a reference leak of layout segment after resetting
pageio read/write to mds.
Cc: stable@vger.kernel.org # v4.0+
Pull NFS client updates from Trond Myklebust:
"Another set of mainly bugfixes and a couple of cleanups. No new
functionality in this round.
Highlights include:
Stable patches:
- Fix a regression in /proc/self/mountstats
- Fix the pNFS flexfiles O_DIRECT support
- Fix high load average due to callback thread sleeping
Bugfixes:
- Various patches to fix the pNFS layoutcommit support
- Do not cache pNFS deviceids unless server notifications are enabled
- Fix a SUNRPC transport reconnection regression
- make debugfs file creation failure non-fatal in SUNRPC
- Another fix for circular directory warnings on NFSv4 "junctioned"
mountpoints
- Fix locking around NFSv4.2 fallocate() support
- Truncating NFSv4 file opens should also sync O_DIRECT writes
- Prevent infinite loop in rpcrdma_ep_create()
Features:
- Various improvements to the RDMA transport code's handling of
memory registration
- Various code cleanups"
* tag 'nfs-for-4.1-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (55 commits)
fs/nfs: fix new compiler warning about boolean in switch
nfs: Remove unneeded casts in nfs
NFS: Don't attempt to decode missing directory entries
Revert "nfs: replace nfs_add_stats with nfs_inc_stats when add one"
NFS: Rename idmap.c to nfs4idmap.c
NFS: Move nfs_idmap.h into fs/nfs/
NFS: Remove CONFIG_NFS_V4 checks from nfs_idmap.h
NFS: Add a stub for GETDEVICELIST
nfs: remove WARN_ON_ONCE from nfs_direct_good_bytes
nfs: fix DIO good bytes calculation
nfs: Fetch MOUNTED_ON_FILEID when updating an inode
sunrpc: make debugfs file creation failure non-fatal
nfs: fix high load average due to callback thread sleeping
NFS: Reduce time spent holding the i_mutex during fallocate()
NFS: Don't zap caches on fallocate()
xprtrdma: Make rpcrdma_{un}map_one() into inline functions
xprtrdma: Handle non-SEND completions via a callout
xprtrdma: Add "open" memreg op
xprtrdma: Add "destroy MRs" memreg op
xprtrdma: Add "reset MRs" memreg op
This reverts commit 5a254d08b086d80cbead2ebcee6d2a4b3a15587a.
Since commit 5a254d08b086 ("nfs: replace nfs_add_stats with
nfs_inc_stats when add one"), nfs_readpage and nfs_do_writepage use
nfs_inc_stats to increment NFSIOS_READPAGES and NFSIOS_WRITEPAGES
instead of nfs_add_stats.
However nfs_inc_stats does not do the same thing as nfs_add_stats with
value 1 because these functions work on distinct stats:
nfs_inc_stats increments stats from "enum nfs_stat_eventcounters" (in
server->io_stats->events) and nfs_add_stats those from "enum
nfs_stat_bytecounters" (in server->io_stats->bytes).
Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org>
Fixes: 5a254d08b086 ("nfs: replace nfs_add_stats with nfs_inc_stats...")
Cc: stable@vger.kernel.org # 3.19+
that's the bulk of filesystem drivers dealing with inodes of their own
Don't use d_inode as a variable name as it now masks a function name.
This patch adds mirrored write support to the pgio layer. The default
is to use one mirror, but pgio callers may define callbacks to change
this to any value up to the (arbitrarily selected) limit of 16.
The basic idea is to break out members of nfs_pageio_descriptor that cannot
be shared between mirrored DSes and put them in a new structure.
Signed-off-by: Weston Andros Adamson <dros@primarydata.com>
Signed-off-by: Tom Haynes <loghyr@primarydata.com>
Signed-off-by: Li RongQing <roy.qing.li@gmail.com>
This was introduced by a merge error with my recent pgio patchset.
struct nfs_pgio_data only exists as a member of nfs_pgio_header, but is
passed around everywhere, because there used to be multiple _data structs
per _header. Many of these functions then use the _data to find a pointer
to the _header. This patch cleans this up by merging the nfs_pgio_data
structure into nfs_pgio_header and passing nfs_pgio_header around instead.
nfs_rw_header was used to allocate an nfs_pgio_header along with an
nfs_pgio_data, because a _header would need at least one _data.
