[ Upstream commit c20106944eb679fa3ab7e686fe5f6ba30fbc51e5 ]
If nfsd has existing listening sockets without any processes, then an error
returned from svc_create_xprt() for an additional transport will remove
those existing listeners. We're seeing this in practice when userspace
attempts to create rpcrdma transports without having the rpcrdma modules
present before creating nfsd kernel processes. Fix this by checking for
existing sockets before calling nfsd_destroy().
Signed-off-by: Benjamin Coddington <bcodding@redhat.com>
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
commit f2e717d655040d632c9015f19aa4275f8b16e7f2 upstream.
RFC3530 notes that the 'dircount' field may be zero, in which case the
recommendation is to ignore it, and only enforce the 'maxcount' field.
In RFC5661, this recommendation to ignore a zero valued field becomes a
requirement.
Fixes: aee377644146 ("nfsd4: fix rd_dircount enforcement")
Cc: <stable@vger.kernel.org>
Signed-off-by: Trond Myklebust <trond.myklebust@hammerspace.com>
commit 51b2ee7d006a736a9126e8111d1f24e4fd0afaa6 upstream.
If you export a subdirectory of a filesystem, a READDIRPLUS on the root
of that export will return the filehandle of the parent with the ".."
entry.
The filehandle is optional, so let's just not return the filehandle for
".." if we're at the root of an export.
Note that once the client learns one filehandle outside of the export,
they can trivially access the rest of the export using further lookups.
However, it is also not very difficult to guess filehandles outside of
the export. So exporting a subdirectory of a filesystem should
considered equivalent to providing access to the entire filesystem. To
avoid confusion, we recommend only exporting entire filesystems.
Reported-by: Youjipeng <wangzhibei1999@gmail.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
Cc: stable@vger.kernel.org
[ Upstream commit a4abc6b12eb1f7a533c2e7484cfa555454ff0977 ]
nfsd4_process_cb_update() invokes svc_xprt_get(), which increases the
refcount of the "c->cn_xprt".
The reference counting issue happens in one exception handling path of
nfsd4_process_cb_update(). When setup callback client failed, the
function forgets to decrease the refcnt increased by svc_xprt_get(),
causing a refcnt leak.
Fix this issue by calling svc_xprt_put() when setup callback client
failed.
Signed-off-by: Xiyu Yang <xiyuyang19@fudan.edu.cn>
Signed-off-by: Xin Tan <tanxin.ctf@gmail.com>
[ Upstream commit 255fbca65137e25b12bced18ec9a014dc77ecda0 ]
As the man(2) page for utime/utimes states, EPERM is returned when the
second parameter of utime or utimes is not NULL, the caller's effective UID
does not match the owner of the file, and the caller is not privileged.
However, in a NFS directory mounted from knfsd, it will return EACCES
(from nfsd_setattr-> fh_verify->nfsd_permission). This patch fixes
that.
Signed-off-by: zhengbin <zhengbin13@huawei.com>
[ Upstream commit b493fd31c0b89d9453917e977002de58bebc3802 ]
__cld_pipe_upcall() emits a "do not call blocking ops when
!TASK_RUNNING" warning due to the dput() call in rpc_queue_upcall().
Fix it by using a completion instead of hand coding the wait.
Signed-off-by: Scott Mayhew <smayhew@redhat.com>
[ Upstream commit 3b2d4dcf71c4a91b420f835e52ddea8192300a3b ]
Since commit 10a68cdf10 (nfsd: fix performance-limiting session
calculation) (Linux 5.1-rc1 and 4.19.31), shares from NFS servers with
1 TB of memory cannot be mounted anymore. The mount just hangs on the
client.
The gist of commit 10a68cdf10 is the change below.
-avail = clamp_t(int, avail, slotsize, avail/3);
+avail = clamp_t(int, avail, slotsize, total_avail/3);
Here are the macros.
#define min_t(type, x, y) __careful_cmp((type)(x), (type)(y), <)
#define clamp_t(type, val, lo, hi) min_t(type, max_t(type, val, lo), hi)
`total_avail` is 8,434,659,328 on the 1 TB machine. `clamp_t()` casts
the values to `int`, which for 32-bit integers can only hold values
−2,147,483,648 (−2^31) through 2,147,483,647 (2^31 − 1).
`avail` (in the function signature) is just 65536, so that no overflow
was happening. Before the commit the assignment would result in 21845,
and `num = 4`.
When using `total_avail`, it is causing the assignment to be
18446744072226137429 (printed as %lu), and `num` is then 4164608182.
My next guess is, that `nfsd_drc_mem_used` is then exceeded, and the
server thinks there is no memory available any more for this client.
Updating the arguments of `clamp_t()` and `min_t()` to `unsigned long`
fixes the issue.
Now, `avail = 65536` (before commit 10a68cdf10 `avail = 21845`), but
`num = 4` remains the same.
Fixes: c54f24e338ed (nfsd: fix performance-limiting session calculation)
Signed-off-by: Paul Menzel <pmenzel@molgen.mpg.de>
[ Upstream commit c54f24e338ed2a35218f117a4a1afb5f9e2b4e64 ]
We're unintentionally limiting the number of slots per nfsv4.1 session
to 10. Often more than 10 simultaneous RPCs are needed for the best
performance.
