commit 40cdc7a530c7a075557651a071354bb42b99df08 upstream.
Commit df52699e4fcef ("NFSv4.1: Don't cache deviceids that have no
notifications") causes the Linux NFS client to stop caching deviceid's
unless a server pretends to support deviceid notifications. While this
behavior is stupid and the language around this area in rfc5661 is a
mess carified by an errata that I submittted, Trond insists on this
behavior. Not caching deviceids degrades block layout performance
massively as a GETDEVICEINFO is fairly expensive.
So add this hack to make the Linux client happy again.
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
When testing pnfs with nfsd_debug on, nfsd print a negative number
of layout length and foff in nfsd4_block_proc_layoutget as,
"GET: -xxxx:-xxx 2"
Signed-off-by: Kinglong Mee <kinglongmee@gmail.com>
Add a small shim between core nfsd and filesystems to translate the
somewhat cumbersome pNFS data structures and semantics to something
more palatable for Linux filesystems.
Thanks to Rick McNeal for the old prototype pNFS blocklayout server
code, which gave a lot of inspiration to this version even if no
code is left from it.
