path: root/fs/nfsd/nfs4state.c
2014-01-27nfsd: consider CLAIM_FH when handing out delegationMing Chen
CLAIM_FH was added by NFSv4.1. It is the same as CLAIM_NULL except that it uses only current FH to identify the file to be opened. The NFS client is using CLAIM_FH if the FH is available when opening a file. Currently, we cannot get any delegation if we stat a file before open it because the server delegation code does not recognize CLAIM_FH. We tested this patch and found delegation can be handed out now when claim is CLAIM_FH. See http://marc.info/?l=linux-nfs&m=136369847801388&w=2 and http://www.linux-nfs.org/wiki/index.php/Server_4.0_and_4.1_issues#New_open_claim_types Signed-off-by: Ming Chen <mchen@cs.stonybrook.edu> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2014-01-27nfsd4: minor nfs4_setlease cleanupJ. Bruce Fields
As far as I can tell, this list is used only under the state lock, so we may as well do this in the simpler order. Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2014-01-06NFSD: Fix a memory leak in nfsd4_create_sessionKinglong Mee
If failed after calling alloc_session but before init_session, nfsd will call __free_session to free se_slots in session. But, session->se_fchannel.maxreqs is not initialized (value is zero). So that, the memory malloced for slots will be lost in free_session_slots for maxreqs is zero. This path sets the information for channel in alloc_session after mallocing slots succeed, instead in init_session. Signed-off-by: Kinglong Mee <kinglongmee@gmail.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2014-01-03NFSD: fix bad length checking for backchannelKinglong Mee
the length for backchannel checking should be multiplied by sizeof(__be32). Signed-off-by: Kinglong Mee <kinglongmee@gmail.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2014-01-03NFSD: fix a leak which can cause CREATE_SESSION failuresKinglong Mee
check_forechannel_attrs gets drc memory, so nfsd must put it when check_backchannel_attrs fails. After many requests with bad back channel attrs, nfsd will deny any client's CREATE_SESSION forever. A new test case named CSESS29 for pynfs will send in another mail. Signed-off-by: Kinglong Mee <kinglongmee@gmail.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2014-01-03Add missing recording of back channel attrs in nfsd4_sessionKinglong Mee
commit 5b6feee9608dce7afd2646f457c93e612526d1d8 forgot recording the back channel attrs in nfsd4_session. nfsd just check the back channel attars by check_backchannel_attrs, but do not record it in nfsd4_session in the latest kernel. Signed-off-by: Kinglong Mee <kinglongmee@gmail.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-11-16Merge branch 'nfsd-next' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd changes from Bruce Fields: "This includes miscellaneous bugfixes and cleanup and a performance fix for write-heavy NFSv4 workloads. (The most significant nfsd-relevant change this time is actually in the delegation patches that went through Viro, fixing a long-standing bug that can cause NFSv4 clients to miss updates made by non-nfs users of the filesystem. Those enable some followup nfsd patches which I have queued locally, but those can wait till 3.14)" * 'nfsd-next' of git://linux-nfs.org/~bfields/linux: (24 commits) nfsd: export proper maximum file size to the client nfsd4: improve write performance with better sendspace reservations svcrpc: remove an unnecessary assignment sunrpc: comment typo fix Revert "nfsd: remove_stid can be incorporated into nfs4_put_delegation" nfsd4: fix discarded security labels on setattr NFSD: Add support for NFS v4.2 operation checking nfsd4: nfsd_shutdown_net needs state lock NFSD: Combine decode operations for v4 and v4.1 nfsd: -EINVAL on invalid anonuid/gid instead of silent failure nfsd: return better errors to exportfs nfsd: fh_update should error out in unexpected cases nfsd4: need to destroy revoked delegations in destroy_client nfsd: no need to unhash_stid before free nfsd: remove_stid can be incorporated into nfs4_put_delegation nfsd: nfs4_open_delegation needs to remove_stid rather than unhash_stid nfsd: nfs4_free_stid nfsd: fix Kconfig syntax sunrpc: trim off EC bytes in GSSAPI v2 unwrap gss_krb5: document that we ignore sequence number ...
