path: root/fs/nfs_common
2011-03-22Remove pointless memset in nfsacl_encode()Jesper Juhl
Remove pointless memset() in nfsacl_encode(). Thanks to Trond Myklebust <Trond.Myklebust@netapp.com> for pointing out that it is not needed since posix_acl_init() will set everything regardless.. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-25NFS: Prevent memory allocation failure in nfsacl_encode()Chuck Lever
nfsacl_encode() allocates memory in certain cases. This of course is not guaranteed to work. Since commit 9f06c719 "SUNRPC: New xdr_streams XDR encoder API", the kernel's XDR encoders can't return a result indicating possibly a failure, so a memory allocation failure in nfsacl_encode() has become fatal (ie, the XDR code Oopses) in some cases. However, the allocated memory is a tiny fixed amount, on the order of 40-50 bytes. We can easily use a stack-allocated buffer for this, with only a wee bit of nose-holding. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-01-25NFS: nfsacl_{encode,decode} should return signed integerChuck Lever
Clean up. The nfsacl_encode() and nfsacl_decode() functions return negative errno values, and each call site verifies that the returned value is not negative. Change the synopsis of both of these functions to reflect this usage. Document the synopsis and return values. Reported-by: Trond Myklebust <trond.myklebust@netapp.com> Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2008-12-23SUNRPC: nfsacl_encode/nfsacl_decode should be exported as GPL-onlyTrond Myklebust
Again, this has never been intended as a public abi for out-of-tree modules. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-10-20[PATCH] nfs_common endianness annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-11[PATCH] nfsacl: Solaris VxFS compatibility fixAndreas Gruenbacher
Here is a compatibility fix between Linux and Solaris when used with VxFS filesystems: Solaris usually accepts acl entries in any order, but with VxFS it replies with NFSERR_INVAL when it sees a four-entry acl that is not in canonical form. It may also fail with other non-canonical acls -- I can't tell, because that case never triggers: We only send non-canonical acls when we fake up an ACL_MASK entry. Instead of adding fake ACL_MASK entries at the end, inserting them in the correct position makes Solaris+VxFS happy. The Linux client and server sides don't care about entry order. The three-entry-acl special case in which we need a fake ACL_MASK entry was handled in xdr_nfsace_encode. The patch moves this into nfsacl_encode. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-16[PATCH] NFS: Ensure ACL xdr code doesn't overflow.Trond Myklebust
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-22[PATCH] NFSD: Add server support for NFSv3 ACLs.Andreas Gruenbacher
This adds functions for encoding and decoding POSIX ACLs for the NFSACL protocol extension, and the GETACL and SETACL RPCs. The implementation is compatible with NFSACL in Solaris. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Olaf Kirch <okir@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
