path: root/fs/nfsd/export.c
2011-07-15nfsd: Remove deprecated nfsctl system call and related code.NeilBrown
As promised in feature-removal-schedule.txt it is time to remove the nfsctl system call. Userspace has perferred to not use this call throughout 2.6 and it has been excluded in the default configuration since 2.6.36 (9 months ago). So this patch removes all the code that was being compiled out. There are still references to sys_nfsctl in various arch systemcall tables and related code. These should be cleaned out too, probably in the next merge window. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-04-29nfsd4: fix wrongsec handling for PUTFH + op casesJ. Bruce Fields
When PUTFH is followed by an operation that uses the filehandle, and when the current client is using a security flavor that is inconsistent with the given filehandle, we have a choice: we can return WRONGSEC either when the current filehandle is set using the PUTFH, or when the filehandle is first used by the following operation. Follow the recommendations of RFC 5661 in making this choice. (Our current behavior prevented the client from doing security negotiation by returning WRONGSEC on PUTFH+SECINFO_NO_NAME.) Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-03-07nfsd: kill unused macro definitionShan Wei
These macros had never been used for several years. So, remove them. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-01-13nfsd: don't support msnfs export optionJ. Bruce Fields
We've long had these pointless #ifdef MSNFS's sprinkled throughout the code--pointless because MSNFS is always defined (and we give no config option to make that easy to change). So we could just remove the ifdef's and compile the resulting code unconditionally. But as long as we're there: why not just rip out this code entirely? The only purpose is to implement the "msnfs" export option which turns on Windows-like behavior in some cases, and: - the export option isn't documented anywhere; - the userland utilities (which would need to be able to parse "msnfs" in an export file) don't support it; - I don't know how to maintain this, as I don't know what the proper behavior is; and - google shows no evidence that anyone has ever used this. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-09-27sunrpc: Add net to pure API callsPavel Emelyanov
There are two calls that operate on ip_map_cache and are directly called from the nfsd code. Other places will be handled in a different way. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-09-26nfsd: fix /proc/net/rpc/nfsd.export/content displayJ. Bruce Fields
Note with "first" always 0, and "lastflags" initially 0, we always dump a spurious set of 0 flags at the start, among other problems. Fix. And attempt to make the code a little more obvious. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-09-22nfsd: allow deprecated interface to be compiled out.NeilBrown
Add CONFIG_NFSD_DEPRECATED, default to y. Only include deprecated interface if this is defined. This allows distros to remove this interface before the official removal, and allows developers to test without it. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-09-07sunrpc: extract some common sunrpc_cache code from nfsdNeilBrown
Rather can duplicating this idiom twice, put it in an inline function. This reduces the usage of 'expiry_time' out side the sunrpc/cache.c code and thus the impact of a change that is about to be made to that field. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-05-04Merge commit 'v2.6.34-rc6'J. Bruce Fields
Conflicts: fs/nfsd/nfs4callback.c
2010-04-22nfsd: potential ERR_PTR dereference on exp_export() error paths.Dan Carpenter
We "goto finish" from several places where "exp" is an ERR_PTR. Also I changed the check for "fsid_key" so that it was consistent with the check I added. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-16nfsd: factor out hash functions for export caches.NeilBrown
Both the _lookup and the _update functions for these two caches independently calculate the hash of the key. So factor out that code for improved reuse. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2010-02-08Revert "nfsd4: fix error return when pseudoroot missing"J. Bruce Fields
Commit f39bde24b275ddc45d fixed the error return from PUTROOTFH in the case where there is no pseudofilesystem. This is really a case we shouldn't hit on a correctly configured server: in the absence of a root filehandle, there's no point accepting version 4 NFS rpc calls at all. But the shared responsibility between kernel and userspace here means the kernel on its own can't eliminate the possiblity of this happening. And we have indeed gotten this wrong in distro's, so new client-side mount code that attempts to negotiate v4 by default first has to work around this case. Therefore when commit f39bde24b275ddc45d arrived at roughly the same time as the new v4-default mount code, which explicitly checked only for the previous error, the result was previously fine mounts suddenly failing. We'll fix both sides for now: revert the error change, and make the client-side mount workaround more robust. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-12-15nfsd: remove pointless paths in file headersJ. Bruce Fields
The new .h files have paths at the top that are now out of date. While we're here, just remove all of those from fs/nfsd; they never served any purpose. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-12-15nfsd: move most of nfsfh.h to fs/nfsdJ. Bruce Fields
Most of this can be trivially moved to a private header as well. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-12-15nfsd: make V4ROOT exports read-onlyJ. Bruce Fields