2013-11-09locks: introduce new FL_DELEG lock flagJ. Bruce Fields
For now FL_DELEG is just a synonym for FL_LEASE. So this patch doesn't change behavior. Next we'll modify break_lease to treat FL_DELEG leases differently, to account for the fact that NFSv4 delegations should be broken in more situations than Windows oplocks. Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-11-04Revert "nfsd: remove_stid can be incorporated into nfs4_put_delegation"J. Bruce Fields
This reverts commit 7ebe40f20372688a627ad6c754bc0d1c05df58a9. We forgot the nfs4_put_delegation call in fs/nfsd/nfs4callback.c which should not be unhashing the stateid. This lead to warnings from the idr code when we tried to removed id's twice. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-10-30nfsd4: nfsd_shutdown_net needs state lockJ. Bruce Fields
A comment claims the caller should take it, but that's not being done. Note we don't want it around the cancel_delayed_work_sync since that may wait on work which holds the client lock. Reported-by: Benny Halevy <bhalevy@primarydata.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-10-29nfsd4: need to destroy revoked delegations in destroy_clientBenny Halevy
[use list_splice_init] Signed-off-by: Benny Halevy <bhalevy@primarydata.com> [bfields: no need for recall_lock here] Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-10-29nfsd: no need to unhash_stid before freeBenny Halevy
idr_remove is about to be called before kmem_cache_free so unhashing it is redundant Signed-off-by: Benny Halevy <bhalevy@primarydata.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-10-28nfsd: remove_stid can be incorporated into nfs4_put_delegationBenny Halevy
All calls to nfs4_put_delegation are preceded with remove_stid. Signed-off-by: Benny Halevy <bhalevy@primarydata.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-10-28nfsd: nfs4_open_delegation needs to remove_stid rather than unhash_stidBenny Halevy
In the out_free: path, the newly allocated stid must be removed rather than unhashed so it can never be found. Signed-off-by: Benny Halevy <bhalevy@primarydata.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-10-28nfsd: nfs4_free_stidBenny Halevy
Make it symmetric to nfs4_alloc_stid. Signed-off-by: Benny Halevy <bhalevy@primarydata.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-10-24nfsd: switch to %p[dD]Al Viro
2013-10-02nfsd: switch to %p[dD]Al Viro
2013-08-30nfsd4: fix leak of inode reference on delegation failureJ. Bruce Fields
This fixes a regression from 68a3396178e6688ad7367202cdf0af8ed03c8727 "nfsd4: shut down more of delegation earlier". After that commit, nfs4_set_delegation() failures result in nfs4_put_delegation being called, but nfs4_put_delegation doesn't free the nfs4_file that has already been set by alloc_init_deleg(). This can result in an oops on later unmounting the exported filesystem. Note also delaying the fi_had_conflict check we're able to return a better error (hence give 4.1 clients a better idea why the delegation failed; though note CONFLICT isn't an exact match here, as that's supposed to indicate a current conflict, but all we know here is that there was one recently). Reported-by: Toralf Förster <toralf.foerster@gmx.de> Tested-by: Toralf Förster <toralf.foerster@gmx.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-08-30Revert "nfsd: nfs4_file_get_access: need to be more careful with O_RDWR"J. Bruce Fields
This reverts commit df66e75395c839c3a373bae897dbb1248f741b45. nfsd4_lock can get a read-only or write-only reference when only a read-write open is available. This is normal. Cc: Harshula Jayasuriya <harshula@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-08-30Merge tag 'v3.11-rc5' into for-3.12 branchJ. Bruce Fields
For testing purposes I want some nfs and nfsd bugfixes (specifically, 58cd57bfd9db3bc213bf9d6a10920f82095f0114 and previous nfsd patches, and Trond's 4f3cc4809a98a165a9708b72b47de71643797bbd).