This calculation was meant to prevent any one client from using up more
than a third of the limit we set for total memory use across all clients
and sessions. Instead, it's limiting the client to a third of the
maximum for a single session.
Fix this.
Reported-by: Chris Tracy <ctracy@engr.scu.edu>
Fixes: de766e570413 "nfsd: give out fewer session slots as limit approaches"
[ Upstream commit de766e570413bd0484af0b580299b495ada625c3 ]
Instead of granting client's full requests until we hit our DRC size
limit and then failing CREATE_SESSIONs (and hence mounts) completely,
start granting clients smaller slot tables as we approach the limit.
The factor chosen here is pretty much arbitrary.
[ Upstream commit 44d8660d3bb0a1c8363ebcb906af2343ea8e15f6 ]
An NFSv4.1+ client negotiates the size of its duplicate reply cache size
in the initial CREATE_SESSION request. The server preallocates the
memory for the duplicate reply cache to ensure that we'll never fail to
record the response to a nonidempotent operation.
To prevent a few CREATE_SESSIONs from consuming all of memory we set an
upper limit based on nr_free_buffer_pages(). 1/2^10 has been too
limiting in practice; 1/2^7 is still less than one percent.
[ Upstream commit 0b8f62625dc309651d0efcb6a6247c933acd8b45 ]
A fuzzer recently triggered lockdep warnings about potential sb_writers
deadlocks caused by fh_want_write().
Looks like we aren't careful to pair each fh_want_write() with an
fh_drop_write().
It's not normally a problem since fh_put() will call fh_drop_write() for
us. And was OK for NFSv3 where we'd do one operation that might call
fh_want_write(), and then put the filehandle.
But an NFSv4 protocol fuzzer can do weird things like call unlink twice
in a compound, and then we get into trouble.
I'm a little worried about this approach of just leaving everything to
fh_put(). But I think there are probably a lot of
fh_want_write()/fh_drop_write() imbalances so for now I think we need it
to be more forgiving.
commit e6abc8caa6deb14be2a206253f7e1c5e37e9515b upstream.
If there are multiple callbacks queued, waiting for the callback
slot when the callback gets shut down, then they all currently
end up acting as if they hold the slot, and call
nfsd4_cb_sequence_done() resulting in interesting side-effects.
In addition, the 'retry_nowait' path in nfsd4_cb_sequence_done()
causes a loop back to nfsd4_cb_prepare() without first freeing the
slot, which causes a deadlock when nfsd41_cb_get_slot() gets called
a second time.
This patch therefore adds a boolean to track whether or not the
callback did pick up the slot, so that it can do the right thing
in these 2 cases.
commit dd838821f0a29781b185cd8fb8e48d5c177bd838 upstream.
Commit 62a063b8e7d1 "nfsd4: fix crash on writing v4_end_grace before
nfsd startup" is trying to fix a NULL dereference issue, but it
mistakenly checks if the nfsd server is started. So fix it.
Fixes: 62a063b8e7d1 "nfsd4: fix crash on writing v4_end_grace before nfsd startup"
Reviewed-by: Joseph Qi <joseph.qi@linux.alibaba.com>
Signed-off-by: Yihao Wu <wuyihao@linux.alibaba.com>
commit b602345da6cbb135ba68cf042df8ec9a73da7981 upstream.
If the result of an NFSv3 readdir{,plus} request results in the
"offset" on one entry having to be split across 2 pages, and is sized
so that the next directory entry doesn't fit in the requested size,
then memory corruption can happen.
When encode_entry() is called after encoding the last entry that fits,
it notices that ->offset and ->offset1 are set, and so stores the
offset value in the two pages as required. It clears ->offset1 but
*does not* clear ->offset.
Normally this omission doesn't matter as encode_entry_baggage() will
be called, and will set ->offset to a suitable value (not on a page
boundary).
But in the case where cd->buflen < elen and nfserr_toosmall is
returned, ->offset is not reset.
This means that nfsd3proc_readdirplus will see ->offset with a value 4
bytes before the end of a page, and ->offset1 set to NULL.
It will try to write 8bytes to ->offset.
If we are lucky, the next page will be read-only, and the system will
BUG: unable to handle kernel paging request at...
If we are unlucky, some innocent page will have the first 4 bytes
corrupted.
nfsd3proc_readdir() doesn't even check for ->offset1, it just blindly
writes 8 bytes to the offset wherever it is.
Fix this by clearing ->offset after it is used, and copying the
->offset handling code from nfsd3_proc_readdirplus into
nfsd3_proc_readdir.
(Note that the commit hash in the Fixes tag is from the 'history'
tree - this bug predates git).
Fixes: 0b1d57cf7654 ("[PATCH] kNFSd: Fix nfs3 dentry encoding")
Fixes-URL: https://git.kernel.org/pub/scm/linux/kernel/git/history/history.git/commit/?id=0b1d57cf7654
Cc: stable@vger.kernel.org (v2.6.12+)
Signed-off-by: NeilBrown <neilb@suse.com>
[ Upstream commit 62a063b8e7d1db684db3f207261a466fa3194e72 ]
Anatoly Trosinenko reports that this:
1) Checkout fresh master Linux branch (tested with commit e195ca6cb)
2) Copy x84_64-config-4.14 to .config, then enable NFS server v4 and build
3) From `kvm-xfstests shell`:
results in NULL dereference in locks_end_grace.