I can't see any use for writeable V4ROOT exports. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-12-15nfsd: allow exports of symlinksJ. Bruce Fields
We want to allow exports of symlinks, to allow mountd to communicate to the kernel which symlinks lead to exports, and hence which symlinks need to be visible on the pseudofilesystem. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-12-15nfsd: introduce export flag for v4 pseudorootSteve Dickson
NFSv4 differs from v2 and v3 in that it presents a single unified filesystem tree, whereas v2 and v3 exported multiple filesystem (whose roots could be found using a separate mount protocol). Our original NFSv4 server implementation asked the administrator to designate a single filesystem as the NFSv4 root, then to mount filesystems they wished to export underneath. (Often using bind mounts of already-existing filesystems.) This was conceptually simple, and allowed easy implementation, but created a serious obstacle to upgrading between v2/v3: since the paths to v4 filesystems were different, administrators would have to adjust all the paths in client-side mount commands when switching to v4. Various workarounds are possible. For example, the administrator could export "/" and designate it as the v4 root. However, the security risks of that approach are obvious, and in any case we shouldn't be requiring the administrator to take extra steps to fix this problem; instead, the server should present consistent paths across different versions by default. These patches take a modified version of that approach: we provide a new export option which exports only a subset of a filesystem. With this flag, it becomes safe for mountd to export "/" by default, with no need for additional configuration. We begin just by defining the new flag. Signed-off-by: Steve Dickson <steved@redhat.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-12-14nfsd: Move private headers to source directoryBoaz Harrosh
Lots of include/linux/nfsd/* headers are only used by nfsd module. Move them to the source directory Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-12-14nfsd: Source files #include cleanupsBoaz Harrosh
Now that the headers are fixed and carry their own wait, all fs/nfsd/ source files can include a minimal set of headers. and still compile just fine. This patch should improve the compilation speed of the nfsd module. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-09-28nfsd4: fix error return when pseudoroot missingJ. Bruce Fields
We really shouldn't hit this case at all, and forthcoming kernel and nfs-utils changes should eliminate this case; if it does happen, consider it a bug rather than reporting an error that doesn't really make sense for the operation (since there's no reason for a server to be accepting v4 traffic yet have no root filehandle). Also move some exp_pseudoroot code into a helper function while we're here. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-09-23seq_file: constify seq_operationsJames Morris
Make all seq_operations structs const, to help mitigate against revectoring user-triggerable function pointers. This is derived from the grsecurity patch, although generated from scratch because it's simpler than extracting the changes from there. Signed-off-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-03NFSd: Fix filehandle leak in exp_pseudoroot() and nfsd4_path()Trond Myklebust
nfsd4_path() allocates a temporary filehandle and then fails to free it before the function exits, leaking reference counts to the dentry and export that it refers to. Also, nfsd4_lookupp() puts the result of exp_pseudoroot() in a temporary filehandle which it releases on success of exp_pseudoroot() but not on failure; fix exp_pseudoroot to ensure that on failure it releases the filehandle before returning. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-08-09SUNRPC: Allow the cache_detail to specify alternative upcall mechanismsTrond Myklebust
For events that are rare, such as referral DNS lookups, it makes limited sense to have a daemon constantly listening for upcalls on a channel. An alternative in those cases might simply be to run the app that fills the cache using call_usermodehelper_exec() and friends. The following patch allows the cache_detail to specify alternative upcall mechanisms for these particular cases. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-06-22Merge branch 'for-2.6.31' of git://fieldses.org/git/linux-nfsdLinus Torvalds
* 'for-2.6.31' of git://fieldses.org/git/linux-nfsd: (60 commits) SUNRPC: Fix the TCP server's send buffer accounting nfsd41: Backchannel: minorversion support for the back channel nfsd41: Backchannel: cleanup nfs4.0 callback encode routines nfsd41: Remove ip address collision detection case nfsd: optimise the starting of zero threads when none are running. nfsd: don't take nfsd_mutex twice when setting number of threads. nfsd41: sanity check client drc maxreqs nfsd41: move channel attributes from nfsd4_session to a nfsd4_channel_attr struct NFS: kill off complicated macro 'PROC' sunrpc: potential memory leak in function rdma_read_xdr nfsd: minor nfsd_vfs_write cleanup nfsd: Pull write-gathering code out of nfsd_vfs_write nfsd: track last inode only in use_wgather case sunrpc: align cache_clean work's timer nfsd: Use write gathering only with NFSv2 NFSv4: kill off complicated macro 'PROC' NFSv4: do exact check about attribute specified knfsd: remove unreported filehandle stats counters knfsd: fix reply cache memory corruption knfsd: reply cache cleanups ...