2013-08-07nfsd4: Fix MACH_CRED NULL dereferenceJ. Bruce Fields
Fixes a NULL-dereference on attempts to use MACH_CRED protection over auth_sys. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-07-26nfsd4: fix setlease error returnJ. Bruce Fields
This actually makes a difference in the 4.1 case, since we use the status to decide what reason to give the client for the delegation refusal (see nfsd4_open_deleg_none_ext), and in theory a client might choose suboptimal behavior if we give the wrong answer. Reported-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-07-23nfsd: nfs4_file_get_access: need to be more careful with O_RDWRHarshula Jayasuriya
If fi_fds = {non-NULL, NULL, non-NULL} and oflag = O_WRONLY the WARN_ON_ONCE(!(fp->fi_fds[oflag] || fp->fi_fds[O_RDWR])) doesn't trigger when it should. Signed-off-by: Harshula Jayasuriya <harshula@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-07-11Merge branch 'for-3.11' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd changes from Bruce Fields: "Changes this time include: - 4.1 enabled on the server by default: the last 4.1-specific issues I know of are fixed, so we're not going to find the rest of the bugs without more exposure. - Experimental support for NFSv4.2 MAC Labeling (to allow running selinux over NFS), from Dave Quigley. - Fixes for some delicate cache/upcall races that could cause rare server hangs; thanks to Neil Brown and Bodo Stroesser for extreme debugging persistence. - Fixes for some bugs found at the recent NFS bakeathon, mostly v4 and v4.1-specific, but also a generic bug handling fragmented rpc calls" * 'for-3.11' of git://linux-nfs.org/~bfields/linux: (31 commits) nfsd4: support minorversion 1 by default nfsd4: allow destroy_session over destroyed session svcrpc: fix failures to handle -1 uid's sunrpc: Don't schedule an upcall on a replaced cache entry. net/sunrpc: xpt_auth_cache should be ignored when expired. sunrpc/cache: ensure items removed from cache do not have pending upcalls. sunrpc/cache: use cache_fresh_unlocked consistently and correctly. sunrpc/cache: remove races with queuing an upcall. nfsd4: return delegation immediately if lease fails nfsd4: do not throw away 4.1 lock state on last unlock nfsd4: delegation-based open reclaims should bypass permissions svcrpc: don't error out on small tcp fragment svcrpc: fix handling of too-short rpc's nfsd4: minor read_buf cleanup nfsd4: fix decoding of compounds across page boundaries nfsd4: clean up nfs4_open_delegation NFSD: Don't give out read delegations on creates nfsd4: allow client to send no cb_sec flavors nfsd4: fail attempts to request gss on the backchannel nfsd4: implement minimal SP4_MACH_CRED ...
2013-07-08nfsd4: allow destroy_session over destroyed sessionJ. Bruce Fields
RFC 5661 allows a client to destroy a session using a compound associated with the destroyed session, as long as the DESTROY_SESSION op is the last op of the compound. We attempt to allow this, but testing against a Solaris client (which does destroy sessions in this way) showed that we were failing the DESTROY_SESSION with NFS4ERR_DELAY, because we assumed the reference count on the session (held by us) represented another rpc in progress over this session. Fix this by noting that in this case the expected reference count is 1, not 0. Also, note as long as the session holds a reference to the compound we're destroying, we can't free it here--instead, delay the free till the final put in nfs4svc_encode_compoundres. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-07-01nfsd4: return delegation immediately if lease failsJ. Bruce Fields
This case shouldn't happen--the administrator shouldn't really allow other applications access to the export until clients have had the chance to reclaim their state--but if it does then we should set the "return this lease immediately" bit on the reply. That still leaves some small races, but it's the best the protocol allows us to do in the case a lease is ripped out from under us.... Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-07-01nfsd4: do not throw away 4.1 lock state on last unlockJ. Bruce Fields
This reverts commit eb2099f31b0f090684a64ef8df44a30ff7c45fc2 "nfsd4: release lockowners on last unlock in 4.1 case". Trond identified language in rfc 5661 section 8.2.4 which forbids this behavior: Stateids associated with byte-range locks are an exception. They remain valid even if a LOCKU frees all remaining locks, so long as the open file with which they are associated remains open, unless the client frees the stateids via the FREE_STATEID operation. And bakeathon 2013 testing found a 4.1 freebsd client was getting an incorrect BAD_STATEID return from a FREE_STATEID in the above situation and then failing. The spec language honestly was probably a mistake but at this point with implementations already following it we're probably stuck with that. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-07-01nfsd4: clean up nfs4_open_delegationJ. Bruce Fields
The nfs4_open_delegation logic is unecessarily baroque. Also stop pretending we support write delegations in several places. Some day we will support write delegations, but when that happens adding back in these flag parameters will be the easy part. For now they're just confusing. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-07-01NFSD: Don't give out read delegations on createsSteve Dickson
When an exclusive create is done with the mode bits set (aka open(testfile, O_CREAT | O_EXCL, 0777)) this causes a OPEN op followed by a SETATTR op. When a read delegation is given in the OPEN, it causes the SETATTR to delay with EAGAIN until the delegation is recalled. This patch caused exclusive creates to give out a write delegation (which turn into no delegation) which allows the SETATTR seamlessly succeed. Signed-off-by: Steve Dickson <steved@redhat.com> [bfields: do this for any CREATE, not just exclusive; comment] Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-07-01nfsd4: fail attempts to request gss on the backchannelJ. Bruce Fields