Check that nfsd has been started before trying to end the grace period.
Reported-by: Anatoly Trosinenko <anatoly.trosinenko@gmail.com>
[ Upstream commit 5b7b15aee641904ae269be9846610a3950cbd64c ]
We're encoding a single op in the reply but leaving the number of ops
zero, so the reply makes no sense.
Somewhat academic as this isn't a case any real client will hit, though
in theory perhaps that could change in a future protocol extension.
Reviewed-by: Jeff Layton <jlayton@kernel.org>
[ Upstream commit 3171822fdcdd6e6d536047c425af6dc7a92dc585 ]
When running a fuzz tester against a KASAN-enabled kernel, the following
splat periodically occurs.
The problem occurs when the test sends a GETDEVICEINFO request with a
malformed xdr array (size but no data) for gdia_notify_types and the
array size is > 0x3fffffff, which results in an overflow in the value of
nbytes which is passed to read_buf().
If the array size is 0x40000000, 0x80000000, or 0xc0000000, then after
the overflow occurs, the value of nbytes 0, and when that happens the
pointer returned by read_buf() points to the end of the xdr data (i.e.
argp->end) when really it should be returning NULL.
Fix this by returning NFS4ERR_BAD_XDR if the array size is > 1000 (this
value is arbitrary, but it's the same threshold used by
nfsd4_decode_bitmap()... in could really be any value >= 1 since it's
expected to get at most a single bitmap in gdia_notify_types).
[ 119.256854] ==================================================================
[ 119.257611] BUG: KASAN: use-after-free in nfsd4_decode_getdeviceinfo+0x5a4/0x5b0 [nfsd]
[ 119.258422] Read of size 4 at addr ffff880113ada000 by task nfsd/538
[ 119.259146] CPU: 0 PID: 538 Comm: nfsd Not tainted 4.17.0+ #1
[ 119.259662] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.9.3-1.fc25 04/01/2014
[ 119.261202] Call Trace:
[ 119.262265] dump_stack+0x71/0xab
[ 119.263371] print_address_description+0x6a/0x270
[ 119.264609] kasan_report+0x258/0x380
[ 119.265854] ? nfsd4_decode_getdeviceinfo+0x5a4/0x5b0 [nfsd]
[ 119.267291] nfsd4_decode_getdeviceinfo+0x5a4/0x5b0 [nfsd]
[ 119.268549] ? nfs4svc_decode_compoundargs+0xa5b/0x13c0 [nfsd]
[ 119.269873] ? nfsd4_decode_sequence+0x490/0x490 [nfsd]
[ 119.271095] nfs4svc_decode_compoundargs+0xa5b/0x13c0 [nfsd]
[ 119.272393] ? nfsd4_release_compoundargs+0x1b0/0x1b0 [nfsd]
[ 119.273658] nfsd_dispatch+0x183/0x850 [nfsd]
[ 119.274918] svc_process+0x161c/0x31a0 [sunrpc]
[ 119.276172] ? svc_printk+0x190/0x190 [sunrpc]
[ 119.277386] ? svc_xprt_release+0x451/0x680 [sunrpc]
[ 119.278622] nfsd+0x2b9/0x430 [nfsd]
[ 119.279771] ? nfsd_destroy+0x1c0/0x1c0 [nfsd]
[ 119.281157] kthread+0x2db/0x390
[ 119.282347] ? kthread_create_worker_on_cpu+0xc0/0xc0
[ 119.283756] ret_from_fork+0x35/0x40
[ 119.286041] Allocated by task 436:
[ 119.287525] kasan_kmalloc+0xa0/0xd0
[ 119.288685] kmem_cache_alloc+0xe9/0x1f0
[ 119.289900] get_empty_filp+0x7b/0x410
[ 119.291037] path_openat+0xca/0x4220
[ 119.292242] do_filp_open+0x182/0x280
[ 119.293411] do_sys_open+0x216/0x360
[ 119.294555] do_syscall_64+0xa0/0x2f0
[ 119.295721] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 119.298068] Freed by task 436:
[ 119.299271] __kasan_slab_free+0x130/0x180
[ 119.300557] kmem_cache_free+0x78/0x210
[ 119.301823] rcu_process_callbacks+0x35b/0xbd0
[ 119.303162] __do_softirq+0x192/0x5ea
[ 119.305443] The buggy address belongs to the object at ffff880113ada000
which belongs to the cache filp of size 256
[ 119.308556] The buggy address is located 0 bytes inside of
256-byte region [ffff880113ada000, ffff880113ada100)
[ 119.311376] The buggy address belongs to the page:
[ 119.312728] page:ffffea00044eb680 count:1 mapcount:0 mapping:0000000000000000 index:0xffff880113ada780
[ 119.314428] flags: 0x17ffe000000100(slab)
[ 119.315740] raw: 0017ffe000000100 0000000000000000 ffff880113ada780 00000001000c0001
[ 119.317379] raw: ffffea0004553c60 ffffea00045c11e0 ffff88011b167e00 0000000000000000
[ 119.319050] page dumped because: kasan: bad access detected
[ 119.321652] Memory state around the buggy address:
[ 119.322993] ffff880113ad9f00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 119.324515] ffff880113ad9f80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 119.326087] >ffff880113ada000: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 119.327547] ^
[ 119.328730] ffff880113ada080: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 119.330218] ffff880113ada100: fc fc fc fc fc fc fc fc fb fb fb fb fb fb fb fb
[ 119.331740] ==================================================================
commit 9c2ece6ef67e9d376f32823086169b489c422ed0 upstream.
nfsd4_readdir_rsize restricts rd_maxcount to svc_max_payload when
estimating the size of the readdir reply, but nfsd_encode_readdir
restricts it to INT_MAX when encoding the reply. This can result in log
messages like "kernel: RPC request reserved 32896 but used 1049444".