2009-06-11switch rqst_exp_parent()Al Viro
2009-06-11switch rqst_exp_get_by_name()Al Viro
2009-06-11switch exp_parent() to struct pathAl Viro
... and lose the always-NULL last argument (non-NULL case had been split off a while ago). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11nfsd struct path use: exp_get_by_name()Al Viro
2009-04-23rpcgss: remove redundant test on unsignedRoel Kluin
Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-10-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (46 commits) [PATCH] fs: add a sanity check in d_free [PATCH] i_version: remount support [patch] vfs: make security_inode_setattr() calling consistent [patch 1/3] FS_MBCACHE: don't needlessly make it built-in [PATCH] move executable checking into ->permission() [PATCH] fs/dcache.c: update comment of d_validate() [RFC PATCH] touch_mnt_namespace when the mount flags change [PATCH] reiserfs: add missing llseek method [PATCH] fix ->llseek for more directories [PATCH vfs-2.6 6/6] vfs: add LOOKUP_RENAME_TARGET intent [PATCH vfs-2.6 5/6] vfs: remove LOOKUP_PARENT from non LOOKUP_PARENT lookup [PATCH vfs-2.6 4/6] vfs: remove unnecessary fsnotify_d_instantiate() [PATCH vfs-2.6 3/6] vfs: add __d_instantiate() helper [PATCH vfs-2.6 2/6] vfs: add d_ancestor() [PATCH vfs-2.6 1/6] vfs: replace parent == dentry->d_parent by IS_ROOT() [PATCH] get rid of on-stack dentry in udf [PATCH 2/2] anondev: switch to IDA [PATCH 1/2] anondev: init IDR statically [JFFS2] Use d_splice_alias() not d_add() in jffs2_lookup() [PATCH] Optimise NFS readdir hack slightly. ...
2008-10-23[PATCH] switch nfsd to kern_path()Al Viro
2008-10-23[PATCH] sanitize svc_export_parse()Al Viro
clean up the exit paths, get rid of nameidata Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-22nfsd: clean up expkey_parse error casesJ. Bruce Fields
We might as well do all of these at the end. Fix up a couple minor style nits while we're there. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-10-22nfsd: Drop reference in expkey_parse error casesKrishna Kumar
Drop reference to export key on error. Compile tested. Signed-off-by: Krishna Kumar <krkumar2@in.ibm.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-07-30fs/nfsd/export.c: Adjust error handling code involving auth_domain_putJulia Lawall
Once clp is assigned, it never becomes NULL, so we can make a label for it in the error handling code. Because the call to path_lookup follows the call to auth_domain_find, its error handling code should jump to this new label. The semantic match that finds this problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @r@ expression x,E; statement S; position p1,p2,p3; @@ ( if ((x = auth_domain_find@p1(...)) == NULL || ...) S | x = auth_domain_find@p1(...) ... when != x if (x == NULL || ...) S ) <... if@p3 (...) { ... when != auth_domain_put(x) when != if (x) { ... auth_domain_put(x); ...} return@p2 ...; } ...> ( return x; | return 0; | x = E | E = x | auth_domain_put(x) ) @exists@ position r.p1,r.p2,r.p3; expression x; int ret != 0; statement S; @@ * x = auth_domain_find@p1(...) <... * if@p3 (...) S ...> * return@p2 \(NULL\|ret\); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-04-23IPv6 support for NFS server export cachesAurélien Charbon
This adds IPv6 support to the interfaces that are used to express nfsd exports. All addressed are stored internally as IPv6; backwards compatibility is maintained using mapped addresses. Thanks to Bruce Fields, Brian Haley, Neil Brown and Hideaki Joshifuji for comments Signed-off-by: Aurelien Charbon <aurelien.charbon@bull.net> Cc: Neil Brown <neilb@suse.de> Cc: Brian Haley <brian.haley@hp.com> Cc: YOSHIFUJI Hideaki / 吉藤英明 <yoshfuji@linux-ipv6.org> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-14d_path: Make d_path() use a struct pathJan Blunck
d_path() is used on a <dentry,vfsmount> pair. Lets use a struct path to reflect this. [akpm@linux-foundation.org: fix build in mm/memory.c] Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Bryan Wu <bryan.wu@analog.com> Acked-by: Christoph Hellwig <hch@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14d_path: Make seq_path() use a struct path argumentJan Blunck
seq_path() is always called with a dentry and a vfsmount from a struct path. Make seq_path() take it directly as an argument. Signed-off-by: Jan Blunck <jblunck@suse.de> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Use struct path in struct svc_expkeyJan Blunck
I'm embedding struct path into struct svc_expkey. Signed-off-by: Jan Blunck <jblunck@suse.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Acked-by: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Use struct path in struct svc_exportJan Blunck