We don't support gss on the backchannel. We should state that fact up front rather than just letting things continue and later making the client try to figure out why the backchannel isn't working. Trond suggested instead returning NFS4ERR_NOENT. I think it would be tricky for the client to distinguish between the case "I don't support gss on the backchannel" and "I can't find that in my cache, please create another context and try that instead", and I'd prefer something that currently doesn't have any other meaning for this operation, hence the (somewhat arbitrary) NFS4ERR_ENCR_ALG_UNSUPP. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-07-01nfsd4: implement minimal SP4_MACH_CREDJ. Bruce Fields
Do a minimal SP4_MACH_CRED implementation suggested by Trond, ignoring the client-provided spo_must_* arrays and just enforcing credential checks for the minimum required operations. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-07-01svcrpc: store gss mech in svc_credJ. Bruce Fields
Store a pointer to the gss mechanism used in the rq_cred and cl_cred. This will make it easier to enforce SP4_MACH_CRED, which needs to compare the mechanism used on the exchange_id with that used on protected operations. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-06-29locks: protect most of the file_lock handling with i_lockJeff Layton
Having a global lock that protects all of this code is a clear scalability problem. Instead of doing that, move most of the code to be protected by the i_lock instead. The exceptions are the global lists that the ->fl_link sits on, and the ->fl_block list. ->fl_link is what connects these structures to the global lists, so we must ensure that we hold those locks when iterating over or updating these lists. Furthermore, sound deadlock detection requires that we hold the blocked_list state steady while checking for loops. We also must ensure that the search and update to the list are atomic. For the checking and insertion side of the blocked_list, push the acquisition of the global lock into __posix_lock_file and ensure that checking and update of the blocked_list is done without dropping the lock in between. On the removal side, when waking up blocked lock waiters, take the global lock before walking the blocked list and dequeue the waiters from the global list prior to removal from the fl_block list. With this, deadlock detection should be race free while we minimize excessive file_lock_lock thrashing. Finally, in order to avoid a lock inversion problem when handling /proc/locks output we must ensure that manipulations of the fl_block list are also protected by the file_lock_lock. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-21nfsd: avoid undefined signed overflowJim Rees
In C, signed integer overflow results in undefined behavior, but unsigned overflow wraps around. So do the subtraction first, then cast to signed. Reported-by: Joakim Tjernlund <joakim.tjernlund@transmode.se> Signed-off-by: Jim Rees <rees@umich.edu> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-05-13nfsd4: store correct client minorversion for >=4.2J. Bruce Fields
This code assumes that any client using exchange_id is using NFSv4.1, but with the introduction of 4.2 that will no longer true. This main effect of this is that client callbacks will use the same minorversion as that used on the exchange_id. Note that clients are forbidden from mixing 4.1 and 4.2 compounds. (See rfc 5661, section 2.7, #13: "A client MUST NOT attempt to use a stateid, filehandle, or similar returned object from the COMPOUND procedure with minor version X for another COMPOUND procedure with minor version Y, where X != Y.") However, we do not currently attempt to enforce this except in the case of mixing zero minor version with non-zero minor versions. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-05-03Merge branch 'for-3.10' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd changes from J Bruce Fields: "Highlights include: - Some more DRC cleanup and performance work from Jeff Layton - A gss-proxy upcall from Simo Sorce: currently krb5 mounts to the server using credentials from Active Directory often fail due to limitations of the svcgssd upcall interface. This replacement lifts those limitations. The existing upcall is still supported for backwards compatibility. - More NFSv4.1 support: at this point, if a user with a current client who upgrades from 4.0 to 4.1 should see no regressions. In theory we do everything a 4.1 server is required to do. Patches for a couple minor exceptions are ready for 3.11, and with those and some more testing I'd like to turn 4.1 on by default in 3.11." Fix up semantic conflict as per Stephen Rothwell and linux-next: Commit 030d794bf498 ("SUNRPC: Use gssproxy upcall for server RPCGSS authentication") adds two new users of "PDE(inode)->data", but we're supposed to use "PDE_DATA(inode)" instead since commit d9dda78bad87 ("procfs: new helper - PDE_DATA(inode)"). The old PDE() macro is no longer available since commit c30480b92cf4 ("proc: Make the PROC_I() and PDE() macros internal to procfs") * 'for-3.10' of git://linux-nfs.org/~bfields/linux: (60 commits) NFSD: SECINFO doesn't handle unsupported pseudoflavors correctly NFSD: Simplify GSS flavor encoding in nfsd4_do_encode_secinfo() nfsd: make symbol nfsd_reply_cache_shrinker static svcauth_gss: fix error return code in rsc_parse() nfsd4: don't remap EISDIR errors in rename svcrpc: fix gss-proxy to respect user namespaces SUNRPC: gssp_procedures[] can be static SUNRPC: define {create,destroy}_use_gss_proxy_proc_entry in !PROC case nfsd4: better error return to indicate SSV non-support nfsd: fix EXDEV checking in rename SUNRPC: Use gssproxy upcall for server RPCGSS authentication. SUNRPC: Add RPC based upcall mechanism for RPCGSS auth SUNRPC: conditionally return endtime from import_sec_context SUNRPC: allow disabling idle timeout SUNRPC: attempt AF_LOCAL connect on setup nfsd: Decode and send 64bit time values nfsd4: put_client_renew_locked can be static nfsd4: remove unused macro nfsd4: remove some useless code nfsd4: implement SEQ4_STATUS_RECALLABLE_STATE_REVOKED ...