Restrict rd_dircount similarly (no reason it should be larger than
svc_max_payload).
[ Upstream commit 66282ec1cf004c09083c29cb5e49019037937bbd ]
Clients must be able to read a file in order to execute it, and for pNFS
that means the client needs to be able to perform a LAYOUTGET on the file.
This behavior for executable-only files was added for OPEN in commit
a043226bc140 "nfsd4: permit read opens of executable-only files".
This fixes up xfstests generic/126 on block/scsi layouts.
[ Upstream commit 99bbf6ecc694dfe0b026e15359c5aa2a60b97a93 ]
consider the sequence of commands:
mkdir -p /import/nfs /import/bind /import/etc
mount --bind / /import/bind
mount --make-private /import/bind
mount --bind /import/etc /import/bind/etc
exportfs -o rw,no_root_squash,crossmnt,async,no_subtree_check localhost:/
mount -o vers=4 localhost:/ /import/nfs
ls -l /import/nfs/etc
You would not expect this to report a stale file handle.
Yet it does.
The manipulations under /import/bind cause the dentry for
/etc to get the DCACHE_MOUNTED flag set, even though nothing
is mounted on /etc. This causes nfsd to call
nfsd_cross_mnt() even though there is no mountpoint. So an
upcall to mountd for "/etc" is performed.
The 'crossmnt' flag on the export of / causes mountd to
report that /etc is exported as it is a descendant of /. It
assumes the kernel wouldn't ask about something that wasn't
a mountpoint. The filehandle returned identifies the
filesystem and the inode number of /etc.
When this filehandle is presented to rpc.mountd, via
"nfsd.fh", the inode cannot be found associated with any
name in /etc/exports, or with any mountpoint listed by
getmntent(). So rpc.mountd says the filehandle doesn't
exist. Hence ESTALE.
This is fixed by teaching nfsd not to trust DCACHE_MOUNTED
too much. It is just a hint, not a guarantee.
Change nfsd_mountpoint() to return '1' for a certain mountpoint,
'2' for a possible mountpoint, and 0 otherwise.
Then change nfsd_crossmnt() to check if follow_down()
actually found a mountpount and, if not, to avoid performing
a lookup if the location is not known to certainly require
an export-point.
[ Upstream commit 81833de1a46edce9ca20cfe079872ac1c20ef359 ]
restart_grace() uses hardcoded init_net.
It can cause to "list_add double add" in following scenario:
1) nfsd and lockd was started in several net namespaces
2) nfsd in init_net was stopped (lockd was not stopped because
it have users from another net namespaces)
3) lockd got signal, called restart_grace() -> set_grace_period()
and enabled lock_manager in hardcoded init_net.
4) nfsd in init_net is started again,
its lockd_up() calls set_grace_period() and tries to add
lock_manager into init_net 2nd time.
Jeff Layton suggest:
"Make it safe to call locks_start_grace multiple times on the same
lock_manager. If it's already on the global grace_list, then don't try
to add it again. (But we don't intentionally add twice, so for now we
WARN about that case.)
With this change, we also need to ensure that the nfsd4 lock manager
initializes the list before we call locks_start_grace. While we're at
it, move the rest of the nfsd_net initialization into
nfs4_state_create_net. I see no reason to have it spread over two
functions like it is today."
Suggested patch was updated to generate warning in described situation.
Suggested-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Vasily Averin <vvs@virtuozzo.com>
[ Upstream commit ae254dac721d44c0bfebe2795df87459e2e88219 ]
Prevent the use of the closed (invalid) special stateid by clients.
Signed-off-by: Andrew Elble <aweits@rit.edu>
[ Upstream commit 9271d7e509c1bfc0b9a418caec29ec8d1ac38270 ]
After taking the stateid st_mutex, we want to know that the stateid
still represents valid state before performing any non-idempotent
actions.
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
[ Upstream commit fb500a7cfee7f2f447d2bbf30cb59629feab6ac1 ]
commit 1995266727fa8143897e89b55f5d3c79aa828420 upstream.
Commit bdcf0a423ea1 ("kernel: make groups_sort calling a responsibility
group_info allocators") appears to break nfsd rootsquash in a pretty
major way.
It adds a call to groups_sort() inside the loop that copies/squashes
gids, which means the valid gids are sorted along with the following
garbage. The net result is that the highest numbered valid gids are
replaced with any lower-valued garbage gids, possibly including 0.
We should sort only once, after filling in all the gids.
Fixes: bdcf0a423ea1 ("kernel: make groups_sort calling a responsibility ...")
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
Acked-by: J. Bruce Fields <bfields@redhat.com>
Cc: Wolfgang Walter <linux@stwm.de>
commit bdcf0a423ea1c40bbb40e7ee483b50fc8aa3d758 upstream.
