path: root/fs/nfsd/nfs4acl.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-15nfsd: remove pointless paths in file headersJ. Bruce Fields
The new .h files have paths at the top that are now out of date. While we're here, just remove all of those from fs/nfsd; they never served any purpose. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-12-14nfsd: Source files #include cleanupsBoaz Harrosh
Now that the headers are fixed and carry their own wait, all fs/nfsd/ source files can include a minimal set of headers. and still compile just fine. This patch should improve the compilation speed of the nfsd module. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-10-27nfsd: Fix sort_pacl in fs/nfsd/nf4acl.c to actually sort groupsFrank Filz
We have been doing some extensive testing of Linux support for ACLs on NFDS v4. We have noticed that the server rejects ACLs where the groups are out of order, for example, the following ACL is rejected: A::OWNER@:rwaxtTcCy A::user101@domain:rwaxtcy A::GROUP@:rwaxtcy A:g:group102@domain:rwaxtcy A:g:group101@domain:rwaxtcy A::EVERYONE@:rwaxtcy Examining the server code, I found that after converting an NFS v4 ACL to POSIX, sort_pacl is called to sort the user ACEs and group ACEs. Unfortunately, a minor bug causes the group sort to be skipped. Signed-off-by: Frank Filz <ffilzlnx@us.ibm.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-08-27nfsd4: remove ACE4_IDENTIFIER_GROUP flag from GROUP@ entryFrank Filz
RFC 3530 says "ACE4_IDENTIFIER_GROUP flag MUST be ignored on entries with these special identifiers. When encoding entries with these special identifiers, the ACE4_IDENTIFIER_GROUP flag SHOULD be set to zero." It really shouldn't matter either way, but the point is that this flag is used to distinguish named users from named groups (since unix allows a group to have the same name as a user), so it doesn't really make sense to use it on a special identifier such as this.) Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-08-24nfsd: Fix unnecessary deny bits in NFSv4 ACLFrank Filz
The group deny entries end up denying tcy even though tcy was just allowed by the allow entry. This appears to be due to: ace->access_mask = mask_from_posix(deny, flags); instead of: ace->access_mask = deny_mask_from_posix(deny, flags); Denying a previously allowed bit has no effect, so this shouldn't affect behavior, but it's ugly. Signed-off-by: Frank Filz <ffilzlnx@us.ibm.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-09-01nfsd: fix buffer overrun decoding NFSv4 aclJ. Bruce Fields
The array we kmalloc() here is not large enough. Thanks to Johann Dahm and David Richter for bug report and testing. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Cc: David Richter <richterd@citi.umich.edu> Tested-by: Johann Dahm <jdahm@umich.edu>
2007-07-17knfsd: nfsd4: fix handling of acl errrorsJ. Bruce Fields
nfs4_acl_nfsv4_to_posix() returns an error and returns any posix acls calculated in two caller-provided pointers. It was setting these pointers to -errno in some error cases, resulting in nfsd4_set_nfs4_acl() calling posix_acl_release() with a -errno as an argument. Fix both the caller and the callee, by modifying nfsd4_set_nfs4_acl() to stop relying on the passed-in-pointers being left as NULL in the error case, and by modifying nfs4_acl_nfsv4_to_posix() to stop returning garbage in those pointers. Thanks to Alex Soule for reporting the bug. Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Cc: Alexander Soule <soule@umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17knfsd: nfsd4: silence a compiler warning in ACL codeJ. Bruce Fields
Silence a compiler warning in the ACL code, and add a comment making clear the initialization serves no other purpose. Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09remove nfs4_acl_add_ace()Adrian Bunk
nfs4_acl_add_ace() can now be removed. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Neil Brown <neilb@cse.unsw.edu.au> Acked-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-27[PATCH] knfsd: nfsd4: fix inheritance flags on v4 ace derived from posix ↵Bruce Fields
default ace A regression introduced in the last set of acl patches removed the INHERIT_ONLY flag from aces derived from the posix acl. Fix. Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] knfsd: nfsd4: fix handling of directories without default ACLsJ. Bruce Fields
When setting an ACL that lacks inheritable ACEs on a directory, we should set a default ACL of zero length, not a default ACL with all bits denied. Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] knfsd: nfsd4: acls: avoid unnecessary deniesJ. Bruce Fields
We're inserting deny's between some ACEs in order to enforce posix draft acl semantics which prevent permissions from accumulating across entries in an acl. That's fine, but we're doing that by inserting a deny after *every* allow, which is overkill. We shouldn't be adding them in places where they actually make no difference. Also replaced some helper functions for creating acl entries; I prefer just assigning directly to the struct fields--it takes a few more lines, but the field names provide some documentation that I think makes the result easier understand. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] knfsd: nfsd4: acls: don't return explicit maskJ. Bruce Fields