2013-04-29nfsd: convert nfs4_alloc_stid() to use idr_alloc_cyclic()Jeff Layton
Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: "J. Bruce Fields" <bfields@fieldses.org> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-26nfsd4: better error return to indicate SSV non-supportJ. Bruce Fields
As 4.1 becomes less experimental and SSV still isn't implemented, we have to admit it's not going to be, and return some sensible error rather than just saying "our server's broken". Discussion in the ietf group hasn't turned up any objections to using NFS4ERR_ENC_ALG_UNSUPP for that purpose. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-04-16nfsd4: put_client_renew_locked can be staticFengguang Wu
Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-04-16nfsd4: remove some useless codefanchaoting
The "list_empty(&oo->oo_owner.so_stateids)" is aways true, so remove it. Signed-off-by: fanchaoting <fanchaoting@cn.fujitsu.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-04-16nfsd4: implement SEQ4_STATUS_RECALLABLE_STATE_REVOKEDJ. Bruce Fields
A 4.1 server must notify a client that has had any state revoked using the SEQ4_STATUS_RECALLABLE_STATE_REVOKED flag. The client can figure out exactly which state is the problem using CHECK_STATEID and then free it using FREE_STATEID. The status flag will be unset once all such revoked stateids are freed. Our server's only recallable state is delegations. So we keep with each 4.1 client a list of delegations that have timed out and been recalled, but haven't yet been freed by FREE_STATEID. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-04-09nfsd4: clean up validate_stateidJ. Bruce Fields
The logic here is better expressed with a switch statement. While we're here, CLOSED stateids (or stateids of an unkown type--which would indicate a server bug) should probably return nfserr_bad_stateid, though this behavior shouldn't affect any non-buggy client. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-04-09nfsd4: check backchannel attributes on create_sessionJ. Bruce Fields
Make sure the client gives us an adequate backchannel. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-04-09nfsd4: fix forechannel attribute negotiationJ. Bruce Fields
Negotiation of the 4.1 session forechannel attributes is a mess. Fix: - Move it all into check_forechannel_attrs instead of spreading it between that, alloc_session, and init_forechannel_attrs. - set a minimum "slotsize" so that our drc memory limits apply even for small maxresponsesize_cached. This also fixes some bugs when slotsize becomes <= 0. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-04-09nfsd4: cleanup check_forechannel_attrsJ. Bruce Fields
Pass this struct by reference, not by value, and return an error instead of a boolean to allow for future additions. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-04-09nfsd4: don't close read-write opens too soonJ. Bruce Fields
Don't actually close any opens until we don't need them at all. This means being left with write access when it's not really necessary, but that's better than putting a file that might still have posix locks held on it, as we have been. Reported-by: Toralf Förster <toralf.foerster@gmx.de> Cc: stable@kernel.org Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-04-09nfsd4: release lockowners on last unlock in 4.1 caseJ. Bruce Fields
In the 4.1 case we're supposed to release lockowners as soon as they're no longer used. It would probably be more efficient to reference count them, but that's slightly fiddly due to the need to have callbacks from locks.c to take into account lock merging and splitting. For most cases just scanning the inode's lock list on unlock for matching locks will be sufficient. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-04-09nfsd4: no need for replay_owner in sessions caseJ. Bruce Fields
The replay_owner will never be used in the sessions case. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2013-04-09nfsd4: remove some redundant commentsJ. Bruce Fields
2013-04-09nfsd: use kmem_cache_free() instead of kfree()Wei Yongjun
memory allocated by kmem_cache_alloc() should be freed using kmem_cache_free(), not kfree(). Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: stable@kernel.org Signed-off-by: J. Bruce Fields <bfields@redhat.com>