In testing, we found that nfsd threads may call set_groups in parallel
for the same entry cached in auth.unix.gid, racing in the call of
groups_sort, corrupting the groups for that entry and leading to
permission denials for the client.
This patch:
- Make groups_sort globally visible.
- Move the call to groups_sort to the modifiers of group_info
- Remove the call to groups_sort from set_groups
Link: http://lkml.kernel.org/r/20171211151420.18655-1-thiago.becker@gmail.com
Signed-off-by: Thiago Rafael Becker <thiago.becker@gmail.com>
Reviewed-by: Matthew Wilcox <mawilcox@microsoft.com>
Reviewed-by: NeilBrown <neilb@suse.com>
Acked-by: "J. Bruce Fields" <bfields@fieldses.org>
[ Upstream commit 800a938f0bf9130c8256116649c0cc5806bfb2fd ]
If you write "-2 -3 -4" to the "versions" file, it will
notice that no versions are enabled, and nfsd_reset_versions()
is called.
This enables all major versions, not no minor versions.
So we lose the invariant that NFSv4 is only advertised when
at least one minor is enabled.
Fix the code to explicitly enable minor versions for v4,
change it to use nfsd_vers() to test and set, and simplify
the code.
[ Upstream commit 928c6fb3a9bfd6c5b287aa3465226add551c13c0 ]
Current code will return 1 if the version is supported,
and -1 if it isn't.
This is confusing and inconsistent with the one place where this
is used.
So change to return 1 if it is supported, and zero if not.
i.e. an error is never returned.
commit d8a1a000555ecd1b824ac1ed6df8fe364dfbbbb0 upstream.
If nfsd4_process_open2() is initialising a new stateid, and yet the
call to nfs4_get_vfs_file() fails for some reason, then we must
declare the stateid closed, and unhash it before dropping the mutex.
Right now, we unhash the stateid after dropping the mutex, and without
changing the stateid type, meaning that another OPEN could theoretically
look it up and attempt to use it.
Reported-by: Andrew W Elble <aweits@rit.edu>
commit 15ca08d3299682dc49bad73251677b2c5017ef08 upstream.
Open file stateids can linger on the nfs4_file list of stateids even
after they have been closed. In order to avoid reusing such a
stateid, and confusing the client, we need to recheck the
nfs4_stid's type after taking the mutex.
Otherwise, we risk reusing an old stateid that was already closed,
which will confuse clients that expect new stateids to conform to
RFC7530 Sections 9.1.4.2 and 16.2.5 or RFC5661 Sections 8.2.2 and 18.2.4.
commit 8c7245abda877d4689b3371db8ae2a4400d7d9ce upstream.
Move the state selection logic inside from the caller,
always making it return correct stp to use.
Signed-off-by: J . Bruce Fields <bfields@fieldses.org>
Signed-off-by: Oleg Drokin <green@linuxhacker.ru>
commit 95da1b3a5aded124dd1bda1e3cdb876184813140 upstream.
If a delegation has been revoked by the server, operations using that
delegation should error out with NFS4ERR_DELEG_REVOKED in the >4.1
case, and NFS4ERR_BAD_STATEID otherwise.
The server needs NFSv4.1 clients to explicitly free revoked delegations.
If the server returns NFS4ERR_DELEG_REVOKED, the client will do that;
otherwise it may just forget about the delegation and be unable to
recover when it later sees SEQ4_STATUS_RECALLABLE_STATE_REVOKED set on a
SEQUENCE reply. That can cause the Linux 4.1 client to loop in its
stage manager.
Reviewed-by: Trond Myklebust <trond.myklebust@primarydata.com>
[ Upstream commit f7d1ddbe7648af7460d23688c8c131342eb43b3a ]
The rpccred gotten from rpc_lookup_machine_cred() should be put when
state is shutdown.
Signed-off-by: Kinglong Mee <kinglongmee@gmail.com>
commit f46c445b79906a9da55c13e0a6f6b6a006b892fe upstream.