Now there is only ever one nfs_pgio_data for each nfs_pgio_header -- move
it to nfs_pgio_header and get rid of nfs_rw_header.
nfs_read_completion relied on the fact that there was a 1:1 mapping
of page to nfs_request, but this has now changed.
Regions not covered by a request have already been zeroed elsewhere.
Operations that modify state for a whole page must be syncronized across
all requests within a page group. In the read path, this is calling
unlock_page and SetPageUptodate. Both of these functions should not be
called until all requests in a page group have reached the point where
they would call them.
This patch should have no effect yet since all page groups currently
have one request, but will come into play when pg_test functions are
modified to split pages into sub-page regions.
Add "page groups" - a circular list of nfs requests (struct nfs_page)
that all reference the same page. This gives nfs read and write paths
the ability to account for sub-page regions independently. This
somewhat follows the design of struct buffer_head's sub-page
accounting.
Only "head" requests are ever added/removed from the inode list in
the buffered write path. "head" and "sub" requests are treated the
same through the read path and the rest of the write/commit path.
Requests are given an extra reference across the life of the list.
Page groups are never rejoined after being split. If the read/write
request fails and the client falls back to another path (ie revert
to MDS in PNFS case), the already split requests are pushed through
the recoalescing code again, which may split them further and then
coalesce them into properly sized requests on the wire. Fragmentation
shouldn't be a problem with the current design, because we flush all
requests in page group when a non-contiguous request is added, so
the only time resplitting should occur is on a resend of a read or
write.
This patch lays the groundwork for sub-page splitting, but does not
actually do any splitting. For now all page groups have one request
as pg_test functions don't yet split pages. There are several related
patches that are needed support multiple requests per page group.
@inode is passed but not used.
At this point the read and write structures look identical, so combine
them into something shared by both.
What we have here is two functions that look identical. Let's share
some more code!
Once again, these two functions look identical in the read and write
case. Time to combine them together!
Most of this code is the same for both the read and write paths, so
combine everything and use the rw_ops when necessary.
These functions are almost identical on both the read and write side.
FLUSH_COND_STABLE will never be set for the read path, so leaving it in
the generic code won't hurt anything.
At this point, the read and write versions of this function look
identical so both should use the same function.
Write adds a little bit of code dealing with flush flags, but since
"how" will always be 0 when reading we can share the code.
The read and write paths set up this struct in exactly the same way, so
create a single shared struct.
Combining these functions will let me make a single nfs_rw_common_ops
struct (see the next patch).
The read and write paths do exactly the same thing for the rpc_prepare
rpc_op. This patch combines them together into a single function.
I create a new struct nfs_rw_ops to decide the differences between reads
and writes. This struct will be set when initializing a new
nfs_pgio_descriptor, and then passed on to the nfs_rw_header when a new
header is allocated.
These functions are identical for the read and write paths so they can
be combined.
The only difference is the write verifier field, but we can keep that
for a little bit longer.
At this point, the only difference between nfs_read_data and
nfs_write_data is the write verifier.
Reads and writes have very similar results. This patch combines the two
structs together with comments to show where the differing fields are
used.
Reads and writes have very similar arguments. This patch combines them
together and documents the few fields used only by write.
The read_pageio_init method is just a very convoluted way to grab the
right nfs_pageio_ops vector. The vector to chose is not a choice of
protocol version, but just a pNFS vs MDS I/O choice that can simply be
done inside nfs_pageio_init_read based on the presence of a layout
driver, and a new force_mds flag to the special case of falling back
to MDS I/O on a pNFS-capable volume.
Tested-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
A fileid in NFS is a uint64. There are some occurrences where dprintk()
outputs a signed fileid. This leads to confusion and more difficult to
read debugging (negative fileids matching positive inode numbers).