I'm embedding struct path into struct svc_export. [akpm@linux-foundation.org: coding-style fixes] [ezk@cs.sunysb.edu: NFSD: fix wrong mnt_writer count in rename] Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: J. Bruce Fields <bfields@citi.umich.edu> Acked-by: Christoph Hellwig <hch@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Erez Zadok <ezk@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Introduce path_put()Jan Blunck
* Add path_put() functions for releasing a reference to the dentry and vfsmount of a struct path in the right order * Switch from path_release(nd) to path_put(&nd->path) * Rename dput_path() to path_put_conditional() [akpm@linux-foundation.org: fix cifs] Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Cc: <linux-fsdevel@vger.kernel.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Embed a struct path into struct nameidata instead of nd->{dentry,mnt}Jan Blunck
This is the central patch of a cleanup series. In most cases there is no good reason why someone would want to use a dentry for itself. This series reflects that fact and embeds a struct path into nameidata. Together with the other patches of this series - it enforced the correct order of getting/releasing the reference count on <dentry,vfsmount> pairs - it prepares the VFS for stacking support since it is essential to have a struct path in every place where the stack can be traversed - it reduces the overall code size: without patch series: text data bss dec hex filename 5321639 858418 715768 6895825 6938d1 vmlinux with patch series: text data bss dec hex filename 5320026 858418 715768 6894212 693284 vmlinux This patch: Switch from nd->{dentry,mnt} to nd->path.{dentry,mnt} everywhere. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix cifs] [akpm@linux-foundation.org: fix smack] Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Convert ERR_PTR(PTR_ERR(p)) instances to ERR_CAST(p)David Howells
Convert instances of ERR_PTR(PTR_ERR(p)) to ERR_CAST(p) using: perl -spi -e 's/ERR_PTR[(]PTR_ERR[(](.*)[)][)]/ERR_CAST(\1)/' `grep -rl 'ERR_PTR[(]*PTR_ERR' fs crypto net security` Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01knfsd: don't bother mapping putrootfh enoent to epermJ. Bruce Fields
Neither EPERM and ENOENT map to valid errors for PUTROOTFH according to rfc 3530, and, if anything, ENOENT is likely to be slightly more informative; so don't bother mapping ENOENT to EPERM. (Probably this was originally done because one likely cause was that there is an fsid=0 export but that it isn't permitted to this particular client. Now that we allow WRONGSEC returns, this is somewhat less likely.) In the long term we should work to make this situation less likely, perhaps by turning off nfsv4 service entirely in the absence of the pseudofs root, or constructing a pseudofilesystem root ourselves in the kernel as necessary. Thanks to Benny Halevy <bhalevy@panasas.com> for pointing out this problem. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Cc: Benny Halevy <bhalevy@panasas.com>
2008-02-01knfsd: allow cache_register to return error on failureJ. Bruce Fields
Newer server features such as nfsv4 and gss depend on proc to work, so a failure to initialize the proc files they need should be treated as fatal. Thanks to Andrew Morton for style fix and compile fix in case where CONFIG_NFSD_V4 is undefined. Cc: Andrew Morton <akpm@linux-foundation.org> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01knfsd: cache unregistration needn't return errorJ. Bruce Fields
There's really nothing much the caller can do if cache unregistration fails. And indeed, all any caller does in this case is print an error and continue. So just return void and move the printk's inside cache_unregister. Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2007-10-22exportfs: remove old methodsChristoph Hellwig
Now that all filesystems are converted remove support for the old methods. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: <linux-ext4@vger.kernel.org> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: David Chinner <dgc@sgi.com> Cc: Timothy Shimmin <tes@sgi.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fs/nfsd/export.c: make 3 functions staticAdrian Bunk
This patch makes the following needlessly global functions static: - exp_get_by_name() - exp_parent() - exp_find() Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31knfsd: eliminate unnecessary -ENOENT returns on export downcallsJ. Bruce Fields
A succesful downcall with a negative result (which indicates that the given filesystem is not exported to the given user) should not return an error. Currently mountd is depending on stdio to write these downcalls. With some versions of libc this appears to cause subsequent writes to attempt to write all accumulated data (for which writes previously failed) along with any new data. This can prevent the kernel from seeing responses to later downcalls. Symptoms will be that nfsd fails to respond to certain requests. Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