When I push NFSv4.1 / RDMA hard, (xfstests generic/089, for example),
I get this crash on the server:
Oct 28 22:04:30 klimt kernel: general protection fault: 0000 [#1] SMP DEBUG_PAGEALLOC
Oct 28 22:04:30 klimt kernel: Modules linked in: cts rpcsec_gss_krb5 iTCO_wdt iTCO_vendor_support sb_edac edac_core x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm btrfs irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel lrw gf128mul glue_helper ablk_helper cryptd xor pcspkr raid6_pq i2c_i801 i2c_smbus lpc_ich mfd_core sg mei_me mei ioatdma shpchp wmi ipmi_si ipmi_msghandler rpcrdma ib_ipoib rdma_ucm acpi_power_meter acpi_pad ib_ucm ib_uverbs ib_umad rdma_cm ib_cm iw_cm nfsd auth_rpcgss nfs_acl lockd grace sunrpc ip_tables xfs libcrc32c mlx4_ib mlx4_en ib_core sr_mod cdrom sd_mod ast drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ttm drm crc32c_intel igb ahci libahci ptp mlx4_core pps_core dca libata i2c_algo_bit i2c_core dm_mirror dm_region_hash dm_log dm_mod
Oct 28 22:04:30 klimt kernel: CPU: 7 PID: 1558 Comm: nfsd Not tainted 4.9.0-rc2-00005-g82cd754 #8
Oct 28 22:04:30 klimt kernel: Hardware name: Supermicro Super Server/X10SRL-F, BIOS 1.0c 09/09/2015
Oct 28 22:04:30 klimt kernel: task: ffff880835c3a100 task.stack: ffff8808420d8000
Oct 28 22:04:30 klimt kernel: RIP: 0010:[<ffffffffa05a759f>] [<ffffffffa05a759f>] release_lock_stateid+0x1f/0x60 [nfsd]
Oct 28 22:04:30 klimt kernel: RSP: 0018:ffff8808420dbce0 EFLAGS: 00010246
Oct 28 22:04:30 klimt kernel: RAX: ffff88084e6660f0 RBX: ffff88084e667020 RCX: 0000000000000000
Oct 28 22:04:30 klimt kernel: RDX: 0000000000000007 RSI: 0000000000000000 RDI: ffff88084e667020
Oct 28 22:04:30 klimt kernel: RBP: ffff8808420dbcf8 R08: 0000000000000001 R09: 0000000000000000
Oct 28 22:04:30 klimt kernel: R10: ffff880835c3a100 R11: ffff880835c3aca8 R12: 6b6b6b6b6b6b6b6b
Oct 28 22:04:30 klimt kernel: R13: ffff88084e6670d8 R14: ffff880835f546f0 R15: ffff880835f1c548
Oct 28 22:04:30 klimt kernel: FS: 0000000000000000(0000) GS:ffff88087bdc0000(0000) knlGS:0000000000000000
Oct 28 22:04:30 klimt kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Oct 28 22:04:30 klimt kernel: CR2: 00007ff020389000 CR3: 0000000001c06000 CR4: 00000000001406e0
Oct 28 22:04:30 klimt kernel: Stack:
Oct 28 22:04:30 klimt kernel: ffff88084e667020 0000000000000000 ffff88084e6670d8 ffff8808420dbd20
Oct 28 22:04:30 klimt kernel: ffffffffa05ac80d ffff880835f54548 ffff88084e640008 ffff880835f545b0
Oct 28 22:04:30 klimt kernel: ffff8808420dbd70 ffffffffa059803d ffff880835f1c768 0000000000000870
Oct 28 22:04:30 klimt kernel: Call Trace:
Oct 28 22:04:30 klimt kernel: [<ffffffffa05ac80d>] nfsd4_free_stateid+0xfd/0x1b0 [nfsd]
Oct 28 22:04:30 klimt kernel: [<ffffffffa059803d>] nfsd4_proc_compound+0x40d/0x690 [nfsd]
Oct 28 22:04:30 klimt kernel: [<ffffffffa0583114>] nfsd_dispatch+0xd4/0x1d0 [nfsd]
Oct 28 22:04:30 klimt kernel: [<ffffffffa047bbf9>] svc_process_common+0x3d9/0x700 [sunrpc]
Oct 28 22:04:30 klimt kernel: [<ffffffffa047ca64>] svc_process+0xf4/0x330 [sunrpc]
Oct 28 22:04:30 klimt kernel: [<ffffffffa05827ca>] nfsd+0xfa/0x160 [nfsd]
Oct 28 22:04:30 klimt kernel: [<ffffffffa05826d0>] ? nfsd_destroy+0x170/0x170 [nfsd]
Oct 28 22:04:30 klimt kernel: [<ffffffff810b367b>] kthread+0x10b/0x120
Oct 28 22:04:30 klimt kernel: [<ffffffff810b3570>] ? kthread_stop+0x280/0x280
Oct 28 22:04:30 klimt kernel: [<ffffffff8174e8ba>] ret_from_fork+0x2a/0x40
Oct 28 22:04:30 klimt kernel: Code: c3 66 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 55 48 89 e5 41 55 41 54 53 48 8b 87 b0 00 00 00 48 89 fb 4c 8b a0 98 00 00 00 <49> 8b 44 24 20 48 8d b8 80 03 00 00 e8 10 66 1a e1 48 89 df e8
Oct 28 22:04:30 klimt kernel: RIP [<ffffffffa05a759f>] release_lock_stateid+0x1f/0x60 [nfsd]
Oct 28 22:04:30 klimt kernel: RSP <ffff8808420dbce0>
Oct 28 22:04:30 klimt kernel: ---[ end trace cf5d0b371973e167 ]---
Jeff Layton says:
> Hm...now that I look though, this is a little suspicious:
> struct nfs4_openowner *oo = openowner(stp->st_openstp->st_stateowner);
> I wonder if it's possible for the openstateid to have already been
> destroyed at this point.
> We might be better off doing something like this to get the client pointer:
> stp->st_stid.sc_client;
> ...which should be more direct and less dependent on other stateids
> staying valid.
With the suggested change, I am no longer able to reproduce the above oops.
v2: Fix unhash_lock_stateid() as well
Fix-suggested-by: Jeff Layton <jlayton@redhat.com>
Fixes: 42691398be08 ('nfsd: Fix race between FREE_STATEID and LOCK')
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Cc: Christian Theune <ct@flyingcircus.io>
commit fc788f64f1f3eb31e87d4f53bcf1ab76590d5838 upstream.