Return just the effective permissions, and forget about the mask. It isn't worth the complexity. WARNING: This breaks backwards compatibility with overly-picky nfsv4->posix acl translation, as may has been included in some patched versions of libacl. To our knowledge no such version was every distributed by anyone outside citi. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] knfsd: nfsd4: represent nfsv4 acl with array instead of linked listJ. Bruce Fields
Simplify the memory management and code a bit by representing acls with an array instead of a linked list. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] knfsd: nfsd4: simplify nfsv4->posix translationJ. Bruce Fields
The code that splits an incoming nfsv4 ACL into inheritable and effective parts can be combined with the the code that translates each to a posix acl, resulting in simpler code that requires one less pass through the ACL. Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] knfsd: nfsd4: relax checking of ACL inheritance bitsJ. Bruce Fields
The rfc allows us to be more permissive about the ACL inheritance bits we accept: "If the server supports a single "inherit ACE" flag that applies to both files and directories, the server may reject the request (i.e., requiring the client to set both the file and directory inheritance flags). The server may also accept the request and silently turn on the ACE4_DIRECTORY_INHERIT_ACE flag." Let's take the latter option--the ACL is a complex attribute that could be rejected for a wide variety of reasons, and the protocol gives us little ability to explain the reason for the rejection, so erroring out is a user-unfriendly last resort. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-04[PATCH] knfsd: nfsd4: acls: fix handling of zero-length aclsJ.Bruce Fields
It is legal to have zero-length NFSv4 acls; they just deny everything. Also, nfs4_acl_nfsv4_to_posix will always return with pacl and dpacl set on success, so the caller doesn't need to check this. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: nfsd4: acls: simplify nfs4_acl_nfsv4_to_posix interfaceJ.Bruce Fields
There's no need to handle the case where the caller passes in null for pacl or dpacl; no caller does that, because it would be a dumb thing to do. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: nfsd4: acls: fix inheritanceJ.Bruce Fields
We can be a little more flexible about the flags allowed for inheritance (in particular, we can deal with either the presence or the absence of INHERIT_ONLY), but we should probably reject other combinations that we don't understand. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: nfsd4: acls: relax the nfsv4->posix mappingJ.Bruce Fields
Use a different nfsv4->(draft posix) acl mapping which is 1. completely backwards compatible, 2. accepts any nfsv4 acl, and 3. errs on the side of restricting permissions. In detail: 1. completely backwards compatible: The new mapping produces the same result on any acl produced by the existing (draft posix)->nfsv4 mapping; the one exception is that we no longer attempt to guess the value of the mask by assuming certain denies represent the mask. Since the server still keeps track of the mask locally, sequences of chmod's will still be handled fine; the only thing this will change is sequences of chmod's with intervening read-modify-writes of the acl. That last case just isn't worth the trouble and the possible misrepresentations of the user's intent (if we guess that a certain deny indicates masking is in effect when it really isn't). 2. accepts any nfsv4 acl: That's not quite true: we still reject acls that use combinations of inheritance flags that we don't support. We also reject acls that attempt to explicitly deny read_acl or read_attributes permissions, or that attempt to deny write_acl or write_attributes permissions to the owner of the file. 3. errs on the side of restricting permissions: one exception to this last rule: we totally ignore some bits (write_owner, synchronize, read_named_attributes, etc.) that are completely alien to our filesystem semantics, in some cases even if that would mean ignoring an explicit deny that we have no intention of enforcing. Excepting that, the posix acl produced should be the most permissive acl that is not more permissive than the given nfsv4 acl. And the new code's shorter, too. Neato. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] knfsd: nfsd4: better nfs4acl errorsNeilBrown
We're returning -1 in a few places in the NFSv4<->POSIX acl translation code where we could return a reasonable error. Also allows some minor simplification elsewhere. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] knfsd: nfsd4: Wrong error handling in nfs4aclNeilBrown
this fixes coverity id #3. Coverity detected dead code, since the == -1 comparison only returns 0 or 1 to error. Therefore the if ( error < 0 ) statement was always false. Seems that this was an if( error = nfs4... ) statement some time ago, which got broken during cleanup. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] fs: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove a duplicate of ARRAY_SIZE. Some trailing whitespaces are also deleted. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Cc: David Howells <dhowells@redhat.com> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] knfsd: nfsd4: make needlessly global code staticNeilBrown
This patch contains the following possible cleanups: - make needlessly global code static Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