Signed-off-by: Niels de Vos <ndevos@redhat.com>
CC: Santosh Pradhan <spradhan@redhat.com>
When an NFSv4 client loses contact with the server it can lose any
locks that it holds.
Currently when it reconnects to the server it simply tries to reclaim
those locks. This might succeed even though some other client has
held and released a lock in the mean time. So the first client might
think the file is unchanged, but it isn't. This isn't good.
If, when recovery happens, the locks cannot be claimed because some
other client still holds the lock, then we get a message in the kernel
logs, but the client can still write. So two clients can both think
they have a lock and can both write at the same time. This is equally
not good.
There was a patch a while ago
http://comments.gmane.org/gmane.linux.nfs/41917
which tried to address some of this, but it didn't seem to go
anywhere. That patch would also send a signal to the process. That
might be useful but for now this patch just causes writes to fail.
For NFSv4 (unlike v2/v3) there is a strong link between the lock and
the write request so we can fairly easily fail any IO of the lock is
gone. While some applications might not expect this, it is still
safer than allowing the write to succeed.
Because this is a fairly big change in behaviour a module parameter,
"recover_locks", is introduced which defaults to true (the current
behaviour) but can be set to "false" to tell the client not to try to
recover things that were lost.
Signed-off-by: NeilBrown <neilb@suse.de>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
If the state recovery failed, we want to ensure that the application
doesn't try to use the same file descriptor for more reads or writes.
This patch ensures that we free the rpc_task after the cleanup callbacks
are done in order to avoid a deadlock problem that can be triggered if
the callback needs to wait for another workqueue item to complete.
Cc: Weston Andros Adamson <dros@netapp.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Bruce Fields <bfields@fieldses.org>
Cc: stable@vger.kernel.org [>= 3.5]
Merge Andrew's second set of patches:
- MM
- a few random fixes
- a couple of RTC leftovers
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (120 commits)
rtc/rtc-88pm80x: remove unneed devm_kfree
rtc/rtc-88pm80x: assign ret only when rtc_register_driver fails
mm: hugetlbfs: close race during teardown of hugetlbfs shared page tables
tmpfs: distribute interleave better across nodes
mm: remove redundant initialization
mm: warn if pg_data_t isn't initialized with zero
mips: zero out pg_data_t when it's allocated
memcg: gix memory accounting scalability in shrink_page_list
mm/sparse: remove index_init_lock
mm/sparse: more checks on mem_section number
mm/sparse: optimize sparse_index_alloc
memcg: add mem_cgroup_from_css() helper
memcg: further prevent OOM with too many dirty pages
memcg: prevent OOM with too many dirty pages
mm: mmu_notifier: fix freed page still mapped in secondary MMU
mm: memcg: only check anon swapin page charges for swap cache
mm: memcg: only check swap cache pages for repeated charging
mm: memcg: split swapin charge function into private and public part
mm: memcg: remove needless !mm fixup to init_mm when charging
mm: memcg: remove unneeded shmem charge type
Replace all relevant occurences of page->index and page->mapping in the
NFS client with the new page_file_index() and page_file_mapping()
functions.
Cc: Eric B Munson <emunson@mgebm.net>
Cc: Eric Paris <eparis@redhat.com>
Cc: Mike Christie <michaelc@cs.wisc.edu>
Cc: Neil Brown <neilb@suse.de>
Cc: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: Xiaotian Feng <dfeng@redhat.com>
This patch exports symbols needed by the v4 module. In addition, I also
switch over to using IS_ENABLED() to check if CONFIG_NFS_V4 or
CONFIG_NFS_V4_MODULE are set.
The module (nfs4.ko) will be created in the same directory as nfs.ko and
will be automatically loaded the first time you try to mount over NFS v4.
Signed-off-by: Bryan Schumaker <bjschuma@netapp.com>
The module (nfs2.ko) will be created in the same directory as nfs.ko and
will be automatically loaded the first time you try to mount over NFS v2.