When processing an NFSv4 WRITE operation, argp->end should never
point past the end of the data in the final page of the page list.
Otherwise, nfsd4_decode_compound can walk into uninitialized memory.
More critical, nfsd4_decode_write is failing to increment argp->pagelen
when it increments argp->pagelist. This can cause later xdr decoders
to assume more data is available than really is, which can cause server
crashes on malformed requests.
commit 93407472a21b82f39c955ea7787e5bc7da100642 upstream.
Replace all 1 << inode->i_blkbits and (1 << inode->i_blkbits) in fs
branch.
This patch also fixes multiple checkpatch warnings: WARNING: Prefer
'unsigned int' to bare use of 'unsigned'
Thanks to Andrew Morton for suggesting more appropriate function instead
of macro.
[geliangtang@gmail.com: truncate: use i_blocksize()]
Link: http://lkml.kernel.org/r/9c8b2cd83c8f5653805d43debde9fa8817e02fc4.1484895804.git.geliangtang@gmail.com
Link: http://lkml.kernel.org/r/1481319905-10126-1-git-send-email-fabf@skynet.be
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Signed-off-by: Geliang Tang <geliangtang@gmail.com>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
commit b26b78cb726007533d81fdf90a62e915002ef5c8 upstream.
If an NFSv4 client asks us for the supattr_exclcreat, then we must
not return attributes that are unsupported by this minor version.
Fixes: 75976de6556f ("NFSD: Return word2 bitmask if setting security..,")
commit 9a307403d374b993061f5992a6e260c944920d0b upstream.
if we receive a compound such that:
- the sessionid, slot, and sequence number in the SEQUENCE op
match a cached succesful reply with N ops, and
- the Nth operation of the compound is a PUTFH, PUTPUBFH,
PUTROOTFH, or RESTOREFH,
then nfsd4_sequence will return 0 and set cstate->status to
nfserr_replay_cache. The current filehandle will not be set. This will
cause us to call check_nfsd_access with first argument NULL.
To nfsd4_compound it looks like we just succesfully executed an
operation that set a filehandle, but the current filehandle is not set.
Fix this by moving the nfserr_replay_cache earlier. There was never any
reason to have it after the encode_op label, since the only case where
he hit that is when opdesc->op_func sets it.
Note that there are two ways we could hit this case:
- a client is resending a previously sent compound that ended
with one of the four PUTFH-like operations, or
- a client is sending a *new* compound that (incorrectly) shares
sessionid, slot, and sequence number with a previously sent
compound, and the length of the previously sent compound
happens to match the position of a PUTFH-like operation in the
new compound.
The second is obviously incorrect client behavior. The first is also
very strange--the only purpose of a PUTFH-like operation is to set the
current filehandle to be used by the following operation, so there's no
point in having it as the last in a compound.
So it's likely this requires a buggy or malicious client to reproduce.
Reported-by: Scott Mayhew <smayhew@redhat.com>
commit f961e3f2acae94b727380c0b74e2d3954d0edf79 upstream.
In error cases, lgp->lg_layout_type may be out of bounds; so we
shouldn't be using it until after the check of nfserr.
This was seen to crash nfsd threads when the server receives a LAYOUTGET
request with a large layout type.
GETDEVICEINFO has the same problem.
Reported-by: Ari Kauppi <Ari.Kauppi@synopsys.com>
commit 13bf9fbff0e5e099e2b6f003a0ab8ae145436309 upstream.
The NFSv2/v3 code does not systematically check whether we decode past
the end of the buffer. This generally appears to be harmless, but there
are a few places where we do arithmetic on the pointers involved and
don't account for the possibility that a length could be negative. Add
checks to catch these.
Reported-by: Tuomas Haanpää <thaan@synopsys.com>
Reported-by: Ari Kauppi <ari@synopsys.com>
commit db44bac41bbfc0c0d9dd943092d8bded3c9db19b upstream.
Use a couple shortcuts that will simplify a following bugfix.
(Minor backporting required to account for a change from f34b95689d2c
"The NFSv2/NFSv3 server does not handle zero length WRITE requests
correctly".)
commit e6838a29ecb484c97e4efef9429643b9851fba6e upstream.
A client can append random data to the end of an NFSv2 or NFSv3 RPC call
without our complaining; we'll just stop parsing at the end of the
expected data and ignore the rest.
Encoded arguments and replies are stored together in an array of pages,
and if a call is too large it could leave inadequate space for the
reply. This is normally OK because NFS RPC's typically have either
short arguments and long replies (like READ) or long arguments and short
replies (like WRITE). But a client that sends an incorrectly long reply
can violate those assumptions. This was observed to cause crashes.
Also, several operations increment rq_next_page in the decode routine
before checking the argument size, which can leave rq_next_page pointing
well past the end of the page array, causing trouble later in
svc_free_pages.
So, following a suggestion from Neil Brown, add a central check to
enforce our expectation that no NFSv2/v3 call has both a large call and
a large reply.
As followup we may also want to rewrite the encoding routines to check
more carefully that they aren't running off the end of the page array.
We may also consider rejecting calls that have any extra garbage
appended. That would be safer, and within our rights by spec, but given
the age of our server and the NFS protocol, and the fact that we've
never enforced this before, we may need to balance that against the
possibility of breaking some oddball client.
commit 783112f7401ff449d979530209b3f6c2594fdb4e upstream.
Both the NFS protocols and the Linux VFS use a setattr operation with a
bitmap of attributes to set to set various file attributes including the
file size and the uid/gid.
The Linux syscalls never mix size updates with unrelated updates like
the uid/gid, and some file systems like XFS and GFS2 rely on the fact
that truncates don't update random other attributes, and many other file
systems handle the case but do not update the other attributes in the
same transaction. NFSD on the other hand passes the attributes it gets
on the wire more or less directly through to the VFS, leading to updates
the file systems don't expect. XFS at least has an assert on the
allowed attributes, which caught an unusual NFS client setting the size
and group at the same time.
To handle this issue properly this splits the notify_change call in
nfsd_setattr into two separate ones.
Tested-by: Chuck Lever <chuck.lever@oracle.com>
commit 758e99fefe1d9230111296956335cd35995c0eaf upstream.
Simplify exit paths, size_change use.
commit d19fb70dd68c4e960e2ac09b0b9c79dfdeefa726 upstream.
nfsd assigns the nfs4_free_lock_stateid to .sc_free in init_lock_stateid().
If nfsd doesn't go through init_lock_stateid() and put stateid at end,
there is a NULL reference to .sc_free when calling nfs4_put_stid(ns).
This patch let the nfs4_stid.sc_free assignment to nfs4_alloc_stid().
Fixes: 356a95ece7aa "nfsd: clean up races in lock stateid searching..."
commit 885848186fbc2d1d8fb6d2fdc2156638ae289a46 upstream.
nfsd4_release_lockowner finds a lock owner that has no lock state,
and drops cl_lock. Then release_lockowner picks up cl_lock and
unhashes the lock owner.
During the window where cl_lock is dropped, I don't see anything
preventing a concurrent nfsd4_lock from finding that same lock owner
and adding lock state to it.
Move release_lockowner() into nfsd4_release_lockowner and hang onto
the cl_lock until after the lock owner's state cannot be found
again.
Found by inspection, we don't currently have a reproducer.
Fixes: 2c41beb0e5cf ("nfsd: reduce cl_lock thrashing in ... ")
commit dd257933fa4b9fea66a1195f8a15111029810abc upstream.
nfsd4_lock will take the st_mutex before working with the stateid it
gets, but between the time when we drop the cl_lock and take the mutex,
the stateid could become unhashed (a'la FREE_STATEID). If that happens
the lock stateid returned to the client will be forgotten.
Fix this by first moving the st_mutex acquisition into
lookup_or_create_lock_state. Then, have it check to see if the lock
stateid is still hashed after taking the mutex. If it's not, then put
the stateid and try the find/create again.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Tested-by: Alexey Kodanev <alexey.kodanev@oracle.com>
commit 42691398be08bd1fe99326911a0aa31f2c041d53 upstream.
When running LTP's nfslock01 test, the Linux client can send a LOCK
and a FREE_STATEID request at the same time. The outcome is:
Frame 324 R OPEN stateid [2,O]
Frame 115004 C LOCK lockowner_is_new stateid [2,O] offset 672000 len 64
Frame 115008 R LOCK stateid [1,L]
Frame 115012 C WRITE stateid [0,L] offset 672000 len 64
Frame 115016 R WRITE NFS4_OK
Frame 115019 C LOCKU stateid [1,L] offset 672000 len 64
Frame 115022 R LOCKU NFS4_OK
Frame 115025 C FREE_STATEID stateid [2,L]
Frame 115026 C LOCK lockowner_is_new stateid [2,O] offset 672128 len 64
Frame 115029 R FREE_STATEID NFS4_OK
Frame 115030 R LOCK stateid [3,L]
Frame 115034 C WRITE stateid [0,L] offset 672128 len 64
Frame 115038 R WRITE NFS4ERR_BAD_STATEID
In other words, the server returns stateid L in a successful LOCK
reply, but it has already released it. Subsequent uses of stateid L
fail.
To address this, protect the generation check in nfsd4_free_stateid
with the st_mutex. This should guarantee that only one of two
outcomes occurs: either LOCK returns a fresh valid stateid, or
FREE_STATEID returns NFS4ERR_LOCKS_HELD.
Reported-by: Alexey Kodanev <alexey.kodanev@oracle.com>
commit 999653786df6954a31044528ac3f7a5dadca08f4 upstream.
Use set_posix_acl, which includes proper permission checks, instead of
calling ->set_acl directly. Without this anyone may be able to grant
themselves permissions to a file by setting the ACL.
Lock the inode to make the new checks atomic with respect to set_acl.
(Also, nfsd was the only caller of set_acl not locking the inode, so I
suspect this may fix other races.)
This also simplifies the code, and ensures our ACLs are checked by
posix_acl_valid.
The permission checks and the inode locking were lost with commit
4ac7249e, which changed nfsd to use the set_acl inode operation directly
instead of going through xattr handlers.
Reported-by: David Sinquin <david@sinquin.eu>
[agreunba@redhat.com: use set_posix_acl]
Fixes: 4ac7249e
commit 5cc1fb2a093e254b656c64ff24b0b76bed1d34d9 upstream.
To avoid racing entry into nfs4_get_vfs_file().
Make init_open_stateid() return with locked stateid to be unlocked
by the caller.
